how to find the solutions of a system of recursive equations? And the plot too.
I tried but...
B := rsolve({a(0) = 0, a(i) = (1 + 10^(-5)*(0.01*(i - 1) - 0.007)/0.0001)*a(i - 1) + 0.1*10^(-5)*c(i - 1), c(0) = 0, c(i) = 0.01*10^(-5)*(i - 1)/0.0001*a(i - 1) + (1 - 10^(-5))*0.1*c(i - 1)}, {a(i), c(i)}, 'genfunc'(t));
B := rsolve({a(i) = (0.9983000000 + 0.001000000000 i) a(i - 1)
   + 0.000001000000000 c(i - 1),
  c(i) = 0.001000000000 (i - 1) a(i - 1) + 0.09999900000 c(i - 1)
  }, {a(i), c(i)}, genfunc(t))
rsolve_for_system_of_recursive_equations.mw
This is a simple problem of Chemistry. I solved the exercise, but there are three aspects I don't like about output:
1) Even kg*m2 *s-2 = J (SI unit to energy) and both are correct, one must be explicit with units in order to be totally clear, so I need an output with units of J/mol and not kg*m2 *s-2 mol-1.
2) I had to hardcode number of significant figures, so I had to analize quantitys in order to determine this number, wich as you can see, is three. I think Maple can compute significant figures automatically, but I could not find the command in documentation and even in this case is not totally needed, I would like to learn how do it because it could be very useful for more complex expressions.
3) Finally, output must be expressed using scientific notation, it's say enthalpy = 10.4*104 J/mol.
Therefore: How can I get adecuate output?
Thank you for helping me;
Greetings;
Lic. Marcus Vinicio Mora Sallas;
Chemist;
Postgraduate student. question4.mw
*** e1.501
Using this equation attributed to Clausius and Clapeyron,
ln(P[2]/P[1]) = Delta*H[vap]/R 1/T[1]-1/T[2]
and these data for the vapour pressure of liquid mercury at the indicated temperatures,
      P =  1.6 10^(-4) Pa at T = 273.15 K and P = 36.4 Pa at T = 373.15 K
estimate the enthalpy change Delta*H[vap] for vapourization of mercury over this range of temperature.
p := [1.6e-4*Unit('Pa'), 36.4*Unit('Pa')]:
Delta(H[vap]) = 0.105e6*Units:-Unit(m^2*kg/(s^2*mol*K))*Units:-Unit(K)
Download question4.mw
system_of_PDE.mw
Digits := 30; with(PDEtools); with(plots); Ops1 := numpoints = 100; Ops2 := color = magenta; Ops3 := color = blue; Ops4 := color = "BlueViolet"; Ops5 := axes = boxed, shading = zhue, orientation = [40, 50]; a := 0; b := 1; Tf := .5
.5
E := 1480
1480
Ebes := 5990
5990
n0 := 900000
900000
ro := 1200
1200
m := 12.6
12.6
f := sig(x, t)-Ebes*`ϵij`(x, t)
sig(x, t)-5990*`ϵij`(x, t)
n := 900000*exp(-(sig(x, t)-E*`ϵij`(x, t))/m)
900000*exp(-0.793650793650793650793650793651e-1*sig(x, t)+117.460317460317460317460317460*`ϵij`(x, t))
P := 5
5
w := 4
4
k := 7
7
i := 5
5
eq1 := diff(sig(x, t), x, x) = ro*(diff(sig(x, t), x, x))/E+ro*(diff(sig(x, t), t)-Ebes*f/(9000000*exp(-(sig(x, t)-E*`ϵij`(x, t))/m)))*(1+f/m)/(9000000*exp(-(sig(x, t)-E*`ϵij`(x, t))/m))
diff(diff(sig(x, t), x), x) = (30/37)*(diff(diff(sig(x, t), x), x))+(1/7500)*(diff(sig(x, t), t)-(599/900000)*(sig(x, t)-5990*`ϵij`(x, t))/exp(-0.793650793650793650793650793651e-1*sig(x, t)+117.460317460317460317460317460*`ϵij`(x, t)))*(1+0.793650793650793650793650793651e-1*sig(x, t)-475.396825396825396825396825397*`ϵij`(x, t))/exp(-0.793650793650793650793650793651e-1*sig(x, t)+117.460317460317460317460317460*`ϵij`(x, t))
eq2 := diff(`ϵij`(x, t), t) = f/(9000000*exp(-(sig(x, t)-E*`ϵij`(x, t))/m))
diff(`ϵij`(x, t), t) = (1/9000000)*(sig(x, t)-5990*`ϵij`(x, t))/exp(-0.793650793650793650793650793651e-1*sig(x, t)+117.460317460317460317460317460*`ϵij`(x, t))
(14)
sys := {eq1, eq2}
{diff(diff(sig(x, t), x), x) = (30/37)*(diff(diff(sig(x, t), x), x))+(1/7500)*(diff(sig(x, t), t)-(599/900000)*(sig(x, t)-5990*`ϵij`(x, t))/exp(-0.793650793650793650793650793651e-1*sig(x, t)+117.460317460317460317460317460*`ϵij`(x, t)))*(1+0.793650793650793650793650793651e-1*sig(x, t)-475.396825396825396825396825397*`ϵij`(x, t))/exp(-0.793650793650793650793650793651e-1*sig(x, t)+117.460317460317460317460317460*`ϵij`(x, t)), diff(`ϵij`(x, t), t) = (1/9000000)*(sig(x, t)-5990*`ϵij`(x, t))/exp(-0.793650793650793650793650793651e-1*sig(x, t)+117.460317460317460317460317460*`ϵij`(x, t))}
(15)
IBC1 := {sig(0, t) = P*sin(w*k*i), sig(10, t) = P*sin(w*k*i), sig(x, 0) = 0, sig(x, 1) = 0, `ϵij`(x, 0) = 0}
{sig(0, t) = 5*sin(140), sig(10, t) = 5*sin(140), sig(x, 0) = 0, sig(x, 1) = 0, `ϵij`(x, 0) = 0}
(16)
S := 1/100; Ops := spacestep = S, timestep = S; Sol1 := pdsolve(sys, IBC1, [sig, `ϵij`], numeric, time = t, range = a .. b, Ops)
1/100
spacestep = 1/100, timestep = 1/100
Error, (in pdsolve/numeric) unable to handle elliptic PDEs
Download system_of_PDE.mw
Sometimes its easier when doing math in maple input mode to use first the 2d maple input mode and convert this to maple input
Is there a hotkey assigned in Maple to do this toggling from 1d input to 2d input ( also from 1d output to 2d output  )
Now it must be done by mouse
In relation with the following code and its respective output:
I want get an output in wicht left side of equalitys be expressed in radical terms and not in terms of trigonometric expressions. I tried convert(expr, radical), but the result is not that I want. Could someone help me please? Also I want to know if exists a method to avoid hardcoding list of the forloop other than [seq(i, i = 1..5)];
Greetings;
Lic. Marcus Vinicio Mora Salas;
Chemist;
postgraduate student in University of Costa Rica
Do someone tell me how can I solve this exersise using a created procedure? Also I would like to know if using a procedure is useful and if in that form code lines will be reduce. If procedures are not useful. What is the best aproach?
Here the exercise and the code:
Before to begin to learn Maple, I used to do math with python. I usually built function and classes in order to reduce code lines and to generalize the problem, but I don't know if this aproach is useful with Maple. In fact, I have another question. Is it possible to write in a document some codeblocks using Maple and another using python? If answer is yes, how can I do it?
Greetings;
Chemist
Hi MaplePrimes team,
Is there a generalized way to fill an extremely CONCAVE closed 3d parametric plane curve in Maple with spacecurve command (NO implicitplot3d), preferably without doing any multi-decomposition or creating a particular skeleton, or algorithm/programming?
Here my example:
#Circle of reference
R0 := 1:
C0 := t-> < cos(t), sin(t), 0 >:
#Variable radius
R := t-> R0*(1 + 1/2*sin(t)):
#Variable phase
Dt := t-> Pi/2*sin(2*t):
#CONCAVE Curve
C := t-> R(t)*C0(t - Dt(t)):
'C(t)' = C(t);
#Range
t1, t2 := 0, 2*Pi:
#Plot
GC := spacecurve(C(t), t = t1..t2, color = "Red", thickness = 3
, linestyle = solid
, scaling = constrained, axes = frame, orientation = [50,40,0]):
GC;
We know how to do it easily for any convex 3d plane curve (circle, ellipse, regular polygon, etc ...).
We also know how to do it for 2d curve with the Maple’s plot option filled = true but obviously not in 3d.
Thank you for your time.
Best.
Guy.
Hello, I am new with Maple. I am using because I am taking a course in my college where I need it. I have the following problem: How it can be seen in image, code is not been adecuatelly executed, because I need numerical values at output. I think this problem is because a configuration issue, but I am not sure.
How can I restore default configuration in order to try a solution for this issue?
I have defined a function II1norm of one variable. The variable has units "microns". It plots perfecting using a range defined in microns, but gives an error when I try to find the root using NextZero. If I just leave off the "microns" in the second argument, NextRoot just reports "FAIL". If I rewite the worksheet without units, then the NextZero executes fine. Why? How to I use units when finding roots?
I need to calculate the eigenvalues and eigenvectors of a big marix with enough Digits. When i apply the command Eigenvectors(K,M) for this purpose, it takes approximately 40 min to be calculated by maple. Where only 1/4 of cores of my CPU is used in this computation.
How is it possible to use all of my CPU cores to calculate the eigenvalues and eigenvectors of a big matrix faster?
change the txt to m for the following files.
K.txt
M.txt
This is so useful to see geometrical mapping diagram to visualize Complex analysis
Something that also can be made for Maple
Mapping Diagram for Cauchy Integral Formula – GeoGebra
Using GeoGebra for visualizing complex variable. (google.com)
I highly encourage everyone interested in complex variable to read Tristan Needham „Visual Complex Analysis” and try to solve problems with or without aid of GeoGebra. I hope that in this workshop we will manage to get a feeling of complex functions and as a final point understand how complex integration works. It is a common misconception that complex integration can't be visualized, and using Tristan Needham's ideas we will try to explore this idea. It's a pity that we don't have a lot of time, thus we will skip a lot of important information and construct only some graphs.
There is so much experimenting with Geogebra software and doing too this in Maple ?
  How do you transform vector expression (*) into [M,A] – 3[M,B] = 7[M,C] using Maple command?
  Thank you for your help !
How to find the eigenvalues and eigenvectors of a problem that have some zero diagonal elements which dont have the usual form of the standard eigenvalue problem? I have tested some ways, but the results was not accurate enough.
If it is possible please provide me an example with relatively large matrices (e.g. M>50)
Note that M>N.
Hello there,
Would you allow me to ask one question?
Is there any way to get a saturated water vapor pressure value with a temperature outside of the range?
The range here means [273.06 K, 647.096 K]. The pressure value certainly exists (T<273.06 K), but the API only comes up with an error.
Here is the Maple worksheet where I got into this issue:
with(ThermophysicalData):
with(CoolProp):
with(Units[Standard]):
with(ScientificConstants):
T2 := (-40.0 + 273.15) * Unit('K');
233.15*Units:-Unit(K)
xbb := 1: # 100% steam, saturated.
Pg2 := PropsSI("P", "T", T2, "Q", xbb, "water");
Error, (in ThermophysicalData:-CoolProp:-PropsSI) Temperature to QT_flash [233.15 K] must be in range [273.06 K, 647.096 K] : PropsSI("P","T",233.15,"Q",1,"water")
Download Q20220111.mw
First 379 380 381 382 383 384 385 Last Page 381 of 2458
