I have some troubles in solving a system of three trigonometric equations using the function 'solve' of Matleb.The program finds three solutions but a message of 'Warning: Warning, solutions may have been lost' also appears. Does it mean that there are other three solutions? If yes, how can I see also these three numbers?
Thanx!
In particular because the TAB key doesn't work in Maple, is it possible to define a shortcut key for a few spaces? I found this quite annoying that I couldn't simply tab over a few spaces when programming. Is Maple going to fix it in the future? Why doesn't TAB work anyway, did they forget about it?
I have a particular system of partial differential equations to which I want to apply a change of variables involving square roots using PDEtools[dchange]. The result turns out to be not in a simple form due to the square roots. Why is this so ? Is there a better way solving the problem than the one I am suggesting below ? The system of partial differential equations of interest is the following:
While solving a différential equation, I encounter an integral:
Anyone know a slick way to change the arguments of a function to possibly different things depending on what they are?
Let's say I have objects a, b and c.  a and b are of type function and c is of type set.  F is another function object.
F(a,b,c) is defined.
What I want to do is construct F(g(a),g(b), h(c)).....
Ideas?
Reduce::nsmet: This system cannot be solved with the methods \
available to Reduce. >>
Hi, I'd like to know where's maple directory by default on my computer. I just found a program that would really help which is run on maple. I will join the read me file of the program i want to install.
The unclear part for me is "  (b) Copy the file dot.mapleinit in the Bethe root directory into your
    home directory where it is read in from MAPLE      cp dot.mapleinit ---> [user-home]/.mapleinit"
Hi all
Hi everybody.
Hey guys,
I am struggling again trying to solve very similar pde in Maple V.
pdesolve(-a*u(t,x)+diff(u(t,x),t)+(c^2)*b*(1/t)*[log(2*T/t)]^(-b-1)diff(u(t,x),x,x)=0,u(t,x))
Could anybody try running it in the older version? Are there any solutions?
Thank you,
Vilen
Hallo Everybody,
I hope someone can help me.
I want to solve numerically the diffusion equation,
          diff(csh(rh, t), t) = Dif*(diff(rh^2*(diff(csh(rh, t), rh)), rh))/(r0*rh^2)
          where "Dif" is the diffusivity and "r0" is the initial value of rh (the equations were normalized).
subject to the following boundary and initial conditions:
In Classic, this input:
753406.29+42098.70;
yields this output:
795504.99
But in Standard, the same input yields
7.9550499 10
How do I set my options in Standard so that the output format is like it is in Classic?
I poked around "display options" etc. but did not find anything.
If I have some element tau in my matrix, how do I declare it to be real?
> with(LinearAlgebra);
> A := `<|>`(`<,>`(-sqrt(5/3)*tau, -tau, 0, 0), `<,>`(-tau, -sqrt(3/5)*tau, -2*tau/sqrt(15), 0), `<,>`(0, -2*tau/sqrt(15), sqrt(3/5)*tau, 0), `<,>`(0, 0, -tau, sqrt(5/3)*tau));
The time function doesn't seem to be working consistantly.
Following the example in the help page for the time() function I can't get as low as .041.  The best I get is .046 and sometimes .047 .062 and .063.  Are there services running in the background that can affect the run performance like a firewall for example?
Can anyone else get .041?  For comparison I'm using a P4 - 3 GHz. and 2.5 Gb RAM @ 533 MHz. with 48 processes running in the task manager.
In doc A, I have a matrix in 2D Input.
In doc B, I
Change input to 2D Input; type in natrix name, :=. Cursor location says it is 2D Input. I copy matrix from doc A and paste it into doc B. The style changes to 2D Math.
~R~
First 2250 2251 2252 2253 2254 2255 2256 Last Page 2252 of 2458
