Visualizing_the_SVD_.mw
Hola ev1:
I like to shorten the size of the command, through setoptions3d function. But it seems that it does not interact with ApplyLinearTransformPlot function.
How to get to label the vectors?
Gracias
I am working on hybrid dynamical systems an encounter the warning: "dependencies in discrete equations cannot be ordered". What does this mean and should I care about it?
> restart;
> with(plots);
BridgeHeight := 40;
BridgeFromCenter := 20;
BridgeToEdge := 35;
BridgeWidth := BridgeToEdge+BridgeFromCenter;
BridgeFromTheWater := 15;
BridgeLines := 10;
SpaceBetweenLines := 2*BridgeToEdge/BridgeLines;
LineStart := BridgeWidth;
CountLines := 0;
LineWidth := BridgeWidth;
while BridgeLines > CountLines do
CountLines := CountLines+1;
If i have the line:
S:=Sum( 1/16^k))*(4/(8*k+1)-2/ (8*k+4)-1/ (8*k+5)-1/ (8*k+6)), k=0..m);
and i want to establish the first m for which |Pi-Sm|<= 10^(-8)
when putting it into a while loop i get the error message that it cannot determine whether the expression is true or false:
while (Pi-S <= 10^(-8)) do
od;
etc,
what am i doing wrong here?
with(Optimization); nx := Maximize(abs(.5539395590*x^2+1.130864333*x+.9891410756-exp(x)), {-1. <= x, x <= 1.})
give [0.443368608590448687e-1, [x = 1.]]
but I know that it is not the maximum because:
abs(.5539395590*.56^2+1.130864333*.56+.9891410756-exp(.56))=0.045468048
with(Optimization); nx := maximize(abs((29.83428688*x-57.16914857)/(x-2.196093020)-exp(x)), x = 5.0 .. 6.0, location)
if we plot this function we see that the solution exists.
with(Optimization); nx := maximize(abs(.5547114632*x^2+1.130478381*x+.9883691714-exp(x)), x = -1 .. 1, location)
nx := 0.4568872387e-1, {[{x = 1.002012310}, 0.4568872387e-1]}
but 1.002 isn't in -1..1
I have a set of functions and parameters, I am computing Jacobian to those functions. I get a matrix rectangular in dimensions. So, determine Jacobian of sub-matrices(formed by removing one column for each sub-matrix) and equating them to zero.
> T := Matrix([[0], [4*t], [0]]); X := Matrix([[x1], [x2], [x3]]); R := Matrix([[1, 0, 0], [0, cos(pi*t), -sin(pi*t)], [0, sin(pi*t), cos(pi*t)]]);
> c1 := x1^2+x2^2-1/4-(1/4)*sin(l1); c2 := x3-sin(l2); c3 := t-1/2-(1/2)*sin(l3);>
Hi e-friends,
I want to minimize a function subject to a set of S restrictions.
The restrictions are related to matrices V, W, X and Y:
V = [v1, .., vS]  order L x S
W = [w1, .., wS] order L x S
X = [x1, .., xS]  order LxS
Y = [y11,.. yS] order L x S
How may I write in MAPLE in compact form  the following S inequalities (for any arbitrary integers L and S)?. ...
In the help, a structure block diagram is given under the DynamicSystems[SystemConnect] command for the explaination of the use for the general connection,
that's intuitive and gives clear connections among every structure block,
so, I wonder whether there is a method to build that diagram or similar fig using the GraphTheory package,
that will be amazing,
is there a method? I want to know how to get it.
What it is wrong with this one-line-document:
with(Optimization): nx := Maximize(e^x, {x <= 1.})
that give this answer:
[9.99990000000000000*10^19, [e = 9.99990000000000000*10^19, x = 1.]]
this is the model of my laptop : Sony VAIO VGN-FE590P
http://www.computercrowd.com/Itm160503097051_177_Sony_VAIO_VGN-FE590P.aspx
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNFE590P
I am going to work with maple 14 on it ,
please check its hardware details !
and tell me usually a laptop with this condition ...
Let X=(0,∞) x R and y=>g(y) be a given function. Find the solution:
(x,y)==>u(x,y)
To the initial value problem
(-x-y)ux(x,y)-(y)uy(x,y)+u(x,y)=0 for all (x,y)belonging to X
subject to u(0,y)=g(y).
I keep getting stuck; Any help would be amazing!
here is a matrix
A := Matrix(2, 2, {(1, 1) = ((1/2)*I)*E[0]*d[ba]/`&hbar;`, (1, 2) = -((1/2)*I)*delta, (2, 1) = ((1/2)*I)*delta, (2, 2) = ((1/2)*I)*E[0]*d[ab]/`&hbar;`})
it is clear that there is a common coeff with each element by ((1/2)*I,i just want to show the matrix with traditional way.
#A:="((1/2)*I*Matrix(2, 2, {(1, 1) = -E[0]*d[ba]/`&hbar;`, (1, 2) = delta, (2, 1) = -delta, (2, 2) = -E[0]*d[ab]/`&hbar;`})"
A1:=((1/2)*I;
First 1952 1953 1954 1955 1956 1957 1958 Last Page 1954 of 2463
