Dear Sirs,
Can someone explain to why if I load Real Domain, that the derivate of a function at certain value comes out like in screendump?
Thanks in advance :)
https://imgur.com/a/sHJEj
Fred
I have this set of four equations and five constants, how I will shoot for x5 to find the unique solution
I assumme x5= pi/2 as initial guess but no solution
any body can help?
I am writing a textbook in biomedical engineering and using Maple 14 for generating figures.  In many of the graphs, my axis labels have subscripts or superscripts.  For example in a 2D plot statement I type   labels=[x,f[0](x)] which gives a subscript 0.   However, both x and f0(x) appear in italics.  How can I have them appear as normal...i.e. without italics? The labelfont command does not seem to have an instruction to remove the italics.  Can you assist me?
I would like to solve {x^2+y^2+z^2 = 3, x+y+z = 3} over the reals. Clearly x=1,y=1,z=1 is a solution.
Maple seems to have a hard time with this. I have tried using with(RealDomain) and various commands.
The last solution  is getting closer to the real number answer if i substitute z = 1, but then i get the strange answer { 1=1, x=1,y=1}
I tried using wolfram and it showed me the correct answer.
Rest assured, I am a strong maple fan. I sometimes use wolfram for quick and dirty solutions.
Also is there a way to turn off "with(RealDomain)", switch back to the default domain, without using 'restart'.
Is there any way i can define a value to a variable together with an angle?
I am looking to do something like this:
the example is from Mathcad, but i was hoping there was some way to do it in Maple also?
I want to write a code for solving following PDE with Cauchy data.
Equation:  (y-u(x,y))*(diff(u(x,y), x))+(u(x,y)-x)*(diff(u(x, y), y)) =x-y
Cauchy Data: u(x,y)=0 on xy=1.
THE CODE:
PDE := (y-u(x,y))*(diff(u(x,y), x))+(u(x,y)-x)*(diff(u(x, y), y)) =x-y;ic:=u(x, 1/x)=0;
ans := pdsolve({PDE,ic});
pdetest(ans, PDE);
Maple doesn' t give a solution.Why?
"Error, (in PDEtools:-Library:-NormalizeBoundaryConditions) unexpected occurrence of the variables {x} in the 2nd operand of u(x, 1/x) in the given initial conditions"
I
How to get the number of parameters of an operator/procedure? Like this.
How do I move a circle around a sphere?
See attached:  WA61_circle_sphere_post.mw
Circle shares surface area of sphere, how can circle be moved independently around sphere?
I would like to retain the patchwork of the sphere to resemble latitude/longitude lines.
Les
I am using the LinearAlgebra package to do dynamics between a rotating Cartesian coordinate system and a fixed Cartesian coordinate system. The VectorCalculus package is not what I need.
Since I can't seem to get my test worksheet to paste into this post, I will manually enter an "approximation" to it. I assume that the notation [x, y, z] represents a column vector. I also assume that x represents the cross product operator from the operator pallete.
I just want to get any one of the three ways of doing a vector cross product (see below) to simply display in math notation as R x V. What I get from the three methods below for an unevaluated cross product is "ugly".
Any help or advice will be greatly appreciated.
> restart
> with(LinearAlgebra):
> R := Vector(3, [x, y, z])
                                                 R := [x, y, z]
> V := Vector(3, [u, v, w])
                                                 V := [u, v, w]
>R x V
                                                [-vz + wy, uz - wx, -uy + vx]
>'R x V'
                                               Typesetting:-delayCrossProduct(R,V)
>CrossProduct(R, V)
>'CrossProduct(R,V)'
                                               LinearAlgebra:-CrossProduct(R,V)
> R &x V
'R &x V'
                                               LinearAlgebra:-&x(R,V)
Can any one disprove maple answer in the attached document?
If not, what is the conclusion?
coulditbe(3*I > 0)
coulditbe(3*I > 0)
coulditbe(3*I < 0)
coulditbe(-2+3*I = 0)
coulditbe(abs(I) > 0)
coulditbe(2+3*I < 0)
What is your opinion?
My opinion from the above is : When a is real and b is complex, a and b can not be compared.
Like number of goats and number of lions  can not be added to give an answer in number of lions alone or number of goats alone!!
Riemann's function Zeta is a function of Complex number
solve(abs(Zeta(s+2*I)) = 0, s)
-2*I+RootOf(Zeta(_Z))
-2.0000-2.*I
solve(Zeta(s+2*I) = 0, s)
-2.0000-2.*I
What does the above results convey??
Am I correct if i state that 's' should be a complex number only and not a real number.
Download s_is_complex.mw
s_is_complex.mw
Is there any way to solve sin(x)=0 with solutions x=k*pi in Maple?
Many thanks!
Hey, guys. Can you help me one more time about the non-homogeneous differential equation, the function is shown below:
ODE:
y''(x)-0.00003019*y(x)^0.337=[9.542*10^(-13)]*x  ;    0<=x<=2945
BCs:
y(0)=0; y'(2945)=0;
Actually, the right part is applied bending moment due to own weight. it is very small, but I don't think I may neglect it.  The exact solution is the best answer for me, the numerical solution is also available for me.  Can you show your code of Maple? Thank you for your any help in advance.   Sincerely, I appreciate it so so so much!!!
I use the convert(real_number, string) Maple 18 function and get the following :
tmp:=convert(0.0141,string); # I get ".141e-1"  What I really want is : "0.0141"
Is there any other way to convert a real number and leave it in its original form ?
I have a expression with polylog functions.I want to simplifying to Pi's constans.I tired with:
1. simplify
2. convert
but seems dosen't work:
simplify(sum((sin(k)/k)^7, k = 0 .. infinity))
#1+(1/128*I)*polylog(7, exp(7*I))-(7/128*I)*polylog(7, exp(5*I))+(21/128*I)*polylog(7, exp(3*I))-
(35/128*I)*polylog(7, exp(I))+(35/128*I)*polylog(7, exp(-I))-(21/128*I)*polylog(7, exp(-3*I))+
(7/128*I)*polylog(7, exp(-5*I))-(1/128*I)*polylog(7, exp(-7*I))
 Mathematica give me:
How to do it in Maple?
My problem is fitting two complex-valued functions f and g:
|f(x,a,b,c)-g(x)|^2 < epsilon
I want to find best approximation for a, b and c where parameters are real.
Can you suggest the method to solve this problem?
I have the analytic form of the functions f and g.
First 954 955 956 957 958 959 960 Last Page 956 of 2460
