Is it possible to find the limit
limit(int(x*cos(x)/(1+3*sin(n*x)^2), x = 0 .. Pi), n = infinity)assuming n::posint
with Maple?
Calculations suggest the one equals -1.
I calculated following two expressions, x1,and x2.
x1:=map(f,a+b);
x2:=map(f,y=a+b);
The results of these are
f(a) + f(b)
f(y) = f(a + b)
for each. And, I can understand the logic of this.
If I want to derive the result of x2 as f(y)=f(a)+f(b), how should I do about x2?
Isn't there other way than to write
map(f, lhs(x2))=map(f,rhs(x2))
Please teach me this.
Thank you in advance.
Taro
How can I get maple to integrate this expression numerically.
For a specific value 0<s<1 it should be enough to integrate from -40..40 instead of -infinity..infinity
Anyway. My maple version always hangs up :-(
(1/2)*(-4*dilog(-(exp(2*t)*s-(-s^2+1)^(1/2)+1)/(-1+(-s^2+1)^(1/2)))*exp(4*t)+arctanh((-1+s)/(-s^2+1)^(1/2))*s^2+arctanh((exp(2*t)*s-exp(2*t)-s+1)/((exp(2*t)+1)*(-s^2+1)^(1/2)))*s^2+8*(-s^2+1)^(1/2)*exp(4*t)+4*dilog((exp(2*t)*s+(-s^2+1)^(1/2)+1)/(1+(-s^2+1)^(1/2)))*exp(4*t)+4*exp(4*t)*arctanh((-1+s)/(-s^2+1)^(1/2))-8*arctanh((exp(2*t)*s-exp(2*t)-s+1)/((exp(2*t)+1)*(-s^2+1)^(1/2)))*exp(4*t)*s^2*t-4*ln(1+(-s^2+1)^(1/2))*exp(4*t)*s^2*t+4*ln(1-(-s^2+1)^(1/2))*exp(4*t)*s^2*t-4*ln(exp(2*t)*s-(-s^2+1)^(1/2)+1)*exp(4*t)*s^2*t+4*ln(exp(2*t)*s+(-s^2+1)^(1/2)+1)*exp(4*t)*s^2*t+12*(-s^2+1)^(1/2)*exp(4*t)*t-16*arctanh((exp(2*t)*s-exp(2*t)-s+1)/((exp(2*t)+1)*(-s^2+1)^(1/2)))*exp(4*t)*t-8*ln(1+(-s^2+1)^(1/2))*exp(4*t)*t+8*ln(1-(-s^2+1)^(1/2))*exp(4*t)*t-8*ln(exp(2*t)*s-(-s^2+1)^(1/2)+1)*exp(4*t)*t+8*ln(exp(2*t)*s+(-s^2+1)^(1/2)+1)*exp(4*t)*t-(-s^2+1)^(1/2)*exp(2*t)*s+8*arctanh((exp(2*t)*s-exp(2*t)-s+1)/((exp(2*t)+1)*(-s^2+1)^(1/2)))*exp(2*t)*s+4*exp(2*t)*arctanh((-1+s)/(-s^2+1)^(1/2))*s-(-s^2+1)^(1/2)*exp(6*t)*s-8*arctanh((exp(2*t)*s-exp(2*t)-s+1)/((exp(2*t)+1)*(-s^2+1)^(1/2)))*exp(6*t)*s+4*exp(6*t)*arctanh((-1+s)/(-s^2+1)^(1/2))*s+2*dilog((exp(2*t)*s+(-s^2+1)^(1/2)+1)/(1+(-s^2+1)^(1/2)))*exp(4*t)*s^2+2*(-s^2+1)^(1/2)*exp(4*t)*s^2-arctanh((exp(2*t)*s-exp(2*t)-s+1)/((exp(2*t)+1)*(-s^2+1)^(1/2)))*exp(8*t)*s^2+exp(8*t)*arctanh((-1+s)/(-s^2+1)^(1/2))*s^2+2*exp(4*t)*arctanh((-1+s)/(-s^2+1)^(1/2))*s^2-6*(-s^2+1)^(1/2)*ln(exp(4*t)*s+2*exp(2*t)+s)*exp(4*t)+6*(-s^2+1)^(1/2)*ln(s)*exp(4*t)-2*dilog(-(exp(2*t)*s-(-s^2+1)^(1/2)+1)/(-1+(-s^2+1)^(1/2)))*exp(4*t)*s^2)/((-s^2+1)^(1/2)*exp(8*t)*s^2-2*arctanh((-s^2+1)^(1/2)/(1+s))*exp(8*t)*s^2+4*(-s^2+1)^(1/2)*exp(6*t)*s-8*arctanh((-s^2+1)^(1/2)/(1+s))*exp(6*t)*s+2*(-s^2+1)^(1/2)*exp(4*t)*s^2-4*arctanh((-s^2+1)^(1/2)/(1+s))*exp(4*t)*s^2+4*(-s^2+1)^(1/2)*exp(4*t)-8*arctanh((-s^2+1)^(1/2)/(1+s))*exp(4*t)+4*(-s^2+1)^(1/2)*exp(2*t)*s-8*arctanh((-s^2+1)^(1/2)/(1+s))*exp(2*t)*s+(-s^2+1)^(1/2)*s^2-2*arctanh((-s^2+1)^(1/2)/(1+s))*s^2)
I have an equation as follows:
By inspection one can see that the last three terms can be simplified (factored) to
How can I coerce Maple to do this? None of the available tools seem to be getting close to this. A partial solution is like this: Writ a procedure as follows:
Fac:=proc(xpr,a,b);
  tmp:=xpr+(a^2+2*a*b+b^2);
  return tmp-(a+b)^2;
and then call it:
Fac(lhs(eq),k0,2*Pi*n/L)=rhs(eq);
to get
which is what I want. But procedure Fac() is not general at all; e.g. it fails if the overall sign of the polynomial terms are different. There does not seem to be any way in Maple to determine the sign of a term in the sum of lhs(eq), I can only find ways to determine signs of a simple indeterminate. I'd like to make this procedure more general (which is trivial enough for a human) but I just cannot find any tools in Maple to support this.
Any ideas out there?
Mac Dude.
after a matrix operation, the result is not exactly the matrix i want
there is around 0.0001 difference difference in all element in matrix
how to deal with this random difference in order to be exact?
In order to get a little acquainted with the Grassmannian capabilities of the Physics package, I presently consider the following simple setup:
with(Physics):
Setup(
   mathematicalnotation = true,
   anticommutativepre   = theta
A := Matrix(2,(i,j) -> theta||i||j);
B := A . A;
C := Expand(B);
producing for A, B, and C the following results:
To me the [2,2]-entry of B seems erroneous: the first addend has the wrong ordering of the theta's, or, equivalently, the wrong sign. Not so surprisingly, this error is then present also in the [2,2]-entry of C. But in C, the [1,2]- and [2,1]-entries seem erroneous as well: the sign of theta11 in the [1,2]-entry is wrong, and so, too, is the sign of theta22 in the [2,1]-entry.
Have I fundamentally misunderstood something?
Hi everyone,
I have a very complicated function y with only one independent variable x, and want to fit or approximate it by a simpler function, say polynomial. Many books or maple reference seem to tell how to fit a set of data instead of a given function. But the argument x in the function is assumed to be continuous other than discrete, so I don't know whether it is possible to express datax in form of x's range such as 0..1, and express datay in form of the function. After that , maybe I can fit the two created data sets by a polynomial function.
Or, does anyone have a better or more direct way to do the fitting linking two fucntions?
I am appreciated for your help.
Best,
GOODLUCK
I have the following expression (obtained from an earlier calculation):
I want to collect all the terms under one summation. So I define a rule:
collectf:=proc(f)
A::algebraic*f(a::algebraic)+B::algebraic*f(b::algebraic)\
 +C::algebraic*f(c::algebraic)+D::algebraic*f(d::algebraic)=f(A*a+B*b+C*c+D*d);
and then
applyrule(collectf(Sum),%);
I get
Error, (in +) unable to identify A::algebraic
I used similar constructs before so I think the rule is constructed correctly. I should, however, mention that I use the Physics:-Vectors package and in fact the expression I start up with here reads, in 1-d Maple inputform:
Physics[Vectors][`+`](Physics[Vectors][`+`](Physics[Vectors][`+`](-y*(Sum((diff(a[n](r), r))/(exp(I*Pi*n/L))^2, n))/r, (2*I)*(Sum(a[n](r)/(exp(I*Pi*n/L))^2, n))*k0), y*(Sum(a[n](r)/(exp(I*Pi*n/L))^2, n))*k0^2), -y*(Sum((diff(a[n](r), r, r))/(exp(I*Pi*n/L))^2, n)))
Is my problem related to the use of Physics:-Vectors? If so, how can I get around that?
TIA,
Mac Dude
How can I show the expression of the following summation as the output, not 11?
3+7+1
Hi all and happy new year
First I am a beginner in Maple and I want to solve an equation, but I obtain a complexe result with this _Z, my equation is 6th order and the unkown is alpha:
I tried these instructions but without resul:
z := solve(my eq,alpha)
zsol := allvalues(z)
evalf(zsol)
And I get this result
I want a simple result and what is the meaning of _Z
 For some reason maple does not simplify root in the following cases:
sqrt((c^2, r^2));
another one is
sqrt(4), ....
Such square roots occur after this command:
eigenvectors := simplify(simplify(evectors, g * (g - 1) * (e - u * u + v * v + w * w) * 1/2 = c * c), sqrt, simbolic)
Looking at the code of PDEtools:-declare, one sees that it does some brief initializing and then passes the job off to `PDEtools/declare`. I'd like to view this latter procedure, but I can't find it. It is not at the top level, nor is it an export or local of module PDEtools. So where is it?
How to find the sum of the products given below
where I couldn't write j not equal to i in the product.
sum(a[i],i=1..n)*product(s-b[j],j=1..n)
Has anyone an idea how to integrate
int(t^2/(1+s*cosh(2*t))^2,t=-infinity..infinity)
0<s<1
FirstEigenVector := Matrix(3, 1, {(1, 1) = -.736895432967255+0.*I, (2, 1) = -.588906969844997+0.*I, (3, 1) = -.331924240964690+0.*I});
SecondEigenVector := Matrix(3, 1, {(1, 1) = -.589856901397123+0.*I, (2, 1) = .320280857681335+0.*I, (3, 1) = .741275257969058+0.*I});
ThirdEigenVector := Matrix(3, 1, {(1, 1) = .330233185410229+0.*I, (2, 1) = -.742030156443046+0.*I, (3, 1) = .583384341736151+0.*I});
LHS := ProjOfEigenVector;
LHS := Matrix(3, 3, {(1, 1) = -.736895432967255+0.*I, (1, 2) = -.589856901397123+0.*I, (1, 3) = .330233185410229+0.*I, (2, 1) = -.588906969844997+0.*I, (2, 2) = .320280857681335+0.*I, (2, 3) = -.742030156443046+0.*I, (3, 1) = -.331924240964690+0.*I, (3, 2) = .741275257969058+0.*I, (3, 3) = .583384341736151+0.*I});
RHS := c1*FirstEigenVector+c2*SecondEigenVector+c3*ThirdEigenVector;
RHS := Matrix(3, 1, {(1, 1) = (-.736895432967255+0.*I)*c1+(-.589856901397123+0.*I)*c2+(.330233185410229+0.*I)*c3, (2, 1) = (-.588906969844997+0.*I)*c1+(.320280857681335+0.*I)*c2+(-.742030156443046+0.*I)*c3, (3, 1) = (-.331924240964690+0.*I)*c1+(.741275257969058+0.*I)*c2+(.583384341736151+0.*I)*c3});
solve([LHS[1][1] = RHS[1][1], LHS[2][2] = RHS[2][1], c1^2+c2^2+c3^2 = 1], [c1, c2, c3]);
after calculated the projection matrix,
it is a 3*3 matrix on left hand side
however, combination of eigenvectors on right hand side is 3*1 matrix
when calculated c1,c2,c3 under the condition c1^2+c2^2+c3^2 = 1
how to know whether LHS[1][1] = RHS[1][1], or LHS[1][2] = RHS[1][1] or
LHS[1][3] = RHS[1][1]
First 1522 1523 1524 1525 1526 1527 1528 Last Page 1524 of 2471
