I am trying to solve the following system of odes where the unknowns are xhat, yhat, uhat and vhat. They depend on the variables (x, y, u, v, a_1, a_2, a_3, a_4, f(x)) where f(x) is an arbitrary function and I want to solve it with respect to a_1. The RHS has f(x) and its derivative with respect to x. The dsolve function fails to solve the ode when I add f(x) at the list of variables.
vars := x, y, u, v, a_1, a_2, a_3, a_4, f(x);
sys_ode := diff(xhat(vars), a_1) = a_3*x + a_1, diff(yhat(vars), a_1) = a_2 - a_4*y + f(x), diff(uhat(vars), a_1) = a_3*u + 2*a_4*u, diff(vhat(vars), a_1) = a_4*v + diff(f(x), x)*u;
initvars := x, y, u, v, 0, a_2, a_3, a_4, f(x);
ics := xhat(initvars) = x, yhat(initvars) = y, uhat(initvars) = u, vhat(initvars) = v;
solution_a1 = dsolve([sys_ode, ics], [xhat, yhat, uhat, vhat]);
Can anyone help regarding this issue ?
Hello dear experts. Please help me with a specific issue.
There is an article (attached A_Fuzzy_Best_Worst_approach_to_the_determination_of_the_importance_level_of_digital_supply_chain_on_sustainability.pdf) that describes the Fuzzy Best Worst method for solving a specific problem. On page 7, in the description “Step 5”, it is indicated that the calculation of the equation takes place in the Maple software. As a result, they receive fuzzy criteria weights.
Also on page 9, at the very top, the model itself is described, which is used in Maple.
Please tell me how these fuzzy criteria weights are calculated in Maple? Thanks in advance.
Anyone could help me know how to use of "Back Solving Assistant", please? I can't understand how to enter a formular. When I enter a formula, even the one suggested by Maple, and then click the "Proceed to Back-Solver" button, I always get an error message. Please help me!
how can i Roand my answers to 2 number after decimal point.
That is, Maple shows me only two digits after the decimal point. like this.
with(LinearAlgebra);
K := evalf(Matrix(3, [1/3, -20/3, -20/3, 200/3, 70000/3, 4000/3, 1.44]), 6);
I was searching for an “uneval” command that returns an expression unevaluated (as Maple returns an output). In the attached example I am using eval which works in this instance since the integral is entered in an inert form.
Int(1/sqrt(x), x)
Int(1/x^(1/2), x)
(eval = value)(Int(1/x^(1/2), x))
Int(1/x^(1/2), x) = 2*x^(1/2)
Since the use of eval to obtain something unevaluated is somehow confusing (and might not work in all instances): Is there a better way than to use eval?
Download expr_equals_evalexpr.mw
Maple (2015) fails to instanciate a Matrix with a list of elements of type string
(for instance Matrix(2, 2, ["A", "B", "C", "D"]) )
Matrix(2$2, [1$4]):    # ok
Matrix(2$2, [A$4]):    # ok
Matrix(2$2, ["A"$4]);  # not correctly understood by Maple (2015)
Error, (in Matrix) initializer defines more columns (4) than column dimension parameter specifies (2)
Is this a bug?
Maybe something corrected in earlier versions?
Depth-first search (DFS) is an algorithm for traversing or searching tree or graph data structures. The algorithm starts at the root node (selecting some arbitrary node as the root node in the case of a graph) and explores as far as possible along each branch before backtracking. see  https://en.wikipedia.org/wiki/Depth-first_search
Here I write a  DFS function in maple  language according to the principle of  BFS algorithm.
Pseudo codes:
procedure DFS_iterative(G, v) is
    let S be a stack
    S.push(v)
    while S is not empty do
        v = S.pop()
        if v is not labeled as discovered then
            label v as discovered
            for all edges from v to w in G.adjacentEdges(v) do
                S.push(w)
Maple DFS codes:
DFS:=proc(g::Graph,x)
local  s,seen,vertex,nodes,w,vertexlist;
s := stack[new]():
stack[push](x, s):
seen :=[x]:
vertexlist:= []:
while not stack[empty](s) do
      vertex:=stack[pop](s):
      vertexlist:= [op(vertexlist),vertex]:
      nodes:= Neighborhood(g, vertex):
      for w in nodes do
            if not evalb(w in seen) then:
                stack[push](w, s):
                seen :=[op(seen),w]:
            end if:
return  vertexlist
with(GraphTheory):with(SpecialGraphs):
P := PetersenGraph():
DrawGraph(P);
DFS(P,1)
[1, 6, 10, 9, 8, 4, 3, 7, 5, 2]
The result of a depth-first search of a graph can be conveniently described in terms of a spanning tree of the vertices reached during the search.
But I haven't figured out how to improve the  above codes to get this DFS spanning tree.
PS: The stack seems to be deprecated in maple2021.
As another way to search BFS algorithm, Carl Love  provided an example of the application of BFS algorithm.
I also wrote a BFS code implementation based on the queue as follows.
BFS:=proc(g::Graph,x)
s:= SimpleQueue():
s:-enqueue(x):
seen :=[x]:
vertexlist:= []:
while not s:-empty() do
      vertex:=s:-dequeue():
      for w in nodes do
                s:-enqueue(w):
            end if:
return  vertexlist
BFS(P,1)
[1, 2, 5, 6, 3, 9, 4, 8, 7, 10]
Hello, which operator should I use instead of ":=" (assignment statement) so that the graph H remains unchanged in the code below?
with(GraphTheory);
G := CompleteGraph(4);
DrawGraph(G);
H := G;
DeleteEdge(G, {1, 2}, inplace = true);
DrawGraph(G);
DrawGraph(H);
I am evaluating Maple Flow 20212.2 on a Macbook Air M1 running MacOs Monterey 12.2.
Unfortunately this is being severly hampered because for every keystroke Maple Flow is entering
that Character twice.  Disabling keyboard autorepeat and restarting Mac or Maple Flow makes no difference.
Anyone got a solution for this?
Good day everyone,
I am having a problem writing a PDE code and it is given an error code
"Error, (in pdsolve/numeric) initial/boundary conditions must be defined at one or two points for each independent variable"
The link is attached below. Please, help. Thanks
PDE_solution.mw
I am trying to compute the determinant of a 3 x 3 matrix. It has very involved symbolic entries.
The cpu goes to 100% and after about a minute I get BSOD on windows 10. Using a 4 core i7 64 gig of ram.
Can I stop Maple using all the cores to see if this helps the BSOD.?
I bought a subscription for the Maple calculator on google play and the app still wont give me more than 5 steps a day. Does anyone know what the problem could be?
How can i get mapple code for solving Fractional Patfial Differential Equation with Laplace, Adomian and New Iteration Method
I want to draw a 2d directionfield with arrows for a differential equation system with three equations. I have tried the following:
mu := 1/(365*80);
alpha := 20;
psi := 100;
varphi := 2;
K := 100;
theta := 0.5;
sigma := 0.001;
with(DEtools);
with(PDEtools);
beta := 0.3;
des := diff(S(t), t) = (psi + mu)*K - beta*S(t)*In(t) - (mu + varphi + psi)*S(t) + (theta - psi)*V(t) - psi*In(t), diff(V(t), t) = varphi*S(t) - sigma*beta*In(t)*V(t) - (mu + theta)*V(t), diff(In(t), t) = beta*S(t)*In(t) + sigma*beta*In(t)*V(t) - (mu + alpha)*In(t);
phaseportrait([des], [S(t), V(t), In(t)], t = 0 .. 100, [[S(0) = 70, V(0) = 0, In(0) = 30]], V = 0 .. 100, In = 0 .. 100, stepsize = 0.05, arrows = medium, scene = [V(t), In(t)], linecolour = sin(t*Pi/2))
The problem is, Maple plots only the curve for the initial values and not the arrows of the direction field. How can I solve this problem?
Tanks
How do I use ErrorPlots to put error bars on my scatter plot of data, AT THE LOCATION OF THE SCATTER PLOT DATA POINT? Below I write an example demonstrating how I plot the data and error bars using ErrorPlots.  When I use display to combine plots you clearly see that the errorbars are not on the scatter plot data points.  How do I give ErrorPlots, the x-y locations of the data points, so it knows to print the error bars on the location of the data points?  Is there a better approach to putting horizontal and vertical error bars onto scatter plot data?
First 373 374 375 376 377 378 379 Last Page 375 of 2458
