I'm using Maple versions 9.5 and 14.
I have a quite complicated functtion defined by means of a piecewise statement. Translation of that function into C code is required, so I tried to use CodeGeneration[C] and codegen[prep2trans]. The help of Maple version 9.5 tells me that the prep2trans command isneccessary to get the job done. It's about converting the MAPLE piecewise instruction into a  if ... then ... else if ......
Hi, I am new to using maple. For one of my classes we have been asked to find the root of a function using the bisection method. The function I am trying to find the root for is x-2^(-x) for 0<=x<=1. This is the sequence of commands that I am using
 f:= x-> x-2^(-x);
a:=0; b:=1;
 while b-a> 0.00001 do
      m:= (a+b)/2:
      if f(a...
How can I call a procedure value from inside a string?
I would like to build a piecewise function automatically.
I would like something like this but with 33 pieces:
> piecewise(0<=t and t<1, f[1](t)[i][j], 1<=t and t<2, f[2](t-1)[i][j], 2<=t and t<3, f[3](t-2)[i][j], ...,0);
I tried to use the seq command, and it worked with the condition argument of piecewise.:
> seq(1-q<=t and t<q,q=1..3);
          -t <=...
I get the following error message when trying to use LinearSolve(with inplace option) to solve a linear system of size 2000x2000 with 416 digits.
maple: fatal error, lost connection to kernel
Any suggestion to the cause of this error or how to avoid it?
I would like to make assumptuions about the input parameters of a procedure. The input parameter of the procedure should be the (1,1) element of a 2-dimensional Matrix. I make the same assumptions for the elements of the Matrix as expected by the procedure. When I  call he procedure with the (1,1) element of the matrix, it gives the following error. How should I use the assumptions or how to pass correctly the parameter to the procedure in this particular case?
I want to plot a function with a restricted domain, specifically f(x) = |x| if -Pi <= x < Pi.
I want to first define the function, then use it in the plot command.
I know to define the function f(x) = |x|, I do
f := x -> |x|
...but how do I tell Maple to include the domain, -Pi <= x < Pi?
I would like to differentiate a sinlge-variable function containing abs(), min(), and max() calls. For smaller functions it seems to work, however for my procedure, it does not seem to work. What can be the problem? I would appreciate any comment.
It seems to work for the followings:
> diff(min(5*x,3),x);
It is not corect in my problem to get different parameters a, b, c, ... for fmin, fmax and the objective function.
The probleme is to minimize the objective function (fmax-fmin)/fmoy.
NLPSolve((fmax-fmin)/fmoy,t = 0 .. Pi/p/wr,a=1..5,b=0.1..0.5,c=0.4..0.8,d=10..20,wr=200..300,p=5..20);...
The example below is the same as my code:
restart:with(Optimization):f:=(a+2*b+c*d)*sin(wr*p*t);
fmoy := p*wr*(int(f, t = 0 .. Pi/p/wr))/Pi;
fmax:=NLPSolve(f,t = 0 .. 2,a=1..5,b=0.1..0.5,c=0.4..0.8,d=10..20,wr=200..300,p=5..20,maximize);
fmin:=NLPSolve(f,t = 0 .. 2,a=1..5,b=0.1..0.5,c=0.4..0.8,d=10..20,wr=200..300,p=5..20);
Taux:=NLPSolve((fmax-fmin)/fmoy,t = 0 .. 2,a=1..5,b=0.1..0.5,c=0.4..0.8,d=10..20,wr=200..300,p=5..20);
In MapleSim, I need a half-sin signal source element.
Of couse, I yielded a half-sin puls by using the combination of 2 sine souce elements and add element.
But i think it is not the best way. I want to use custom element in Maple to create it,
but I don't know how to write the equation code in Maple.
Please help me.
thinks
This error has occured for me several times, and I can't seem to find any way around it.
When I make an error in either the algorithm or especially in the grading part, I sometimes get something like this:
Part 2: The character ; cannot be used in a formula.
...or some other error message. I can figure out what I've done wrong and how I might fix it, but I cannot edit the question. Whenever I click on "edit", all I get is the error message....
The first line below is my code for computing the angle between vectors U and v.
It works and gives correct answers.  But it appears on the screen with this  "Typesetting: delay"  for each of the dot products.
What does it mean?  Is there a package I should have loaded?
This is for a lab where I want students to use the formula as it appears in the textbook rather than using some built in function that makes it "too easy."
As shown in the image bellow. The first statement of fsolve function yields nothing but evaluating the expression. I copied the expression into the second command line and got the result. How can I make the first one works, since it belongs to a proc in my program.
This is another elementary question (I tried searching MaplePrimes but couldn't find anything):
Suppose I'd like to use "solve" to solve a system of equations specified as vectors:
z := <yb,x1b,x2b>:
v1 := <v1y,v1x1,v1x2>:
v2 := <v2y,v2x1,v2x2>:
e1 := z = v1 + v2;
e2 := v1 <= UU*delta1;
e3 := v2 <= UU*delta2;
Invoking "solve([e1,e2,e3],[z,v1,v2])" does not work.
How do I convert each element...
First 1990 1991 1992 1993 1994 1995 1996 Last Page 1992 of 2463
