Why I maple dont send out 1????
I expcect Q be 1, but receive  .9261583073444211949, Why?
A := Matrix(10, 10, {(1, 1) = 0.358665012985547e-3, (1, 2) = -0.164628637225196e-2, (1, 3) = 0.808705603350256e-3, (1, 4) = 0.131914692392149e-2, (1, 5) = -0.120745384995453e-2, (1, 6) = -0.127685186328850e-3, (1, 7) = -0.368262140727460e-3, (1, 8) = 0.722934152182773e-3, (1, 9) = 0.406838157326509e-3, (1, 10) = -0.270949354604275e-3, (2, 1) = -1.04811784877605, (2, 2) = -0.227246433636184e-2, (2, 3) = 1.12987295590946, (2, 4) = 0.320910227706809e-2, (2, 5) = -0.837137925723646e-1, (2, 6) = -0.590494756927829e-3, (2, 7) = 0.141893953127997e-2, (2, 8) = -0.431705701475750e-3, (2, 9) = 0.529611988652095e-3, (2, 10) = 0.876913927974057e-4, (3, 1) = -0.186537779517955e-2, (3, 2) = 0.731113455007046e-3, (3, 3) = -0.916700660778503e-2, (3, 4) = -0.429742144388156e-2, (3, 5) = 0.171402262358938e-1, (3, 6) = 0.147242552352914e-2, (3, 7) = -0.837021118160759e-2, (3, 8) = 0.348174114649671e-2, (3, 9) = 0.225687533471807e-2, (3, 10) = -0.139775301206369e-2, (4, 1) = -1.52107139964422, (4, 2) = 0.808077875491177e-2, (4, 3) = 1.64372029140351, (4, 4) = -0.847286100516818e-2, (4, 5) = -.127335986762229, (4, 6) = 0.118070315638635e-2, (4, 7) = 0.424032693235149e-2, (4, 8) = -0.111038208252920e-2, (4, 9) = 0.434602411991222e-3, (4, 10) = 0.318930385884084e-3, (5, 1) = 0.289424730370674e-2, (5, 2) = -0.172887794344293e-2, (5, 3) = 0.157061251396572e-1, (5, 4) = -0.363778806608431e-2, (5, 5) = -0.221497403961738e-1, (5, 6) = 0.205810013144210e-2, (5, 7) = 0.290388608347142e-2, (5, 8) = 0.554530769943721e-2, (5, 9) = 0.645600822073613e-3, (5, 10) = -0.223995662113480e-2, (6, 1) = 4.05367823691209, (6, 2) = -0.669541776787987e-2, (6, 3) = -4.37687402333541, (6, 4) = 0.100071882622313e-1, (6, 5) = .331612307231483, (6, 6) = -0.222866442868341e-2, (6, 7) = -0.854247230826875e-2, (6, 8) = -0.198825849939076e-2, (6, 9) = 0.144764377225621e-3, (6, 10) = 0.887581546748840e-3, (7, 1) = 0.437884803847533e-3, (7, 2) = -0.468560550990847e-2, (7, 3) = -0.274035269283456e-2, (7, 4) = 0.132221205985872e-2, (7, 5) = 0.587286710360397e-2, (7, 6) = 0.141670610986008e-2, (7, 7) = -0.324890905770655e-2, (7, 8) = 0.346314407352620e-2, (7, 9) = -0.313507643096885e-3, (7, 10) = -0.150449109852917e-2, (8, 1) = -1.74365543905306, (8, 2) = 0.329936253329467e-2, (8, 3) = 1.88180005384087, (8, 4) = -0.307966351872919e-2, (8, 5) = -.141724173079475, (8, 6) = 0.461487956516473e-3, (8, 7) = 0.455622531837965e-2, (8, 8) = -0.147959204065083e-2, (8, 9) = -0.964311997155483e-3, (8, 10) = 0.776900663643289e-3, (9, 1) = -0.182153308681337e-2, (9, 2) = 0.731579627122705e-2, (9, 3) = -0.459671306590223e-2, (9, 4) = 0.528628529817773e-2, (9, 5) = 0.340926625224384e-3, (9, 6) = -0.480044705401815e-2, (9, 7) = 0.906564729308528e-2, (9, 8) = -0.131891681339107e-1, (9, 9) = -0.298963526401197e-2, (9, 10) = 0.539189475787896e-2, (10, 1) = .259153153490112, (10, 2) = -0.239896326933024e-2, (10, 3) = -.278509331317189, (10, 4) = -0.165332320182602e-2, (10, 5) = 0.211686310866469e-1, (10, 6) = 0.115660284907533e-2, (10, 7) = -0.165524436062079e-2, (10, 8) = 0.496708050164578e-2, (10, 9) = -0.161592001287913e-3, (10, 10) = -0.203232293033617e-2})
Q := A/max(abs(A)):
max(Q)
.926158307610656317
Download suuual.mw
WARNING: This is a pretty silly question. I know it, but I've been on this for hours already...
I have this function rather simple but which depends on a natural number n. When I try a Fourier transform on it, it cannot evaluate the result for any n.
I have to define another function, and evaluate n=2, in order to get an explicit result.
h := piecewise(abs(t) < 2*Pi*n, cos(t), 0)
   F.T.
---------->         fourier(piecewise(abs(t) < 2*Pi*n, cos(t), 0), t, w)         # doesn't work for any n
h2 := eval(h, n = 2)
                      piecewise(abs(t) < 4*Pi, cos(t), 0)
   F.T.               2 w sin(4 Pi w)
---------->          ------------------                                          # works with fixed n=2
                      (w - 1) (w + 1)
How can I have an explicit result for any natural n ?
Thanks for your time
after i tryrring to instell another vergion of maple and it failed when i reinstell the older vergion of maple i get this error
what is missing and i did wronge
l := (n+m+sum(a[i], i = 1 .. n)+sum(b[j], j = 1 .. m))*ln(alpha)+n*ln(lambda[1])+m*ln(lambda[2])+lambda[1]*(sum(x[i], i = 1 .. n))+lambda[2]*(sum(y[j], j = 1 .. m))-(sum((2+a[i])*ln(exp(lambda[1]*x[i])-1+alpha), i = 1 .. n))-(sum((2+b[j])*ln(exp(lambda[2]*y[j])-1+alpha), j = 1 .. m));
Error, (in property/ConvertProperty) invalid input: PropRange uses a 2nd argument, b, which is missing
Given the vector A = 4.00i^+7.00j^ , find the magnitude of the vector.
ithprime(n)  gives the unique prime whose index is n, thus ithprime(10) returns 29. Question: is there an inverse function in Maple, which given prime p would return n such that ithprime(n) = p?
Or if no such function exists can anyone suggest a way such a function could be coded?
David.
These are the timings for various algorithms, using different starting points deriving surfaces of dimension 5, 4, 3, 2, 1
times3:=[[], [.140], [1.344, .891], [1.578, 1.312, 1.375, 1.437, 1.922, 2.625, 6.406], [2.188, 2.312, 1.687, 2.110, 2.047, 1.578, 8.953, 1.891, 1.875, 9.344, 2.203, 55.969, 2.266, 2.531, 81.078, 2.172, 50.641, 2.500, 3.141, 61.656, 3.406, 3.375]]
times1:=[[.718], [.766, 4.703], [.750, .797, 7.594, 3.938], [6.594, 7.718, 11.969, 8.485, 11.391, 130.583, 548.284, 974.435], [7.281, 8.515, 65.569, 7.016, 8.312, 9.500, 8.562, 9.766, 10.641, 12.609, 13.281, 17.453, 18.640, 1763.860, 2659.990, 7812.89, 8189.139]]
So far i can get a boxplot of either:
Statistics:-BoxPlot(`~`[`~`[log10]](times3));
Statistics:-BoxPlot(`~`[`~`[log10]](times1));
but what I'd like is a boxplot like this but i can't work out how to do this.
A := (a^6)^(1/3)*(-b^3)^(1/3)/a^3
I Can't get this to simplify to -b/a.
suppose i have afunction F(x) and i want to draw a sample for X from F(x)
Even and odd complement each other
how to find other sequence which complement each other?
such as 3 sequences divided integers or 5 sequences divided whole integers
is there monomials creation method such that solve result about coefficient and power are integers when right side columns are sequences?
i find even multiplication numbers are always solved into integers coefficient and power.
is there any more other sequences?
if I choose six multiplication table sequence,
what is this complement of six multiplication table sequence?
AJUSTEMENTIMAGE.mwAJUSTEMENTIMAGE.mwHi,
How do to insert image in Plot0 ?
I am working on a simple program (4 lines excluding header/footer and debug command) that calculates a Lie-derivatives of a function G, supplied by the user, with the rule:
derivative of x[i]=F[i]  (an input supplied by the user),
derivative of y[i]=y[i+1].
this calculation revolves around a dot product, and I can't seem to work out what has gone wrong. My impression is that is because nops of a Vector gives you  1 more than the length of the Vector, so the Vector handed to DotProduct is wrong- but i can't see why it doesn't work in the case of G2 and F2 but does for G and F.
lieDer2_problems_mwe.mw
I am developing an algorythm which returns some differential equation, which I want to simplify. Here is an example:
eqq:= k[t]*(`&ell;`^2)*(diff(q[3](tau), tau, tau)+(5*alpha-sigma+2*theta+1)*q[3](tau)+(-4*alpha+sigma-theta)*q[2](tau)+q[1](tau)*alpha) = -(sqrt(m*(1/k[t]))*`&ell;`*k[t]*`&Delta;&theta;`*(q[3](tau)-q[2](tau))*sin(sqrt(Lambda*k[t]*(1/m))*sqrt(m*(1/k[t]))*tau)+2*xi*sqrt(lambda*k[t]*m)*(diff(q[3](tau), tau)))*`&ell;`*(1/sqrt(m*(1/k[t])))
I want the parameters to be associated to the the variables, q[1](tau)q[2](tau)q[3](tau) and their derivattives. So, I have used "collect" command, as below:
vars:= {q[1](tau),q[2](tau),q[3](tau),diff(q[1](tau),tau),diff(q[2](tau),tau),diff(q[3](tau),tau),diff(q[1](tau),tau$2),diff(q[2](tau),tau$2),diff(q[3](tau),tau$2)}:
collect(eqq,vars);
The problem is that the equations remain with non-simplified terms, such as the terms inside the "sine" functions and the term "k[t]*ell^2". The command "simplify" does not have any effect. Ideally, I would like to have something like this:
(diff(q[3](tau), tau, tau))+alpha*q[1](tau)+(-4*alpha+sigma-theta)*q[2](tau)+(5*alpha-sigma+2*theta+1)*q[3](tau)+2*xi*sqrt(lambda)/`&ell;`*(diff(q[3](tau), tau))-`&Delta;&theta;`*sin(sqrt(Lambda)*tau)*q[2](tau)+`&Delta;&theta;`*q[3](tau)*sin(sqrt(Lambda)*tau) = 0;
Does anyone know how to solve that?
I am having trouble with the syntax for entering a limit of a multivariate function with direction specifiers.
For a single variate function f(x) the limit for x -> a from the right is specified by
limit(f(x),x=a,right)
A limit of a multivariate function f(x,y) for x -> a and y -> b can be entered by
limit(f(x,y),{x=a,y=b})
However I do not know how to specify directions in this case. Say, I want x to approach a from the right, and y to approach b from the left. What is the syntax to do this?
Cheers!
we have a matrix A (s.p.d) and b where LDL^t=A is the cholesky decompositon.
Why is the commands output
LUDecomposition(A, method = 'Cholesky', output = ['L', 'U']);
different from the output described in books or wikipedia.
To be exact:
L, the lower triangular matrix, is not normalized (the diagonal entries should be 1, they are not!)
L^t (upper triangular matrix) too.
D is not available for Cholesky at all.
If we calculate it with GaussianElimination
LUDecomposition(A, output = ['L', 'U'])
L is the wanted normalized lower triangular matrix, but its not normalized with cholesky.
And the DIAGONAL enntries are the wanted diagonal matrix D with cholesky.
This output is very confusing. Please can someone explain how to use/get the correct decomposition?
A example worksheet is attached.
Thank you :)!
with(LinearAlgebra)
[`&x`, Add, Adjoint, BackwardSubstitute, BandMatrix, Basis, BezoutMatrix, BidiagonalForm, BilinearForm, CARE, CharacteristicMatrix, CharacteristicPolynomial, Column, ColumnDimension, ColumnOperation, ColumnSpace, CompanionMatrix, CompressedSparseForm, ConditionNumber, ConstantMatrix, ConstantVector, Copy, CreatePermutation, CrossProduct, DARE, DeleteColumn, DeleteRow, Determinant, Diagonal, DiagonalMatrix, Dimension, Dimensions, DotProduct, EigenConditionNumbers, Eigenvalues, Eigenvectors, Equal, ForwardSubstitute, FrobeniusForm, FromCompressedSparseForm, FromSplitForm, GaussianElimination, GenerateEquations, GenerateMatrix, Generic, GetResultDataType, GetResultShape, GivensRotationMatrix, GramSchmidt, HankelMatrix, HermiteForm, HermitianTranspose, HessenbergForm, HilbertMatrix, HouseholderMatrix, IdentityMatrix, IntersectionBasis, IsDefinite, IsOrthogonal, IsSimilar, IsUnitary, JordanBlockMatrix, JordanForm, KroneckerProduct, LA_Main, LUDecomposition, LeastSquares, LinearSolve, LyapunovSolve, Map, Map2, MatrixAdd, MatrixExponential, MatrixFunction, MatrixInverse, MatrixMatrixMultiply, MatrixNorm, MatrixPower, MatrixScalarMultiply, MatrixVectorMultiply, MinimalPolynomial, Minor, Modular, Multiply, NoUserValue, Norm, Normalize, NullSpace, OuterProductMatrix, Permanent, Pivot, PopovForm, ProjectionMatrix, QRDecomposition, RandomMatrix, RandomVector, Rank, RationalCanonicalForm, ReducedRowEchelonForm, Row, RowDimension, RowOperation, RowSpace, ScalarMatrix, ScalarMultiply, ScalarVector, SchurForm, SingularValues, SmithForm, SplitForm, StronglyConnectedBlocks, SubMatrix, SubVector, SumBasis, SylvesterMatrix, SylvesterSolve, ToeplitzMatrix, Trace, Transpose, TridiagonalForm, UnitVector, VandermondeMatrix, VectorAdd, VectorAngle, VectorMatrixMultiply, VectorNorm, VectorScalarMultiply, ZeroMatrix, ZeroVector, Zip]
b := `<,>`(1, 2, 2)
Vector[column](%id = 18446744078207759414)
A := Matrix(3, 3, {(1, 1) = 4, (1, 2) = 6, (1, 3) = 2, (2, 1) = 6, (2, 2) = 10, (2, 3) = 8, (3, 1) = 2, (3, 2) = 8, (3, 3) = 30})
Matrix(%id = 18446744078207760614)
Matrix(%id = 18446744078207732662), Matrix(%id = 18446744078207732422)
Matrix(%id = 18446744078207771822), Matrix(%id = 18446744078207772062)
Download dasfindetnichtmalpeterlustig.mw
How do i change keyboard shortcuts, E.g one of my keyboard keys are broken or have stopped working. How do i redirect my shortcut to another keyboard combination or another hotkey simply.
First 811 812 813 814 815 816 817 Last Page 813 of 2459
