Hello Folks I've been a Maple user for quite a bit and I've never found an easy way to do an extremely simple thing: just want to input an expression like (1/4)*a + (1/4)*b + (1/4)*c and get (1/4)*(a+b+c). I've tried the collect, factor, coeff, combine, simplify, expand commands and nothing seems to work. Maybe I'm choosing the wrong options for these commands. The fact is that I always end up with (1/4)*a + (1/4)*b + (1/4)*c or other arrangement of the expression, but I cannot get just the
I need to create a density plot from data in a 50x25 matrix (measurements of Platinum concentrations on the surface of a circular metal disc).  Wich is working fine more or less.  Except I am unable to create a legend wich tells me wich shade of grey corresponds to wich concentration.  Is this possible in maple? I've tried the legend option but to no avail.
Tom
Hi experts, I used matrixplot for plotting B[n,m]. In B[n,m] I saved n->17 and m->17 values (so 17*17)...... when I use matrixplot(B,.....) I get the following error message: Error, (in plots/matrixplot) invalid input: `convert/Matrix` expects its 1st argument, M, to be of type {Matrix, Vector, Array, array, list}, but received B thanks a lot for your help!
Hi, have attached a worksheet with some question that I don’t know how to solve in maple. Yours Gustav Hjertén
Hi, i am new to Maple. I am having so much trouble right now...
I need to draw directions of eigenvectors. Can I get some help?
x'(t)=  A * x(t)
A is a 2x2 matrix.  First row 1   1    Second row   4   1
Thank you all.
I need to plot this. Help!!!!! I am stuck.
with(linalg):
A := matrix(2,2,[1,1,4,1]);
exp(A*t);
B := exponential (A, t);
c := matrix(2,1,[c1,c2]);
multiply(B,c);
x := t-> first row of the matrix above
y:= t-->second row of the matrix above
I need to plot x and y in this case. What do I do next ???? :(
I need to find the first local extremum of a polynomial function. For my purposes I need to start at 0 and go toward increasingly positive values of the independent variable. I also need to be able to specify whether I am looking for a maximum or a minimum.
Is there an easy way I can do this?
Thanks!!
David
I installed maple 12 as root user successfully. But sometimes simple command like
1+1 or any command takes a long time to complete. After a long delay maple
displays result. It's happening very often and it's annoying. I'm using Debian
Etch, kernel 2.16.8-custom.
Hi there, I am ultimately trying to solve a system of differential equation numerically that reads
diff(y(x),x,x) + (2/x)diff(y(x),x) + y(x)(1-(y(x))^2) = (F(x) - G(x)/x^2)
(1/2 - Xi(x))F(x) = -diff(G(x),x) - (1/x)G(x)
(1/2 + Xi(x))G(x) = diff(F(x),x) - (1/x)F(x)
Hi to everybody. I have to create a fortran output a lot of time for different polinomials.and CodeGeneration gives me an error. i give you a simple example to understand my problem:
 with(CodeGeneration):
 np:=10;
 basex := Vector(np):
 for i from 1 to np do
    basex[i] := unapply(x^(i-1)-1,x);
 Fortran(basex(x),optimize,deducetypes=false,defaulttype=numeric);
How do I use Maple to create the following Euler circuit
I have already created the circuit now I would like to know how can I create it using Maple.
Please see the attached Maple file. View 1327_Euler circuit.mw on MapleNet or Download 1327_Euler circuit.mw
View file details
Hi to everybody. Im trying to use "solve" to find the coefficient that solve a set of equations(a set of polynomials).
> restart;
> with(linalg):
> with(codegen):
> M:=3;
> np:=(M+1)*(M+2)/2;
I can not manage to figure out how to shade specfic regions under a normal curve. For example:
with(Statistics): X:=RandomVariable(Normal(0,1)): DensityPlot(X, range= -3..3)
I want to shade a region greater than or less than some X value.
Similarly, I would like to add a vertical line for some X value.
Rob White
Hi Everybody: I've a question about "convolution". How can I afford the convolution of different scaled functions?... In Example: F (2*X/T) in convolution with G ( X/T ) ? Is this equals to : Int ( F(2*w/T) * G((X-w)/T), w=-infinity.. infinity)? Am I wrong?... The particular problem is : Convolution of ( T*Triangle(2*X/T) ) with ( shah( X/T ) ), with Shah (x) = Sum( Dirac (x-n), n= - infinity.. infinity). Thanks for helping!
Hi there, I'm trying to plot a piecewise function. The problem is, the individual pieces are evaluated separately and maple seems to evaluate the numbers into square brackets.. As a result maple can't plot these, it can however plot it if I substitute the evaluated numbers and delete the brackets. Here's and example: > P := S[0]*(d+x)/(d-p); gives 10*([23/2]+x)/[8] and when I try either plot(p,x); or plot((10*([23/2]+x)/[8]),x) it fails however it can plot((10*(23/2+x)/8),x) any help would be awesome! thanks in advance
First 2171 2172 2173 2174 2175 2176 2177 Last Page 2173 of 2459
