I just started using Maple few weeks ago, so i am very new to Maple. I tried to write a program to:
1. read data from excel
2. process the data obtained from different excel sheets to find different possible combinations and calculate costs
3. then to find the minimum cost option
program i wrote is
> with(ExcelTools);
> SHEET1 := Import("analysis.xls", "su1", "A4");
`output redirected...`> print(); # input placeholder
Dears, I wrote with maple the following expressions
if i <> k then
for i to M do
for k to M do
alpha :=(i, k)→evalf(((x[k]-x[i])*ydot[k]-(y[k]-y[i])*xdot[k])*dtheta[i]/((x[k]-x[i])^2+(y[k]-y[i])^2)^2)
end do
end do
beta :=(i)→evalf((1/2)*(y2dot[i]*xdot[i]-x2dot[i]*ydot[i])*dtheta[i]/omega[i]^2-Pi);
Matrix(M, M, (i, k) →`if`(i = k, beta, alpha);
I haven't really explored the use of dials and gauges.  Normally the data responds to the dial settings, but does it work in reverse?  Can we have the gauges set up so that they respond to the data, during for example say an animation or something?
 I don't really have anything specific in mind, I was just wondering if it could be done.
I am trying to define some AntiCommutator-Relation to work with operators depending on a large number of creation- and annihilation-operators in the fermionic case.
Let "b" be the creation and "a" be the annihilation-operator. Then i am looking, for example, for "a[i]a[j]b[k]a[l]a[m]"...
Now I define the relations:
with(Physics)
Setup(quantumop={a,b},algebrarule={%AntiCommutator(a[i],a[j])=KroneckerDelta[i,j...
I have found out another problem with a maplet slider. It can not have a noninteger value. I put up with tickmarks which could be visible only for whole units (integers), but why there is not a possibility to obtain for example a value "0.4" from a slider?
I would like to ask either MAPLE is capable to solve >2 boundaries value problem.
Actually I'm solving a system of ODEs in a membrane divided electrochemical cell, basically a REDOX process.In 1 part I have 2 species reacting and in another part I have 3 species reacting , 2 of the species exist in both part.
At the end I wanted to coupled all the species together.
So basically I have 4 boundaries and I would like to solve it simultaneosly.
How to plot and animate an expression like this:
f:=x1+a*y1+1; plots[animate](plot, [f, x1 = 0 .. 5, y1 = 0 .. 25, y=0..10],a=0..1, frames=100);
This is just an example for understanding my need.
thanks for help
Hello! Im kinda new to maple so it must be a noob question :) im using it for like 24 hours to get around some basing math in it :)
Just got some understanding of this 2d/1d/worksheet/document modes and stucked at some operations with fractions.
1) How do i enter Mixed fractions to calculate right?
2) How to compare Two or More fractions?
3) How to get output in mixed fractions? or to expand fractions.
I needed to create assumed variables for a problem I´m working on. After working on them in a last step I need to replace the assumptions with values so as to get a real number. - I don´t want to define values to the variables from the beginning as I want to avoid rounding errors and I don´t know any other way around the problem.
Giving you the exact problem would be bit too complicated, but you might get to know what I would like to do with this example:...
I am currently trying to build some procedures in Maple that calculate the Legendre-Fenchel transformation for functions that are convex, nonconvex, differentiable and non-differentiable functions. I seem to be ok in the convex case, but cannot seem to find a way of getting Maple to calculate this transformation symbolically for nonconvex functions (both differentiable and non-differentiable). It appears to me that the only way to deal with these cases is to...
I'm finding limited information on how to do row or column operations on Arrays.  For example how to multiply a whole column by one number.  I have tried using the map command ....
map(a->[a[1],-3*a[2],a[3]],a)  # multiply the third row in the array by -3 however brings an error.
This doesn't work for Array however it works on lists.  At the moment I can't think of how to do it without converting it to a list.  Any ideas?
I thought this would be simple enough, but I can't seem to get this to work...
If I have the following...
> e1 := fsolve({Qd, Qs1}, {x, y});
                       {x = 60., y = 40.}
Then how can extract the appropriate numeric format to plot this point? I keep getting data type errors.
Any help would be much appreciated!
I'm trying to plot an arrow in polar coordinates.  Here's an example for an arrow who's base is at (1,Pi/4) pointing right with unit length.  It seems like the coords option is being ignored by plottools[arrow].
The following lines give me the same results in Maple:
plots[display](plottools[arrow]([1,Pi/4], [1,0], 0.05, 0.1, 0.1, coords=polar));
plots[display](plottools[arrow]([1,Pi/4], [1,0], 0.05, 0.1, 0.1));
Is this a bug?
Kevin
Is there also possibility to view the source code of Plot Builder?
My Maple 13 puts small curly brackets to the left side of an expression and this causes several problem for me. What should I change to write good ones? (I mean normal, big brackets, not small brackets to index.) (I use the AltGr+b combination to write a left curly bracket.)
First 1998 1999 2000 2001 2002 2003 2004 Last Page 2000 of 2463
