I have a complicated function (combination of exponential and sin), and I want to find the infinite integral of that from 0 to infinity which I know that the function itself converges to zero at infinity. I used evalf to force maple to do that but it fails to give the numerical answer. How can I resolve the problem?
Hamid
An animation runs in Maple and it runs in a browser (Chrome) if I export it directly to a .gif file. But if I manually resize (expand) it and export it to .gif, the exported file fails to run in the browser. Why is this, and is there a work-around? The file is about 4.7 MB in size.
Mac w OS X, 10.4.6, 3.06 GHz Intel Duo with 4GB RAM, Maple14 Student
I  have to solve this initial value problem:
pde := (-x+y)*(diff(u(x, y), x))+(-y*(diff(u(x, y), y)))+c*u(x, y)=0
subject to u(0,y)=g(y)
I have had a go and this is what I have so far:
a := -x(s)+y(s)
b := -y(s)
c := 1
pde := a*(diff(u(x, y), x))+b*(diff(u(x, y), y))+c*u(x, y) = 0
chareq1 := diff(x(s), s) = a
chareq2 := diff(y(s), s) = b
here is an equation
eq := I*`ℏ`*(sum((diff(c[n](t), t))*f[n](r)*exp(-I*omega[n]*t), n = l .. k)) = (1/2)*E[0](e_.r_)*e*(sum(c[n](t)*f[n](r)*omega[n]*(exp(I*t*(-omega[n]+Omega))+exp(-I*t*(omega[n]+Omega))), n = l .. k))
req := Int(conjugate(f[m](r))*rhs(eq), r)
leq := Int(conjugate(f[m](r))*lhs(eq), r)
sup:=Int(conjugate(f[m](r))*f[n](r), r) = delta[m, n]
ans:=applyrule(sup,leq=req)
how can get the result as
ans := I*`ℏ`*(diff(c[m...
I have solved a set of ODEs. For example I have obtained L(t). Now, I have a relation between "t" and for example "z", such as "t = exp(z)". How can I get for example L(z=1)?
Download for_mapleprimes.mw
I used dolve for dsystem,
but I got this error:cannot evaluate right than .....
is there anyway to overcome this problem?
GCD := proc (a, b) local sol, x, y, eqs, vars; vars := [x, y]; eqs := [Typesetting:-delayDotProduct(cos(x), sin(y)) = 0, y+sin(x) = b]; sol := solve(eqs, vars); sol end proc
I tried to convert this code into C, using C(GCD) and got an error message that target language may not recognize commands like solve etc., which is obvious. Please let me know if there is any way to convert procedures involving such commands into C code.
I am using CodeGeneration[Fortran] to generate a Fortran subroutine.  The subroutine simply takes a vector state as input and generates a large matrix as output.  However, upon calling "Fortran" I have been getting the following warning that I have not been able to figure out:
"Warning, character limit for Fortran77 statements exceeded; please filter input through codegen[split] first."
If anyone can provide some tips, I would appreciate it.
I have got an equation of Sum.i want to split the eqution three parts of Sum,how can do?
ans:=sum(I*`ℏ`*(diff(c[n](t), t))*phi(r)*exp(-I*omega[n]*t)-(1/2)*E[0](e_.r_)*e*c[n](t)*phi(r)*omega[n]*exp(-I*omega[n]*t+I*Omega*t)-(1/2)*E[0](e_.r_)*e*c[n](t)*phi(r)*omega[n]*exp(-I*omega[n]*t-I*Omega*t), n = l .. k)
i want to  result like this
ans1:=sum(I*'ℏ'*(diff(c[n](t), t))*phi(r)*exp(-I*omega[n]*t), n = l .. k) = sum((1/2)*E[0...
Hi, I have recently started working with Maple. I need some help with solve command.
VectorCalculus[`*`](cos(x), sin(y)) = 0
y = VectorCalculus[`*`](2, sin(x))
Now if I run solve on above two equations for values...
Not sure why pdsolve is choking on my input.  The file is attached below.  It works fine for my first expression if the term without the square root sign is not included.  When I include that term as you will see at the end it simply does nothing?
Any advice??
I keep getting this error,
not matter what command.
How can I solve this please?
Please help,
how can i create hierarchical tree whith maple 10.
Forexample i have data and i want to make hierarchical tree
We have been asked to write a general code for the revised simplex method in Maple.  We have been trying for several days but haven't got anywhere.  We think we have written (a very basic) code for the first iteration but we don't know how to do a loop so that it keeps going until the solution has been found.
PS its a maximisation problem.
Using SVD to underst.mw
Hola ev1;
In the procedure PLOTSVD, I get the error
"Error, (in SVDPLOT) invalid input: linearalgebra" SingularValues Expects output value for keyword parameter to Be of type {list (identical (U, S, Vt, list)), identical (U, S, Vt, list)}
First 1953 1954 1955 1956 1957 1958 1959 Last Page 1955 of 2463
