I have a transcendental equation
equ := 2+(s+1)*exp(tau*s) = 0
where s is a complex variable,and the range of tau is tau = 0 .. 1, I want to plot the trajectory of every roots,namely,s, in a complex plane according to the variety of tau. I try to use the command implicitplot, but get a curve in real plane.
Can you help me?
Best regards.
In Classic, you can also first issue plotsetup(maplet) and get a Java-based plotter that supports more 2D Math. That plotter will show nicely typeset subscripts using your original example's syntax plot(y[r]^2,labels=[y[r],x[c]]) .
However, when i want to export as eps it exported it but without color.
could...
Hello (again),
is there a possibility in MAPLE to draw multiple plots on a e.g. 2x2 grid (see image below). In Gnuplot this is feasible with the multiplot option? Is there a MAPLE equivalent...
Tobias
i'd like to fit data of a Matrix M with M[x][y] = z(x,y) to a general parabola of the form: z=a*x^2+b*y^2+c*x+d*y+e
I'd like to use the statistics[Fit] package. Reading the documentation this should work but it doesn't
Please try the following code as example:
with(combinat);
with(Statistics);
M := randmatrix(5, 5);
XYValues := convert(sort(permute([seq(1 .. 5), seq(1 .. 5)], 2)), matrix);
ZValues := convert(Flatten(convert(M, listlist)), vector);
Hello.
I want to find books of probability or stadistics where all topics are explained in depth. I need books where all formulas are deduced and all theorems are demonstrated.
May somedody recommend to me some books?
hey there,
i have a textfile with three columns and i am using the "readdata" command. the first column is a filepath that i read in as a string. unfortunately the filepath is saved with backslashes ("c:\data\...") and therefore i cannot open the file that is indicated by the path. how can i replace the backslashes with forward slashes? any other ideas are also appreciated. thanks!
phone_code_mprime.mw
given 2 pools of letters, i need a procedure to select from the list of 2 letter permutations the appropriate candidates (that are in the correct order).
permute produces a lot of candidates, but i need an english word formed in the correct order.
attached file should explain
i need to calculate the radius of an arc. i have that the chord lenght is 96 inches and the distance between the chord and the arc is 6 inches perpendicular from the center of the chord. assuming that i am working with a circle.... how do i calculate the radius of the circle????
Let f:R-> Rm a linear function i need help about a proc about matrix of the linear map Df(x),
our input will be n,m and f
such that,f:R2->R3 ,f(x,y,z)->(x+y,y+2z,x+y+z) and i wish resulting output with derivative matrix with respect to the standard bases in R2 and R3
it just won't work
simply hovering over tools crashes it
going into a menu crashes it
trying to execute a command crashes it
it just freezes up completely such that it won't even close down without using task manager
i know fully how to use maple, i've used it on my university network but using it on my home pc won't work for some reason, even though my computer is very modern and i am sure meets the specs.
is this a common thing?...
i try to use your code (i mean other way )   that give to me but it doesnot work. it give x[c] and y[r] at label.
i have maple 14 .
could you please help what is the problem?
last answer is wrtten by
It can be done with the labels option (see ?plot/options
I have a problem with plot using maple. I want to plot x_c agaist y_r
However, i have no idea how to make at label that   y_r  . In other word, i want to make r under y and ignore dash (-) that between y and r
and the same idea for x_c.
could you please help me in this plot label problem?
0 = 0, -(1/16)*cos(l1)*cos(l2)*cos(l3)*cos(l4)*(-Pi*x3+4*cos(Pi*t)) = 0, -(1/16)*cos(l1)*cos(l2)*cos(l3)*cos(l4)*(-Pi*x2+4*sin(Pi*t)) = 0, (1/16)*cos(l1)*cos(l2)*cos(l3)*cos(l4) = 0, 0 = 0, -(1/8)*cos(l1)*cos(l3)*cos(l4)*(-Pi*x3+4*cos(Pi*t)) = 0, -(1/8)*cos(l1)*cos(l2)*cos(l4)*(-Pi*x2+4*sin(Pi*t)) = 0, (1/8)*cos(l1)*cos(l2)*cos(l3) = 0
After I ran solve({eq1, eq2, eq3, eq4, eq5, eq6, eq7, eq8}, {l1, l2, l3, l4, t, x1, x2, x3}, AllSolutions); I got...
Here is my code where I get the problem of taking the coeff of theta dot . The output of matlab Cm shows the coeff in the output matlab ( Cmatrix , optimize) at t2727 I see coeff .Meaning when the loop ran coeff didn't execute.
> J[p1] := Matrix(3, 4, {(1, 1) = -sin(theta[1](t))*`Δx`[1]-cos(theta[1](t))*`Δz`[1], (1, 2) = 0, (1, 3) = 0, (1, 4) = 0, (2, 1) = cos(theta[1](t))*`Δx`[1]-sin(theta[1...
I keep getting this error although the code is running fine in maple 14 , Help is greatly appreciated Thanks alot
> restart; with(LinearAlgebra);
> A[0] := Vector(3, {(1) = 0, (2) = 0, (3) = -g});
> type(a[0], Vector);
> omega[0] := Vector(3, {(1) = 0, (2) = 0, (3) = 0});
First 1951 1952 1953 1954 1955 1956 1957 Last Page 1953 of 2463
