I vaguely recall others complain about disappearing Code Edit Regions. Does anyone else recall that? I had one disappear from the very top of the attached worksheet (right after the restart), causing me to lose about 15-30 minutes of work. I've totally recreated the work, so I have no interest in this worksheet being repaired. I'm merely posting it in case anyone wants to do an autopsy on it.
Another issue that happened twice with this worksheet is that when I unchecked the "Expanded" box on the Code Edit Region menu (pull out from the right side of the screen) and copied the text to my clipboard (for posting on MaplePrimes), that copied text was missing my most-recent changes to the code. They reappeared when I expanded again. (But it's really difficult to copy-and-paste a multi-screen Code Edit Region when it's expanded.)
My final issue (and this has bothered me for years), is how the heck are you supposed to find the line with the syntax error in a several-hundred-line Code Edit Region? Unlike with inline code, the cursor is not placed near the error location._Binomial_missing_Code_region.mw
How do I remove infinity from a list
s:=[f(x) , exp(a), GAMMA(2x)-1 , infinity , 1, -infinity]
remove(has,%,infinity)
does not work.
It should yield
s:=[f(x) , exp(a), GAMMA(2x)-1 , 1]
with(StringTools)
s := "xABCx etc"; RegMatch("x(.+)x", s, 'm', 'n'); m; n; RegSubs(m = n, s)
"xABCx etc"
"xABCx"
"ABC"
"ABC etc"
s := "(ABC) etc"; RegMatch("\\((.+)\\)", s, 'm', 'n'); m; n; RegSubs(m = n, s)
"(ABC) etc"
"(ABC)"
"ABC"
"(ABC) etc"
In the second case RegSubs treats the expression m as containing special characters. Can one tell it to treat what it receives as a literal string - perhaps some "escape" function?
Download regsubs_problem.mw
EDIT  There is such a function. suffices.
How to solve the following second order ODE system? (I want to solve analytically and numerically and to compare the results) Thanks. Best regards.
where
Initial conditions:
Other symbols in the equation (v_0,a_0 etc.) are constant.
MY CODE TRY:  Code.mw
I tried to write a code for matrices in the question. ( I used x instead of gamma in the code)
n:=2:
  M:= tau -> Matrix
      ( n,
        n,
        shape=identity
      +Matrix
      ( n,
        n,             (i,j)->2*x*sin(i*Pi*v_0*tau)*sin(j*Pi*v_0*tau)
  C:=tau -> Matrix
              ( n,
                n,
                (i,j)->4*(i*Pi*v_0*tau)*sin(i*Pi*v_0*tau)*cos(j*Pi*v_0*tau)
  K:=tau -> n^4*Pi^2* Matrix
      ( n,
        n,
        shape=identity
      )-Matrix
      ( n,
        n,
        (i,j)-> 2*mu*(i*Pi*v_0)^2*sin(i*Pi*v_0*tau)*sin(j*Pi*v_0*tau)+2*mu*(i*Pi*a_0)*sin(i*Pi*v_0*tau)*cos(j*Pi*v_0*tau)
f:=tau -> Vector
      ( n,
        (i,j)-> x*Pi^2*(Pi/2+v_0^2*sum(((1-(-1)^k)/k^3)*sin(k*Pi*v_0*tau),k=1..infinity)-a_0*sum(((1-(-1)^k)/k^4)*cos(k*Pi*v_0*tau),k=1..infinity))*sin(i*Pi*v_0*tau)
X:= Vector(n, i-> x[i](t)):
sys:= M(tau).diff~(X, tau$2)+C(tau).diff~(X, tau)+K(tau).X=f(tau):
how I can determined time period?
thank you
period.mw
d := (10+20*cos(Omega*t)+30*cos(9*sqrt(2)*t))^2
(10+20*cos(Omega*t)+30*cos(9*2^(1/2)*t))^2
with(StringTools)
period(d)
period((10+20*cos(Omega*t)+30*cos(9*2^(1/2)*t))^2)
Download period.mw
For some reason algsub or applyrule is not performing what they has to do.
I dont understand exactly where the below lines are wrongly declared. Clearly the variable is not substituted
I get the following errors when attempting to use the Sockets package to interface with the serial input and output for a USB device connected and reported to have no known problems by Windows 10:
with(Sockets):
LookupService("busboy");
Error, could not determine determine port number for service "busboy"
LookupService(998);
Errror, cannot  determine "tcp"  service on port 998
server :=
proc (sid)
Sockets:-Write(sid, sprintf("Hello %s on port %d, from %s\r\n", Sockets:-GetPeerHost(sid), Sockets:-GetPeerPort(sid), Sockets:-GetHostName()))
Sockets:-Serve(GetPeerPort(sid), server);
Error, (in Sockets:-GetPeerHost) Unknown error
sid := Open("localhost", "echo");
Error, (in Sockets:-Serve) cannot bind address: Unknown error
Can this expression be transferred to gamma function form?
Int(exp(-Pr*(s*eta*lambda^2+lambda*eta+exp(-lambda*eta))/lambda^2), eta)
How can we solve the following pde by Maple?
where v is velocity, v with dot is acceleration. (So, I think we will assume that acceleration is fixed.) And \delta is Dirac distribution.  E,I,m, M , g are fixed numbers.
Boundary conditions are:
Initial conditions are:
You can find the equation in the code: question.mw
this "sum(1/(1+x)^t, t=1..infinity)" is (in my opionon) one of the most standard infinity summation and has the closed form 1/x.
i used maple 18 and it was executed and i got the closed form 1/x.
with maple 2018 i get the non executed form, also the same inert form as "Sum(1/(1+x)^t, t=1..infinity)".
if i try "sum(1/(1+2)^t, t=1..infinity)" i get 1/2 as result.
why does the version above not working? any ideas?
thank you.
Dear friends,
I'm trying to solve a linear system of PDEs. After applying the casesplit command Maple returns:
diff(U, z, y, x, x) = 0; diff(G, y,y,z) = diff(U,x,y,z);  diff(G,x,y,z) = diff(U,x,x,z)
(with U(x,y,z), G(x,y,z))
The solution to the first equation is U = F4(x, y)+ F3(x, z) + F2(y, z) + x*F1(y, z).
However, given this solution, I cannot satisfy diff(G,x,y,z) = diff(U,x,x,z).  What could I be doing wrong?
Many thanks for your help.
I have a problem with my maple.
corrupt file
Is there anybody who can help me solve this problem.
Casper
sys:={x+y=10,x^2-y^2+z^2=1};
{x+y = 10, x^2-y^2+z^2 = 1}
isolve(sys, n);
{x = -(1/20)*(1+20*n)^2+101/20, y = (1/20)*(1+20*n)^2+99/20, z = 1+20*n}
_SolutionsMayBeLost;  # It was set in Maple 10 or so!  E.g. x=5,y=5,z=-1 is not found.
_SolutionsMayBeLost
# Workaround
yz:=eliminate(sys,x);
[{x = -y+10}, {z^2-20*y+99}]
S:=isolve(yz[2], n);
{y = 20*n^2-38*n+23, z = 19-20*n}, {y = 20*n^2-22*n+11, z = 11-20*n}, {y = 20*n^2-18*n+9, z = 9-20*n}, {y = 20*n^2-2*n+5, z = 1-20*n}
map(u -> ( u union eval(yz[1],u) ), [S])[];  # The correct solution
{x = -20*n^2+38*n-13, y = 20*n^2-38*n+23, z = 19-20*n}, {x = -20*n^2+22*n-1, y = 20*n^2-22*n+11, z = 11-20*n}, {x = -20*n^2+18*n+1, y = 20*n^2-18*n+9, z = 9-20*n}, {x = -20*n^2+2*n+5, y = 20*n^2-2*n+5, z = 1-20*n}
This may seem a bit trivial, but I prefer f'(x) to writing diff(f(x),x) in 1D input. How to achieve?
differential.mw
15
"maple init loaded..."
In Document mode, this works fine.
f := proc (x) options operator, arrow; x^2 end proc
diff(f(x), x)
2*x
But I mainly use Worksheet (1D) mode, and I can't seem to acheve the same, without using diff(f(x),x)
f:x->x^2
f'(x)
Error, unexpected single forward quote
Download differential.mw
First 797 798 799 800 801 802 803 Last Page 799 of 2470
