How can I combine two plots so that one is above the other and they have the same x-axis.
Here's an example of what I want.
I tried array of plots, but in this case each plot has its own axes and they are side by side horizontally.
Any other suggestions?
I am dealing with the following problem, which has extensive symbolic computations. It was taking extremely long in MATLAB so I thought of Maple. It turns out that Maple is also taking pretty long time. Is there any way to accelerate this in Maple (or in MATLAB).
I am attaching a two-line Maple code (Thanks Alec for the previous help)
u := (1-cos(x)):
for i to 10 do u := u+int(subs(x = t, diff(u, [`$`(x, 2)])+u-A*(1+2*u+3*u^2+4*u^3))*(t-x), t = 0 .. x) end do:
where A is a constant.
I am new to Maple and wish to convert the following simple code written in Matlab to its equivalent Maple.
syms x
F=x^2;
for i=1:5
    G=F+int(F);
    F=G;
end
Does anybody know how to solve the attached quation analytically for rho? The solve command fails.
(Solving numerically and plotting with implicitplot3d works well.)
View 6629_maple1.mw on MapleNet or Download 6629_maple1.mw
View file details
How would I find the number of vertices, the number of edges and the degree of each vertex in the given undirected graph.
Please see the attached Maple file.  It has my work.
I would really appreciate any reply back.
Take care
Say I have an expression like this:
E = 1/(x^2 + y^2) + (x^2+y^2)
And let's say I want to make a substitution for t = (x^2 + y^2);
E = 1/t + t
Now I want to be able to differentiate this.  eg,
diff(E, x)
I should get:
- dt/dx / t^2 + dt/dx
How can I make Maple provide output in this form?  ie, I do not want to see an output of - 2*x/(x^2+y^2)^2 + 2*x
Hey, does anyone here know how to program the product Nystrom method for solving integral equations of the second kind? Thanks
Hi i am having difficulty converting a text file consisting of words into ascii code. using maple and vice versa.
I dont know how to.
My notepad text is  "(testing)" and i wanted maple to show me "testing"  in ascii code but i just dnt knw how to get it to do it.
Can someone please help me i would be very gratefull
Thank u
Hello.  I'm quite new to Maple and I've run into a problem.
My assignment is to create a program that takes input as plaintext, converts it into a matrix X using an alphabet, then encrypts it by multiplying the matrix X by a key matrix M.  Only problem is, I can't even get Maple to recognize a proper if statement.  The if statement is never triggered.
with(Maplets[Elements]):
with(StringTools):
block := 3;
maplet := Maplet(
I have a Bivariate Distribution that has a PDF equal to
(1/2)*exp(-RootOf(erf(_Z)*b*exp(exp((-x+a)/b))+b*exp(exp((-x+a)/b))-2*exp((-x+a)/b))^2-RootOf(erf(_Z)*sqrt(Pi)*d+sqrt(Pi)*d-sqrt(2)*exp(-(1/2)*(-y+c)^2/d^2))^2)/Pi
Hi everyone,
I am trying to write a proc for the binomial method for option prices.  I have the following code:
treeStockPrices := proc (s0, X, r, sigma, T, N)
local dt, u, d, a, b, p, L, i, j, k, m;
<p>How do I force values to be shown in scientific notation in a spreadsheet? The Format:Numeric Formatting ... menu selection seems to have no effect in this case. I also can find no option (ie hfloat) or interface parameter (ie Digits) that can be run within a function that will "massage" numbers to be scientific notation.</p>
<p>My application is ... I have a table of values and am doing a calculation ...</p>
<p><maple></p>
<p>DT := table():</p>
Hello, How can I combine a 2d contour plot with a 3d plot? i.e. the contour plot would appear at some z-level in the same box containing the 3d plot. Thank you
Dear all:
   suppossed i have a function as following :
f(x):=2*sin(x)*(sin(x)+I3*sin(3*x)+I5*sin(5*x))
where  x is belong to (0,Pi/2), I3,I5 is defined to I3^2+I5^2 < .232.
i have ploted some curves of f(x) . As to different I3 and I5, the curve of f(x) have different point of intersection with y=1 function, may one point or two  point or three where 0<x<Pi/2.
How come this doesn't work:
> A := {Matrix(2, 2, {(1, 1) = 1, (1, 2) = 1, (2, 1) = 1, (2, 2) = 1}), Matrix(2, 2, {(1, 1) = 0, (1, 2) = 0, (2, 1) = 0, (2, 2) = 0})};
> evalb(`in`(Matrix(2, 2, {(1, 1) = 0, (1, 2) = 0, (2, 1) = 0, (2, 2) = 0}), A));
Maple answers here false. Is the in-command only for numbers and not for matrices? How can I solve this problem?
Thanks!!
First 2167 2168 2169 2170 2171 2172 2173 Last Page 2169 of 2459
