i want to generate grid for a C_D nozzle but i dont know ho to plot it. please help me how to plot.
alpha := 0;
beta := 2;
Imax := 11;
Jmax := 11;
L := 10;
`Δζ` := L/(Imax-1);
`Δx` := `Δζ`;
`Δη` := 1/(Jmax-1);
printlevel := 2;
for i to Imax do for j to Jmax do x[i] := `Δζ`*(i-1); eta[j] := `Δη`*(j-1); z := (eta[j]-alpha)*ln((beta+1)/(beta-1))/(1-alpha); H[i] := 3+2*tanh(x[i]-6); H1[i] := 0; H2[i] := -H[i]; y[i, j] := -H[i]*(2*beta/(exp(z)+1)-beta-2*alpha)/(2*alpha+1); Y[i, j] := (H1[i]+(-H1[i]*x[i]+H2[i])/L)*eta[j] end do end do;
If I have an expression like this
f:=ln((1-x)^2*(x+1)^2/((-I*x-I+sqrt(-x^2+1))^2*(I*x+I+sqrt(-x^2+1))^2))
maple has trouble to simplify the argument.
In particular is it possible to apply expand() only to the denominator?
This is meant in general, so if I have many terms with expressions like this (possibly of products with other functions in each term), I want this simplification to be done termwise for the arguments of the functions.
Expanding the fraction doesn't work as in frontend(expand, [f]).
I am looking to test ANOVA ( Two Way).Maple does not directly gives this possibility.I found a procedure from Mr Tannis but i can t run it? Some ideas?
ThanksANOVA2.mw
This is not a problem per se, but more to understand the background.
f := polylog(2, -x);
int(f/(x+1), x);
convert(f, dilog);
int(%/(x+1), x)
The integration of the polylog maple is not capable of doing, but after converting to dilog it finds an anti derivative.
That leads to the question, why is dilog as a separate to polylog(2,*) implemented anyway? Why couldn't it all be done with the more general polylog function?
I'm also wondering why maple has difficulties to integrate
int(dilog(x+1)/(x+a),x)
for general a.
How would I go about getting true or false returned on these propositions?
I have tried just about every eval and various syntax methods, but nothing has worked so far.
I know most can easilly be done by hand/thinking, but I'm sure Maple should have a way to do this as well.
∀n∈Z:2n>n+2   ,   ∃n∈Z:2|(3n+1)    ,   ∃k∈Z:∀n∈Z:n=kn   ,   ∃k∈Z:∀n∈Z:2|(n+k)   ,   ∀n∈Z:∀k∈Z:(n>k∨k≥n)
Using Maple 2018.2.1, I'm receiving a lost kernel message when importing the attached data file with ImportMatrix. I traced the issue to a "*" symbol at the end of the file but would have expected this to cause an error message (if any error at all) instead of the connection to the kernel to be lost. Is this a bug or am I misunderstanding the usage of ImportMatrix?
test.mw
test2.txt
How we can obtain inversion of the high-dimensional matrix (for example 600*600) in maple?
(A fast-time command)
i want someone hlep me in this worksheet the diff eq of complex i want to sovle it with any numeric method
with(Physics):
with(IntegrationTools):
v := 1;
.1
.5
.5
M[1] := Int(-Physics:-`*`(Physics:-`*`(Physics:-`*`(2, I), exp(-Physics:-`*`(Physics:-`*`(Physics:-`*`(.5, I), v), tt))), 1/Physics:-`*`(Physics:-`*`(sqrt(b^2+tt^2), v^2), exp(sqrt(b^2+tt^2))))+Physics:-`*`(Physics:-`*`(Physics:-`*`(2, I), exp(Physics:-`*`(Physics:-`*`(Physics:-`*`(.5, I), v), tt))), 1/Physics:-`*`(Physics:-`*`(sqrt(b^2+tt^2), v^2), exp(sqrt(b^2+tt^2)))), tt = -500 .. z)
Int(-(2*I)*exp(-(.5*I)*tt)/((0.1e-1+tt^2)^(1/2)*exp((0.1e-1+tt^2)^(1/2)))+(2*I)*exp((.5*I)*tt)/((0.1e-1+tt^2)^(1/2)*exp((0.1e-1+tt^2)^(1/2))), tt = -500 .. z)
M[2] := Int(Physics:-`*`(Physics:-`*`(Physics:-`*`(Physics:-`*`(4, I), tt), exp(-Physics:-`*`(Physics:-`*`(Physics:-`*`(.5, I), v), tt))), 1/Physics:-`*`(Physics:-`*`(sqrt(b^2+tt^2), v^2), exp(sqrt(b^2+tt^2))))-Physics:-`*`(Physics:-`*`(Physics:-`*`(Physics:-`*`(4, I), tt), exp(Physics:-`*`(Physics:-`*`(Physics:-`*`(.5, I), v), tt))), 1/Physics:-`*`(Physics:-`*`(sqrt(b^2+tt^2), v^2), exp(sqrt(b^2+tt^2)))), tt = -500 .. z):
M[3] := Int(-Physics:-`*`(Physics:-`*`(Physics:-`*`(Physics:-`*`(2, I), tt^2), exp(-Physics:-`*`(Physics:-`*`(Physics:-`*`(.5, I), v), tt))), 1/Physics:-`*`(Physics:-`*`(sqrt(b^2+tt^2), v^2), exp(sqrt(b^2+tt^2))))+Physics:-`*`(Physics:-`*`(Physics:-`*`(Physics:-`*`(2, I), tt^2), exp(Physics:-`*`(Physics:-`*`(Physics:-`*`(.5, I), v), tt))), 1/Physics:-`*`(Physics:-`*`(sqrt(b^2+tt^2), v^2), exp(sqrt(b^2+tt^2)))), tt = -500 .. z):
M[4] := Int(-Physics:-`*`(Physics:-`*`(2, exp(-Physics:-`*`(Physics:-`*`(Physics:-`*`(.5, I), v), tt))), 1/Physics:-`*`(v, exp(sqrt(b^2+tt^2))))-Physics:-`*`(Physics:-`*`(2, exp(Physics:-`*`(Physics:-`*`(Physics:-`*`(.5, I), v), tt))), 1/Physics:-`*`(v, exp(sqrt(b^2+tt^2))))+Physics:-`*`(Physics:-`*`(Physics:-`*`(2, tt), exp(-Physics:-`*`(Physics:-`*`(Physics:-`*`(.5, I), v), tt))), 1/Physics:-`*`(v, exp(sqrt(b^2+tt^2))))+Physics:-`*`(Physics:-`*`(Physics:-`*`(2, tt), exp(Physics:-`*`(Physics:-`*`(Physics:-`*`(.5, I), v), tt))), 1/Physics:-`*`(v, exp(sqrt(b^2+tt^2)))), tt = -500 .. z):
M := Physics:-`*`(z^2, M[1])+Physics:-`*`(z, M[2])+Physics:-`*`(z, M[3])+M[4]:
Mc[1] := Physics:-`*`(z^2, Int(-Physics:-`*`(Physics:-`*`(Physics:-`*`(2, I), exp(-Physics:-`*`(Physics:-`*`(Physics:-`*`(.5, I), v), tt))), 1/Physics:-`*`(Physics:-`*`(sqrt(b^2+tt^2), v^2), exp(sqrt(b^2+tt^2))))+Physics:-`*`(Physics:-`*`(Physics:-`*`(2, I), exp(Physics:-`*`(Physics:-`*`(Physics:-`*`(.5, I), v), tt))), 1/Physics:-`*`(Physics:-`*`(sqrt(b^2+tt^2), v^2), exp(sqrt(b^2+tt^2)))), tt = -500 .. z)):
Mc[2] := Physics:-`*`(z, Int(Physics:-`*`(Physics:-`*`(Physics:-`*`(Physics:-`*`(4, I), tt), exp(-Physics:-`*`(Physics:-`*`(Physics:-`*`(.5, I), v), tt))), 1/Physics:-`*`(Physics:-`*`(sqrt(b^2+tt^2), v^2), exp(sqrt(b^2+tt^2))))-Physics:-`*`(Physics:-`*`(Physics:-`*`(Physics:-`*`(4, I), tt), exp(Physics:-`*`(Physics:-`*`(Physics:-`*`(.5, I), v), tt))), 1/Physics:-`*`(Physics:-`*`(sqrt(b^2+tt^2), v^2), exp(sqrt(b^2+tt^2)))), tt = -500 .. z)):
Mc[3] := Physics:-`*`(z, Int(-Physics:-`*`(Physics:-`*`(2, exp(-Physics:-`*`(Physics:-`*`(Physics:-`*`(.5, I), v), tt))), 1/Physics:-`*`(v, exp(sqrt(b^2+tt^2))))-Physics:-`*`(Physics:-`*`(2, exp(Physics:-`*`(Physics:-`*`(Physics:-`*`(.5, I), v), tt))), 1/Physics:-`*`(v, exp(sqrt(b^2+tt^2)))), tt = -500 .. z)):
Mc[4] := Int(-Physics:-`*`(Physics:-`*`(Physics:-`*`(Physics:-`*`(2, I), tt^2), exp(-Physics:-`*`(Physics:-`*`(Physics:-`*`(.5, I), v), tt))), 1/Physics:-`*`(Physics:-`*`(sqrt(b^2+tt^2), v^2), exp(sqrt(b^2+tt^2))))+Physics:-`*`(Physics:-`*`(Physics:-`*`(Physics:-`*`(2, I), tt^2), exp(Physics:-`*`(Physics:-`*`(Physics:-`*`(.5, I), v), tt))), 1/Physics:-`*`(Physics:-`*`(sqrt(b^2+tt^2), v^2), exp(sqrt(b^2+tt^2))))+Physics:-`*`(Physics:-`*`(Physics:-`*`(2, tt), exp(-Physics:-`*`(Physics:-`*`(Physics:-`*`(.5, I), v), tt))), 1/Physics:-`*`(v, exp(sqrt(b^2+tt^2))))+Physics:-`*`(Physics:-`*`(Physics:-`*`(2, tt), exp(Physics:-`*`(Physics:-`*`(Physics:-`*`(.5, I), v), tt))), 1/Physics:-`*`(v, exp(sqrt(b^2+tt^2)))), tt = -500 .. z):
Mc := Mc[1]+Mc[2]+Mc[3]+Mc[4]:
N[1] := Int(Physics:-`*`(Physics:-`*`(Physics:-`*`(2, tt), exp(-Physics:-`*`(Physics:-`*`(Physics:-`*`(.5, I), v), tt))), 1/Physics:-`*`(Physics:-`*`(sqrt(b^2+tt^2), v), exp(sqrt(b^2+tt^2))))-Physics:-`*`(Physics:-`*`(Physics:-`*`(2, tt), exp(Physics:-`*`(Physics:-`*`(Physics:-`*`(.5, I), v), tt))), 1/Physics:-`*`(Physics:-`*`(sqrt(b^2+tt^2), v), exp(sqrt(b^2+tt^2))))+Physics:-`*`(Physics:-`*`(Physics:-`*`(2, I), exp(-Physics:-`*`(Physics:-`*`(Physics:-`*`(.5, I), v), tt))), 1/exp(sqrt(b^2+tt^2))), tt = -500 .. z):
N[2] := Physics:-`*`(z, Int(-Physics:-`*`(Physics:-`*`(2, exp(-Physics:-`*`(Physics:-`*`(Physics:-`*`(.5, I), v), tt))), 1/Physics:-`*`(Physics:-`*`(sqrt(b^2+tt^2), v), exp(sqrt(b^2+tt^2))))+Physics:-`*`(Physics:-`*`(2, exp(Physics:-`*`(Physics:-`*`(Physics:-`*`(.5, I), v), tt))), 1/Physics:-`*`(Physics:-`*`(sqrt(b^2+tt^2), v), exp(sqrt(b^2+tt^2)))), tt = -500 .. z)):
N := N[1]+N[2]:
Nc[1] := Int(-Physics:-`*`(Physics:-`*`(Physics:-`*`(2., tt), exp(Physics:-`*`(Physics:-`*`(Physics:-`*`(.5, I), v), tt))), 1/Physics:-`*`(Physics:-`*`(sqrt(b^2+tt^2), v), exp(sqrt(b^2+tt^2))))+Physics:-`*`(Physics:-`*`(Physics:-`*`(2., tt), exp(-Physics:-`*`(Physics:-`*`(Physics:-`*`(.5, I), v), tt))), 1/Physics:-`*`(Physics:-`*`(sqrt(b^2+tt^2), v), exp(sqrt(b^2+tt^2))))-Physics:-`*`(Physics:-`*`(Physics:-`*`(2., I), exp(-Physics:-`*`(Physics:-`*`(Physics:-`*`(.5, I), v), tt))), 1/exp(sqrt(b^2+tt^2))), tt = -500 .. z):
Nc[2] := Physics:-`*`(z, Int(Physics:-`*`(Physics:-`*`(2., exp(Physics:-`*`(Physics:-`*`(Physics:-`*`(.5, I), v), tt))), 1/Physics:-`*`(Physics:-`*`(sqrt(b^2+tt^2), v), exp(sqrt(b^2+tt^2))))-Physics:-`*`(Physics:-`*`(2., exp(-Physics:-`*`(Physics:-`*`(Physics:-`*`(.5, I), v), tt))), 1/Physics:-`*`(Physics:-`*`(sqrt(b^2+tt^2), v), exp(sqrt(b^2+tt^2)))), tt = -500 .. z)):
Nc := Nc[1]+Nc[2]:
V := Physics:-`*`(Physics:-`*`(1/Physics:-`*`(4, Pi^2), 1/sqrt(b^2+z^2)), Physics:-`*`(exp(-Physics:-`*`(2, sqrt(b^2+z^2))), Physics:-`*`(2, sqrt(b^2+z^2))+2)-2):
Vc := Physics:-`*`(Physics:-`*`(Physics:-`*`(-1, 1/Physics:-`*`(4, Pi^2)), 1/sqrt(b^2+z^2)), Physics:-`*`(exp(-Physics:-`*`(2, sqrt(b^2+z^2))), Physics:-`*`(2, sqrt(b^2+z^2))+2)-2):
H := proc (z) local t; if not z::numeric then return ('procname')(args) end if; evalf(-I*(z^2*(Int(-(2*I)*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int((4*I)*tt*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))-(4*I)*tt*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int(-2*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))-2*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+Int(-(2*I)*tt^2*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*tt^2*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+2*tt*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))+2*tt*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2))), tt = -500 .. z))*(-1/2+(1/2)*p^2*v^2+1/sqrt(b^2+z^2)+(1/4)*(exp(-2*sqrt(b^2+z^2))*(2*sqrt(b^2+z^2)+2)-2)/(Pi^2*sqrt(b^2+z^2)))/(((z^2*(Int(-(2*I)*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int((4*I)*tt*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))-(4*I)*tt*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int(-(2*I)*tt^2*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*tt^2*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+Int(-2*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))-2*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))+2*tt*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))+2*tt*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2))), tt = -500 .. z))*(z^2*(Int(-(2*I)*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int((4*I)*tt*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))-(4*I)*tt*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int(-2*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))-2*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+Int(-(2*I)*tt^2*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*tt^2*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+2*tt*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))+2*tt*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2))), tt = -500 .. z))-1)*v)+I*((-1/2+(1/2)*p^2*v^2+1/sqrt(b^2+z^2))*(z^2*(Int(-(2*I)*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int((4*I)*tt*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))-(4*I)*tt*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int(-2*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))-2*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+Int(-(2*I)*tt^2*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*tt^2*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+2*tt*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))+2*tt*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+Int((-1)*2.*tt*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v*exp(sqrt(b^2+tt^2)))+2.*tt*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v*exp(sqrt(b^2+tt^2)))+(-1)*2.*I*exp((-1)*.5*I*v*tt)/exp(sqrt(b^2+tt^2)), tt = -500 .. z)+z*(Int(2.*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v*exp(sqrt(b^2+tt^2)))+(-1)*2.*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v*exp(sqrt(b^2+tt^2))), tt = -500 .. z)))/(((z^2*(Int(-(2*I)*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int((4*I)*tt*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))-(4*I)*tt*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int(-(2*I)*tt^2*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*tt^2*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+Int(-2*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))-2*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))+2*tt*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))+2*tt*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2))), tt = -500 .. z))*(z^2*(Int(-(2*I)*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int((4*I)*tt*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))-(4*I)*tt*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int(-2*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))-2*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+Int(-(2*I)*tt^2*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*tt^2*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+2*tt*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))+2*tt*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2))), tt = -500 .. z))-1)*v)) end proc:
H(500)
-6.287499768+0.1713975e-19*I
L := proc (z) local t; if not z::numeric then return ('procname')(args) end if; evalf(-I*(z^2*(Int(-(2*I)*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int((4*I)*tt*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))-(4*I)*tt*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int(-2*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))-2*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+Int(-(2*I)*tt^2*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*tt^2*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+2*tt*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))+2*tt*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2))), tt = -500 .. z))*((-1/2+(1/2)*q^2*v^2+1/sqrt(b^2+z^2))*(z^2*(Int(-(2*I)*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int((4*I)*tt*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))-(4*I)*tt*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int(-(2*I)*tt^2*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*tt^2*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+Int(-2*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))-2*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))+2*tt*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))+2*tt*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+Int(2*tt*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v*exp(sqrt(b^2+tt^2)))-2*tt*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v*exp(sqrt(b^2+tt^2)))+(2*I)*exp((-1)*.5*I*v*tt)/exp(sqrt(b^2+tt^2)), tt = -500 .. z)+z*(Int(-2*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v*exp(sqrt(b^2+tt^2)))+2*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v*exp(sqrt(b^2+tt^2))), tt = -500 .. z)))/(((z^2*(Int(-(2*I)*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int((4*I)*tt*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))-(4*I)*tt*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int(-(2*I)*tt^2*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*tt^2*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+Int(-2*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))-2*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))+2*tt*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))+2*tt*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2))), tt = -500 .. z))*(z^2*(Int(-(2*I)*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int((4*I)*tt*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))-(4*I)*tt*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int(-2*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))-2*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+Int(-(2*I)*tt^2*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*tt^2*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+2*tt*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))+2*tt*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2))), tt = -500 .. z))-1)*v)+I*(-1/2+(1/2)*q^2*v^2+1/sqrt(b^2+z^2)-(1/4)*(exp(-2*sqrt(b^2+z^2))*(2*sqrt(b^2+z^2)+2)-2)/(Pi^2*sqrt(b^2+z^2)))/(((z^2*(Int(-(2*I)*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int((4*I)*tt*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))-(4*I)*tt*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int(-(2*I)*tt^2*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*tt^2*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+Int(-2*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))-2*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))+2*tt*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))+2*tt*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2))), tt = -500 .. z))*(z^2*(Int(-(2*I)*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int((4*I)*tt*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))-(4*I)*tt*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int(-2*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))-2*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+Int(-(2*I)*tt^2*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*tt^2*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+2*tt*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))+2*tt*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2))), tt = -500 .. z))-1)*v)) end proc:
G := proc (z) local t; if not z::numeric then return ('procname')(args) end if; evalf(I*(-1/2+(1/2)*p^2*v^2+1/sqrt(b^2+z^2)+(1/4)*(exp(-2*sqrt(b^2+z^2))*(2*sqrt(b^2+z^2)+2)-2)/(Pi^2*sqrt(b^2+z^2)))/(((z^2*(Int(-(2*I)*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int((4*I)*tt*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))-(4*I)*tt*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int(-(2*I)*tt^2*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*tt^2*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+Int(-2*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))-2*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))+2*tt*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))+2*tt*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2))), tt = -500 .. z))*(z^2*(Int(-(2*I)*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int((4*I)*tt*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))-(4*I)*tt*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int(-2*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))-2*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+Int(-(2*I)*tt^2*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*tt^2*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+2*tt*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))+2*tt*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2))), tt = -500 .. z))-1)*v)-I*(z^2*(Int(-(2*I)*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int((4*I)*tt*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))-(4*I)*tt*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int(-(2*I)*tt^2*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*tt^2*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+Int(-2*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))-2*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))+2*tt*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))+2*tt*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2))), tt = -500 .. z))*((-1/2+(1/2)*p^2*v^2+1/sqrt(b^2+z^2))*(z^2*(Int(-(2*I)*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int((4*I)*tt*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))-(4*I)*tt*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int(-2*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))-2*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+Int(-(2*I)*tt^2*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*tt^2*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+2*tt*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))+2*tt*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+Int((-1)*2.*tt*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v*exp(sqrt(b^2+tt^2)))+2.*tt*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v*exp(sqrt(b^2+tt^2)))+(-1)*2.*I*exp((-1)*.5*I*v*tt)/exp(sqrt(b^2+tt^2)), tt = -500 .. z)+z*(Int(2.*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v*exp(sqrt(b^2+tt^2)))+(-1)*2.*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v*exp(sqrt(b^2+tt^2))), tt = -500 .. z)))/(((z^2*(Int(-(2*I)*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int((4*I)*tt*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))-(4*I)*tt*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int(-(2*I)*tt^2*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*tt^2*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+Int(-2*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))-2*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))+2*tt*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))+2*tt*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2))), tt = -500 .. z))*(z^2*(Int(-(2*I)*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int((4*I)*tt*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))-(4*I)*tt*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int(-2*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))-2*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+Int(-(2*I)*tt^2*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*tt^2*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+2*tt*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))+2*tt*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2))), tt = -500 .. z))-1)*v)) end proc:
K := proc (z) local t; if not z::numeric then return ('procname')(args) end if; evalf(I*((-1/2+(1/2)*q^2*v^2+1/sqrt(b^2+z^2))*(z^2*(Int(-(2*I)*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int((4*I)*tt*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))-(4*I)*tt*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int(-(2*I)*tt^2*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*tt^2*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+Int(-2*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))-2*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))+2*tt*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))+2*tt*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+Int(2*tt*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v*exp(sqrt(b^2+tt^2)))-2*tt*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v*exp(sqrt(b^2+tt^2)))+(2*I)*exp((-1)*.5*I*v*tt)/exp(sqrt(b^2+tt^2)), tt = -500 .. z)+z*(Int(-2*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v*exp(sqrt(b^2+tt^2)))+2*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v*exp(sqrt(b^2+tt^2))), tt = -500 .. z)))/(((z^2*(Int(-(2*I)*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int((4*I)*tt*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))-(4*I)*tt*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int(-(2*I)*tt^2*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*tt^2*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+Int(-2*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))-2*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))+2*tt*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))+2*tt*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2))), tt = -500 .. z))*(z^2*(Int(-(2*I)*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int((4*I)*tt*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))-(4*I)*tt*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int(-2*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))-2*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+Int(-(2*I)*tt^2*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*tt^2*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+2*tt*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))+2*tt*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2))), tt = -500 .. z))-1)*v)-I*(z^2*(Int(-(2*I)*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int((4*I)*tt*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))-(4*I)*tt*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int(-(2*I)*tt^2*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*tt^2*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+Int(-2*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))-2*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))+2*tt*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))+2*tt*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2))), tt = -500 .. z))*(-1/2+(1/2)*q^2*v^2+1/sqrt(b^2+z^2)-(1/4)*(exp(-2*sqrt(b^2+z^2))*(2*sqrt(b^2+z^2)+2)-2)/(Pi^2*sqrt(b^2+z^2)))/(((z^2*(Int(-(2*I)*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int((4*I)*tt*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))-(4*I)*tt*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int(-(2*I)*tt^2*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*tt^2*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+Int(-2*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))-2*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))+2*tt*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))+2*tt*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2))), tt = -500 .. z))*(z^2*(Int(-(2*I)*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int((4*I)*tt*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))-(4*I)*tt*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+z*(Int(-2*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))-2*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2))), tt = -500 .. z))+Int(-(2*I)*tt^2*exp((-1)*.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+(2*I)*tt^2*exp(.5*I*v*tt)/(sqrt(b^2+tt^2)*v^2*exp(sqrt(b^2+tt^2)))+2*tt*exp((-1)*.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2)))+2*tt*exp(.5*I*v*tt)/(v*exp(sqrt(b^2+tt^2))), tt = -500 .. z))-1)*v)) end proc:
sys := {diff(X(z), z) = Physics:-`*`(H(z), Y(z))+Physics:-`*`(L(z), X(z)), diff(Y(z), z) = Physics:-`*`(G(z), Y(z))+Physics:-`*`(K(z), X(z))}
{diff(X(z), z) = H(z)*Y(z)+L(z)*X(z), diff(Y(z), z) = G(z)*Y(z)+K(z)*X(z)}
IC_1 := {X(-500) = 0, Y(-500) = 1}
dsol3 := dsolve(`union`(sys, IC_1), numeric, method = dverk78, output = procedurelist, known = [H, L, G, K])
proc (x_dverk78) local _res, _dat, _vars, _solnproc, _xout, _ndsol, _pars, _n, _i; option `Copyright (c) 2000 by Waterloo Maple Inc. All rights reserved.`; if 1 < nargs then error "invalid input: too many arguments" end if; _EnvDSNumericSaveDigits := Digits; Digits := 15; if _EnvInFsolve = true then _xout := evalf[_EnvDSNumericSaveDigits](x_dverk78) else _xout := evalf(x_dverk78) end if; _dat := Array(1..4, {(1) = proc (_xin) local _xout, _fcn, _i, _octl, _ctl, _y0, _yini, _ycur, _reinit, _pars, _n, _ysav, _ini, _par; option `Copyright (c) 1993 by the University of Waterloo. All rights reserved.`; Digits := max(15, Digits); _xout := _xin; _octl := array( 1 .. 32, [( 1 ) = (3), ( 2 ) = (1), ( 3 ) = (0), ( 4 ) = (0), ( 5 ) = (0), ( 6 ) = (0), ( 7 ) = (0), ( 9 ) = (1), ( 8 ) = (0), ( 11 ) = (-1), ( 10 ) = (-1), ( 13 ) = (-1), ( 12 ) = (-1), ( 15 ) = (-1), ( 14 ) = (-1), ( 18 ) = (-1), ( 19 ) = (-1), ( 16 ) = (-1), ( 17 ) = (-500.), ( 22 ) = (-1), ( 23 ) = (-1), ( 20 ) = (-500.), ( 21 ) = (-1), ( 27 ) = (-499.), ( 26 ) = (2), ( 25 ) = (-500.), ( 24 ) = (0), ( 31 ) = (-500.), ( 30 ) = (1), ( 29 ) = (2), ( 28 ) = (0.1e-7), ( 32 ) = (0)  ] ); _yini := Array(0..2, {(1) = -500., (2) = 0.}); _y0 := Array(0..2, {(1) = -500., (2) = 0.}); _ycur := array( 1 .. 2, [ ] ); _ctl := array( 1 .. 32, [( 1 ) = (3), ( 2 ) = (1), ( 3 ) = (0), ( 4 ) = (0), ( 5 ) = (0), ( 6 ) = (0), ( 7 ) = (0), ( 9 ) = (1), ( 8 ) = (0), ( 11 ) = (-1), ( 10 ) = (-1), ( 13 ) = (-1), ( 12 ) = (-1), ( 15 ) = (-1), ( 14 ) = (-1), ( 18 ) = (-1), ( 19 ) = (-1), ( 16 ) = (-1), ( 17 ) = (-500.), ( 22 ) = (-1), ( 23 ) = (-1), ( 20 ) = (-500.), ( 21 ) = (-1), ( 27 ) = (-499.), ( 26 ) = (2), ( 25 ) = (-500.), ( 24 ) = (0), ( 31 ) = (-500.), ( 30 ) = (1), ( 29 ) = (2), ( 28 ) = (0.1e-7), ( 32 ) = (0)  ] ); _fcn := proc (N, X, Y, YP) option `[Y[1] = X(z), Y[2] = Y(z)]`; YP[1] := H(X)*Y[2]+L(X)*Y[1]; YP[2] := G(X)*Y[2]+K(X)*Y[1]; 0 end proc; _pars := []; _n := 2; _ysav := Array(1..2, {(1) = 0., (2) = 1.}); if not type(_xout, 'numeric') then if member(_xout, ["start", "left", "right"]) then return _y0[0] elif _xout = "method" then return "dverk78" elif _xout = "numfun" then return round(_ctl[24]) elif _xout = "initial" then return [seq(_yini[_i], _i = 0 .. _n)] elif _xout = "parameters" then return [seq(_yini[_n+_i], _i = 1 .. nops(_pars))] elif _xout = "initial_and_parameters" then return [seq(_yini[_i], _i = 0 .. _n)], [seq(_yini[_n+_i], _i = 1 .. nops(_pars))] elif _xout = "last" then if _ctl[17]-_y0[0] = 0. then error "no information is available on last computed point" else _xout := _ctl[17] end if elif _xout = "enginedata" then return eval(_octl, 1) elif _xout = "function" then return eval(_fcn, 1) elif type(_xin, `=`) and type(rhs(_xin), 'list') and member(lhs(_xin), {"initial", "parameters", "initial_and_parameters"}) then _ini, _par := [], []; if lhs(_xin) = "initial" then _ini := rhs(_xin) elif lhs(_xin) = "parameters" then _par := rhs(_xin) elif select(type, rhs(_xin), `=`) <> [] then _par, _ini := selectremove(type, rhs(_xin), `=`) elif nops(rhs(_xin)) < nops(_pars)+1 then error "insufficient data for specification of initial and parameters" else _par := rhs(_xin)[-nops(_pars) .. -1]; _ini := rhs(_xin)[1 .. -nops(_pars)-1] end if; _xout := lhs(_xout); if _par <> [] then `dsolve/numeric/process_parameters`(_n, _pars, _par, _yini) end if; if _ini <> [] then `dsolve/numeric/process_initial`(_n, _ini, _yini, _pars) end if; if _pars <> [] then _par := {seq(rhs(_pars[_i]) = _yini[_n+_i], _i = 1 .. nops(_par))}; for _i from 0 to _n do _y0[_i] := subs(_par, _yini[_i]) end do; for _i from _n+1 to _n+nops(_pars) do _y0[_i] := _yini[_i] end do else for _i from 0 to _n do _y0[_i] := _yini[_i] end do end if; _octl[25] := _y0[0]; _octl[20] := _y0[0]; _octl[17] := _y0[0]; _octl[31] := _y0[0]; for _i to op(2, op(2, op(_octl))) do _ctl[_i] := _octl[_i] end do; for _i to _n+nops(_pars) do _ysav[_i] := _y0[_i] end do; if _xout = "initial" then return [seq(_yini[_i], _i = 0 .. _n)] elif _xout = "parameters" then return [seq(_yini[_n+_i], _i = 1 .. nops(_pars))] else return [seq(_yini[_i], _i = 0 .. _n)], [seq(_yini[_n+_i], _i = 1 .. nops(_pars))] end if else return "procname" end if end if; if _y0[0]-_xout = 0. then return [seq(_y0[_i], _i = 0 .. _n)] elif _octl[31]-_y0[0] = 0. then _octl[31] := _y0[0]-sign(_xout-_y0[0]) end if; _reinit := false; if _xin <> "last" then if 0 < 0 and `dsolve/numeric/checkglobals`(0, table( [ ] ), _pars, _n, _yini) then _reinit := true; if _pars <> [] then _par := {seq(rhs(_pars[_i]) = _yini[_n+_i], _i = 1 .. nops(_par))}; for _i from 0 to _n do _y0[_i] := subs(_par, _yini[_i]) end do; for _i from _n+1 to _n+nops(_pars) do _y0[_i] := _yini[_i] end do else for _i from 0 to _n do _y0[_i] := _yini[_i] end do end if end if; if _pars <> [] and select(type, {seq(_yini[_n+_i], _i = 1 .. nops(_pars))}, 'undefined') <> {} then error "parameters must be initialized before solution can be computed" end if end if; if _reinit or _ctl[17]-_xout <> 0. then if _reinit or 0 < _ctl[18] and _xout < _ctl[31] or _ctl[18] < 0 and _ctl[31] < _xout then for _i to op(2, op(2, op(_octl))) do _ctl[_i] := _octl[_i] end do; for _i to _n+nops(_pars) do _ysav[_i] := _y0[_i] end do else _ctl[29] := 2 end if; _ctl[9] := 2; _ctl[27] := _xout; if Digits <= trunc(evalhf(Digits)) then try evalhf(`dsolve/numeric/dverk78_engine`(_fcn, var(_ysav), var(_ycur), `dsolve/numeric/dverk78_aa`, `dsolve/numeric/dverk78_cc`, `dsolve/numeric/dverk78_dd`, var(_ctl), var(array( 1 .. 2, [ ] )), var(array( 1 .. 2, [ ] )), var(array( 1 .. 2, 1 .. 23, [ ] )))) catch: if searchtext('evalhf', lastexception[2]) <> 0 or searchtext('real', lastexception[2]) <> 0 or searchtext('hardware', lastexception[2]) <> 0 then `dsolve/numeric/dverk78_engine`(_fcn, _ysav, _ycur, `dsolve/numeric/dverk78_aa`, `dsolve/numeric/dverk78_cc`, `dsolve/numeric/dverk78_dd`, _ctl, array( 1 .. 2, [ ] ), array( 1 .. 2, [ ] ), array( 1 .. 2, 1 .. 23, [ ] )) else error  end if end try else `dsolve/numeric/dverk78_engine`(_fcn, _ysav, _ycur, `dsolve/numeric/dverk78_aa`, `dsolve/numeric/dverk78_cc`, `dsolve/numeric/dverk78_dd`, _ctl, array( 1 .. 2, [ ] ), array( 1 .. 2, [ ] ), array( 1 .. 2, 1 .. 23, [ ] )) end if; if _ctl[29]-3 <> 0 then Rounding := `if`(_y0[0] < _xout, -infinity, infinity); if _ctl[29]+1 = 0 then error "cannot evaluate the solution past %1, maxfun limit exceeded (see <a href='http://www.maplesoft.com/support/help/search.aspx?term=dsolve,maxfun' target='_new'>?dsolve,maxfun</a> for details)", evalf[8](_ctl[20]) elif _ctl[29]+2 = 0 then error "cannot evaluate the solution past %1, hmin > hmax, maybe error tolerance is too small", evalf[8](_ctl[20]) elif _ctl[29]+3 = 0 then error "cannot evaluate the solution past %1, step size < hmin, problem may be singular or error tolerance may be too small", evalf[8](_ctl[20]) else error "cannot evaluate the solution past %1, unknown error code returned from dverk78: %2", evalf[8](_ctl[20]), _ctl[29] end if end if; if _Env_smart_dsolve_numeric = true then if _y0[0] < _ctl[17] and procname("right") < _ctl[17] then procname("right") := _ctl[17] elif _ctl[17] < _y0[0] and _ctl[17] < procname("left") then procname("left") := _ctl[17] end if end if end if; [_ctl[25], seq(_ycur[_i], _i = 1 .. _n)] end proc, (2) = Array(0..0, {}), (3) = [z, X(z), Y(z)], (4) = []}); _vars := _dat[3]; _pars := map(rhs, _dat[4]); _n := nops(_vars)-1; _solnproc := _dat[1]; if not type(_xout, 'numeric') then if member(x_dverk78, ["start", 'start', "method", 'method', "left", 'left', "right", 'right', "leftdata", "rightdata", "enginedata", "eventstop", 'eventstop', "eventclear", 'eventclear', "eventstatus", 'eventstatus', "eventcount", 'eventcount', "laxtol", 'laxtol', "numfun", 'numfun', NULL]) then _res := _solnproc(convert(x_dverk78, 'string')); if 1 < nops([_res]) then return _res elif type(_res, 'array') then return eval(_res, 1) elif _res <> "procname" then return _res end if elif member(x_dverk78, ["last", 'last', "initial", 'initial', "parameters", 'parameters', "initial_and_parameters", 'initial_and_parameters', NULL]) then _xout := convert(x_dverk78, 'string'); _res := _solnproc(_xout); if _xout = "parameters" then return [seq(_pars[_i] = _res[_i], _i = 1 .. nops(_pars))] elif _xout = "initial_and_parameters" then return [seq(_vars[_i+1] = [_res][1][_i+1], _i = 0 .. _n), seq(_pars[_i] = [_res][2][_i], _i = 1 .. nops(_pars))] else return [seq(_vars[_i+1] = _res[_i+1], _i = 0 .. _n)] end if elif type(_xout, `=`) and member(lhs(_xout), ["initial", 'initial', "parameters", 'parameters', "initial_and_parameters", 'initial_and_parameters', NULL]) then _xout := convert(lhs(x_dverk78), 'string') = rhs(x_dverk78); if type(rhs(_xout), 'list') then _res := _solnproc(_xout) else error "initial and/or parameter values must be specified in a list" end if; if lhs(_xout) = "initial" then return [seq(_vars[_i+1] = _res[_i+1], _i = 0 .. _n)] elif lhs(_xout) = "parameters" then return [seq(_pars[_i] = _res[_i], _i = 1 .. nops(_pars))] else return [seq(_vars[_i+1] = [_res][1][_i+1], _i = 0 .. _n), seq(_pars[_i] = [_res][2][_i], _i = 1 .. nops(_pars))] end if elif type(_xout, `=`) and member(lhs(_xout), ["eventdisable", 'eventdisable', "eventenable", 'eventenable', "eventfired", 'eventfired', "direction", 'direction', NULL]) then return _solnproc(convert(lhs(x_dverk78), 'string') = rhs(x_dverk78)) elif _xout = "solnprocedure" then return eval(_solnproc) elif _xout = "sysvars" then return _vars end if; if procname <> unknown then return ('procname')(x_dverk78) else _ndsol; _ndsol := pointto(_dat[2][0]); return ('_ndsol')(x_dverk78) end if end if; try _res := _solnproc(_xout); [seq(_vars[_i+1] = _res[_i+1], _i = 0 .. _n)] catch: error  end try end proc
dsol3(500)
Download dver.mw
how to evaulate the value of R(z) for different values of z=0 to 1 with an interval of 0.1 and print ten values  in one column
R(z):= 1-cos^2*(Pi*z);
I am trying to expand a function f(t) in terms of fractional power series:
for example please see attached file tree.mw
f := proc (x) options operator, arrow; exp(x) end proc:
alpha := 1/2:
N := 10:
f_approximate := proc (x) options operator, arrow; sum(a[i]*x^`i&alpha;`, i = 0 .. N) end proc
Download tree.mw
Hello, to all,
On my computer I have installed Windows 7 Professional, Maple 2018.2.1 and
Physics:-Version()[2];
 2019, January 5, 13:32 hours, version in the MapleCloud: 276,
    version installed in this computer: 276
When I try to compute some examples from your poste "PDE_and_BC_during_2018.mw", I get an error in Example 8:
Example 8: This problem represents the temperature distribution in a thin circular plate whose lateral surfaces are insulated (Articolo example 6.9.2):
pde__8 := diff(u(r, theta, t), t) = (diff(u(r, theta, t), r)+r*(diff(u(r, theta, t), r, r))+(diff(u(r, theta, t), theta, theta))/r)/(25*r);
              d                    1   |/ d                \
   pde__8 := --- u(r, theta, t) = ---- ||--- u(r, theta, t)|
              dt                  25 r |\ dr               /
                                      2                  \
                                     d                   |
                                  -------- u(r, theta, t)|
          /  2                \          2               |
          | d                 |    dtheta                |
      + r |---- u(r, theta, t)| + -----------------------|
          |   2               |              r           |
          \ dr                /                          /
iv__8 := D[1]*u(1, theta, t) = 0, u(r, 0, t) = 0, u(r, Pi, t) = 0, u(r, theta, 0) = (r-(1/3)*r^3)*sin(theta);
   iv__8 := D[1] u(1, theta, t) = 0, u(r, 0, t) = 0,
                                       /    1  3\
     u(r, Pi, t) = 0, u(r, theta, 0) = |r - - r | sin(theta)
                                       \    3   /
pdsolve([pde__8, iv__8], u(r, theta, t), HINT = boundedseries(r = [0]));
Error, (in dsolve) cannot determine if this expression is true or false: not 0 <= -Pi
or I get no answer as in Example 10:
Example 10: A Laplace PDE with one homogeneous and three non-homogeneous conditions:
pde__10 := diff(u(x, y), x, x)+diff(u(x, y), y, y) = 0;
                    /  2         \   /  2         \
                    | d          |   | d          |
         pde__10 := |---- u(x, y)| + |---- u(x, y)| = 0
                    |   2        |   |   2        |
                    \ dx         /   \ dy         /
iv__10 := u(0, y) = 0, u(Pi, y) = sinh(Pi)*cos(y), u(x, 0) = sin(x), u(x, Pi) = -sinh(x);
      iv__10 := u(0, y) = 0, u(Pi, y) = sinh(Pi) cos(y),
pdsolve([pde__10, iv__10]);
There are also no answer as in Examle 10 in the Examples 15, 18, 19
Can you give me a hint,  what could be wrong?
With kind regards
Wolfgang Gellien
Hello everyone!
I am trying to calculate the Killing vectors for the metric below. For such, I used the packages DifferentialGeometry and Physics. However, I found different results these packages. Could someone explain why?
Thanks in advance!
killing_test1.mw
killing_test2.mw
So I was trying to create a shorthand for creating a plot of multiple arrows, with the arrow colour dependent on the magnitude of the vector.
I currently have a set of vectors, v, I want to display, and v[4] is the largest.
I know this could be done by creating an arrow plot for each vector seperately and then by combining them using display:
arrow1 := arrow( v[1], width=0.15,length=20,color=ColorTools:-Color( (norm(v[1])/norm(v[4]))*[0,0,1] ) );
arrow2 := arrow( v[2], width=0.15,length=20,color=ColorTools:-Color( (norm(v[2])/norm(v[4]))*[0,0,1] ) );
print(plots:-display([arrow1, arrow2, ...]));
But I was wondering if it could be done in a fashion similar to this:
arrows := arrow([seq(v[i], i=1..4)],width=0.15,length=20,color=ColorTools:-Color((norm(v[i])/norm(v[4]))*[0,0,1]));
print(arrows);
(btw: it works fine replacing the last i with 1, which draws all arrows nearly black, or with 4, which as you guessed, draws all arrows blue...)
Help appreciated!
Look I have actually purchased the software 3 time in total throughout my life, but i have no money at this point but i have a Linux OS now and i am enjoying learning how to use that, so i was wondering if there is a standard old verson that is open source and availble for a Linux install
Sum of -(2*((-1)^n-1))*sin(n*Pi*x)*exp(-Pi^2*n^2*t)/(Pi*n) from n=20??? Thank you very much
First 766 767 768 769 770 771 772 Last Page 768 of 2459
