I am trying to reuse a function that I computed numerically (using dsolve).
My dsolve line is something like this
Sys:=dsolve({f1(0)=0,diff(f1(x),x)=...},{f1(x)},numeric}
Then I want to define a new function as follows:
g(x):=2*f1(x/2) and use it in solving another ODE system.
How can I do that?
I could solve the ODE only numerically.
the equation is like the pic below:
int(sqrt(1+16*a^2*y^6+24*a*y^5*b+16*a*y^4*c+8*a*y^3*d+9*b^2*y^4+12*b*y^3*c+6*b*y^2*d+4*c^2*y^2+4*c*y*d+d^2), y = 0 .. .2)
i try it by Maple ..but did not get any answer of it ! anyone can help me with this ??or there is no real answer for it ?
since the equation got 4 unknown constants which are a,b,c,d ...so how to use maple to solve it ???
any idea and comment will be much appreciated ...thx
I have a relatively simple question that you can do by hand, but I want to know, if it is possible for MAPLE to compute directly with a single command if any 2 vector functions do intersect.
eg. r(t) = <cos t, sin 2t, exp(t)> s(t) = <sin t, cos t, exp(t)> ,  -2 < t < 2
thanks in advance
<img alt="" src="file:///C:/DOCUME%7E1/raccach/LOCALS%7E1/Temp/moz-screenshot.png" /><img alt="" src="file:///C:/DOCUME%7E1/raccach/LOCALS%7E1/Temp/moz-screenshot-1.png" /><img alt="" src="file:///C:/DOCUME%7E1/raccach/LOCALS%7E1/Temp/moz-screenshot-2.png" /><img alt="" src="file:///C:/DOCUME%7E1/raccach/LOCALS%7E1/Temp/moz-screenshot-3.png" /><br />
<br />
Hello, I was wondering if someone could help me recreate the picture found on http://en.wikipedia.org/wiki/Complex_logarithm Thank you in advance, Herman
Good Evening Everyone,
Would any body be kind to help me with the attached file. My goal is to plot the frequency graph with different sets of variables for a vertical pump on a pile cap to avoid resonace.
Moses
Mam do wykonania kilka zadan lecz niestety nie wiem jak się za nie zabrac. Proszę o jakiąkolwiek pomoc. Oto zadania. 1)Ile jest liczb pierwszych mniejszych niz 567! ? 2)W zbiorze liczb naturalnych {1, 2, ..., 123456!} znajdz wszystkie liczby podzielne przez 13 i 15. Wynik zapisz w postaci zbioru. 3)Czy pierwiastki nastepujacego wielomianu w(x) = x^6 + x^4 + x^2 + 1 leza na okregu jednostkowym? 4)Ile jedynek ma liczba 235465656! w systemie dwójkowym? 5)Zdefiniowac funkcje f(x) = x^234321+cos(x)+ln(x) i obliczyc 10-ta pochodnafunkcji f w punkcie 100.
The question is simple.
How could I find an earlier (not Active) forum topic?
(I use Firefox 3.5 on xp.)
Thanks,    Sandor
Hi I have the expressions: I1 := M*[1-a*exp(-i*theta)]/(1-b*cos(theta)) I2 := M*[1-a*i*exp(i*theta)]/(1+b*sin(theta)) I3 := M*[1+a*exp(-i*theta)]/(1+b*cos(theta)) I4 := M*[1+a*i*exp(i*theta)]/(1-b*sin(theta)) x1 := M*[1-a*cos(theta)]/(1-b*cos(theta)) x2 := M*[1+a*sin(theta)]/(1+b*sin(theta)) x3 := M*[1+a*cos(theta)]/(1+b*cos(theta)) x4 := M*[1-a*sin(theta)]/(1-b*sin(theta)) y1 := M*a*i*sin(theta)/(1-b*cos(theta)) y2 := M*a*i*cos(theta)/(1+b*sin(theta)) y3 := -M*a*i*sin(theta)/(1+b*cos(theta)) y4 := -M*a*i*cos(theta)/(1-b*sin(theta)) I enter the following expression
Please Ignore the previous posting, I had a few mistakes.
I have the following terms: >
a := .178131; 0.178131 >
b := -0.6814e-1*`if`(t = 0, 6, `if`(t = 1, 10, `if`(t = 2, 15, `if`(t = 3, 20, NULL))));
 c := 0.16242e-1*`if`(t = 0, 6, `if`(t = 1, 10, `if`(t = 2, 15, `if`(t = 3, 20, NULL))))^1.5;
The ODE is:
e := -0.6814e-1*`if`(t = 0, 6, `if`(t = 1, 10, `if`(t = 2, 15, `if`(t = 3, 20, NULL))));
 f := 0.16242e-1*`if`(t = 0, 6, `if`(t = 1, 10, `if`(t = 2, 15, `if`(t = 3, 20, NULL))))^1.5;
The ODE is:
Q1: Write a procedure named MULTIPLYMATRIX to find the product of an n x m matrix by an
m x q matrix. Your procedure should print the result matrix. The dimensions n, m, q should be
input parameters in your procedure. Test your procedure by demonstrating multiplication of a 2 x
3 with a 3 x 4 matrix of your choice
I have been struggling to solve this problem.
I want to minimize this function for w, x and y:
((w^2)/2)+((a/3)*x^3)+(2by)+((2a/3)*y^3)
Subject to w+x+2y=1
Where a and b are positive constants
And also, I want to minimize this function for w, x, y and z:
((3w^2)/2)+((2a/3)*x^3)+(by)+(ay^3)+(bz)+((a/2)*z^3)
where a and b are positive constants.
I've tried a ton of stuff on maple and have been unable to figure it out.  Any help is greatly appreciated!
First 2055 2056 2057 2058 2059 2060 2061 Last Page 2057 of 2463
