How can I install GeM software from the link http://cpc.cs.qub.ac.uk/?
I have tried many times but I didn't get.
@mskalsi
I was trying the direct method for conservation law of wave equation.But the fluxes and conserved density are not coming correct in eq.(4)(see attached file) because (1) and (6) are not same.What mistake have I done?
wave_eq_3.mws
Dear friends~I knew that I can copy each function's code into one worksheet bue it's tedious if I need to call many functions.So I want to find another approach with maple's statement.
Thank you ~
I have problem with plot of the function ( See attachment)
Chargement plots
plot((x^3-x^2)^(1/3), x)
Download PlotProblème.mw
I dont fully understand the principle of a global variable for example _Z in RootOf expressions. Can someone please explain this to me.
Hi I've been trying to solve these set of PDEs below and have been at it for very long
My codes are below
I tried solving the first equation by using:
sys_ode := 2*(diff(T(eta), eta, eta, eta))+T(eta)*(diff(T(eta), eta, eta)) = 0
ics := T(0) = 0, (D(T))(0) = 1, (D(T))(20) = 0
Digits := 10
sol1 := dsolve({ics, sys_ode}, numeric, output = operator)
{q(eta) = rhs(sol1[2](eta)), w(eta) = rhs(sol1[3](eta))}
Then inputting into the subsequent two equations:
PDE1 := eval([2/P . (diff(g(x, eta), eta, eta))+q(eta)*(diff(g(x, eta), eta))-g(x, eta)*w(eta) = 2*x*w(eta)*(diff(g(x, eta), x)), 2/S . (diff(phi(x, eta), eta, eta))+q(eta)*(diff(phi(x, eta), eta)) = 2*x*w(eta)*(diff(phi(x, eta), x))])
subBC1 := -phi(x, 0)*exp(g(x, 0)*sqrt(x)/(1+varepsilon*g(x, 0)*sqrt(x)))
subBC2 := alpha . ((phi(x, 0))(sqrt(x)))(exp(g(x, 0)*sqrt(x)/(1+varepsilon*g(x, 0)*sqrt(x))))
BC := {diff(g(0, eta), eta, eta) = 0, diff(phi(0, eta), eta, eta) = 0, g(0, eta) = 0, g(x, 20) = 0, phi(0, eta) = 1, phi(x, 20) = 1, (D[2](g))(x, 0) = subBC1, (D[2](phi))(x, 0) = subBC2}
P = 1
S = 1
pds := pdsolve(PDE, {BC}, numeric, spacestep = .25)
but always end up with :Error, (in pdsolve/numeric/process_PDEs) number of dependent variables and number of PDE must be the same
I know my BC conditions might probably have some major errors too but i really cant proceed on cos i always end up with this same error. I really hope anyone would be able to help me on this
help please
Thought it would be a neat way to create identation for loops and if branches in a text editor and copy the code into Maple. But Maple inserts a new prompt at the beginning of every line.
Is there a solution in 2018?
Hi, Is there any way to set the tolerances in
LinearAlgebra[Rank]
I'm evaluating a matrix which is singular, except the singular values come back as 1 and 10^(-9).  I'd like Maple to compute this as rank 1 rather than rank 2.
If I input 3^665 the whole number is displayed. How to display only last few digits?
When I make the input 2*pi*440 the output is pi880.
How to come to the result 2764,6 radians?
Coding_Basic_Reproduction_Number_2.mw
Anybody know how to simplify the equation?
Some ideas to plot ( animate) tangents at corner point or cusp point?
For examples : f(x)=sqrt(abs(x-1)) , g(x)=sqrt(abs(x^2-4))
factor_problem.mw
I want to factor the following polynomial:
Teller := 2*i1^4*i2*i3+2*i1^4*i2*i4+2*i1^4*i2*i5+2*i1^4*i3*i4+2*i1^4*i3*i5+2*i1^4*i4*i5+4*i1^3*i2^2*i3+4*i1^3*i2^2*i4+4*i1^3*i2^2*i5+4*i1^3*i2*i3^2+6*i1^3*i2*i3*i4+6*i1^3*i2*i3*i5+4*i1^3*i2*i4^2+6*i1^3*i2*i4*i5+4*i1^3*i2*i5^2+4*i1^3*i3^2*i4+4*i1^3*i3^2*i5+4*i1^3*i3*i4^2+6*i1^3*i3*i4*i5+4*i1^3*i3*i5^2+4*i1^3*i4^2*i5+4*i1^3*i4*i5^2+2*i1^2*i2^3*i3+2*i1^2*i2^3*i4+2*i1^2*i2^3*i5+4*i1^2*i2^2*i3^2+6*i1^2*i2^2*i3*i4+6*i1^2*i2^2*i3*i5+4*i1^2*i2^2*i4^2+6*i1^2*i2^2*i4*i5+4*i1^2*i2^2*i5^2+2*i1^2*i2*i3^3+6*i1^2*i2*i3^2*i4+6*i1^2*i2*i3^2*i5+6*i1^2*i2*i3*i4^2+24*i1^2*i2*i3*i4*i5+6*i1^2*i2*i3*i5^2+2*i1^2*i2*i4^3+6*i1^2*i2*i4^2*i5+6*i1^2*i2*i4*i5^2+2*i1^2*i2*i5^3+2*i1^2*i3^3*i4+2*i1^2*i3^3*i5+4*i1^2*i3^2*i4^2+6*i1^2*i3^2*i4*i5+4*i1^2*i3^2*i5^2+2*i1^2*i3*i4^3+6*i1^2*i3*i4^2*i5+6*i1^2*i3*i4*i5^2+2*i1^2*i3*i5^3+2*i1^2*i4^3*i5+4*i1^2*i4^2*i5^2+2*i1^2*i4*i5^3+2*i1*i2^3*i3*i4+2*i1*i2^3*i3*i5+2*i1*i2^3*i4*i5+4*i1*i2^2*i3^2*i4+4*i1*i2^2*i3^2*i5+4*i1*i2^2*i3*i4^2+6*i1*i2^2*i3*i4*i5+4*i1*i2^2*i3*i5^2+4*i1*i2^2*i4^2*i5+4*i1*i2^2*i4*i5^2+2*i1*i2*i3^3*i4+2*i1*i2*i3^3*i5+4*i1*i2*i3^2*i4^2+6*i1*i2*i3^2*i4*i5+4*i1*i2*i3^2*i5^2+2*i1*i2*i3*i4^3+6*i1*i2*i3*i4^2*i5+6*i1*i2*i3*i4*i5^2+2*i1*i2*i3*i5^3+2*i1*i2*i4^3*i5+4*i1*i2*i4^2*i5^2+2*i1*i2*i4*i5^3+2*i1*i3^3*i4*i5+4*i1*i3^2*i4^2*i5+4*i1*i3^2*i4*i5^2+2*i1*i3*i4^3*i5+4*i1*i3*i4^2*i5^2+2*i1*i3*i4*i5^3+4*i1^3*i2*i3+4*i1^3*i2*i4+4*i1^3*i2*i5+4*i1^3*i3*i4+4*i1^3*i3*i5+4*i1^3*i4*i5+8*i1^2*i2^2*i3+8*i1^2*i2^2*i4+8*i1^2*i2^2*i5+8*i1^2*i2*i3^2+12*i1^2*i2*i3*i4+12*i1^2*i2*i3*i5+8*i1^2*i2*i4^2+12*i1^2*i2*i4*i5+8*i1^2*i2*i5^2+8*i1^2*i3^2*i4+8*i1^2*i3^2*i5+8*i1^2*i3*i4^2+12*i1^2*i3*i4*i5+8*i1^2*i3*i5^2+8*i1^2*i4^2*i5+8*i1^2*i4*i5^2+4*i1*i2^3*i3+4*i1*i2^3*i4+4*i1*i2^3*i5+8*i1*i2^2*i3^2+12*i1*i2^2*i3*i4+12*i1*i2^2*i3*i5+8*i1*i2^2*i4^2+12*i1*i2^2*i4*i5+8*i1*i2^2*i5^2+4*i1*i2*i3^3+12*i1*i2*i3^2*i4+12*i1*i2*i3^2*i5+12*i1*i2*i3*i4^2+48*i1*i2*i3*i4*i5+12*i1*i2*i3*i5^2+4*i1*i2*i4^3+12*i1*i2*i4^2*i5+12*i1*i2*i4*i5^2+4*i1*i2*i5^3+4*i1*i3^3*i4+4*i1*i3^3*i5+8*i1*i3^2*i4^2+12*i1*i3^2*i4*i5+8*i1*i3^2*i5^2+4*i1*i3*i4^3+12*i1*i3*i4^2*i5+12*i1*i3*i4*i5^2+4*i1*i3*i5^3+4*i1*i4^3*i5+8*i1*i4^2*i5^2+4*i1*i4*i5^3+4*i2^3*i3*i4+4*i2^3*i3*i5+4*i2^3*i4*i5+8*i2^2*i3^2*i4+8*i2^2*i3^2*i5+8*i2^2*i3*i4^2+12*i2^2*i3*i4*i5+8*i2^2*i3*i5^2+8*i2^2*i4^2*i5+8*i2^2*i4*i5^2+4*i2*i3^3*i4+4*i2*i3^3*i5+8*i2*i3^2*i4^2+12*i2*i3^2*i4*i5+8*i2*i3^2*i5^2+4*i2*i3*i4^3+12*i2*i3*i4^2*i5+12*i2*i3*i4*i5^2+4*i2*i3*i5^3+4*i2*i4^3*i5+8*i2*i4^2*i5^2+4*i2*i4*i5^3+4*i3^3*i4*i5+8*i3^2*i4^2*i5+8*i3^2*i4*i5^2+4*i3*i4^3*i5+8*i3*i4^2*i5^2+4*i3*i4*i5^3+i1^4+3*i1^3*i2+3*i1^3*i3+3*i1^3*i4+3*i1^3*i5+3*i1^2*i2^2+6*i1^2*i2*i3+6*i1^2*i2*i4+6*i1^2*i2*i5+3*i1^2*i3^2+6*i1^2*i3*i4+6*i1^2*i3*i5+3*i1^2*i4^2+6*i1^2*i4*i5+3*i1^2*i5^2+i1*i2^3+3*i1*i2^2*i3+3*i1*i2^2*i4+3*i1*i2^2*i5+3*i1*i2*i3^2+10*i1*i2*i3*i4+10*i1*i2*i3*i5+3*i1*i2*i4^2+10*i1*i2*i4*i5+3*i1*i2*i5^2+i1*i3^3+3*i1*i3^2*i4+3*i1*i3^2*i5+3*i1*i3*i4^2+10*i1*i3*i4*i5+3*i1*i3*i5^2+i1*i4^3+3*i1*i4^2*i5+3*i1*i4*i5^2+i1*i5^3+4*i2^2*i3*i4+4*i2^2*i3*i5+4*i2^2*i4*i5+4*i2*i3^2*i4+4*i2*i3^2*i5+4*i2*i3*i4^2+4*i2*i3*i5^2+4*i2*i4^2*i5+4*i2*i4*i5^2+4*i3^2*i4*i5+4*i3*i4^2*i5+4*i3*i4*i5^2
What is the best strategy using Maple(latest version)? In a previous, less complicated example, the polynomial could be not be factored in a single expression, but I was succesfull to factor it in multiple factors.
kind regards,
Harry Garst
with(PDEtools)
with(plots)
P__r := .71; lambda := 1.0; K__r := 1.0; S__r := .5; m := .5; M := sqrt(10.0); `ϰ` := .5; Omega := sqrt(5.0); Gr := 6.0; Gm := 5.0; S__c := .22
PDE := {diff(phi(x, t), t) = (diff(phi(x, t), x, x))/S__c-K__r*phi(x, t)+S__r*(diff(theta(x, t), x, x)), diff(theta(x, t), t) = lambda*(diff(theta(x, t), x, x))/P__r, diff(u(x, t), t) = diff(u(x, t), x, x)-M^2*(u(x, t)-m*w(x, t))/(m^2+1)-u(x, t)/`ϰ`-2*Omega^2*w(x, t)+Gr*theta(x, t)+Gm*phi(x, t), diff(w(x, t), t) = diff(w(x, t), x, x)+M^2*(m*u(x, t)-w(x, t))/(m^2+1)-w(x, t)/`ϰ`+2*Omega^2*u(x, t)}
{diff(phi(x, t), t) = 4.545454545*(diff(diff(phi(x, t), x), x))-1.0*phi(x, t)+.5*(diff(diff(theta(x, t), x), x)), diff(theta(x, t), t) = 1.408450704*(diff(diff(theta(x, t), x), x)), diff(u(x, t), t) = diff(diff(u(x, t), x), x)-9.999999999*u(x, t)-5.999999996*w(x, t)+6.0*theta(x, t)+5.0*phi(x, t), diff(w(x, t), t) = diff(diff(w(x, t), x), x)+14.00000000*u(x, t)-9.999999999*w(x, t)}
IBC := {phi(0, t) = 1, phi(9, t) = 0, phi(x, 0) = 0, theta(0, t) = 1, theta(9, t) = 0, theta(x, 0) = 0, u(0, t) = t, u(9, t) = 0, u(x, 0) = 0, w(0, t) = 0, w(9, t) = 0, w(x, 0) = 0}
sol := pdsolve(PDE, IBC, numeric, spacestep = 0.1e-1)
_m2167514531200
p1 := sol:-plot(t = .3, color = red); p2 := sol:-plot(t = .5, color = gold); p3 := sol:-plot(t = .7, color = purple); p4 := sol:-plot(t = 1., color = green); plots[display]({p1, p2, p3, p4})
q1, q2, q3, q4 := seq(eval(u(x, t), sol:-value(t = t0, output = listprocedure)), t0 = [.3, .5, .7, 1]); plot([q1, q2, q3, q4], 0 .. 10, color = [red, gold, purple, green])
p1 := sol:-plot(t = 1, S__c = .1, color = red); p2 := sol:-plot(t = 1, S__c = .2, color = gold); p3 := sol:-plot(t = 1, S__c = .3, color = purple); p4 := sol:-plot(t = 1, S__c = .4, color = green); plots[display]({p1, p2, p3, p4})
Error, (in plot/options2d) unexpected option: .22 = .1
Error, (in plot/options2d) unexpected option: .22 = .2
Error, (in plot/options2d) unexpected option: .22 = .3
Error, (in plot/options2d) unexpected option: .22 = .4
q1, q2, q3, q4 := seq(eval(diff(u(0, t), t), sol:-value(t = t0, output = listprocedure)), t0 = [.3, .5, .7, 1]); plot([q1, q2, q3, q4], 0 .. 10, color = [red, gold, purple, green])
Error, (in plot) procedure expected, as range contains no plotting variable
Download pde_baru.mwpde_baru.mw
Dear Prof DRs ,Please see the attachments
how to PLOT PDE IBCS for different  Sc , Pr, Gr, Gm at fixed t? Also for Nusselt (theta prime)  ,skin friction (f double prime)?
sys*{A2+D2 = 0, B1*sin(192*K1)+D1 = 0, 3.383*B2*K1+C2 = 0, B1*K1^2*sin(192*K1)+11.444689*A2*K1^2*cos(568.344*K1)+11.444689*B2*K1^2*sin(568.344*K1) = 0, A2*cos(568.344*K1)+B2*sin(568.344*K1)+168*C2+D2 = 0, -3.383*A2*K1*sin(568.344*K1)+3.383*B2*K1*cos(568.344*K1)+C2-B1*K1*cos(192*K1) = 0};
sys { A2 + D2 = 0, B1 sin(192 K1) + D1 = 0, 3.383 B2 K1 + C2 = 0, B1
    2                              2
  K1  sin(192 K1) + 11.444689 A2 K1  cos(568.344 K1)
   + 11.444689 B2 K1  sin(568.344 K1) = 0,
  A2 cos(568.344 K1) + B2 sin(568.344 K1) + 168 C2 + D2 = 0,
-3.383 A2 K1 sin(568.344 K1) + 3.383 B2 K1 cos(568.344 K1) + C2
   - B1 K1 cos(192 K1) = 0 }
fsolve(sys*{A2, B1, B2, C2, D1, D2});
Error, (in fsolve) number of equations, 1, does not match number of variables, 7
First 891 892 893 894 895 896 897 Last Page 893 of 2463
