I have the following function involving 2 piecewise constructs:
ftotal := -1.70678763408500*10^6*dpp[f]*piecewise(t < 0, 0, 0 <= t and t <= t1, 1-cos(t*Pi/t1), t1 < t, 2)-3.41357526817000*10^6*corrFac*piecewise(t < 0, 0, 0 <= t and t <= t1, 1/2-(1/2)*cos(2*t*Pi/t1), t1 < t, 0)+3.51914976100000*10^8;
(This is a result from a prior calculation in Maple; I did not create this construct orginally). The condition blocks are the same for both piecewise functions so this can be simplified to one piecewise function. Per the Help this can be achieved using convert:
convert(ftotal,piecewise,t);
but I get this error:
Error, (in PiecewiseTools:-Convert) unable to compare 0 and t1
Since I pasted everything into a new sheet I know that t has no assigned value. Same is true for t1 (and specifically I need this for general t and t1). The conversion to Heaviside works; but converting from that back to piecewise fails with the same error.
Is there any way I can achieve the desired result other than doing it by hand?
Sample sheet is attached. I originally ran into this in Maple 2016 but verified the same issue is present in Maple 2017.
M.D.
piecewise.mw
Hi, i have a problem with getting a constant number out of a function, i guess theres a problem in my algorythm but i cant seem to find it. Any help appreciated. In the link i send a screen shot. First picture declares the procedure and second trying to apply it. The result should be a number with no unknown (x).
https://prnt.sc/gv92cy
https://prnt.sc/gv92on
I am having issues opening my document When I try to open the file it brings up a box title TEXT FORMAT CHOICE with the options: MAPLE TEXT, PLAIN TEXT, MAPLE INPUT and CANCEL.
Maple Worksheet - Error
Failed to load the worksheet /maplenet/convert/DS5.mw .
Download DS5.mw
DS5.mw
Any help with how I can rectify this would be extremely helpful.
Many thanks
Is it possible to define a short hand notation for sine and cosine functions and make the output expressed in terms of the defined notation?
For example the matrix below uses c1 instead of cos(theta1) and s2 instead of sin(theta2).
The reason I want to do this is that I am dealing with really long matrices and I need some sort of way to minimize the expressions.
Canberk
Doubt_ForLoopSemicolon_doesnot_function_A_ReactantValues.mwWhy the following two loops do not display the curves though they are obtained in these loops as verified by the 21 loops.(***) later in the end of this document!!?
for i to 9 do
for k to 7 do
p1[i, k] := plot(curve[i, k], x = 2.0 .. 5.0, labels = [xlabel, ylabel[k]], labeldirections = ["horizontal", "vertical"], color = [black], linestyle = Linestyle1[1], thickness = Thickness1[1], title = l[i], caption = cat("Fig.", i), legend = Legend[i]); p2[i, k] := plot(curvep[i, k], style = point, color = [black], symbol = [solidcircle, soliddiamond, solidbox, diamond, asterisk], symbolsize = 8);
plots:-display(p1[i, k], p2[i, k]) end do end do;
The following loop also does not display curves!
for i from 10 to 21 do
for k to 7 do
p1[i, k] := plot(curve[i, k], x = 2.0 .. 5.0, labels = [xlabel, ylabel[k]], labeldirections = ["horizontal", "vertical"], color = [black], linestyle = Linestyle1[2], thickness = Thickness1[2], title = l[i], caption = cat("Fig.", i), legend = Legend[i]); p2[i, k] := plot(curvep[i, k], style = point, color = [black], symbol = [solidcircle, soliddiamond, solidbox, diamond, asterisk], symbolsize = 8);
The following loops dispaly the curves
(*** How come the following curves available did not show in the above for do loop?
for k to 7 do plots:-display(p1[1, k], p2[1, k]) end do;
for k to 7 do plots:-display(p1[2, k], p2[2, k]) end do;
for k to 7 do plots:-display(p1[3, k], p2[3, k]) end do;
for k to 7 do plots:-display(p1[4, k], p2[4, k]) end do;
for k to 7 do plots:-display(p1[5, k], p2[5, k]) end do;
for k to 7 do plots:-display(p1[6, k], p2[6, k]) end do;
for k to 7 do plots:-display(p1[7, k], p2[7, k]) end do;
for k to 7 do plots:-display(p1[8, k], p2[8, k]) end do;
for k to 7 do plots:-display(p1[9, k], p2[9, k]) end do;
for k to 7 do plots:-display(p1[10, k], p2[10, k]) end do;
for k to 7 do plots:-display(p1[11, k], p2[11, k]) end do;
for k to 7 do plots:-display(p1[12, k], p2[12, k]) end do;
for k to 7 do plots:-display(p1[13, k], p2[13, k]) end do;
for k to 7 do plots:-display(p1[14, k], p2[14, k]) end do;
for k to 7 do plots:-display(p1[15, k], p2[15, k]) end do;
for k to 7 do plots:-display(p1[16, k], p2[16, k]) end do;
for k to 7 do plots:-display(p1[17, k], p2[17, k]) end do;
for k to 7 do plots:-display(p1[18, k], p2[18, k]) end do;
for k to 7 do plots:-display(p1[19, k], p2[19, k]) end do;
for k to 7 do plots:-display(p1[20, k], p2[20, k]) end do;
for k to 7 do plots:-display(p1[21, k], p2[21, k]) end do;
I've got a rain drop falling through air with velocity V=[vx,vy] when exposed to to dragforce Fd
formulas in following link
Exposed_for_drag_force.docx
But  Fd= (expression for dragforce*v)* V
How to multiply V=[vx,vy] and recive list for all values so i can make a plot with this values?
need to use Cd= V ->and returns Cd(v) (not proc..)
What am I missing?  Why it is not trivial to ask Maple to find all nth roots of a complex number in standard a+ib form or polar form and receive the answer in simplified polar form as it would be shown in any Trigonometry or PreCalculus textbook?
Hi there, I'm a really noob when it comes to maple.
My teacher wants me to solve a differential equation using this software and the only problem I have is that I dont know which command to use to solve the equation with boundary conditions.
I've already tried the dsolve command but then I realized that it only works with initial conditions, and the conditions I have are boundary (initial-end). So how do I actually solve the differential equation ?
When I download the help document here
https://www.maplesoft.com/support/help/maple/view.aspx?path=int%2Fdetails
I get a bug when I execute the page.
I copied pasted the last line using 1d math notation to replicate the error.
There is no addition symbol between x^2 + O(x^5)
On the help page I don't see an error.
 I uploaded the help file   int-details_(2).mw
Hello people in mapleprimes,
I hope you will help me about modifying an expression.
How can I factor the expression with w and Delta__1 in the attached file?
e2_3 := w^(1-sigma)*((f__11*sigma*Delta__1/L__1)^(-1/(sigma-1))/w)^(k-sigma+1)*k/(Delta__1*(k-sigma+1)*a__0^k);
Thank you for advance.
Modifying_expression_factor.mw
how can i simplify with definition two new parameter
i show in this picture
ii := evalr(csch(INTERVAL(-infinity .. -1, 1 .. infinity)));
             INTERVAL(-csch(1) .. 0, csch(1) .. 0)
evalr(ii-ii);
                            -csch(1)
(Make sure you don't have the Typesetting level set to Extended, or ii won't be displayed correctly.)
There are no functions to test for interval membership (or to compute intersections/unions of intervals), so it's unclear how Maple treats the interval csch(1)..0, but apparently evalr is getting tripped up by it.
Also:
evalr(sech(INTERVAL(-infinity .. -1, 1 .. infinity)));
evalr(arccsch(INTERVAL(-infinity .. -1, 1 .. infinity)));
Error, (in evalr/arccsch) too many levels of recursion
For example, let's say we have the following function
Now if we want to calculate the value of a function we have to
subs([x1=10,x2=20],eval(hf));
My question is the following: How to substitute values for x1 and x2 using values from vector? something like that
x:=[10,20];
subs([x],eval(hf));
Best,
Rariusz
I solve a partial differential equation using the THETA METHOD on Maple17, but what is also of essence is the skin friction and Nusselt Number which are {diff(u(x, t), x)} at x = 0 and {diff(T(x, t), x)} at x = 0 respectively. How can I achieve the two using the THETA METHOD? This is the PDE in it full flesh.
 PDE := {diff(phi(x, t), t) = (diff(phi(x, t), x, x))/S__c, diff(u(x, t), t) = diff(u(x, t), x, x)-M^2*(u(x, t)+m*w(x, t))/(m^2+1)-u(x, t)/`&varkappa;`-2*Omega^2*w(x, t), diff(w(x, t), t) = diff(w(x, t), x, x)+M^2*(m*u(x, t)-w(x, t))/(m^2+1)-w(x, t)/`&varkappa;`+2*Omega^2*u(x, t), diff(theta(x, t), t) = lambda*(diff(theta(x, t), x, x))/P__r+D__r*(diff(phi(x, t), x, x))}
With conditions: BC := {phi(0, t) = 1, phi(12, t) = 0, phi(x, 0) = 0, u(0, t) = t, u(12, t) = 0, u(x, 0) = 0, w(0, t) = 0, w(12, t) = 0, w(x, 0) = 0, theta(0, t) = 1, theta(12, t) = 0, theta(x, 0) = 0}
Where the parameter like P_r, S_c  e.t.c are constants to assign value to.
First 955 956 957 958 959 960 961 Last Page 957 of 2460
