What is the reason/Why:
Error, (in dsolve/numeric/bvp) unable to achieve requested accuracy of 0.1e-5 with maximum 128 point mesh (was able to get 0.66e-1), consider increasing `maxmesh` or using larger `abserr`
Thanks for the help :)
I'm trying to plot the direction field of the second order differential equation x''=x'-cos(x) using dfieldplot:
> with(DEtools); with(plots);
> f1 := (x, y) options operator, arrow; diff(x(t), t)-cos(x(t)) end proc;
/ d \
(x, y) -> |--- x(t)| - cos(x(t))
\ dt /
> dfieldplot([diff(x(t), t) = y(t), diff(y(t), t) = f1(x(t), y(t))], [x(t), y(t)], t = -2 .. 2, x = -2 .. 2, y = -2 .. 2);
Error, (in DEtools/dfieldplot) cannot produce plot, non-autonomous DE(s) require initial conditions.
The error I'm getting says I need initial conditions, but I wasn't provided with any. Is there another way to plot this? Sorry if this is dumb question, but I've only ever plotted first order equations.
The equation
x^7+14*x^4+35*x^3+14*x^2+7*x+88 = 0
has the unique real root
x = (1+sqrt(2))^(1/7)+(1-sqrt(2))^(1/7)-(3+2*sqrt(2))^(1/7)-(3-2*sqrt(2))^(1/7).
Here is its verification:
Is it possible to find that in Maple? I unsuccessfully tried the solve command with the explicit option.
I was required to purchase Maple 17 for my upcoming Calculus III course, and until now, I have been using my TI-Nspire CAS CX for all of my CAS needs.  I am going through various tutorials/labs in an effort to learn how to use the Maple 17 Software. As a part of this process, I am attempting to solve a system of equations and was told to use the following command:
>solve({2*x+3*y=7,5*x+8*y=9},{x,y});
in order to receive the answer
{y=-17,x=29}.
Instead, I have received the following error message, which has no help attached to it through the help page.
solve({2*x+3*y = 7, 5*x+8*y = 9}, {x, y});
I am hoping this has something to do with Mac vs. Windows software, and that it has a simple solution.  I would greatly appreciate any guidance!
There are two normals to a point on a curve.  How do I get the PlotPositionVector of Student[VectorCalculus] to point in the other direction.
with(Student[VectorCalculus]:
R1:=PositionVector([p,p^2],polar[r,t]):
PlotPositionVector(-R1,p=1..2,normal=true,points=[1.5])
The normal vector points towards the insided of the curve.  Can I use PlotPositionVector to have it point the opposite way (towards the outside of the curve)?
ODE:=diff((-diff(u(y),y))^n,y)=A;
bcs:=D(u)(0)=0,u(h)=0;
dsolve({ODE,bcs});
             u(y) = 0
Does anyone has any maple worksheet that generate surface using the PDE method described in this article?  I am trying to learn this method but I am not familiar with the mathematics to do it although the paper gives some description of it.  I hope someone can demonstrate the procedure in Maple.  Thanks
http://www.researchgate.net/publication/259095177_Automatic_shape_optimisation_of_pharmaceutical_tablets_using_Partial_Differential_Equations/file/72e7e52a87ed129d4a.pdf
Pleas i want to do continued fractional expansion to transfer function G(s) with numerator and denomenator as a polynomial in Lplace operator s.
with my gratitude
I need to maximize two multivariate objective functions (f(x1,y1,z1,t1) and g(x2,y2,z2,t2)) with inequality and nonnegativity constraints (x1, x2>0 and y1, z1, t1, y2, z2, t2 >=0). I am looking for parametric not numerical solutions.
What is the best way to find the solution to such a problem using maple?
Hi:
i will plot the following equation so that the horizontal axis in terms of omega and vertical axis in terms of a,but i can not do it,can i help me?
equation:
Hi ,
I would like to resolve the Kortweg and de Devries equation :
> KDV2:= diff( u(X,T), T)+ 6*u(X,T)*diff(u(X,T),X)+ diff(u(X,T),X$3);
I used pdsolve but I have a problem to enter the IBC :
I want
u(infinity, t) =0
u( -infinity, t )=0
u ( x, 0 ) = 1
So I did :
> SOL:=pdsolve(diff( u(X,T), T)+ 6*u(X,T)*diff(u(X,T),X)+ diff(u(X,T),X$3)=0,{u(-10, T) = 0, u(10, T) = 0, u(X, 0) =1},numeric,time=T,range=-10..10);
But it doesn't work.
( I remplace infinity by 10 because then I want the graphic representation of the solution )
Could you help me please ?
I am completely new to Maple (and this kind of software in general).
I am just on my first steps of learning...but I quickly noticed, that if I write Pi and hit enter, I do not get
the well-known greek Pi-symbol. I get an ordinary "p" as the result.
I checked the greek-palette...nearly all items in this palette are ordinary letters.
Does anyone have an idea whats wrong?
BTW: I don`t know if it could have to do with that, but I use a german windows 7 installation.
Thank you,
regards,
Kai
I want to create a linearied model for a single or multi degree of freedom vibration system by MapleSim. i faced a lot of problem such as causalize ports, i search the user manual but i didn't find it useful. i attach a very simply one degree of freedom vibration system. i wondering if every one create a linearized model for it. my final goal is governing the equation and determine the natural frequency with nyquist plots. i have mapleSim 6.2 and Maple 17. Thanks
prob1.msim
F+(1/4)*(4*(-Lambda)^(3/2)*h*m^2-2*sqrt(-Lambda)*exp(Lambda*h^2*m^2)*h*m+sqrt(Pi)*erf(h*m*sqrt(-Lambda)))/(m^2*(-Lambda)^(3/2)) = 0;
how to solve this for m for real roots, where the rest are constants with Lambda>0.
Hi:
I have a curve(plot) in Maple and i should find the math equation for it,everybody can help me how to find it?
First 1487 1488 1489 1490 1491 1492 1493 Last Page 1489 of 2471
