How do I display the area between two curves? ( for example the area in sin and cos?) I tried with the option 'filled ' and 'display'
Deuxcourbes.mw
I'm using the eBookTools package to convert a .mw file as a chapter into a PDF file. However, a problem arises when I convert a document with a few repeated plotting commands (such as plot(x^2)). The issue is that in the final PDF the images of the various plots overlap, and that the individual plots can't be clearly seen. Is there a resolution to this?
Bart
I am generating gaussian distribution by decreasing standard deviation but the distribution generation is getting very slow.
GAUSSIAN.mw
A book I am reading has the following
I cannot produce this in Maple 2017. Please tell me where I go wrong. Thank
"P(t):=(r*Q[inf])/(2+2 cosh(b-r*t))"
proc (t) options operator, arrow; r*Q[inf]/(2+2*cosh(b-r*t)) end proc
"Q(t):=(∫)[0]^(t)P(t) ⅆt"
proc (t) options operator, arrow; int(P(t), t = 0 .. t) end proc
Download Hubbert.mw
the following maple code is to solve the SYS of ODE x',y',z'
then plot z' agianst t
i got confused each plot give me zero
N:=1:M:=sqrt(N*(N+1)):N1:=1+N:w:=10:f:=1;
                             f := 1
ini1:= x(0)=0.5,y(0)=0.5,z(0)=0;
            ini1 := x(0) = 0.5, y(0) = 0.5, z(0) = 0
var:={x(t),y(t),z(t)}:
dsys:={diff(z(t),t)=-(N1+M*cos(2*w*t))*z(t)-1+f*(x(t)+y(t)), diff(x(t),t)=-(N1-I*w-2*M*exp(-2*I*w*t))*x(t)-f*(N1+(z(t)))-2*f*M*exp(2*I*w*t),diff(y(t),t)=-(N1+I*w-2*M*exp(2*I*w*t))*y(t)-f*(N1+(z(t)))-2*f*M*exp(-2*I*w*t)}:
zd:=diff(z(t),t);
                                d
                         zd := --- z(t)
                                dt
res:=dsolve(dsys union {x(0)=0.5,y(0)=0.5,z(0)=0},numeric,output=listprocedure):
tit:=sprintf("F=%g,N=%g",f,N):
P1:=plots[odeplot](res,[[t,(zd)]],0..6,axes=boxed,titlefont=[SYMBOL,14],font=[1,1,18],color=blue,linestyle=1,tickmarks=[3, 4],font=[1,1,14],thickness=2,titlefont=[SYMBOL,12]);
I'm trying to plot a graph of cos(2*theta)*omega*t+2*(sin(theta))^2*sin(omega*t)=0 in Maple (For values of theta between 40 and 88 degrees roughly, with a fixed value of omega). I have substituted x=omega*t and tried to solve, but as I'm sure you can tell it is not outputting the graph I'm after, I was hoping somebody would be able to tell me where I am going wrong. Thanks.
v := 145000;
thetavn := (1/6)*Pi;
omegac := .1;
s := cos(2*thetabn)*x+2*sin(thetabn)^2*sin(x);
plots:-implicitplot(s = 0, thetabn = 43*Pi*(1/180) .. 88*Pi*(1/180), x = -200 .. 200, tickmarks = ["piticks", "decimalticks"], gridrefine = 4, size = [800, 600]);
When generating gaussian distribution I am getting the following error. Please help. Thank you
GAUSSIAN.mw
Is package SumTools supposed to be a superset of the sum command in Maple? Or is it supposed to be a complementary to it? When should one use SumTools vs. sum?
The help on SumTools says
The SumTools package contains commands that help find closed forms of definite and indefinite sums. The package consists of three commands and three subpackages.
But does not make it clear when to use it vs. sum or what is its relation to sum command.
I am asking because on one example, sum is able to give an answer, while SumTools can't. I have expected the other way, where if sum failed, then one will try SumTools.
sum(1/n*sin(n*x),n=1..infinity) assuming 0<x,x<Pi
SumTools:-IndefiniteSummation(1/n*sin(n*x),n=1..infinity) assuming 0<x, x<Pi
I am trying to solve CVRPSD by integer L shape method. I have some problems.
d=(0, 20,20,25,15,10): Demand
p=(1,1,1/3,1/2,1/4): the probability demand
K=50
1) How to write properly Recourse Policy (Q) in maple (I attached my problem) ? Recourse (Penalty cost) is applied when the demand exceed the vehicle capacity. We know that in CVRPSD, we don't know the demand until vehicle arrive at the node(customer).
(Look at my program)
Hopefully anybody could help me to solve this.
Thank you any way.
Exact_CVRPSD.mw
Hi everyone:
I want to calculate the value of eval(diff(y, x), x = 0.418e-1)-eval(diff(y, x), x = 0.1e-1), how?
y := (1-Heaviside(x-0.10e-1))*(cos(9.0218219*x)-.99533285*sin(9.0218219*x)-.99999991*cosh(9.0218219*x)+.99533285*sinh(9.0218219*x))+(Heaviside(x-0.10e-1)-Heaviside(x-0.418e-1))*(.24369100*cos(7.7520047*x)-.36109859*sin(7.7520047*x)-.23739778*cosh(7.7520047*x)+.19615343*sinh(7.7520047*x))+Heaviside(x-0.418e-1)*(.95680995*cos(9.0218219*x)-.80884870*sin(9.0218219*x)-1.0381918*cosh(9.0218219*x)+1.1704059*sinh(9.0218219*x))
with regards...
Hi there
Can anyone explain the following calculation error? (The task seems quite simple.)
Original - very unintuitive calculation error:
Vector(3, {(1) = 20.09230769, (2) = 32.43076923, (3) = 15.26153846}) = Vector[column](%id = 18446746432715486622)NULL
In 1D math it works:
Vector[column](3, [1306./65, 2108./65, 992./65]);
Approximate works:
Vector(3, {(1) = 1306/65, (2) = 2108/65, (3) = 992/65})"(->)"Vector[column](%id = 18446746432750076862)
Multiplying by 1. works:
Vector(3, {(1) = 20.09230769, (2) = 32.43076923, (3) = 15.26153846}) = Vector[column](%id = 18446746432750171550)NULL
Download Maple_-_vector_of_fractions_with_floats.mw
Kind regards,
Jens Jacob Thomsen
how to submit maple job through command line. Thank you.
This should be simple but I am missing something. I want to sum the product of combinations of numbers.
I know I can assign values to a0...a[n-1]. But that isn't nice.
(n,k):= (5,4);
add(mul~(combinat:-choose([a(||)[](0..n-1)], k))) ; =a0*a1*a2*a3+a0*a1*a2*a4+a0*a1*a3*a4+a0*a2*a3*a4+a1*a2*a3*a4  which is correct.
add(mul~(combinat:-choose([(0..n-1)], k))) ;   #should be 24 but I get 0
How I can remove this error.
also, i want to find answer via fsolve.
Error, (in fsolve) too many levels of recursion.
test.mw
Ok I am still not further... Lets assume wie have F_q with q=3^2 and the irreducible polynomial T^2+2T+2...
Be tau the alsias(tau=RootOf(T^2+2T+2));
Then I get in Maple the wrong (??) calculation
(tau+1)(2tau+2)= tau+1 \neq 1, which is supposed to be the right answer: =2tau^2+4tau+2=2(tau^2+2tau+2)-2=0-2=1 because our prime number is 3... WHY does Maple not calculate that stuff correctly??
Another problem:
Be f:= x^2+tau*x;
When I enter Rem(x^q,f,x) mod 3 then Maple returns x, whereas I calculate (tau+1)x...
Where is the mistake?
I build my finite field either via firred := T^2+2*T+2; alias(tau = RootOf(firred))
or
G := GF(3, 2); a := G:-extension; aOut := G:-ConvertOut(a); alias(tau = RootOf(aOut))
But both times the calculations are not correct... I dont know why?
Please, can somebody help?
First 756 757 758 759 760 761 762 Last Page 758 of 2459
