As maple 18 does not, and I see no information about this topic for 2015 version, besides, I don't have a chance to try the software. So any help would be appreciated.
hello i need plot integrale of siampson thank you
> Simpson := proc(f, a, b, n)
> local h, S1, S2, S, i;
> h := (b-a)/n;
> S1 := 0.0;
> for i from 0 to n-1 do
> S1 := S1 + f(a + (2*i+1)*h);
> end do;
> S2 := 0.0;
> for i from 1 to n-1 do
> S2 := S2 + f(a + (2*i)*h);
> end do;
> S := (h/3) * ( f(a)+f(b) + 4*S1 + 2*S2 );
> return S;
> end proc:
> Digits := 5;
                             Digits := 5
> f := x -> 1/sqrt(39.24*x-44.65*(x*arccos(x)-sqrt(1-x^2)-13.88*(1-x^2)^1.5));
  f := x -> 1/sqrt(39.24 x
                                          2                2 1.5
         - 44.65 (x arccos(x) - sqrt(1 - x ) - 13.88 (1 - x )   ))
> Simpson(f, 0, 1, 100):
> p:=int(f(x), x=0..0.1);
                            p := 0.0038931
> w:=int(f(x), x=0.1..0.2);
                            w := 0.0039570
> m:=int(f(x), x=0.2..0.3);
                            m := 0.0040826
> l:=int(f(x), x=0.3..0.4);
                            l := 0.0042836
> kohv:=int(f(x), x=0.4..0.5);
                          kohv := 0.0045860
> q:=int(f(x), x=0.5..0.6);
                            q := 0.0050373
> s:=int(f(x), x=0.6..0.7);
                            s := 0.0057306
> d:=int(f(x), x=0.8..0.9);
                            d := 0.0089874
> f:=int(f(x), x=0.9..1);
                            f := 0.013349
When I take the derivative of abs(x), I use the chain rule and get this
When I ask Maple to differentiate abs(x), I get this:
I read the help file on "signum", and I expected this to work, but it does not.
How can I represent signum in normal calculus syntax when working the derivative of functions involving abs(x)?
Hi All,
I am using pds:-animate to show the results of integration of a two function system, u(x,t) and v (x,t). I would like this command uses two different colors for each line but the command "color=[blue, green]" is not working and both lines have the same color (blue).
Some help?
Thanks a lot,
Javier
Evaluation of Primitive Hydrogenic Coulomb & Exchange Integrals
I would appreciate if someone would check my worksheet wherein these integrals are evaluated applying the method of Eyring, Walter, & Kimball, p 396, Quantum Cemistry, Wiley (1944).
Please write me at cordes@stny.rr.com, and I'll email you a MAPLE worksheet.
Thank you for your consideration.
Dear,
I have this code generating a piecewise function:
> with(CurveFitting);
> points := [[0, 1], [1, 2.5], [3, 2.3], [4.2, 5], [5, 3.5], [5.8, 4.2], [7, 7], [8, 10]];
> splcurve := Spline(points, v);
In this particular case I have seven distinct polynomials. Someone knows how could I get one specific polynomial, for example, the one exactly before v < 4.2?
In other terms:
I'd like to define a new function, say 'f', that is exactly the polynomial just before v < 4.2 (e.g, something like f:=(splcurve, v < 4.2)). Do exists this possibility? (I have been looking for it elsewhere but without success!!)
Thanks in advance! Best regards!
I need to display amounts of M2 and 1.15*P2 instead of Notations
TEXT([M2,1.15*P2],'`(M2,1.15P2)`
There is a slight display difference of the code between showstate() and print(). It has to do with '` name `' use where print does not show the outside '' characters.
Here is an example
showstat(`dsolve`);
and now using print
interface(verboseproc=3);
print(`dsolve`);
When I used
with(LibraryTools);
Browse();
and looked at the source code there, it matched what showstat(`dsolve`); gave and not the print command. Is there a reason why print does not show all those extra characters exactly as in the source code? It seems a formatting issue, but it is better to be looking at an exact copy of the source code.
Knowing that the Taylor series for cos(x) is:
sum := sum+(-1)^i*x^(2*i)/(2*i)!
How would I write the following Maple code?
Generate an animation sequence showing the Taylor series approximation of cos(x) from N=1..10, where N is the number of terms in the series. Each subsequent frame of the animation should show a more accurate representation of cos(x) than the previous one. Plot the animation from x = -2*Pi .. 2*Pi, y = -5 .. 5
     I want to know what K1 and K2 means in the answer after using Euler Lagrange command.
Under what is new in Maple 2015, it gives lists of commands that has been updated. For example
So suppose one wants to find what changed in the "add" command, how would they find this out? Clicking on the add command shows no indication of what was changed or what options added or modified. For example, with Mathematica, clicking on command, shows the changes in the current releases with different color (light yellow) when clicking on "show changes" (here is an example)
Is  this information available somewhere else? May be using the command line with some option?
Just giving list of commands changed, without any indication of what changed, is not very useful really.
I am having some issues trying to convert this matlap code into Maple code, can somebody help me out?
% Solve v'(t)=-0.0207v(t)^2-893.58 with y0=0
clc;
y0 = 0;                  % Initial Condition
h = 0.1;                 % Time step
t = 0:h:5;               % t goes from 0 to 5 seconds.
vstar = zeros(size(t)); % Preallocate array (good coding practice)
vstar(1) = y0;           % Initial condition gives solution at t=0.
for i=1:(length(t)-1)
    k1 = 0.0207*vstar(i)^2-893.58; % Previous approx for y gives approx for derivative
    vstar(i+1) = vstar(i) + k1*h; % Approximate solution for next value of y
end
figure(1)
plot(t,vstar);
h = 0.05;                 % Time step
end
figure(2)
plot(t,vstar);
I have a Maple package which is a .mla file.
How can I open it to have access to the source code ?
I would like to open it in order to modify a procedure and to use it indepently of the package.
Thanks a lot for your help.
whenever i use maplesoft, i`m wondering about the instruction which is to show me the explanation about answers.
Maplesofte must be worked by some principles , therefore it can show the explanation of any answers to users
please let me know what is the instruction that i can watch explanations.
for example /
> int(f(x)*g(x),x);
sin(x) - x cos(x) - 1/2 cos(x) sin(x) + 1/2 x
 how can it get an answer, i wanna see that
First 1344 1345 1346 1347 1348 1349 1350 Last Page 1346 of 2471
