I am trying this evalm example (from the help page of evalm, Maple 12):
alias(Id = `&*`());
# Simplification of matrix operations
evalm((`&*`(`&*`(A, B), 2))*B-`&*`(B, Id));
Error, (in evalm/amperstar) &* is reserved for matrix multiplication
A and B are not defined as Matrix in the help page. Is it the problem?
So given characteristic polynomial of a 2X2 Matrix of char (A,x) = (x-1) how do I find all possibilities for the Jordan and rational canonical forms?
Hi to all
I want to convert a maple file to Latex. How it sholud be done. Any one can help me.
Hi Maple experts,
hi, I have 12 equations that I want to solve, when I try to solve them using maple 12 it gives me nothing just empty [ ]  but when I remove an equation from them, maple solved the other 11 equations !!
but i want to solve the 12 equations together.  the equations are :-
exp(-z[1][1]/t[1])*(sum(p[2][j]*exp(-z[2][j]/t[j]), j = 1 .. 3))*(sum(p[3][j]*exp(-z[3][j]/t[j]), j = 1 .. 3)) = t[1](1-w)/(p[1][1]*w),
is it imaginary:
evalf((-1)^(1/3))
Dear Experts, I have created the tabel B[n,m] with an high amount of values (n=1000,m=1000). Now I saw that I need a matrix for my further proceeding. But just running the thing again with declaring B as a matrix would take too much time. So my question: Is it possible to convert the table B afterwards into a Matrix B?
I'm trying to plot and need to use implicit plot to graph 3x^2+2xy+y^2=4 on the interval [-5,5].  Any help would be appreciated.
How do get the range and domain of an equation for function.  x^2-1/x+1 = 0    or for f(x) = sqrt 144-x^2
Hi everyone,
I recently started to use maple and some problem arised that I can't figure out what to do.
My first problem was to multiply 2 Matrixes with GF elements, but I successfully overcame that problem by creating my own procedure to multiply matrixes, so no problem there.
In my 3 D histogram the colums have a 1*1 base, so normally they would be labeled 1,2,3,4,5 on the x and the y axes but instead of this I want to label them 0.25,.05,0.75,1,1.25,1.5 and so on.......... Is there a way to do it?
Hi experts, I created a 3D histogram with(plots); with(LinearAlgebra); A := [[2],[3],[3],[4]]; matrixplot(A, heights = histogram, labels = [c1, c2, ExpectedProfit], tickmarks = [spacing(2), [seq(i, i = 0 .. 8, 3)], default], axes = normal) Now I want to assign a colour to each column. When the value is 2 of the Matrix it should be red for example, when it is 3 for example yellow and so on. Later Later I want to expand it to a Matrix with B[n,m]n=10 values... Thanks alot in advance for your help!
Download 10597_discretized Brownian path.doc
View file details
I need the plot for the attached problem. I need it before 3 April 2009. Please some one help me.
Hi to all,
I am new to maple. I want a maple procedure for the following Boundary values problem.
Download 10597_Elliptic PDE.doc
View file details
Any one can help me. I need the plot of W(i+1/2)=1/2*(W(i)+W(i+1))+1/2*sqrt(sagma*t)*g(i)    where g(i) is an independent N(0,1) sample.
First 2170 2171 2172 2173 2174 2175 2176 Last Page 2172 of 2459
