I must program exc set 3 task 2(i) and 2(ii)
Perhaps too much asked here on the mapleprime forum to come up with the solutions for this programming task ?
I did already some investigation how the code roughly works
Its a graphical programming task to let show the tread-riser outlines for a right -hand rule and mid-pointrule in a graph
exc_set_3_task_1_a_b.mw
blz_61_exc_set_3.pdf
blz_62.pdf
This is my code:
NEUZMinus:= proc(Unten, Oben, f,G,Liste,n)::real;
  #Unten:= Untere Intervallgrenze; Oben:= Obere Intervallgrenze; f:= zu integrierende Funktion;
  #G:= Gewicht; n:= Hinzuzufügende Knoten;
  local i;
  with(LinearAlgebra);
  with(ListTools);
  Basenwechsel:=proc(Dividend, m);
  print(Anfang,Dividend,p[m]);
  Koeffizient:=quo(Dividend, p[m],x);
  Rest:=rem(Dividend, p[m],x);
  if m=0 then
    Basenwechsel:=[Koeffizient];
    Basenwechsel:=[Koeffizient,op(Basenwechsel(Rest,m-1))];
p[-1]:=0;
p[0]:=1;
for i from 1 to (numelems(Liste)+n)*2 do
  p[i]:=(x^i-add(int(x^i*p[j]*diff(G,x),x=Unten..Oben)*p[j]/int(p[j]^2*diff(G,x),x=Unten..Oben),j=0..i-1));
  print(p[i]);
c[i-1]:=coeff(p[i],x,i)/coeff(p[i-1],x,i-1);
d[i-1]:=(coeff(p[i],x,(i-1))-coeff(p[i-1],x,(i-2)))/coeff(p[i-1],x,(i-1));
if i <> 1 then
  e[i-1]:=coeff(p[i]-(c[i-1]*x+d[i-1])*p[i-1],x,i-2)/coeff(p[i-2],x,i-2);
  e[i-1]:=0;
print(Liste[1],numelems(Liste));
Hn:=mul(x-Liste[i],i=1..numelems(Liste));
print(Hn);
 Koeffizienten:=Reverse(Basenwechsel(Hn,n)); #!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
print(Koeffizienten,HIER);
print(c,d,e);
a[0][0]:=1;
a[1][0]:=x;
a[1][1]:=-e[1]*c[0]/c[1]+(d[0]-d[1]*c[0]/c[1])*x+c[0]/c[1]*x^2;
for s from 2 to numelems(Liste)+n do
  a[s][0]:=x^s;
  a[s][1]:=-e[s]*c[0]/c[s]*x^(s-1)+(d[0]-d[s]*c[0]/c[s])*x^s+c[0]/c[s]*x^(s+1);
    print (coeff(a[s][1],x,s),as1s);
  for j from 2 to s do
      print(c[j-1]*sum(coeff(a[s][j-1],x,k-1)/c[k-1]*x^k,k=abs(s-j)+2..s+j));  print(sum((d[j-1]-c[j-1]*d[k]/c[k])*coeff(a[s][j-1],x,k)*x^k,k=abs(s-j)+1..s+j-1));  print(c[j-1]*sum(e[k+1]*coeff(a[s][j-1],x,k+1)/c[k+1]*x^k,k=abs(s-j)..s+j-2));print(e[j-1]*sum(coeff(a[s][j-2],x,k)*x^k,k=s-j+2..s+j-2));
     a[s][j]:=c[j-1]*sum(coeff(a[s][j-1],x,k-1)/c[k-1]*x^k,k=abs(s-j)+2..s+j)+sum((d[j-1]-c[j-1]*d[k]/c[k])*coeff(a[s][j-1],x,k)*x^k,k=abs(s-j)+1..s+j-1)-c[j-1]*sum(e[k+1]*coeff(a[s][j-1],x,k+1)/c[k+1]*x^k,k=abs(s-j)..s+j-2)+e[j-1]*sum(coeff(a[s][j-2],x,k)*x^k,k=abs(s-j)+2..s+j-2);
for s from 0 to numelems(Liste)-1 do
  for j from 0 to s do
    print(a[s][j], Polynom[s][j]);
M:=Matrix(n,n);
V:=Vector(n);
  for s from 0 to n-1 do
      M(s+1,j+1):=sum(coeff(a[s][j],x,k)*Koeffizienten[k+1],k=0..n);
      if s<>j then
        M(j+1,s+1):=M(s+1,j+1);
      print(M,1);
    print(testb1);print(coeff(a[n][s],x,2));print(Koeffizienten[3]);print(testb2);
    V(s+1):=-sum(coeff(a[n][s],x,k)*Koeffizienten[k+1],k=0..n);
    print(M,V);
print(M,V);
K:=LinearSolve(M,V);
K(n+1):=1;
print(K);
print(test2,coeff(a[max(3,2)][min(1,2)],x,2));
for l from 0 to n do
  for m from 0 to numelems(Liste)do
    print(Koeffizienten[m+1]*coeff(a[7][l],x,m),a[7][l],m,Koeff,Koeffizienten[m+1])
  print(K(l+1)*add(Koeffizienten[m+1]*coeff(a[max(k,l)][min(k,l)],x,m),m=0..numelems(Liste)));
    nNeu:=add(p[k]*add(K(l+1)*add(Koeffizienten[m+1]*coeff(a[max(k,l)][min(k,l)],x,m),m=0..numelems(Liste)),l=0..n),k=numelems(Liste)..numelems(Liste)+n);
fsolve(nNeu);
Em:=add(p[i]*K[i+1],i=0..n);
Hnm:=Hn*Em;
KnotenHnm:=fsolve(Hnm);
print(Hn,alt,Em,neu,Hnm);
print(Testergebnis,nNeu);
print(fsolve(Hnm),fsolve(nNeu));
KoeffizientenHnm:=Reverse(Basenwechsel(Hnm,n+numelems(Liste)));  #!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
print(KoeffizientenHnm);
h0:=int(diff(G,x),x=Unten..Oben);
b[n+numelems(Liste)+2]:=0;
b[n+numelems(Liste)+1]:=0;
  for i from 1 to n+numelems(Liste) do
    for j from n+numelems(Liste) by -1 to 1 do
      print(test21);
      b[j]:=KoeffizientenHnm[j]+(d[j]+KnotenHnm[i]*c[j])*b[j+1]+e[j+1]*b[j+2];
  print(test22);
    print(test23);
    gxi:=quo(Hnm,x-KnotenHnm[i],x);
   print(test24);
    Gewichte[i]:=c[1]*b[2]*h0/gxi(i);
    Delta[i]:=c[1]*b[2];
print(KnotenHnm);
print(Gewichte);
sum(Knoten[k]*Gewichte[k],k=1..n+numelems(Liste));
end proc
With the first use of the subprocedure Basenwechsel, everything works fine. With the input
NEUZMinus(-1,1,x,x,[-sqrt(3/5),0,sqrt(3/5)],4)
I get the result [0,0,0,1,0] correctly.
The following time I use it, the polynomial is different, and m is 7 in that case, so the list should have 8 entries, it just returns the same [0,0,0,1,0] again, however. Changing the polynomial in the first application to say 5*Hn results in [0,0,0,5,0] in both cases again. The procedure seems to have saved the old values and never overwrites them. How can I fix this? I have highlighted the use of the procedure with exclamation marks.
Thank you in advance!
P.S.: The lengthy result is this:
                               x
                              2   1
                             x  - -
                             3   3
                            x  - - x
                                 5
                          4   3    6  2
                         x  + -- - - x
                              35   7
                        5   5      10  3
                       x  + -- x - -- x
                            21     9
                     6    5    5   2   15  4
                    x  - --- + -- x  - -- x
                         231   11      11
                   7   35      105  3   21  5
                  x  - --- x + --- x  - -- x
                       429     143      13
                8    7     28   2   14  4   28  6
               x  + ---- - --- x  + -- x  - -- x
                    1287   143      13      15
              9    63      84   3   126  5   36  7
             x  + ---- x - --- x  + --- x  - -- x
                  2431     221      85       17
         10    63     315   2   210  4   630  6   45  8
        x   - ----- + ---- x  - --- x  + --- x  - -- x
              46189   4199      323      323      19
         11    33      55   3   330  5   330  7   55  9
        x   - ---- x + --- x  - --- x  + --- x  - -- x
              4199     323      323      133      21
    12    33     198   2   2475  4   660  6   495  8   66  10
   x   + ----- - ---- x  + ---- x  - --- x  + --- x  - -- x
         96577   7429      7429      437      161      23
 13    429       2574   3   1287  5   1716  7   429  9   78  11
x   + ------ x - ----- x  + ---- x  - ---- x  + --- x  - -- x
      185725     37145      2185      805       115      25
     14     143      1001   2   1001  4   1001  6   1001  8
    x   - ------- + ------ x  - ---- x  + ---- x  - ---- x
          1671525   111435      6555      1035      345
         1001  10   91  12
       + ---- x   - -- x
         225        27
                           1   (1/2)
                         - - 15     , 3
                           5
               /    1   (1/2)\   /    1   (1/2)\
               |x + - 15     | x |x - - 15     |
               \    5        /   \    5        /
           /    1   (1/2)\   /    1   (1/2)\   4   3    6  2
   Anfang, |x + - 15     | x |x - - 15     |, x  + -- - - x
           \    5        /   \    5        /       35   7
                            3   3     3   3
                   Anfang, x  - - x, x  - - x
                                5         5
                                   2   1
                       Anfang, 0, x  - -
                          Anfang, 0, x
                          Anfang, 0, 1
                     [0, 0, 0, 1, 0], HIER #!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                            c, d, e
                            0, as1s
                            0, as1s
                            0, as1s
                            0, as1s
                            0, as1s
                            0, as1s
                           4   2    4
                           -- x  + x
                           15
                          - -- - -- x
                            45   35
                               1  2
                             - - x
                           9   3    5
                           -- x  + x
                           35
                        - --- x - -- x
                          175     63
                               1  3
                             - - x
                      12   2   8   4    6
                      --- x  + -- x  + x
                      175      45
                        4     8   2   25  4
                     - --- - --- x  - -- x
                       175   175      99
                          12   2   4   4
                        - --- x  - -- x
                          175      15
                           16  4    6
                           -- x  + x
                           63
                        - --- x  - -- x
                          245      99
                               1  4
                             - - x
                      16   3   40   5    7
                      --- x  + --- x  + x
                      245      231
                     64       640   3   36   5
                  - ---- x - ----- x  - --- x
                    3675     14553      143
                          64   3   4   5
                        - --- x  - -- x
                          945      15
                  64   2   16   4   72   6    8
                 ---- x  + --- x  + --- x  + x
                 3675      385      455
                64      144   2    40   4   49   6
             - ----- - ----- x  - ---- x  - --- x
               11025   13475      1001      195
                     24   4   9   6   144   2
                   - --- x  - -- x  - ---- x
                     539      35      8575
                           25  5    7
                           -- x  + x
                           99
                       - ---- x  - --- x
                         6237      143
                               1  5
                             - - x
                     400   4   20   6    8
                     ---- x  + --- x  + x
                     6237      117
                    80   2    500   4   49   6
                   4851      11583      195
                          20   4   4   6
                        - --- x  - -- x
                          297      15
                  80   3    40   5   7   7    9
                 ---- x  + ---- x  + -- x  + x
                 4851      1001      45
                64        640   3   28   5   64   7
             - ----- x - ----- x  - --- x  - --- x
               14553     63063      715      255
                     4   5   9   7    80   3
                   - -- x  - -- x  - ---- x
                     91      35      4851
           64    2    640   4   16   6   160   8    10
          ----- x  + ----- x  + --- x  + ---- x  + x
          14553      63063      455      1071
           64      128   2    80   4   224   6   81   8
        - ----- - ----- x  - ---- x  - ---- x  - --- x
          43659   49049      9009      5967      323
               640   4   16   6   16  8    1280   2
            - ----- x  - --- x  - -- x  - ------ x
              63063      405      63      305613
                          36   6    8
                          --- x  + x
                          143
                       - ---- x  - --- x
                         1573      195
                               1  6
                             - - x
                     100   5   28   7    9
                     ---- x  + --- x  + x
                     1573      165
                   1600   3   336   5   64   7
                   99099      7865      255
                          48   5   4   7
                        - --- x  - -- x
                          715      15
                1600   4   28   6   144  8    10
                ----- x  + --- x  + --- x  + x
                99099      715      935
              320   2    140   4   2352   6   81   8
           - ----- x  - ----- x  - ----- x  - --- x
             77077      14157      60775      323
                    12   6   9   8    180   4
                  - --- x  - -- x  - ----- x
                    275      35      11011
           320   3    320   5   32   7   216   9    11
          77077      33033      935      1463
       256        5120    3    1152   5    4608   7   100  9
    - ------ x - ------- x  - ------ x  - ------ x  - --- x
      231231     2081079      133705      124355      399
               64   5   256   7   16  9    25600   3
            - ---- x  - ---- x  - -- x  - ------- x
              6435      6545      63      6243237
   256    2    320    4    1280   6    800   8   100  10    12
  ------ x  + ------ x  + ------ x  + ----- x  + --- x   + x
  231231      127413      153153      24871      693
   256      64    2    32000    4    1120   6    900   8   121  10
- ------ - ----- x  - -------- x  - ------ x  - ----- x  - --- x
  693693   99099      15162147      138567      24871      483
       8000    4    160   6    600   8   25  10    8000    2
    - ------- x  - ----- x  - ----- x  - -- x   - ------- x
      3270267      18513      16093      99       7630623
                          49   7    9
                          --- x  + x
                          195
                       - ---- x  - --- x
                         9295      255
                               1  7
                             - - x
                     588   6   112  8    10
                     ---- x  + --- x  + x
                     9295      663
                   980   4    5488   6   81   8
                - ----- x  - ------ x  - --- x
                  61347      129285      323
                         196   6   4   8
                       - ---- x  - -- x
                         2925      15
               980   5   2352   7   189   9    11
              ----- x  + ----- x  + ---- x  + x
              61347      60775      1235
            2240   3    84672   5    4032   7   100  9
         - ------ x  - ------- x  - ------ x  - --- x
           552123      8690825      104975      399
                     48   7   9   9    756   5
                  - ---- x  - -- x  - ----- x
                    1105      35      46475
         2240   4    896   6    7776   8   40   10    12
        ------ x  + ----- x  + ------ x  + --- x   + x
        552123      94809      230945      273
      64    2    22400   4    127008   6   1080   8   121  10
   - ----- x  - ------- x  - -------- x  - ----- x  - --- x
     61347      9386091      15011425      29393      483
              1792   6    48   8   16  10    2240   4
           - ------ x  - ---- x  - -- x   - ------ x
             182325      1235      63       552123
  64    3    22400   5    1120   7    600   9   385   11    13
 ----- x  + ------- x  + ------ x  + ----- x  + ---- x   + x
 61347      9386091      138567      19019      2691
    256        51200    3    13440   5    2560   7    5500   9
 - ------ x - -------- x  - ------- x  - ------ x  - ------ x
   920205     84474819      6605027      323323      153387
      144  11
    - --- x
      575
      22400   5    4320   7   1000   9   25  11    56000    3
   - ------- x  - ------ x  - ----- x  - -- x   - -------- x
     9386091      508079      27027      99       54660177
  256    2     7168    4    13440   6    80000    8   100   10
 ------ x  + -------- x  + ------- x  + -------- x  + ---- x
 920205      11471889      6605027      10669659      3289
      504   12    14
    + ---- x   + x
      3575
    256       3072    2    112000    4    112000   6    8100    8
- ------- - -------- x  - --------- x  - -------- x  - ------- x
  2760615   19119815      217965891      59445243      1062347
     264   10   169  12
   - ---- x   - --- x
     7475       675
     89600    4    13440   6    21600   8   140   10   36   12
 - --------- x  - ------- x  - ------- x  - ---- x   - --- x
   149134557      6605027      2719717      3887       143
        768    2
    - ------- x
      2924207
                        1, Polynom[0][0]
                        x, Polynom[1][0]
                     1    2
                     - + x , Polynom[1][1]
                       x , Polynom[2][0]
                    4       3
                    -- x + x , Polynom[2][1]
                    15
                 4   2    4   4
                 -- x  + x  + --, Polynom[2][2]
                 21           45
             Matrix(%id = 18446745693991291350), 1
                             testb1
                             testb2
            Vector[column](%id = 18446745693991291470)
                             testb1
                             testb2
                             testb1
                              16
                              245
                             testb2
                             testb1
                             testb2
           Vector[column](%id = 18446745693991291830)
                                  9
                           test2, --
                                  35
                       0, x , 0, Koeff, 0
                           7
                       0, x , 1, Koeff, 0
                           7
                       0, x , 2, Koeff, 0
                           7
                       0, x , 3, Koeff, 1
                     49   6    8
                  0, --- x  + x , 0, Koeff, 0
                     195
                     49   6    8
                  0, --- x  + x , 1, Koeff, 0
                     195
                     49   6    8
                  0, --- x  + x , 2, Koeff, 0
                     195
                     49   6    8
                  0, --- x  + x , 3, Koeff, 1
                     195
                112  7    9   588   5
             0, --- x  + x  + ---- x , 0, Koeff, 0
                663           9295
                112  7    9   588   5
             0, --- x  + x  + ---- x , 1, Koeff, 0
                663           9295
                112  7    9   588   5
             0, --- x  + x  + ---- x , 2, Koeff, 0
                663           9295
                112  7    9   588   5
             0, --- x  + x  + ---- x , 3, Koeff, 1
                663           9295
         2352   6   189   8    10    980   4
      0, ----- x  + ---- x  + x   + ----- x , 0, Koeff, 0
         60775      1235            61347
      0, ----- x  + ---- x  + x   + ----- x , 1, Koeff, 0
         60775      1235            61347
      0, ----- x  + ---- x  + x   + ----- x , 2, Koeff, 0
         60775      1235            61347
      0, ----- x  + ---- x  + x   + ----- x , 3, Koeff, 1
         60775      1235            61347
    896   5    7776   7   40   9    11    2240   3
0, ----- x  + ------ x  + --- x  + x   + ------ x , 0, Koeff, 0
   94809      230945      273            552123
0, ----- x  + ------ x  + --- x  + x   + ------ x , 1, Koeff, 0
0, ----- x  + ------ x  + --- x  + x   + ------ x , 2, Koeff, 0
   2240    896   5    7776   7   40   9    11    2240   3
  ------, ----- x  + ------ x  + --- x  + x   + ------ x , 3,
  552123  94809      230945      273            552123
    Koeff, 1
/    1   (1/2)\   /    1   (1/2)\       155   10  2    4
|x + - 15     | x |x - - 15     |, alt, --- - -- x  + x , neu,
\    5        /   \    5        /       891   9
  /    1   (1/2)\   /    1   (1/2)\ /155   10  2    4\
  |x + - 15     | x |x - - 15     | |--- - -- x  + x |
  \    5        /   \    5        / \891   9         /
 Testergebnis,
      2459840   5    80254400        188027200   3    2240   7
   - --------- x  - ----------- x + ----------- x  + ------ x
     193795173      44766684963     19185722127      552123
-0.9604912687, -0.7745966692, -0.4342437493, 0., 0.4342437493,
  0.7745966692, 0.9604912687, -1.435338337, -0.8946894490,
  -0.5176357564, 0., 0.5176357564, 0.8946894490, 1.435338337
                        [0, 0, 0, 1, 0] #!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                             test21
Error, (in NEUZMinus) invalid subscript selector
I want to contnue the simulation from the point (time) that the event accure
how can I do it ?
Hello there,
When I tried to solve a set of equations, represented in a matrix form, Maple complained. After the matrix form was decomposed to row by row and solve was attempted, Maple became happy. I wonder if I can solve the set of equations in a matrix form.
Goal: solve this set of equations in terms of Xl12/Xl23/Xl13
X1 = 0.5 * ( Xl12 + Xl13 - Xl23 )
X2 = 0.5 * ( Xl12 + Xl23 - Xl13 )
X3 = 0.5 * ( Xl13 + Xl23 - Xl12 )
X:=<X1, X2, X3>;
Vector(3, {(1) = X1, (2) = X2, (3) = X3})
Xeq:= X = <1/2*(xl12 + xl13-xl23), 1/2*(xl12 + xl23-xl13), 1/2*(xl13 + xl23-xl12)>;
(Vector(3, {(1) = X1, (2) = X2, (3) = X3})) = (Vector(3, {(1) = (1/2)*xl12+(1/2)*xl13-(1/2)*xl23, (2) = (1/2)*xl12+(1/2)*xl23-(1/2)*xl13, (3) = (1/2)*xl13+(1/2)*xl23-(1/2)*xl12}))
solve(Xeq, {xl12, xl13, xl23});
Error, invalid input: solve expects its 1st argument, eqs, to be of type {`and`, `not`, `or`, algebraic, relation(algebraic), ({list, set})({`and`, `not`, `or`, algebraic, relation(algebraic)})}, but received (Vector(3, {(1) = X1, (2) = X2, (3) = X3})) = (Vector(3, {(1) = (1/2)*xl12+(1/2)*xl13-(1/2)*xl23, (2) = (1/2)*xl12+(1/2)*xl23-(1/2)*xl13, (3) = (1/2)*xl13+(1/2)*xl23-(1/2)*xl12}))
Did not work.
solve({X1=1/2*(xl12 + xl13-xl23), X2=1/2*(xl12 + xl23-xl13), X3=1/2*(xl13 + xl23-xl12)}, {xl12, xl13, xl23});
{xl12 = X1+X2, xl13 = X3+X1, xl23 = X2+X3}
Did work.
Download Q_20200609.mw
I want to shade the function y=x*ln(x) on the domain of (0,1].
It would seem that if a package is loaded at the "top-level" via with() and the worksheet also has a procedure definition which contains a 'uses' statement for the same package (OK, admittedly a bit redundant), the commands from the relevant package actually "go missing".
See the output from test4() in the attached.
I can't believe that this is deliberate, because when trying to 'compartmentalise' code, then a 'uses' statement in a procedure seems like a good idea. To have this fail because the "top-level" worksheet contains a with() statement loading the same package seems perverse.
Please don't post workarounds - I already know several ways to do achieve it. I'm trying to find out if this behaviour is "deliberate" or a "bug". If the latter, it has been around for a long time because I have checked all the way back to Maple 18: every version exhibits the same behaviour
  kernelopts(version);
  test1:= proc(M::Matrix)
               uses LinearAlgebra:
               return MatrixInverse(M):
  test2:= proc(M::Matrix)
               return LinearAlgebra:-MatrixInverse(M):
  test3:= proc(M::Matrix)
  test4:= proc(M::Matrix)
               uses LinearAlgebra:
  test1( Matrix( [[1,2],[3,4]]));
  test2( Matrix( [[1,2],[3,4]]));
  test3( Matrix( [[1,2],[3,4]]));
  test4( Matrix( [[1,2],[3,4]]));
`Maple 2020.0, X86 64 WINDOWS, Mar 4 2020, Build ID 1455132`
Matrix(2, 2, {(1, 1) = -2, (1, 2) = 1, (2, 1) = 3/2, (2, 2) = -1/2})
MatrixInverse(Matrix(%id = 18446744074373391174))
Download usewith.mw
Please everybody, help me to make phaseportrait 3D
f:= (ln(4x-4)/4)-(ln(4x+4)/4)+(arctan(x)/2)
When I do plots([f(x),f(x)-2,f(x)+2]), the graphs don't extend infinitely like I want. They stop just themselves. How get I the plots to extended more? I attached a picture.
it really confused, with generating different sample some times the command fsolve is working and some times don't . is there any other way to solve this system of equations. because I am going to generate 1000 samples and for each sample, I supposed to solve this system.
f[1] := VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`*`(VectorCalculus:-`+`(n_x, n_y), 1/theta1), VectorCalculus:-`-`(sum(VectorCalculus:-`*`(VectorCalculus:-`*`(VectorCalculus:-`+`(theta2, -1), x[t]), 1/VectorCalculus:-`+`(VectorCalculus:-`*`(VectorCalculus:-`*`(theta1, theta2), x[t]), 1)), t = 1 .. n_x))), VectorCalculus:-`-`(sum(VectorCalculus:-`*`(VectorCalculus:-`*`(VectorCalculus:-`+`(2, R_x[t]), x[t]), 1/VectorCalculus:-`*`(VectorCalculus:-`+`(VectorCalculus:-`*`(VectorCalculus:-`*`(theta1, theta2), x[t]), 1)^VectorCalculus:-`+`(1, VectorCalculus:-`-`(1/theta2)), VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`*`(VectorCalculus:-`*`(theta1, theta2), x[t]), 1)^(1/theta2), -1), theta3))), t = 1 .. n_x))), VectorCalculus:-`-`(sum(VectorCalculus:-`*`(VectorCalculus:-`*`(VectorCalculus:-`+`(theta2, -1), y[T]), 1/VectorCalculus:-`+`(VectorCalculus:-`*`(VectorCalculus:-`*`(theta1, theta2), y[T]), 1)), T = 1 .. n_y))), VectorCalculus:-`-`(sum(VectorCalculus:-`*`(VectorCalculus:-`*`(VectorCalculus:-`+`(2, R_y[T]), y[T]), 1/VectorCalculus:-`*`(VectorCalculus:-`+`(VectorCalculus:-`*`(VectorCalculus:-`*`(theta1, theta2), y[T]), 1)^VectorCalculus:-`+`(1, VectorCalculus:-`-`(1/theta2)), VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`*`(VectorCalculus:-`*`(theta1, theta2), y[T]), 1)^(1/theta2), -1), theta4))), T = 1 .. n_y))):
N_x := 30:
n_x := 30:
R_x := [seq(0, nl = 1 .. 30)];
[0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
`&lambda;&lambda;` := 5; -1; QQ := 1; -1; `&alpha;&alpha;1` := 2; -1; `&alpha;&alpha;2` := 4
4
W := GenerateUniform(n_x, 0, 1):
fsolve({f[1], f[2], f[3], f[4]}, {theta1 = 0 .. infinity, theta2 = 0 .. infinity, theta3 = .5 .. infinity, theta4 = .5 .. infinity})
Download ask_maple.mw
I just need someone to explain to me why the following occurs:
showstat(rand)
rand := proc(r::{posint, numeric .. numeric}, $)
   1   if nargs = 0 then
   2     RandomTools:-MersenneTwister:-GenerateInteger()
   3     try
   4       if type(r,('numeric') .. ('numeric')) then
   5         if rhs(r) < lhs(r) then
   6           error "invalid range, end points are out of order"
             elif not type(r,('integer') .. ('integer')) then
   7           return () -> RandomTools:-Generate(float(('range') = r,('method') = ('uniform')))
             end if
   8       return RandomTools:-MersenneTwister:-NewGenerator(('range') = r)
         catch :
   9       error
         end try
       end if
end proc
showstat(RandomTools:-MersenneTwister:-GenerateInteger)
RandomTools:-MersenneTwister:-GenerateInteger := proc({range::{integer, integer .. integer} := 1000000000000}, $)
local bits, divisor, offset;
   1   if nargs = 0 then
   2     return MTKernelInterface(4)
   3   if type(range,'integer') then
   4     divisor := range;
   5     offset := 0
   6     if rhs(range) < lhs(range) then
   7       error "illegal range, end points out of order"
   8     if lhs(range) = rhs(range) then
   9       return lhs(range)
  10     offset := lhs(range);
  11     divisor := rhs(range)-offset+1
  12   if divisor = 0 then
  13     return offset
  14   bits := MTKernelInterface(5,divisor);
  15   MTKernelInterface(6,divisor,bits)+offset
end proc
showstat(MTKernelInterface)
Error, (in showstat) procedure name expected
Download rand_showstat.mw
Does maple provide any method for finding the saddle point of a function? Thank you
I am trying to write maple program for Gauss Siedel method. I needed two for loop. One for running the iterative method and the other for checking where (the number of iteration required) the results converge.
Please, I need help.
Hi guys! I'm having trouble using int with a few expressions, for example:
is returning
however simpler expressions such as
int(x^2 + x, x)
or int(x/2 + 1/2, x)
are working correctly and returning
respectively. I'm using Maple 2020 in worksheet mode using Math 2D Input/Output.
Here's my screen, any help would be much appreciated thanks!
First 576 577 578 579 580 581 582 Last Page 578 of 2459
