How do i solve differential equations using Maple.
For example:
dx/dt+(1-cos(t))*x = exp(sin(t))
I have a nice function whose graph is approximately quadratic; the plot shows the area under it should be around 1.6
However, it seems Maple thinks the area is 0.1465
Presumably there is something simple I am doing wrong, but I can't see it.
What follows may seem strange -- it is certainly strange to me -- but I need to be able to make integration work with my functions as apposed to the built-in functions one sees in examples...
with(Student[Calculus1]);
 Digits:= 64;
Hi everybody,
I am trying to convert a String from a Maplet Texttfield into a polynom to use it.
Unfortunately it is not as easy as predicted. Can anybody help me with my problem?
I allready tried this, but it did not work:
polyString := "alpha";
poly := convert(polyString, poly);
Thanks a lot.
Rainer
I'm trying to orthonormalize the set of basis vectors of the form form p(x)*exp(-x^2/2), where p(x) is a polynomial of degree less than N.
The basis I'm using for this function space is |e1> = exp(-x^2/2), |e2> = x*exp(-x^2/2), |e3> = x^2 * exp(-x^2/2), and so on.
However the GramSchmidt procedure in the LinearAlgebra package only accepts vectors.
Can someone help me to get around this, and use some procedure to orthonormalize the first four bases for this function space?
Hallo dear proffesionals of Maple
I use Debian 4.0 r3 version with gcc compiler v 4.xx
I have installed properly in my computer the Maple 11 version.
the problem is :
I'm using an old maple worksheet (Maple V) and some of the commands are now not valid (well actually most probably aren't).
Specifically numbers(string) and Digitize.  Numbers()  has gone to something like length() but I'm not sure about Digitize.
Would be nice if you could look these up in a command update page that lists all the commands that are valid for what versions and what they translate to in the newer versions.  Be much easier than trying to trudge through and track down the history changes.
Dear all, I'm trying to solve a difficult metric in maple. I did the following: restart; with(tensor): coords:=[t, r, theta,phi]: g:=array(symmetric,sparse,1..4,1..4): g[1,1]:=1+mu*a(r); g[2,2]:=-(1+mu*b(r)): g[3,3]:=-r^2*(1+mu*b(r)): g[4,4]:=-r^2*(sin(theta))^2*(1+mu*b(r)): g[4,1]:=mu*omega*f(r)*r^2*sin(theta)^2*(1+mu*b(r))/c: metric:=create([-1,-1], eval(g)); tensorsGR(coords,metric,contra_metric,det_met, C1, C2, Rm, Rc, R, G, C): display_allGR (coords,metric,contra_metric, det_met, C1, C2, Rm, Rc, R, G, C);
Hello. I am trying to do a question on inverses of matrices, and I have chosen the fill in the blacks method. I want to produce a matrix for students to enter their answers in. I can get it to produce a matrix with the answers in but when I try and make the answers into blanks it does not work. Does anyone know how to do this? Thanks, nj.
Hi,  assume i have a list
m:=[1,5,3];
My (to the core reduced) problem is:
I want to write a procedure that generates  the sequence containing the listname  together with its elements:
m1,m5,m3
my try:
p:=proc(L::list)
`L`||(op(L));
This doesn't work (illegal use of a formal parameter).
What to do ?
want to solve this equation for t  but getting 'Solutions may be lost' error.
eq3 := exp(-1/k*t)*k/(1+k^2)+(-cos(t)*k+sin(t))/(1+k^2);
solve(eq3=0, t);
Solutions maybe lost.
Is this too much for the symbolic engine? Does anyone know of a technique to solve this type of equation?
Appreciated.
Does anyone here know of any Maple code (public, or in the Maple Library, or on www.mapleapps.com, etc) that implements alpha-beta pruning?
I would like to see some examples of how this can be implemented and used in Maple, and possibly learn from it.
How to export worksheet to the HTML format programmatically? And how to export Maple output as GIF or other graphic format programmatically?
I'm seeing some curious behaviour when I use maple to produce MathML for my TA questions. What I want to do is generate the first few terms of a sequence, followed by "...". I've managed to achieve this in Maple, but it's the conversion to MathML that is causing trouble. I've pasted the code below, showing what I'm trying to do. Maple TA code: $W1=maple("printf(MathML:-ExportPresentation( [seq('ln'(2*3^i),i=0..3),`...`] ))");
How do I find for which t is the following equation true?
I went to a particular website where I downloaded Maple programs in .txt files.
If I open the files and cut and paste the .txt into a Maple worksheet,
a > is inserted at the start of every line. It would take forever to delete each of these
>'s from the start of each line in a program with 500 lines.  Someone suggested that I put the command
read C:\\filename.txt
into my Maple worksheet. But, this - and many variations, with and without single quotes, file extensions, etc. - does not work.
Any suggestions?
First 2253 2254 2255 2256 2257 2258 2259 Last Page 2255 of 2458
