hello, now i confront a problem of a maple function---msolve.
I want to sovle the problem like this: i have a matrix with all entries only one or zero. and i have known the sum of unknows in each row and column. i want to get the entries in the matrix.
For example i have 3 by 3 matrix.
[x1 x2 x3
x4 x5 x6
x7 x8 x9]
i have known the sum of unknows in each row and column. for example,
x1+x2+x3=1; x4+x5+x6=1; x7+x8+x9=1; x1+x4+x7=1; x2+x5+x8=1; x3+x6+x9=1;
another constraint is x1 to x9 are only one or zero.
hello.
I have calculated an integral equation (general goursat problem) with an iteration method. I want to know how could I use MAPLE to derive a function for.
I found the first 4 iteration for function f.
the exact problem is Uxy=2.U.Ux .
U(x,y)=2x on y=x^2+x and U(x,y)=3x^2 on y=0.
I want to find the U function.
y=t^2+t
U0=2t-3t^2+3x^2
Un=U0+int(2*Un*(Un)x)
I am using Maple 11.
I try to plot implcitly with filled regions such function:
(5-|2*x+2*y-13|)
When I use the plot assistant, I can get on a preview my implicit plot which is a ring. But, when I click plot, I get an error.
So, Maple show the right preview and cannot get plot.
What is wrong?
HI all,
I know that :
alias(delta=Dirac):
`δ*g` = int(delta(x)*g(t-x), x = 0 .. t) and int(delta(x)*g(t-x), x = 0 .. t) = g(t);
But look what happen.  Can someone justify this behavior
The attached worksheet starts off with two quick videos that show you how to write square roots, fractions and exponents. Feel free to create and attach a worksheet with all of your questions and math expressions. I'll go thought it and help out !
I really need to be able to continue this calculation past nmax=14 but maple just won't do it.
I'd like to take it as far as possible. Does anyone know why maple won't calculate past nmax=14 and
if it can be overcome? Is this too difficult to achieve? I'm completely lost. can anybody help?
>restart;with(plots);
> with(LinearAlgebra);
> nmax:=14:
> Order:=nmax+1:
Can anyone help with a purely Maple solution to this problem? (i.e. not having to download anything extra.)
Just for reference I'm woking on problem number 26 in "Schaum's Outline Series " for tensor Calculus.
It gives you a Schwarzchild metric and asks you to calculate the Einstein Tensor.  I'm using the example of doing this that's given in the "tensor" package help pages.  However I'm not getting quite the right answer.
hello. I have calculated an integral equation (general goursat problem) with an iteration method. I want to know how could I use MAPLE to derive a function for. I found the first 4 iteration for function f. the exact problem is Uxy=2.U.Ux . U(x,y)=2x on y=x^2+x and U(x,y)=3x^2 on y=0. I want to find the U function. y=t^2+t U0=2t-3t^2+3x^2 Un=U0+int(2*Un*(Un
is possible to continue a numerical integration from a know point and add the solution the the know one?
i.e.
if I have:
P=dsolve(... range=0..1)
and I want continue the integration until 3 (so without reintegrate the 0..1 interval) and add that solution tothe first one.
hi
i made an implementation of the euklid algo (rekusiv and iterativ) und meassured the time that was needed to calculate the gcd. even for big numbers really fast, but if i use the maple command igcd i get a runtime that is far longer then the time i get with my own implementation.
how does that come ? what algo does maple use the calculate the gcd ?
anyone knows?
thx for reply
#fM2{Sz{&fg{Z22
&{,_32zU{&Y2{r~_%_92{%u$z?TT+{_&
2%{92{f?{J{Y_%{%2yf`Y2z2%{3Y2{9_F@&yzf`3{ZYfyY{Y_%{3Y2{3z_F&9@3_3fSF{`zSy2%@z2o{J{3S,%{Y2z{3Y_3{J{Y_%on>f3YS@3{3Y2{
2tU{&fzU{2gy@&2{92{f?{J{l2,f2M2{3Y2{3YfFL{f9`S&&fl,2onjS{tS@{Zf&Y{92{3S{F_92{tS@z{
2tU{9_%_92)nJ?{tS@{`,2_&2onJ{3Y2F{3S,%{Y2z{3Y2{
2tbZSz%U{ZYfyY{l2,SFL&{3S{FS{,_FL@_L2U{_F%{J{&_Z{Y2z{&@z`zf&2o{kY2{3S,%{92{3Y_3{f3{Z_&{f9`S&&fl,2U{?Sz{&Y2{l2,f2M2%{Y2z&2,?{3Y2{SF,
does anyone know how i would write a simple maple program that generated random numbers and simulated rolling 5 die that output the expected number of turns ( your initial roll then two more rolls with selected die) that it would take to get a yahtzee?
I am a beginning user and have no idea how one can view or import a table structure in maple. I used a procedure to compute some tables and it frustrates me that I don't know how to get them out efficiently.
The procedure is like the following:
get_quantities:=proc(j1,j2)
local x_min, x_max, y_min, y_max, x_seg,y_seg,idx_x,idx_y, q1;
option trace;
x_min:=j1-1.5;
x_max:=1.5;
y_min:=j2-1.5;
y_max:=1.5;
How could I find the max x value of the following plotted graph?
plot(diff(2*Pi*(x+1)*(ln(sqrt(x)+1)),x$4));
I've tried finding the max x value of this graph with
solve(diff(2*Pi*(x+1)*(ln(sqrt(x)+1)),x$5)=0);
but it failed to give me a numerical answer.
Sam
I'm going nuts trying to get the commands(code) to solve the following two problems:
Problem 1 Verify that the given function is a solution of the initial value problem.
y:=x^2*(1+ln(x));       y'':=(3*x*y-4*y)/(x^2                      y(e)=2e^2        y'(e)=5e
First 2218 2219 2220 2221 2222 2223 2224 Last Page 2220 of 2458
