Is it possible to have the labels of the x-axis and of the tickmarks above the axis?
How to find 2013th term in the sequence
1, 2, 2, 3, 3, 3, 4, 4, 4, 4, ...?
in which the n-th positive integer appears n times.
I don't know how to start.
Polya deals out cards from a deck one by one. How many cards must Polya deal out until he is sure that a flush (five cards of the same suit) has appeared amongst the dealt cards? What if Polya wants a straight (five cards in sequence, with an ace counting low or high)?
 The answers are 17 and 45, but how? in Maple?
for the flush the chances are 1/numbperm(13,5)/numbperm(4,1)
for the straight 1/10/numbperm(4,1)^5.
http://www.math.hawaii.edu/~ramsey/Probability/PokerHands.html
In a mechanical problem, i have to deal with a system with trigonometric expression. The variables are gamma[1](t), psi[1](t), phi[1](t), alpha(t), beta(t), x(t). The orthers are parameters.
I would like to have a explicit relations between  gamma[1](t), psi[1](t), phi[1](t) and alpha(t), beta(t), x(t).
In orthers words, i would like to have
alpha(t)= f(gamma[1](t), psi[1](t), phi[1](t)).
beta(t)= f(gamma[1](t), psi[1](t), phi[1](t)).
 x(t) = f( gamma[1](t), psi[1](t), phi[1](t)).
Of course, the expresions of alpha(t), beta(t), and x(t) should be complex. Nevertheless, it will avoid me to have to solve Newton Raphson algorithm to solve these constraints equations.
Normally, it should be feasible.
When i have only one equation and not a system, isolate function is helpful.
But in this case, i don't manage to have my relations.
Have you some ideas to expression these relations ?
Here the code of the equations :
with(Student[MultivariateCalculus]):
constants:= ({constants} minus {gamma})[]:
`evalf/gamma`:= proc() end proc:
`evalf/constant/gamma`:= proc() end proc:
unprotect(gamma);
unprotect(gamma);
eq_liai[1]:= rF[1]*cos(a[1])-cos(a[1])*cos(gamma[1](t))*e[1]-l[1]*(cos(phi[1](t))*cos(a[1])*cos(gamma[1](t))*cos(psi[1](t))-cos(phi[1](t))*cos(a[1])*sin(gamma[1](t))*sin(psi[1](t))-sin(a[1])*sin(phi[1](t)))-cos(alpha(t))*rBTP[1]*cos(a[1])-sin(alpha(t))*sin(beta(t))*rBTP[1]*sin(a[1])-sin(alpha(t))*cos(beta(t))*h = 0;
eq_liai[2]:= rF[1]*sin(a[1])-sin(a[1])*cos(gamma[1](t))*e[1]-l[1]*(cos(phi[1](t))*sin(a[1])*cos(gamma[1](t))*cos(psi[1](t))-cos(phi[1](t))*sin(a[1])*sin(gamma[1](t))*sin(psi[1](t))+cos(a[1])*sin(phi[1](t)))-cos(beta(t))*rBTP[1]*sin(a[1])+sin(beta(t))*h = 0;
eq_liai[3] := h[1]+sin(gamma[1](t))*e[1]+l[1]*(sin(gamma[1](t))*cos(psi[1](t))+cos(gamma[1](t))*sin(psi[1](t)))*cos(phi[1](t))+sin(alpha(t))*rBTP[1]*cos(a[1])-cos(alpha(t))*sin(beta(t))*rBTP[1]*sin(a[1])-cos(alpha(t))*cos(beta(t))*h-z(t) = 0;
or directly a maple file
constraints.mw
Thanks a lot for your help
Hi.
How to present two indexed values a[n] and b[n] in form
a0 = ...,
a1 = ...,    b1 = ...;
a2 = ...,   b2 = ...;
in MathContainer component?
Does Maplesim allow hardware integration such as a joystick so that I can feed in joystick commands (via USB or serial) from the computer and then control my Maplesim model in the virtual space? Suggestions?
I'm currently working on a manipulator model in Maplesim and will import CAD attachments to each of the links. The Solidworks model, once imported to Maplesim, is not located in the same position as the Maplesim part but is offset by X,Y,Z. The scaling is also off. Is there some way to align the CAD to the component instead of trial and error?
I have encounter a Maple response but I don't know how to interpret it.
When I tried the following Maple codes:
A := solve( x^4 + x^3 + x^2 + x + 1  = n, x ):
asympt( A, n, 2 )
Maple responded with a mysterious "pt".  What is going on?  Any help will be appreciated!
Cheers, Yen-chi Roger Lin
Assistant Professor in Mathematics
National Taiwan Normal University
Good morning Maple users.
I request your kind suggestion to the above cited question.
With thanks & Regards
M.Anand
SR International Institute of Technology,
Hyderabad, Andhra Pradesh, INDIA.
I am playing around with a crude implementation of the bisection algorithm. I am using printf  to display some of the output, however there are a couple extra characters, namely, ()^2, at the end. When the very last line is removed, it goes away. What is causing this?
restart; f := proc (x) options operator, arrow; evalf(x^3-3*x^2+1) end proc; a := 0.; b := 1.0; count := 0; while abs(b-a) > 10^(-8) do count := 1+count; m := (a+b)*(1/2); print([a, m, b]); if f(a)*f(m) < 0 then b := m else a := m end if end do; fval := f(m); printf("\n The function value at %10.10g is %10.10g.\n", m, fval)*printf("\n Number of interations: %d.\n", count)
()^2
 The function value at 0.6527036502 is   -1.5e-08.
Download bisect.mw
Consider the following Matrix constructor:
M := Matrix(3,(i,j) -> a||i||j + I*b||i||j,shape = hermitian);
It generates the following output:
That appears to me to be definitely wrong, a hermitian matrix allowing nonzero real-valued diagonal elements (otherwise quantum mechanics would be a rather vacuous theory). For shape = antihermitian, the diagonal still contains only zeros, even though it should contain nonzero purely complex-imaginary elements. Have I fundamentally misunderstood something?
PS: I was aware of this shortcoming back in Maple 9.5 (the previous version I have been working with), there manually circumventing it, but I certainly expected that it had been fixed since then.
Maple Player seems like it could be an outstanding piece of software, yet with the new operating system for Ipad, the program crashes immediately. I am unable to find any solutions. I also stumbled across a post in which Maplesoft is no longer providing support for the APP. Is this true?
I am attaching my file. Many of you have given great help on how to get dynamic Maple activities working.  My question again is along those lines. I have created a parabola with sliders a,h, and k.  What I am trying to do is have a button that says show vertex on the equation y=a(x-h)^2+k. However, when I connect the button with Plot3, I plot the the vertex in a new window.  Here is the most successful code I used:
Do(%Plot3=(plot([[%Slider2,%Slider1]],style=point,colour=blue,symbol=solidcircle,symbolsize=18)));
So I do get the point I want (h,k), but the point is not on the function itself.  I have tried muliple maple commands with no luck.  I am wonder how I can get the point (h,k) to be on the function when I hit the "show vertex" button.
Parabolas_In_Vertex_.mw
Thank you for you time,
Nicholas
diffeq := diff(w(r), `$`(r, 1))+2*beta*(diff(w(r), `$`(r, 1)))^3-(1/2)*S*(r-m^2/r) = 0;
con := w(1) = 1;
ODE := {con, diffeq};
sol := dsolve(ODE, w(r), type = numeric);
How can i have numerical solution of the above differential equation with corresponding boundary condition?
Good time friends,
Recently, I saw this link http://math.stackexchange.com/q/613753/8581. There we asked to find the functions f(x) ang g(x) by having both composition functions fog(x) and gof(x). I know what to do to find any of f(x) (or g(x)) if I am given fog(x) (or gof(x)) respectively, but I confess I don't know what to do with this one. Can Maple overcome this knid of problem? Thanks for your time.
First 1527 1528 1529 1530 1531 1532 1533 Last Page 1529 of 2471
