I want to plot 3d from seq. and then i get the apperance as a grid.
View 2735_add.mw on MapleNet or Download 2735_add.mw
View file details
what i want is a procedure to do the following:
given an integer input, add the digits together. if the no. of digits resulting is >1 repeat until a single digit remains.
I am trying to integrate a second order diff. equation one step at a time, but the dsolve command takes you directly to the solution, which is the second integration of the original ODE.  Is there a way to sequence the integration one step at a time?
Thank you for your assistance.
The equation is listed below as  Maple input:
ode1:=diff(phi(x),x$2)+1/x*diff(phi(x),x)-phi(x)/x^2=-1/D*(q*x/2+P/(2*Pi*x));
I'd like to declare a Matrix of variables, then assign each to a value, then just display the resulting Matrix...seems pretty simple. Evalm used show the evaluated version, but I guess that is now depricated. How do I do it in Maple 13....for example
gradV:=Matrix([[a11*x1+a12*x2],[a21*x1+a22*x2]]);
a11:=1;
a12:=0;
a21:=0;
a22:=1;
gradV;
thank you.
Hi, I'm using Maple 12, and I'm having problems when I want to convert a maple document to a rich text file (RTF). For longer equations, the formatting will be weird and indent the equation very early, so the equation is difficult to read. Also, because I write my equations like "(13) {some equation}", for example, the '(13)' that precedes the longer equations will be copied into the equation image, which doesn't happen for the shorter equations.
hi, i know that Q_8 (the quaternion group) has 5 conjugacy classes. is there any way to check this in Maple using the elements below? G:=[ [[1,0],[0,1]], # 1 [[0,1],[-1,0]], # j [[-1,0],[0,-1]], #-1 [[0,-1],[1,0]],# -j [[I,0],[0,-I]], # i [[0,-I],[-I,0]], # -k [[-I,0],[0,I]], # -i [[0,I],[I,0]] # k ]: thank you.
for example:this equation:(1 - 2 x y[x]) y'[x] == x^2 + (y[x])^2 - 2
and how to make the solution in this form:
y=(x^3)/3+x*(-2+y^2)+C
not the form y=f(x)
sum((1/(1+2/a[k]))^(2*k+1)/(2*k+1), k = 0 .. n)
here a[k] >0, we may also assume that a[k+1] > a[k]
Hi! is there an option in Maple that can calculate a kernel and an image of a function. e.g. f: C -> R (complex to real numbers under addition) complex numbers expressed as w = x + i*y f(x + i*y) = x+y need to find ker(f) and im(f) - kernel and image of f. many thanx!
Have a look at the following
test:=proc(s::string)
local M,a;
a:=rand(10..100)();
M:= Matrix([a-1,a,a+1]);
ExportMatrix(cat("Matrix_",s),M);
test("1");test("2");test("3");test("4");test("5");test("6");
it saves in file
Matrix_1, Matrix_2,Matrix_3 .....Matrix_6
however,
I've got a block of code that I use once in a simple form, and then a second time in a more cascaded form but the second bunch doesn't work. And it seems as though tan won't evaluate numerically for me - it's really bugging me. Maple 11. Here's the block of code that does work: > eqn := Zin = (70.71*(100+(70.71*I)*tan(2*Pi*f/(3*10^8)*0.25e-1)))/(70.71+(100*I)*tan(2*Pi*f/(3*10^8)*0.25e-1)); > eqn1 := GAMMA[i] = (Zin-50)/(Zin+50); > eqn2 := (1+abs(GAMMA[i]))/(1-abs(GAMMA[i])); > sol := subs(eqn, eqn1); > sol1 := subs(sol, eqn2); > unapply(sol1, f);
How can I prove that the product of the slopes of two perpendicular lines is -1?
thanks,
I was wondering how I double underline a result? E.g. 2 + 2 = 4 where I would like to double underline 4. /Ayatollah
how to orient the long label of the vertical axis "VERTICAL" ?
I am looking at some asymptotic expansions of a PDE and need to do some differentiating with complex conjugates.  Specifically, I have a number of functions that are functions of both z and conjugate(z), they may look something like:
S -> (z,conjugate(z),xi)
I would like to take the conjugate(z) derivative,
S[conjugate(z)]  = diff(S(z,conjugate(z),xi),conjugate(z)),
but I get:
D1S(z,conjugate(z),xi) + D2S(z,conjugate(z),xi)(-\frac{conjugate(z)}{z} - \frac{abs(1,z)}{signum(z)}
First 2104 2105 2106 2107 2108 2109 2110 Last Page 2106 of 2459
