Is there a way to plot a single graph with multiple functions, where I can set a different scale for each function?
I want to get something similar to this:
I can plot multiple functions in one graph with display(); but it is the multiple scales part that's giving me a headache...
Thomas
I was wondering if there is a way to return only the subscript of an element in a sequence.
Essentially I have something like t:=a[[1,2]] and I want the list [1,2] to be returned. I can't think of anyway to do this. For instance solve(t=a_x,x)...
I have to create a n-dimensional interpolation to get function to use it in a numerically solved differential equation. T:=(x,y)->ArrayInterpolation(Ranges,Img,[[x],[y]],method=linear)[1][1]: T(3.3,4.1); 1.30999999999999983 int(T(3.3,x),x=0.0..1); Error, (in CurveFitting:-ArrayInterpolation) invalid input: coordinates of xvalues must be of type numeric
Does anyone know how to reset the memory during a large number of loops? I've read jet's post on this subject and someone mentioned garbage collection but I'm not clear how to go about doing this.
Basically what I want to do is after every 10 loops or so export the answers, keep the few variables I need and then reset the memory (equivalent to closing down maple & reopening).
How do I save output from print(%) in a list [ ] ?
I can copy and past the output and then define it but I want to find a way without copy paste
A:=[ output 1 from print(), output 2 from print(), output 3 from print() etc etc ]
ok, I have an excel sheet contaning three columns of data for 250 stocks .
time          stock             close
2005         stock A           200
2006         stock A           300
2005         stock B          100
I have Maple 11.0. I met a wield problem just now. After I put following expression to the math sheet: (exp(-x)-1)(exp(x)-1)/(exp(-x)-exp(x)) It gave me : ((exp(-x))(exp(x)-1)-1)/(exp(-x)-exp(x)) Obviously it's not what I want when I plot it. it gave me a curve across (0,0.5). But it can easily be calculated the value of this function equals zero when the input is zero.
Dear, all
I got a problem during my ploting a 3d figure.
One of the axis, say axis-X, is ranged between 1000 to 2000,
after ploting I found the labels appear like this: (100, 150, 200) *10
I would like to convert it to (1000, 1500, 2000), since this kind of value is more familiar in our fields.
I tried to change the numerical format in the format tool manual, but it seems that is only for the text but no plot.
Any idea?
I have a list of smaller lists. E.g.
A:=[[a,b],[b,c],[b,c,c],[d,c,c]]
I want to write a code that views any elements where all but the first element in the smaller list agree and gets rid of spares. So in A I would want to get rid of [b,c,c] (or [d,c,c]- I don't care which one). I wrote:
I have a large section of code which comes down to one single value  which is different each time you execute the section due to a
random component.  I want find a simple way I can loop the complete section of code and get the output 1, output 2, output 3 etc etc
without having to go in and put [ i , j ] on every single variable. I can do it manually by just start in the begining and press
enter all the way , write down the result and move the cursor to the begining again and start all over again but it is very time consuming.
Hello, I know (more or less) how to obtain the Lie symmetry generators of an ode, but how can I do symmetry analysis (finding the classical symmetries, canonical coordinates, reducing the system) on systems of nonlinear first order ode's? Regards, Nijso
I'm running Maple 11.02 on an intel mac. I can no longer access the help menu search function or access any help topics for that matter. Also, if I hover over the 'help' pulldown menu, I get the spinning pizza of death. Reluctantly, the pulldown menu works but I still can't access anything other than a description of maple help. Thanks for any comments, Court Ashbaugh
Hello all,
I am sure that there is probably a simple way of doing this, but I can't figure out how. I want to take n sets. Say 2 for the moment: {a,b}, {c,d} and I want to output all the possible n-tuples (n=2) with 1 element from each set. So: [a,c],[c,a],[a,d],[d,a],[b,c].[c,b],[b,d],[d,b].
Does anyone know how I might be able to do this?
Thanks, S
i'm solving an expression with the result being a range of the type RealRange.
e.g. RealRange(Open(-1.345464), Open(4.5343535))
How can i substract the max element Open(4.5343535) as real from that range.
Many thanks,
Remco
First 2227 2228 2229 2230 2231 2232 2233 Last Page 2229 of 2458
