Frac_C := proc (expr, a, t, alpha) local ig, m, tau;
m := ceil(alpha);
ig := (t-tau)^(m-alpha-1)*(diff(eval(expr, t = tau), tau$m));
`assuming`([(int(ig, tau = a .. t))/GAMMA(m-alpha)], [a < t]);
r := .5;
k := .7;
eq1 := Frac_C(x, 0, t, r)-y(t) = 0;
eq2 := Frac_C(y, 0, t, k)-x(t)-2*t = 0;
eq3 := x(0)-y(1) = 0;
eq4 := Frac_C(x, 0, t, r)-(eval(diff(y(x), x), x = 1)) = 0;
eq5 := Frac_C(x, 0, t, r)-(eval(diff(y(x), x, x), x = 1)) = 0;
eq6 := eval(diff(y(x), x), x = 0)-x(1)-2 = 0;
eq7 := y(0) = 0;
N := 5;
x[c] := [seq(a[i], i = 0 .. N)];
y[c] := [seq(b[i], i = 0 .. N)];
for n to N do
subs([seq(x(i) = x[c][i], i = 0 .. n), seq(y(i) = y[c][i], i = 0 .. n)], {eq1, eq2, eq3, eq4, eq5, eq6, eq7});
soln := solve({eq3, eq4, eq5, eq6, eq7, seq(coeff(lhs(eq), t, j) = 0, eq in {eq1, eq2})}, {a[n+1], b[n+1]});
x[c][n+1] := eval(a[n+1], soln);
y[c][n+1] := eval(b[n+1], soln);
x[s] := add(x[c][i]*t^(i-1), i = 1 .. N+1);
y[s] := add(y[c][i]*t^(i-1), i = 1 .. N+1);
x[s];
y[s];
Hi, i want to calculate fourier transform of functions with fractional powers. how can i do this? for example what is fourier transform of sqrt(x) ? I want a function or an expression as output, not the inetgral itself. thnx in advance
restart:with(inttrans):
f := x -> x^(1/2);
int(f(x)*exp(-I*w*x), x = -infinity .. infinity);
proc (x) options operator, arrow; x^(1/2) end proc
int(x^(1/2)*exp(-I*w*x), x = -infinity .. infinity)
fourier(f(x),x,w)
fourier(x^(1/2), x, w)
Download fracfourier.mw
How can I export data from the plot? Following is my Maple code.
with(PDEtools);
v_0 := 1;
vstar := 10;
r_0 := 1;
k := 0.1;
m := 0.1;
PDE := diff(v(r, t), t) = k*(diff(v(r, t), r, r) + diff(v(r, t), r)/r);
                                                / d         \
                           /  2         \   0.1 |--- v(r, t)|
          d                | d          |       \ dr        /
  PDE := --- v(r, t) = 0.1 |---- v(r, t)| + -----------------
          dt               |   2        |           r
                           \ dr         /
ans := pdsolve(PDE, HINT = f(r)*g(t));
ans := Typesetting:-mcomplete|vApplyFunction(rt)equalsf__1
                                              ||DifferentialD
  ApplyFunction(r) f__2ApplyFunction(t) where ||--------------
                                              ||DifferentialDt
  f__2ApplyFunction(t)equals0.1 f__2ApplyFunction(t) _c[1]
  DifferentialD
  --------------- f__1ApplyFunction(r)equals1. f__1ApplyFunction(
  DifferentialDr
                /DifferentialD                      \//
             1. |-------------- f__1ApplyFunction(r)|||
                \DifferentialDr                     /||
  r) _c[1] - ----------------------------------------||,
                                r                    ||
  Typesetting:-_Hold|[PDESolStruc|v(r, t) = f__1(r) f__2(t), [<
   d
  --- f__2(t) = 0.1 f__2(t) _c[1],
   dt
                                       / d         \\ ]\]\\
    2                               1. |--- f__1(r)|| ]|]||
   d                                   \ dr        /| ]|]||
  ---- f__1(r) = 1. f__1(r) _c[1] - ---------------- >]|]||
     2                                     r        | ]|]||
   dr                                               | ]|]||
build(ans);
                  /1         \             /           (1/2)  \
v(r, t) = c__3 exp|-- _c[1] t| c__1 BesselJ\0, (-_c[1])      r/
                  \10        /
             /1         \             /           (1/2)  \
   + c__3 exp|-- _c[1] t| c__2 BesselY\0, (-_c[1])      r/
             \10        /
design;
BC1 := eval(v(r, t) - v_0 = 0, r = 20);
                    BC1 := v(20, t) - 1 = 0
BC2 := D[1](v)(0, t) = 0;
NULL;
IC := v(r, 0) = v_0 + (vstar - v_0)*exp(-0.5*(r - r_0)^2/m^2)/(m*sqrt(2*Pi));
                                    (1/2)    /            2\
   IC := v(r, 0) = 1 + 25.38853126 2      exp\-50. (r - 1) /
conds := {BC1, BC2, IC};
    conds := { v(20, t) - 1 = 0,
                                 (1/2)    /            2\
      v(r, 0) = 1 + 25.38853126 2      exp\-50. (r - 1) /,
      D[1](v)(0, t) = 0 }
answer:=pdsolve(PDE,conds,HINT=);
Error, invalid =
Typesetting:-mambiguous(answerAssignpdsolveApplyFunction(PDEcomma
  condscommaTypesetting:-mambiguous(HINTequalslowast,
  Typesetting:-merror("invalid =")))semi)
u := r -> v_0 + (vstar - v_0)*exp((-1)*0.5*(r - r_0)^2/m^2)/(m*sqrt(2*Pi));
u := proc (r) options operator, arrow, function_assign;
   v_0+(vstar-v_0)*exp(-.5*(r-r_0)^2/m^2)/(m*sqrt(2*Pi)) end proc
plot(u(r), r = 0 .. 10);
                                 (1/2)    /            2\
      D[1](v)(0, t) = 0 }
BCs := {BC1, BC2};
          BCs := {v(20, t) - 1 = 0, D[1](v)(0, t) = 0}
pde_solve = pdsolve(PDE, BCs, IC);
solution := pdsolve(PDE, conds, numeric);
                  solution := _m1440390954528
t1 = 0 .. 10;
r1 = 0 .. 10;
solution, t1, r1;
                        solution, t1, r1
sol := pdsolve(PDE, conds, numeric, time = t, range = 0 .. 20, spacestep = 0.1, timestep = 0.1);
                     sol := _m1440421519392
sol:-animate(t = 0 .. 20, frames = 100);
M := sol:-value();
sol:-plot3d(r = 0 .. 10, t = 0 .. 20);
I have give this below fit command my data is only continous data either positive or negative float data. Their never any complex number at all.
I use the below fit command
Error, complex argument to max/min
It can be observed it is running into error in C1 I dont know why can someone suggest where should I check and why is this happening kind help.   In Excel we can see the intercept coming big.
I attach the toycode to see the error I get too
toycode.mw
I want to know the exponent of one particular factor of an integer. For example:
k:=24;
ifactor(k) = (2)^3(3)
and I want to write a module to extract the exponent of (3) for any arbitrary k.
I can't select for the presence of 3 because it will pick up the factor (2)^3 and then it gets complicated to decide that I don't want this factor anyway.
If I somehow manage to select the factor (3) using "op" and scanning through each factor in turn, then substitute 3=x, it turns out that degree(%,x) doesn't work because the factor x is enclosed in brackets; similarly trying
log(%,3) fails for the same reason.
There has to be a simple way, but I just don't see it.
Any suggestions are appreciated.
In GraphTheory ,how do you make more than one edge between two points.
Could you help me to solve this problem for the parameter beta?
e1:= 0.5; e2:=0.2;theta:=5;yeq:=e2;
.5
.2
5
.2
f:=(theta*x-1)*(1-x)*(1+beta*x^2)-y;
g:=x/(1+beta*x^2); gs:=unapply(g,x);
(5*x-1)*(1-x)*(beta*x^2+1)-y
x/(beta*x^2+1)
proc (x) options operator, arrow; x/(beta*x^2+1) end proc
fs:=subs(y=yeq,f);
(5*x-1)*(1-x)*(beta*x^2+1)-.2
assumptions:=x>1/theta, x<1,beta>0,beta<1,gs(x)>e1;
solve(fs=0,x,useassumptions) assuming assumptions;
1/5 < x, x < 1, 0 < beta, beta < 1, .5 < x/(beta*x^2+1)
Warning, solve may not respect assumed property 'real' on 'x/(beta*x^2+1)'.
Error, (in type/realcons) too many levels of recursion
gs2:=subs(beta=0.6,gs(x));
x/(.6*x^2+1)
sol:= solve(subs(beta=0.6,fs=0),x,useassumptions) assuming x>1/theta, x<1;
.2514854589, .9665623271
subs(x=sol[1],gs2);
.2422912423
Download Rootsfind.mw
I put this command and It keep saying  plot(f(x), x = -0.667 .. 1.71, y = -5 .. 20, gridlines); Error, (in plot) unexpected options: [1.71 = -.667 .. 1.71, y = -5 .. 20] . How can I fix this
How can I show all the parameters in title ?
with(DEtools):with(plots):with(plottools):
sigma1:=e1*alpha: sigma2:=e2*delta:
g:=x/(1+beta*x^2);
h:=alpha*g-z-sigma1;
j:=delta*y-sigma2;
x/(beta*x^2+1)
(theta*x-1)*(1-x)*(beta*x^2+1)-y
alpha*x/(beta*x^2+1)-e1*alpha-z
-delta*e2+delta*y
p0:=theta->plot([1/theta,y,y=0..1],linestyle=dash,color= green):
p1:=e1->plot([x,e1,x=0....1.5],color=blue):
q0:=animate(p0,[theta],theta=2...10):
q1:=animate(p1,[e1],e1=0.1..1):
q2:=plot([1,y,y=0..1],linestyle=dash,color= green):
p3:=beta->plot([x,x/(1+beta*x^2),x=0..1.5],color=magenta);
q3:=animate(p3,[beta],beta=0..1.5):
display([q0,q1,q2,q3],view=[0..1.5,0..1]);
proc (beta) options operator, arrow; plot([x, x/(1+beta*x^2), x = 0 .. 1.5], color = magenta) end proc
Download animate_plots.mw
I am quite a rookie in using Maple.
A project is going on while I need to use previous formulas and variables defined in A.mw, while I don't want to redefine everything again in my worksheet, is there any approach to inherit everything in A.mw to my current worksheet?
How would I go about creating a tetrad of a specific signature in the Differential Geometry package. The GrahmSchmidt and NullTetrad give me orthonormal and complex null tetrads. But I was wondering if there was a way to generate a tetrad of specific signature.
The union is simple
with(plottools):
display([torus([1,1,1], 1, 2),torus([1,6,1], 1, 2)], scaling=constrained, lightmodel=light1, shading=zgrayscale,color=[red,red]);
but how to plot the intersection?
I have been try to code the
mdl:-Fit(x, y, opts)
command in Deep learning package
But i feel new to that command I am making errors
Can I get a small toy code how to call it and its output on train and test
so that i could learn
kind help please
 i want to increase my value monotonically  . but i don't want to do it like sequence. how can i write code.
for example my value ..starts at 0...to some values i just want to increase.
help me plz
First 248 249 250 251 252 253 254 Last Page 250 of 2463
