Hi everybody
Hi everybody
p.276 from the advanced programming guide: example 2 line 11
> r := z = -3 .. 3;
                              r := z = -3 .. 3
> minz:=lhs('if'(r::range,r,rhs(r)));
Error, unable to match delimiters
I encounter a similar  problem of parsing once:
I thought before that &where is not  a keyword, but I don't understand the difference here (I found &where in the solutions of pdes):
f1:=a &where b;
op(2,f1);
it gives me {b}
f2:=a &something b;
op(2,f2);
gives me simply b
I don't find any information on &where in the help.
Hi all..
After i evaluated an answer using matrices..the resulting answer is stored in a Matrix..but im not able to see the anwers instead it displays...11 x 1 Matrix...DataType:anything....storage: Rectangular..Order: Fortran Order...wat to do to make the results display?
thanks.
I’m using maple 11. In my problem, I’ve five axioms:
I have tried unsuccessfully to follow the help but cannot figure it out.
I am using Maple 12 Standard with Windows XP.   I found the palette "Diacritical Marks" so I can make an umlaut and a u. I have tried various combinations of Crtl+R, Crtl + Shift, Ctrl + Alt  +O but wasn't able to find the right combination.  Could someone please tell me the right key stroke sequence.  I can manage to get the umlaut over the u, but it is too high up. :-(
Edwin
Is there a way to generate a parametric curve that includes the orientation?  i.e. an arrow or series of arrows?
I solved the homogeneous differential equation of a damped oscillator ((D@@2)(x))(t)+d*(D(x))(t)+k^2*x(t) = A*sin(omega*t) with maple, the output is:
x(t) = _C1*exp((-(1/2)*d+(1/2)*sqrt(d^2-4*k^2))*t)+_C2*exp((-(1/2)*d-(1/2)*sqrt(d^2-4*k^2))*t)
Now, as there is damping, the limit for t->infinity shoud be 0. I substituted:
hommod := subs(d^2-4*k^2 = Delta, rhs(l_hom))
 Then, I tried the limit(hommod, t = infinity) command for the three cases
It's been half an hour that I am looking to the example 5 and I can't figured how you can state that x run from 1 to 3 and y from 1 to 2 just by looking at LL.  If I undestand this, I will know how to write those twelve points.
Does anyone would have the patience to explain it to me?
Mario
i am deriving lagrangian shape function symbolically for an 1-D element of order p in FEM....so the eleemnt will have p+1 nodes....
                                   N(k,i) = product((X-Xother)) / product(Xcurrent-Xother)
Hi everybody
de := diff(theta(t), `$`(t, 2))+c*(diff(theta(t), t))+9.8*sin(theta(t))/L = 0; c := 2; L := 2;
init := theta(0) = 0, (D(theta))(0) = 4;
sol := dsolve({de, init}, theta(t), numeric, output=listprocedure);
Theta := subs(sol, theta(t));
plots[animate](plots[arrow],[[0,0],[L*sin(Theta(t)),-L*cos(Theta(t))],colour=red],t=0..5, axes=none,scaling=constrained);
these lines of codes were posted by robert Israel in one of his posts.
As I understand to plot a surface in spherical coordinates we most establish the function relationship of  the radius in terms of theta and phi.  Then using plot3d and specifying coords=spherical gives you surface.  How does one do this for a cone:
Hi, people say that for-next loops are the worst way to apply repeated operations (why?). Assume i have the list
L:=[1,3,5,6];
and the command line that does some stuff in it :
for i from 1 to nops(L)-1 do
 sqrt(5*L[i]-L[i+1]);
Whats a better way to do this? I guess map is useful here, but i cant get it to work.
First 2252 2253 2254 2255 2256 2257 2258 Last Page 2254 of 2458
