I've got a pretty intensive run going on in Maple and I wanted to speed it up. It involves computing every power up to some large number (100,000+) of small matrices (2x2) but with very complicated abstract polynomials inside. There's really no way to speed this up as far as coding is concerned so my only option is to use multithreading, since I need mutiple runs, or run this on some faster server/cloud.
1) Multithreading will...
sendtomap1.mw, sendtomap2.mw, wood_riess.zipHi! I've written a program for my work to obtain "chi square" for a range of data. Can someone tell me why my first example which I have attached and I've called it "sendtomap1" works correctly, but the second one "sendtomap2" has an error?...
why won't VectorCalculus[Jacobian] accept vectors?
... to prevent me from frying my system? or is it an unnecessary restriction?
Here's what I mean:
Fvec := Vector([x[1]*x[2],3*x[3]]);
Xvec := Vector([x[1],x[2]]);
Flst := [x[1]*x[2],3*x[3]];
Xlst := [x[1],x[2]];
VectorCalculus[Jacobian](Fvec,Xlst);
VectorCalculus[Jacobian](Flst,Xlst);
VectorCalculus[Jacobian](Flst,Xvec);
Error, invalid input: too many and/or wrong type...
I want to plot a graph for the two variable function f(x,y)= xy^2/(x^2 + y^2 +1 )
over the region x = [-2,2] and y = [-2,2].
How I can create a coloured [or with different shades of grey to see the difference in a black and white printout] "contour" plot of this function over the same reagion? Using 8 contours and in such a way that it is illustrative...
I have the space curve with parametric equations x = t ,  y = 0.5t2 , and z = t2
I need to find the unit tangent vector, unit normal vector and the binormal vector  at t=1
I also need to find the curvature at t=1
How I can calculate that step by step that in maple and also plot the space curve and the curvature graph seperat in maple?
How I can find parametric equations for the line of intersection of the planes 3x - 5y + z = -7 and x + 8y - 4z = 13
in maple with a step by step approach?
and also plot a graph in maple showing the two planes and the line of intersection?
please i want to write the maple programme  for solving y/ =y, y(0)=1, 0≤x1 with h=0.1 using the following three schemes simultaneously:
1. (7/12)yn+1 - yn+1/2 +5/12yn =(h/12)fn+2
2. yn+2 - (4/3)yn+1 +1/3yn =(2h/3)fn+2
3. yn+1 -yn =hfn+1/2
How do you enter h in a Euler's method problem? I need to change h=0.1 to h=0.05
I'm using the 2D input in Maple 14.
So far I have this:
> DE2 := diff(y(t), t) = 3+t-y(t);
> Euler(DE2, y(0) = 1, t = .4);
> Euler(DE2, y(0) = 1, t = .4, output = Error);
> Euler(DE2, y(0) = 1, t = .4, output = information);
When I learning "Maple introductory programming guide", there is a little procedure attracting me:
_________________________________
NewName := proc ()
    global N;
    N := N+1;
    while assigned(cat(C, N)) do
        N := N+1;
    cat(C, N);
end proc
Dear primers,
I have a curve that shows 4 maxima (green curve in the image, red curve is the derivative). Now i simply want the coordinates of these maxima without defining a threshold. I tried the "ExtremePoints" function, but it returns an error ("...cannot determine discontinuities") and the "extrema" function which gives me only one max and min value.It would be great, if somebody could give me a hint...
Normally after Maple calculations i obtain results like this one:
(-1+du1(t))/(C*L)
when i would very much like to obtain it with a slight difference:
(du1(t)-1)/(C*L)
Is there a way i can achieve this?
When I solved:
restart: mu:=solve(h*sin(mu*b)+mu*cos(mu*b)=0,mu,AllSolutions=true);
where b and h are constant, the solution is:
Let us consider the simple single-variable function,y=f(x)=x*x(i,e,x^2).Now suppose that we don't know our func is x*x,instead we are given:
                                x                        ...
I'm currently working on a project where I need to create a 3D graph with close to 5500 data points. For smaller datasets, I have been able to create the graphs using the with (plots): pointplot3d command. An example of syntax used:
with (plots): pointplot3d({[23.8, 2399, 24.2],[23.6, 3030, 24.0],[23.6, 3876, 24.2]},axes=normal,symbol=box);
However, when I try to use the same method to graph the larger data set, the program freezes ...
whats the difference between A.B and A&*B given that both A and B are matrices.
First 1969 1970 1971 1972 1973 1974 1975 Last Page 1971 of 2463
