Does anyone exports Maple worksheets to as a LaTeX file?
All my work is typed in LaTeX but I rarely export a Maple file as LaTeX because Maple uses its own LaTeX macros that in a generous evaluation are a lot of "junk" around the LaTeX code. In practice  it is is easier to copy and past the Maple output and then make modifications to LaTeX by hand than to modify Maple's LaTeX code.
Does anyone know of a more efficient alternative than manually copying and pasting?
The ability to export LaTeX useful LaTeX code should be a basic to any symbolic math software, this is one of the few feature os Maple that are really disappointing.
i have got alot of mixed and high degree derivatives. For example:
u[x]*u[x,t]*eta[x,t]+u[]^2*u[x]*eta[x]+kis(x,y)u[x,t]^2*u[]+eta(x, y)*u[]*u[x]^2+ksi[x,t]*u[x]^2*u[x,t]+......
like this alot of terms
my question is how can i solve divided by the derivative of the u(x,t) partial differential equations system and so  how can i find eta(x,t,u) and ksi(x,t,u)
Good afternoon. As a function of ImpulseResponsePlot set the pulse? for example, 1 millisecond or 10 microseconds. Whether it is possible to set the duration?
How can I introduce an arbitrary 4D metric in GRTENSOR, to calculate various components of corresponding Riemannian Tensor Components.
Dear readers,
I want to assign a name, say Lett with D (not the string "D", just the symbol D). I cant do that thoug I already use the command 'unprotect(D)':
> unprotect(D);
   Lett:=D
How can I be succeeded to do it?
Dear Sirs,
I actually rigoruos to know what is the algorithm of BVP[midrich]? how it can obtain the solution of ODE with singularities?
Did anyone introduce a reference about the algorithm like this?
Thanks for your attention in advance
Amir
What is going on here?
cos/sin != cot???
Does anybody use maple 17 in the Mac's Mavericks OS? Or it does not support the new OS yet.
It seems in the sysytem requirement of maple 17, it said only supports OS 10.7, 10.8.
Hi all
I have following program to solve time delay system...
the solution is good by choosing r:=11... but for r greater than 11(e.g r=20) the system take about4-5 minute to do and then it says:"" K2:=simplify(inverse(K1)):Error, (in minor) object too large""
and for plotting says:""     Warning, unable to evaluate 1 of the 2 functions to numeric values in the region; see the plotting command's help page to ensure the calling sequence is correct""
i don't know what is the problem?
any one can help me???
best wishes
> restart:
> with(plots):
> with(linalg):
> with(LinearAlgebra):
> L:=1:
> r:=20:
> tau:=0.3:
> #definition of exact solution
> T1 := piecewise(t<0,0,t>=0 and t<0.3,1+t^2,t>=0.3 and t<0.6,(691/1000)+(109/100)*t+(7/10)*t^2+(1/3)*t^3,0.6<=t and t<0.9,(4409/5000)+(209/500)*t+(69/50)*t^2+(2/15)*t^3+(1/12)*t^4,0.9<=t and t<1,(1500917/2000000)+(35107/40000)*t+(1617/2000)*t^2+(87/200)*t^3+(1/120)*t^4+(1/60)*t^5):
> plot(T1,t=0..1,numpoints=10000,discont = true):
> g:=t^2:
> a[0]:=evalf((1/L)*Int(g,t=0..L)):
> for i1 from 1 to r do
> a[i1]:=evalf((2/L)*Int(g*cos(2*i1*Pi*t/L),t=0..L)):
> od:
> for j1 from 1 to r do
> b[j1]:=evalf((2/L)*Int(g*sin(2*j1*Pi*t/L),t=0..L)):
> od:
> X00:=matrix([[a[0]]]);
> X10:=matrix(1,r,0):
> for j from 1 to r do
> X10[1,j]:=a[j]:
> od:
> X20:=matrix(1,r,0):
> X20[1,j]:=b[j]:
> od:
X00 := [0.3333333333]
> X00:=blockmatrix(1,3,[X00,X10,X20]):
> Z:=linalg[matrix](2*r+1,2*r+1):
> Z[1,1]:=tau:
> for iz from 2 to r+1 do
> Z[iz,1]:=(L/(2*(iz-1)*Pi))*sin(2*(iz-1)*Pi*tau/L):
> od:
> for iz from r+2 to 2*r+1 do
> Z[iz,1]:=(L/(2*(iz-1-r)*Pi))*(1-cos(2*(iz-1-r)*Pi*tau/L)):
> od:
> for jz from 2 to 2*r+1 do
> for iz from 1 to 2*r+1 do
> Z[iz,jz]:=0;
> od:
> od:
> Dtau00:=matrix([[1]]):
> Dtau01:=matrix(1,r,0):
> Dtau02:=matrix(1,r,0):
> Dtau10:=matrix(r,1,0):
> Dtau20:=matrix(r,1,0):
> Dtau1:=linalg[matrix](r,r):
> for i from 1 to r do
> Dtau1[i,i]:=cos(2*(i)*Pi*tau/L):
> if i<>j then Dtau1[i,j]:=0 fi:
> od:
> od:
> Dtau2:=linalg[matrix](r,r):
> Dtau2[i,i]:=sin(2*(i)*Pi*tau/L):
> if i<>j then Dtau2[i,j]:=0 fi:
> od:
> od:
> Dtau3:=linalg[matrix](r,r):
> Dtau3[i,i]:=-sin(2*(i)*Pi*tau/L):
> if i<>j then Dtau3[i,j]:=0 fi:
> od:
> od:
> Dtau4:=linalg[matrix](r,r):
> Dtau4[i,i]:=cos(2*(i)*Pi*tau/L):
> if i<>j then Dtau4[i,j]:=0 fi:
> od:
> od:
> Dtau:=blockmatrix(3,3,[Dtau00,Dtau01,Dtau02,Dtau10,Dtau1,Dtau2,Dtau20,Dtau3,Dtau4]):
> P00:=matrix([[L/2]]):
> P01:=matrix(1,r,0):
> P02:=matrix(1,r,0):
> P02[1,j]:=-L/(j*Pi):
> od:
> P10:=matrix(r,1,0):
> P20:=matrix(r,1,0):
> P20[i,1]:=L/(2*i*Pi):
> od:
> P1:=linalg[matrix](r,r):
> P1[i,j]:=0
> od;
> od;
> P2:=linalg[matrix](r,r):
> P2[i,i]:=L/(2*i*Pi):
> if i<>j then P2[i,j]:=0 fi:
> od:
> od:
> P3:=linalg[matrix](r,r):
> P3[i,i]:=-L/(2*i*Pi):
> if i<>j then P3[i,j]:=0 fi:
> od:
> od:
> P4:=linalg[matrix](r,r):
> P4[i,j]:=0:
> od:
> od:
> P:=blockmatrix(3,3,[P00,P01,P02,P10,P1,P2,P20,P3,P4]):
> I1:=Matrix(2*r+1,shape=identity):
> K1:=simplify(evalm(I1-Dtau&*P+Dtau&*Z)):
> X0:=matrix(1,2*r+1,0):
> X0[1,1]:=1:
> for j from 2 to 2*r+1 do
> X0[1,j]:=0:
> od:
> X:=simplify(evalm(evalm((X0+X00))&*K2)):
> for h from 1 to r do
> f1(h):=cos(2*h*Pi*t/L):
> od:
> for k from 1 to r do
> f2(k):=sin(2*k*Pi*t/L):
> od:
> XP:=X[1,1]+evalf(sum(X[1,l+1]*f1(l)+X[1,r+l+1]*f2(l),l=1..r )):
> plot({XP,T1},t=0..1);
Hi everybody,
Suppose that in an equation, I have the term x/(t).  I want to substitute it by v(t).  Any suggestion because I am trying but don't find an help page on this.
Thank you in advance for your help!
Mario Lemelin
Maple 17.01 Ubuntu 13.10 - 64 bits
Maple 17 Win 7 - 64 bits messagerie : mario.lemelin@cgocable.ca téléphone :  (819) 376-0987
In maple I have:
> evalf(Re(BRW(10.))); evalf(Re(BRZ(10.))); evalf(Re(BRF(10.))); evalf(Re(TOT(10.)));
0.07948364664
0.08085621836
0.8395727755
2.006454216 10 ^{-36}
Now , when I want to print maple give me problems:
file:=fopen("/home/nicoviaux/Post-Doc/BRT4.txt",WRITE):
try
for i to 3 do
fprintf(file,"%g %g %g %g\n",i/10.0,evalf(Re(BRW(i/10.0))),evalf(Re(BRZ(i/10.0))),evalf(Re(BRF(i/10.0)))):
od
end try:
Error, (in fprintf) number expected for floating point format
fclose(file):
Someone have an idea for this?
I want to collect a two terms expression x/2+y/2.
But, I cannot do it as follows.
> x/2+y/2;
> normal(%);
>factor(%)
result was 1/2*x+1/2*y.
With which can I have maple modify the above expression to (x+y)/2.
Thank you in advance.
taro
what is the name of this decomposition?
Y = S^-1*X*S, where S is unitary fourier transform
do maple have function to solve this?
I want to solve following PDE question with forward difference method inn Maple. Can you help me please?
du/dt=d^2u/dx^2, 0<x<2, t>0
u(x,0)=sin(2*pi*x)
u(0,t)=0, u(2,t)=0
Use h=0.4 and k=0.1. and compare your answers at  t=0.5 to the exact solution u(x,t)=exp(-4*pi^2*t)*sin(2pi*x). Then use h=0.4 and k=0.05,and compare the answers.
How to calculate a matrix's self adjoint matrix if given any matrix?
<Px, y> = <x, Py>
hermitian is a kind of self adjoint
L:=Matrix(H,shape=hermitian);
is above command convert a general matrix H into self adjoint L?
any other methods
First 1520 1521 1522 1523 1524 1525 1526 Last Page 1522 of 2471
