Given a list of n characters, for example [a,1,=,#,@,B,...]. Please help me use Maple command to randomly pick k elements, each element consists of q consecutive random characters, for example, randomly pick 4 elements, each element consists of 3 consecutive random characters a1=, aa&, BC!, 90%. Thank you very much for your help!
i don't know how replace the function which remove the sign of integral even i know the author replaced by sin(t) and t and combined them like the picture but i don't know why my pdes not give me zero
h-pde-M.mw
I am working on reproducing Fig. 12 (Isotherms) and Fig. 13 (Streamlines) from the attached paper, cacity_paper_work.pdf which deals with natural convection of GO–MgO/silicone oil hybrid nanofluid inside square and H-shaped cavities under a periodic magnetic field.
Equations (9–11) in the paper describe the steady-state 2D flow and heat transfer in terms of u(x,y), v(x,y), and θ(x,y). I have already set up the full PDE system, parameters, and boundary conditions (BCs) in Maple.
Now, iusing pdsolve(..., numeric, method=fd),
Solve these equations for both square and H-shaped cavities using the given ICs and BCs, and
Generate Isotherm and Streamline plots (similar to Figs. 12 and 13 in the paper).
I have attached:
The PDF (showing equations and figures), and
My Maple worksheet containing the PDE definitions and parameters.
I would really appreciate guidance on:
Whether dsolve can be used effectively for this PDE system,
How to define the BCs correctly for the H-shaped cavity (especially the partially heated wall, θ=1 for 0.4 < y < 0.6), and
How to extract and plot the temperature (θ) and streamfunction (ψ) fields similar to the paper’s plots.
error_in_cavity_work.mw
Here is a 3D plot of a hemisphere punctured by a cylinder.  I had to think a bit about how to produce this graphics in Maple.  I am posting it here for your amusement, and a challenge for your spare time.
I have more examples like this. Sometimes odetest give false negative result. dsolve solution is actually correct, but odetest does not return all zeros as result of its checking.
Example 1
`The "Physics Updates" version in the MapleCloud is 1881 and is the same as the version installed in this computer, created 2025, October 7, 16:4 hours Pacific Time.`
SupportTools:-Version();
ode:=x^2*diff(y(x),x)+sin(2*y(x)) = 1;
IC:=y(infinity)=11*Pi/4;
maple_sol:=dsolve([ode,IC]);
odetest(maple_sol,[ode,IC])
x^2*(diff(y(x), x))+sin(2*y(x)) = 1
y(infinity) = (11/4)*Pi
y(x) = -arctan((x+2)/(x-2))+3*Pi
[0, undefined]
#but the IC above should not be undefined. This belows shows it is correct.
limit(maple_sol,x=infinity);
limit(y(x), x = infinity) = (11/4)*Pi
#which is what the IC is.
Download odetest_problem_oct_8_2025.mw
Would you agree that odetest in the above should have returned [0,0] instead? Should this result be considered a bug?
Example 2
More examples where odetest gives false negative. The solution by dsolve is correct but odetest says IC is off but it is not.
ode:=x^2*diff(y(x),x)+cos(2*y(x))=1;
IC:=y(infinity)=10/3*Pi;
x^2*(diff(y(x), x))+cos(2*y(x)) = 1
y(infinity) = (10/3)*Pi
y(x) = (7/2)*Pi-arctan((1/3)*(3^(1/2)*x+6)/x)
odetest(sol,[ode,IC]);
[0, -(1/6)*Pi]
limit(sol,x=infinity);
limit(y(x), x = infinity) = (10/3)*Pi
Download odetest_problem_oct_11_2025.mw
Example 3
ode:=x^2*diff(y(x),x)*cos(y(x))+1=0;
IC:=y(infinity)=16/3*Pi;
x^2*(diff(y(x), x))*cos(y(x))+1 = 0
y(infinity) = (16/3)*Pi
y(x) = arcsin((1/2)*(3^(1/2)*x-2)/x)+5*Pi
[0, (1/3)*Pi]
limit(y(x), x = infinity) = (16/3)*Pi
Download odetest_problem_oct_11_2025_V2.mw
Example 4
ode:=diff(y(x),x)*sin(x)-y(x)*cos(x)=-sin(x)^2/x^2;
IC:=y(infinity)=0;
(diff(y(x), x))*sin(x)-y(x)*cos(x) = -sin(x)^2/x^2
y(infinity) = 0
y(x) = sin(x)/x
[0, undefined]
limit(y(x), x = infinity) = 0
Download odetest_problem_oct_11_2025_V3.mw
Example 5
ode:=x*y(x)^2+exp(x)*diff(y(x),x)=0;
IC:=y(infinity)=1/2;
x*y(x)^2+exp(x)*(diff(y(x), x)) = 0
y(infinity) = 1/2
y(x) = -1/(x*exp(-x)+exp(-x)-2)
[0, undefined]
limit(y(x), x = infinity) = 1/2
Download odetest_problem_oct_11_2025_V4.mw
Will add more examples as I find them....
I am looking at the d'Almbert operator for the Minkowski metric in cartesian coordinates. When using the dAlmbertian command and converting to partial derivatives it gets the coefficients wrong, the negatives are not in the correct place based on the metric. But when I manually write the operator with the metric and derivative operator it returns the correct answer. Any thoughts on this?
See attached, thank you.
with(Physics):
Setup(coordinatesystems=cartesian,signature=`-+++`,metric=Minkowski)
`Systems of spacetime coordinates are:`*{X = (t, x, y, z)}
`The Minkowski metric in coordinates `*[t, x, y, z]
`Signature: `(`- + + +`)
Physics:-g_[mu, nu] = Matrix(%id = 36893488152289591652)
[coordinatesystems = {X}, metric = {(1, 1) = -1, (2, 2) = 1, (3, 3) = 1, (4, 4) = 1}, signature = `- + + +`]
g_[lineelement]
-Physics:-d_(t)^2+Physics:-d_(x)^2+Physics:-d_(y)^2+Physics:-d_(z)^2
CompactDisplay(phi(t,x,y,z))
phi(t, x, y, z)*`will now be displayed as`*phi
dAlembertian(phi(X))
Physics:-dAlembertian(phi(X), [X])
convert(%,diff)
-(diff(diff(phi(X), t), t))-(diff(diff(phi(X), x), x))-(diff(diff(phi(X), y), y))+diff(diff(phi(X), z), z)
g_[~mu,~nu]*d_[nu](d_[mu](phi(X)))
Physics:-g_[`~mu`, `~nu`]*Physics:-d_[mu](Physics:-d_[nu](phi(X), [X]), [X])
SumOverRepeatedIndices((6))
-(diff(diff(phi(X), t), t))+diff(diff(phi(X), x), x)+diff(diff(phi(X), y), y)+diff(diff(phi(X), z), z)
dAlmbert.mw
in this pde I have to find R, and already in the paper finded but  in my openion is not correct even when i tested is not give me solution, in some paper like that i finded R variable by finding some condition in pde but i want a coding for arrange that condition for example in pde we have 4 function of t like C(t),B(t),N(t),and E(t) i have to change them for finding R  like exchange C(t)=C(t), B(t)=C(t),N(t)=-C(t),E(t)=E(t) also we can equal them to one too, this is one of the condition how many condition we can have for substitute each on like that and tested for finding R, one of this condition will make help to find that R  like  this paper
but my equation is different is this equation  in below
i tested the author outcome and not make my pde to zero, also dipersion relation without changing any any function of t is so different and i think he just use the penlevy test variable 6/beta*diff(phi,x) as a tranformation but i think is mistake, so where is problem and how we can find all the condition
pde-condition.mw
in this function contain another function which contain integral but when i replace is just take some of the function and other function is not acceptable i want ask  there is any way for plotting the function when i substitute all other function, is work for csc,sec,cosh, and for other not work and  infinity sign appear likesome other  like t,sin,cos,tan,tanh,sinh, so on
 t-plot.mw
I would like to experiment with error estimation in the symbolic solution of ordinary differential equations. I've written a simple example in the attached file. I would now like to plot both the left side of the ODE and the solution y(x) together in the same coordinate system. I can't do this, and I'm asking for help. How can the cumbersome numerical terms in the solution y(x) be converted to floating-point numbers?
As I said, this is a recreational experiment ;-) .DGL_test.mw
ode := x^2 = sum(x*(diff(y(x), [`$`(x, i)]))/factorial(i), i = 0 .. 3)
x^2 = x*y(x)+x*(diff(y(x), x))+(1/2)*x*(diff(diff(y(x), x), x))+(1/6)*x*(diff(diff(diff(y(x), x), x), x))
ics := y(0) = 0, (D(y))(0) = 0, ((D@@2)(y))(0) = 0
dsolve({ics, ode})
y(x) = x-1+((1/12)*(2-2^(1/2))*(1+2^(1/2))^(2/3)+(1/12)*2^(1/2)*(1+2^(1/2))^(1/3)+1/3)*exp(((1+2^(1/2))^(2/3)*2^(1/2)-(1+2^(1/2))^(2/3)-(1+2^(1/2))^(1/3)-1)*x)+((1/12)*(2^(1/2)-2)*(1+2^(1/2))^(2/3)-(1/12)*2^(1/2)*(1+2^(1/2))^(1/3)+2/3)*exp(-(1/2)*((1+2^(1/2))^(2/3)*2^(1/2)-(1+2^(1/2))^(2/3)-(1+2^(1/2))^(1/3)+2)*x)*cos((1/2)*3^(1/2)*(1+2^(1/2))^(1/3)*(2^(1/2)*(1+2^(1/2))^(1/3)-(1+2^(1/2))^(1/3)+1)*x)-3^(1/2)*(-1+(2^(1/2)-1)*(1+2^(1/2))^(1/3))*2^(1/2)*exp(-(1/2)*((1+2^(1/2))^(2/3)*2^(1/2)-(1+2^(1/2))^(2/3)-(1+2^(1/2))^(1/3)+2)*x)*sin((1/2)*3^(1/2)*(1+2^(1/2))^(1/3)*(2^(1/2)*(1+2^(1/2))^(1/3)-(1+2^(1/2))^(1/3)+1)*x)/((1+2^(1/2))^(2/3)*(12*2^(1/2)-12))
NULL``
Download DGL_test.mw
I have a lot of maple code for analysing electronic design uncertainties and would like to place a clip from the schematic before outputing the analysis results.  I have been working for hours on this with no success but I'm sure it must be simple.
I see that ImageTools,Preview kind of works but it outputs a very small, blurry image.  Is there just a simple command that I can read in my .png image and output it to the display?
I have full access on .../.../version.txt but Maple tells me I have no write access...
Sorry for the previous post, thank you.
If I try with the install command I get the same error.
Kind regards to all
Jean-Michel
PS: have a look on the two inserted screenshots
I'm not sure of the Maple function I have to use to represent the modified Bessel function of the third kind with index 1.
The Bessel function of the third kind is also named the Hankel function.
I mistakenly started to use HankelH1 or HankelH2 but quickly realized they are both complex-valued functions while the paper I'm working on uses a real-valued modified Bessel function of the third kind: finally, does this latter exist in Maple 2015?
undesired_textplot_format.mw
When using textplot() AND display(), how do I ensure that the expression I want in the figure is not modified by display()? See my attached spreadsheet where I demostrate this undesired behaviour.
Evaluation with `&varphi;__0`subscripted
-t(0)+t(`&varphi;`(t)) = Int(1/sqrt(2*C*cos(`&varphi;`)-2*C*cos(`&varphi;__0`)), `&varphi;` = 0 .. `&varphi;`(t), continuous)
-t(0)+t(varphi(t)) = Int(1/(2*C*cos(varphi)-2*C*cos(varphi__0))^(1/2), varphi = 0 .. varphi(t), continuous)
t(0) = 0, `&varphi;`(t) = `&varphi;__0`, t(`&varphi;__0`) = (1/4)*T
t(0) = 0, varphi(t) = varphi__0, t(varphi__0) = (1/4)*T
subs(t(0) = 0, varphi(t) = varphi__0, t(varphi__0) = (1/4)*T, -t(0)+t(varphi(t)) = Int(1/(2*C*cos(varphi)-2*C*cos(varphi__0))^(1/2), varphi = 0 .. varphi(t), continuous))
(1/4)*T = Int(1/(2*C*cos(varphi)-2*C*cos(varphi__0))^(1/2), varphi = 0 .. varphi__0, continuous)
isolate(`assuming`([simplify(value((1/4)*T = Int(1/(2*C*cos(varphi)-2*C*cos(varphi__0))^(1/2), varphi = 0 .. varphi__0, continuous)))], [C > 0, 0 < `&varphi;__0` and `&varphi;__0` < Pi]), T)
T = 4*InverseJacobiAM((1/2)*varphi__0, csc((1/2)*varphi__0))*csc((1/2)*varphi__0)/C^(1/2)
Replacing now in the above varphi__0 by varphi[0]
Evaluation with `&varphi;`[0] indexed
-t(0)+t(`&varphi;`(t)) = Int(1/sqrt(2*C*cos(`&varphi;`)-2*C*cos(`&varphi;`[0])), `&varphi;` = 0 .. `&varphi;`(t), continuous)
-t(0)+t(varphi(t)) = Int(1/(2*C*cos(varphi)-2*C*cos(varphi[0]))^(1/2), varphi = 0 .. varphi(t), continuous)
t(0) = 0, `&varphi;`(t) = `&varphi;`[0], t(`&varphi;`[0]) = (1/4)*T
t(0) = 0, varphi(t) = varphi[0], t(varphi[0]) = (1/4)*T
subs(t(0) = 0, varphi(t) = varphi[0], t(varphi[0]) = (1/4)*T, -t(0)+t(varphi(t)) = Int(1/(2*C*cos(varphi)-2*C*cos(varphi[0]))^(1/2), varphi = 0 .. varphi(t), continuous))
(1/4)*T = Int(1/(2*C*cos(varphi)-2*C*cos(varphi[0]))^(1/2), varphi = 0 .. varphi[0], continuous)
isolate(`assuming`([simplify(value((1/4)*T = Int(1/(2*C*cos(varphi)-2*C*cos(varphi[0]))^(1/2), varphi = 0 .. varphi[0], continuous)))], [C > 0, 0 < `&varphi;`[0] and `&varphi;`[0] < Pi]), T)
T = 4*2^(1/2)*(-(limit(((-cos(varphi)+cos(varphi[0]))/(-1+cos(varphi[0])))^(1/2)*InverseJacobiAM((1/2)*varphi, csgn(sin((1/2)*varphi[0]))*csc((1/2)*varphi[0]))/(cos(varphi)-cos(varphi[0]))^(1/2), varphi = 0, right))*(cos(varphi[0])-cos(varphi[0][0]))^(1/2)+((-cos(varphi[0])+cos(varphi[0][0]))/(-1+cos(varphi[0][0])))^(1/2)*InverseJacobiAM((1/2)*varphi[0], csgn(sin((1/2)*varphi[0][0]))*csc((1/2)*varphi[0][0])))/(C^(1/2)*(cos(varphi[0])-cos(varphi[0][0]))^(1/2))
The double indices in the above limit do not make sense.
In case this is a bug: Is there any workaround for indexed names? I want to use them to have numbers in indices in roman which seems to be not possible with subscripts.
Download Evaluation_of_elliptic_integrals.mw
Is the absence of up/down arrows at the ends of the vertical scroll bar in Maple 2025's worksheet window a bug or by design?
These up/down arrows are helpful for small-increment navigation with the vertical scroll bar.  I hope Maple's designers restore the up/down arrows at the ends of the vertical scroll bar in Maple's worksheet window. These up/down arrows were present in Maple 2024 and earlier.
First 22 23 24 25 26 27 28 Last Page 24 of 2457
