Recently I was looking at an algorithm in one of Knuth's books.
The algorithm is described in steps with many of the form
if condition 1 then goto step 7; if condition 2 go to step 8,
etc.
I managed to write up the algorithm by making each step
a procedure, but had trouble with handling global variables.
Is there in Maple some standard method for dealing with such algorithms.
A friend tells me...
Hey,
I've been running the following program in a maple worksheet and it has worked fine.
Now I want to run it on an Ubuntu machine that has some extra computing power to get through a big data set.
However I get strange "Incomplete Quoted Name" errors, even when I have no quoted names in my input at all.
This is just alittle bit of the output I'm getting:
    |\^/|     Maple 14 (X86 64 LINUX)
._|\|   |/|_. Copyright (c...
I'm seeing strange behavior when I try to numerically solve the heat equation with radiative boundary conditions (heat flux proportional to 4th power of surface temperature).  I set up a simple example of a plate that sees 300K on one side and 310K on the other.  Two obvious flaws in the solution of the radiative example are that the slope of the curve always has the wrong sign at the left boundary (sometimes wrong on both boundaries), and that the solution runs away...
I WAS WONDERING IF ANYONE COULD HELP ME OUT... I DOWNLOADED A STRUCTURAL MECHANICS PACKAGE THE OTHER DAY FROM THE MAPLE APPLICATION PAGE.... I KNOW I CAN RUN EACH OF THE DOCUMENTS INDIVIDUALLY BUT I DON'T KNOW HOW TO CALL THEM UP IN THE PROGRAM.. CAN ANYONE GIVE ME STEP BY STEP INSTRUCTIONS OF HOW I CAN INSTALL THE PACKAGE IN MAPLE 13..
THANKS IN ADVANCE!!!
I have purchased an e-book for Maple called "Advanced Engineering Mathematics". I have found it to be full of red code text (which I understand to be 1-D Maple format, correct?).
Is there a way of converting the contents of my e-book to get rid of this red text (or at least convert it to something more meaningful) ?
Thanks and regards,
Andrew J Fortune,
Melbourne,
Australia
I would like to ask a 2-part question in Maple TA in which the correct response to the second part of the question is based on the student's response to the first part of the question.
Here is a simple example.
Question #1
A) What is 1+4 ?
B) What is 2 times your solution to part A?
Obviously, the correct answer to B is 10, but what if the student thought that the correct answer to A was 4? Then if they put 8 as the answer to B I would...
When I write
evalf(Pi);
I get  3.14159...
But, when I want to visualize the value  "e", after writing
evalf(e);
I get       e .
Why I cannot see the digits of "e"?
Did I instal not properly my Matlab14.0?
Just a simple question:
How do I unassume (remove the assume) all the variables in my code in the easiest way?
Thanks a lot for your help.
In a loop (variables set to some calculation) when maple produces an error how can I set it to a value of zero?
I want to find the first positive and first negative root of a bessel function
j2 := (x, a) -> k(x)^2*a^2*(diff((diff(1000000000*sin(1/1000000000*k(x)*a)/(k(x)*a), x))/(k(x)*a), x))/(k(x)*a)
I couldn't use the built in bessel function with two variables, so I had to enter it by hand.
I want to find the values of x where j2 is zero as a function of a:
f := (a) -> RootOf(j2(x, a), x, 0 .. 2)
plot(f(a), a = 2 .. 2.25, y = -3 .. 3)
Hey folks. I have a massively complicated equation I'm trying to solve and the internal memory can't take it.
Here is the problem.
Let f(x) := 1 - lambda*x^2
alpha := 1/f(1)
By solving the following equation,
alpha*f(f(x/alpha)) = f(x) + O(x^4)
We can determine a value of lambda and hence alpha (for which the real value is roughly -2.5 and the calculated value here is roughly -2.7).
hello everybody
please heeeelp
In the name of God
Dear friends
I have a question about releasing a part of memory occupied by some lists, sequences and matrices, for example matrix "M" or list "L".
If we use the following commands to allocate amount of memory for a matrix or list:
M:=Matrix(2000,2000,float[8]);
L:=[seq(equ[i],i=1..10000)]:
where equ[i...
hello everybody can you help me please
how can i canvert this list [1,2,3,4,5,6] to a number 123456
hi ,friends
  now ,i get a matrix of symbolic expression,it's difficulty to find the simplest forms using the common command  as like simplify or combine
p := Matrix(4, 4, {(1, 1) = (1/2)*exp((1/2)*J[1]-(1/2)*J[2]+(1/2)*J[3])+(1/2)*exp(-(1/2)*J[1]+(1/2)*J[2]+(1/2)*J[3]), (1, 2) = 0, (1, 3) = 0, (1, 4) = (1/2)*exp((1/2)*J[1]-(1/2)*J[2]+(1/2)*J[3])-(1/2)*exp(-(1/2)*J[1]+(1/2)*J[2]+(1/2)*J[3]), (2, 1) = 0, (2, 2) = (1/2)*exp(-(1/2)*J[1...
First 1964 1965 1966 1967 1968 1969 1970 Last Page 1966 of 2463
