Hi at all. In my attachment you will see my problem. I want to fit datapoints with a set curve and I used the Fit-command. If I plot the points and fitting curve the curve is not on the points. Where is the false in my sheet?
test_only_Fit.mw
I used "implicitplot"  and get the plot. But I want know the data of the plot. How to get the data?
I have downloaded and unzipped a student version of Maple 14. When I click on the icon named Maple14MacInstaller.app, it flashes and nothing happens. What now?
Mac w OS X, 10.4.6, 3.06 GHz Intel Duo with 4GB RAM.
I'm not sure if this might be stretching Maple's capabilities a bit, but I was wondering if there was a way to perform model reduction (through substitution) in Maple?
Let me explain. Suppose I have a system of nonlinear equations: f(y,z,u) = 0, where u = input variables, z = intermediate variables, and y = output variables. For instance:
y = z1 + z2^2
z1 = z2 + 3*exp(u)
I have been looking for "creating a folder"-option in my group in Maplecloud. Is this possible at all or can I really only have an hierarchy depth of one?
Best regards,
Al
Since Maple 14 requires a new version of the license manager (which isn't downwards compatible for some reason..), I'm currently trying to figure out how to run two versions of maplelmg on the same Linux host, one for Maple versions 13 and below, one for 14 (and above).
Of course, this would have to happen either on different ports or another IP on the same host, which doesn't really bother me, the problem is that I cannot start two maplelmg's on the same host because...
loop.mw
I want to use loop to get results for two satements with one counter
like this:
for i from 1 by 1 to 5 do Y_i :=i , X_i :=i^2 end do
but maple shows this error unterminated loop
I need to use some statements in one loop and I separated them by comma but maple gives error
What should I do?
  Dear all, I am using fsolve to solve a complex equation. When I solve it, I get the following error:
Error number of equations, 1, does not match number of variables, 2.
But the variables are just one (named u1) I think it is a problem with assume but I am getting cracy to understand the problem.You can find in attachment the short maple file. I try to solve equation e4 for variable u1.
Alberto
the integral
>int(1/x^2-cot(x)/x,x=0..infinity,CauchyPrincipalValue);
with Maple ?
Stars predict it equals Pi/2. Maple 13 easily cracks the integral
>int(tan(x)/x,x=0..infinity,CauchyPrincipalValue)=Pi/2.
Download Simplify_Problem.mw
How come the simplify command does not do a better job of reducing the term?  As anyone can see, all the terms share a common factor in the numerator and denominator which can be cancelled out.  And the factor jw is common to all terms.  See attachment.  Ratch
Some of my students have experienced a phenomenon where all of a sudden all the Maple input and output (this is in pretty print, not Maple text) piles up at the top of the screen all garbled and cant be recovered.  Has anyone else experienced this, or more importantly, does anyone know how to fix or prevent this?
We are running Maple 13.  Thanks.
A recent question prompted me to wonder whether other Maple users are using the latex output from Maple in their formal written work ? Personally I've found the Maple latex output to be lacking in a number of ways, one of which the writer of this question has found
http://www.mapleprimes.com/posts/96808-How-Do-I-Convert-An-Expression-Like
I myself gave up using latex output...
I've downloaded and installed the Maple 14 but when I open it nothing works.  When I click on anything on the opening page an hour glass appears and no matter how long I wait nothing happens.
Probably a very stupid question.
After hesitating for a very long time I decided as a very satisfied user of MAPLE 12 (Classic worksheet, I'm very conservative) to migrate to MAPLE 14.
However the processing of the files is very slow, autosaving takes for example about 2 minutes while with MAPLE 12 only a few seconds. Saving the file gives an alert: there can be problems in saving due to formatting problems.
I think I have to do some formatting of my MAPLE...
In "Maplet Builder", how can i define a  procedure?
(Thank you  for your attention.)
First 1988 1989 1990 1991 1992 1993 1994 Last Page 1990 of 2463
