Hello friends,
When I solve the optimization problem with restriction (below):
NLPSolve( ln(x1) +ln(x2+5), {x1 +x2 <=4}, assume = nonnegative);
     [-Float(infinity),
       [x1 = HFloat(0.0), x2 = HFloat(0.8333333333333334)]]
I get the expression  "-Float(infinity)"..
What do Float(infinity) and  HFloat(0.833333) mean?
Thanks for the attention,
Hello everybody!
I'm working on a statistical problem. I need to plot confidence regions for parameters in the model, but I don't know what I should do. I tried to get some programs from the internet, but either they don't work or I don't understand details of them to change for my work. Can someone introduce a good program to me?, or does anyone have another useful idea for me?
Thanks a lot!
I meet a problem in the use physcis package.
    for example,
                                   restart;  with(Physics); Setup(mathematicalnotation = true):
I am analyzing a system that was at steady state and then subjected to a step change.  I have the steady state modeled with a system of ODEs.
I am going to model the step change with a system of PDE's.  The system will be discretized in space and time (z,t).  I know how to setup one side of the boundary conditions (0,t) for all variables, but the other (i.e A(z,0)) I would like to use the results of the steady analysis. Does anybody have some ideas on...
I would like to do the following
A[1,1],A[2,2],A[3,3]:=seq(i+2,i=1..3)
using seq on the left-hand-side. I know I have done it in the past but don't get it this time. End up with error messages. Not sure what am I missing.
thanks a lot
Dimitrios
I typed  x:=a*cos(t)^3
For a while it was handling this correctly.
But then it started replacing the multiplication sign by ~ every time it used this or anything similar.
Something has changed the status of the a .
If I use b instead of a, it works fine.
Hello Maple experts,
I call "out" the development of the sum(x^2, x=a..b):
"out":= sum(x^2, x=a..b);
     1        3   1        2   1     1   1  3   1  2   1
out=     - (b + 1)  - - (b + 1)  + - b + - - - a  + - a  - - a
Hello All,
I am having a problem plotting the solution of a system of PDE's.  Maple evauates to a module, but when I try to plot any of the dependent variables (of space and time) vs time, all I get back is:
"PLOT(...)"
My module is called Final, and so my plotting command is as follows:
p1:=Final:-plot(A(z,t),t=0.5);
This is where I get "PLOT(...)".  Any help would be greatly appreciated!!! Thanks!
Hello.
I need to generate 200 random numbers from a normal(0,1). I used the following code:
N:=200:
Y:=Array(1..N):
for i from 1 to N by 1 do:
     Y[i]:=Generate(distribution(Normal(0,1))):
This code works. But the numbers generated aren't a random sample. You can check that in the following qqplot.
Dear my friends
I am solving a nonlinear differential equation by Maple. The equation is slarge. A large amount of memory is then required. I have a computer with 8 gigabytes memory. This memory o large and has many terms. Therefore, the algebraic expressions created in process of solving are so is very low to perform some commands of Maple such as "taylor" or "expand". I compel using the "restart" command to clear the memory after saving the results of each...
Let a:= (2x-1)/sqrt(1-4x2)  , b:=sqrt(1-2x)/sqrt(1+2x)
then c:=combine(a/b,radical,symbolic) is 1, it should be -1 !
(Multiply b top and bottom by sqrt(1-2x) to see this).
Am I misunderstanding combine?
Law of Hess and heats of dissolution in acid.б-в Х, КХ
In 298.15 º K are set following the dissolution enthalpy of these compounds in HCl:
B2O3.3CaO           -344.86 kJ/mol,
B2O3.2CaO           -210.40 kJ/mol,
B2O3.CaO  ...
Hi I want to solve the following equation. For this I have written the following program. But Maple showing error.
eq := diff(x(t), `$`(t, 2))+326.1*(diff(x(t), `$`(t, 1)))+3190*(diff(x(t), `$`(t, 1)))^2-37500*sqrt(x(t)*(0.165e-2-x(t)))+2.825
ICs := x(0), Dx(0)-0
sol := dsolve({ICs, eq}, {x(t)}, type = numeric);
but it is showing
eq := {-2*b[2]*B+b[3]*J+b[5]*J-lambda[2]*b[2] = 0,
-2*b[5]*B+b[2]*J+b[4]*J-lambda[2]*b[5] = 0,
-lambda[2]*b[3]-2*b[3]*B+b[4]*J+b[2]*J = 0,
-lambda[2]*b[4]+b[3]*J-2*b[4]*B+b[5]*J = 0,
abs(b[2])^2+abs(b[3])^2+abs(b[4])^2+abs(b[5])^2-1 = 0}
 v := {lambda[2], seq(b[i], i = 2 .. 5)}
 ans:=solve(eq,v)
the result show:
          ans:=
Hello all,
In reference to Acer's workaround for the operator form of the optimization package, I'm having difficulty applying the method to an optimization problem with 7 variables. I'm hoping you can help me see what I'm doing wrong. This is what I've got coded, where EIG is a fairly long, complex procedure that outputs a float value:
> objf := proc (V::Vector)
First 1965 1966 1967 1968 1969 1970 1971 Last Page 1967 of 2463
