I have multiple accounts. I would like to delete them. Please tell me how to delete it. Thank you.
How can I plot functions Vc=(0.5+t)^n
with t=z/h,
Hai any one help me to plot the curves and remove the errors  i am attaching the codes and  sample graph. thanks in advanced.
test.mw
I'm struggling with solving a delayed differential equation with time-dependent delay.
I have already use dde solver with matlab and find it cannot reaches my numerical accuracy.
Does maple can solve this problem? I explore a little bit and don't find there is a document to guide how to tackle with this problem.
Constant delay cannot solve my problem.
Thank you very much,
Peter
Is there a solve(identity ...) command for systems? I have 4 identities in the variable t.
They are Q1, Q2, Q3, Q4. I try solve(identity(Q1,Q2,Q3,Q4),t), A, B, C, D), and other forms of it, but
nothing works.
maplatha
I solved an ODE numerically. Code: question_(2).mw
delta*(M(t)*diff~(X, t$2)+C(t)*diff~(X, t))+K(t)*X=f(t)
How to calculate X(t) for different values t and to create a table like following.
I tried to solve an equation with a A0^2*v0 + .....................= 0 with 0 as a subscripted Index. The value of A0 was 0.35.
Maple returned the result with 0.350 as a variable with subscripted 0 and no numerical result.  When changing the variable to A0 without subscripted index 0 Maple returned the numerical result correct.
Hi there!
I am trying to calculate Eigenvectors of Matrices, Maple does not seem to understand that, however. I have used the structure of the example in the "help" section
A := `<|>`(`<,>`(-1, -3, -6), `<,>`(3, 5, 6), `<,>`(-3, -3, -4));
v, e := Eigenvectors(A)
and even the example itself, it doesn't work. Maple always responds with
"Error, (in Matrix) triangular[] storage expects name parameters"
What can I do?
I am trying to do taylor series expansion around the critical point, but I keep getting an error, because I think Maple is taking my critical point as function {x(t) = 5, y(t) = 10}. I would like to get just the output of x(t)=  from the list of critical points. Ex. Does anyone know the maple code to get "5" and "10" from the list of critical points without typing in 5 and 10.
Hi guys;
can one please show me how to plot graphs in on layout. i want like soundalgekar2004-deka.pdf using this code
variable.mw
with*plots; -1; ode1 := diff(f(eta), eta, eta, eta)-(diff(theta(eta), eta))*(diff(f(eta), eta, eta))/(theta(eta)-R)-(theta(eta)-R)*f(eta)*(diff(f(eta), eta, eta))/(2*R) = 0
diff(diff(diff(f(eta), eta), eta), eta)-(diff(theta(eta), eta))*(diff(diff(f(eta), eta), eta))/(theta(eta)-R)-(1/2)*(theta(eta)-R)*f(eta)*(diff(diff(f(eta), eta), eta))/R = 0
ode2 := diff(theta(eta), eta, eta)-N*pr*(diff(f(eta), eta))*theta(eta)+(1/2)*pr*f(eta)*(diff(theta(eta), eta)) = 0
diff(diff(theta(eta), eta), eta)-N*pr*(diff(f(eta), eta))*theta(eta)+(1/2)*pr*f(eta)*(diff(theta(eta), eta)) = 0
bcs1 := f(0) = 0, (D(f))(0) = 1, (D(f))(38) = 0;
fixedparameter := [pr = 0.2e-1, N = 1];
ode3 := eval(ode1, fixedparameter);
bcs2 := theta(38) = 0, theta(0) = 1;
ode4 := eval(ode2, fixedparameter);
diff(diff(theta(eta), eta), eta)-0.2e-1*(diff(f(eta), eta))*theta(eta)+0.1000000000e-1*f(eta)*(diff(theta(eta), eta)) = 0
L := [2, 10, 15];
[2, 10, 15]
for k to 3 do sol_All := dsolve(eval({bcs1, bcs2, ode3, ode4}, R = L[k]), [f(eta), theta(eta)], numeric, output = listprocedure); Y_sol || k := rhs(sol_All[5]); YP_sol || k := -rhs(sol_All[6]); ftheta || k := rhs(sol_All[3]); pftheta || k := -rhs(sol_All[4]) end do:
for k to 3 do L[k], [(Y_sol || k)(0), (YP_sol || k)(0)] end do;
2, [HFloat(1.0000000000000002), HFloat(0.07429586344532203)]
10, [HFloat(1.0000000000000007), HFloat(0.06509471738660902)]
15, [HFloat(0.9999999999999997), HFloat(0.06453272061469233)]
  plot( [ seq((Y_sol||j)(eta), j = 1..3)],
         eta = 0 .. 6,
         labels = [eta, theta(eta)],
         axes = boxed
plot( [ seq((YP_sol||j)(eta), j = 1..3)],
         eta = 0 .. 6,
         labels = [eta, thetaprime(eta)],
         axes = boxed
 plot( [ seq((ftheta||j)(eta), j = 1..3)],
         eta = 0 .. 6,
         labels = [eta, f(eta)],
         axes = boxed
  plot( [ seq((pftheta||j)(eta), j = 1..3)],
         eta = 0 .. 6,
         labels = [eta, fprime(eta)],
         axes = boxed
Download variable.mw
3.mw Here is my maple code that shows the animation for different values in b. The equation this is referring to is given in the code. I have done (b) and (c), and the animation is in the code, but I am not sure where for what value of b for the behavior changes, any tips on what to look for would be really helpful.
However, I am primarily concerned with (d) as I am not sure how to demonstrate periodic behaviour with dsolve. Thanks for the help!
So I am trying to use Maple to find the integer points in a region(s) bounded buy a set of inequalities. But for a specific set of inequalities, in four variables,
inequalities:= [-a1-a2+a3+a4 <= 2, a1+a2 <= 3, -2*a1 <= -1, -2*a2 <= -1, -2*a3 <= -1, -2*a4 <= -1, -a1+a2+a3-a4 <= 4, -a1+a2-a3+a4 <= 4, a1-a2+a3-a4 <= 4, a1-a2-a3+a4 <= 4]; in four variables, vars :=[a1,a2,a3,a4];
I am getting the following error
Error, (in solver) invalid input: LinearMultivariateSystemInternal expects its 1st argument, eqns, to be of type ({list, set})({`<`, `<=`, `=`}), but received {a1-a2 = 0, -11/2+a1 <> 0}
Also, upon checking the inequalities by hand, I am sure that the region mentioned in the error doesnt come up. as based on the inequalities, it is not possible to have -11/2+a1 > 0. But though I could be wrong about my manual inequality analysis, the error is still suprising and worrying.
Another point to note is that if I do a variable change, as
t1 := a1-a2;
t2 := a1+a2;
r1 := a3-a4;
r2 := a3+a4;
Then with new variables the inequalities are solved without any errors.
I am working with Maple2018 for this problem.
Any help or insight into the root of this problem would be a lot of help.
Hello! I need to solve a system of vector equations (a system with vectors, not a linear system). The coordinates of the vectors are not given. (It is a system of kinetostatic equations, I must to define reaction forces as functions of vectors of external forces.
I'm using the differential operator D to differentiate variables and look at the structure of the equations, i.e. turn things like
D[1]u-vt+v^2=0 into
D[1,2](u)-D[2](v)*t+v*D[1](t)+2*v*D[2](v)=0
However, it is assumed that this is a commutative operator, i.e. D[1,2]=D[2,1]. Can I use an option to have it not commute, or should I look into using the DETools package?
Mike
First 782 783 784 785 786 787 788 Last Page 784 of 2459
