I can't take the inverse laplace transform of one kind of functions.
Would you like to help me?
hello,
i went to plot a complex numerical solution , i used odeplot but did not work
please help
Thank you very much
restart; with(plots)
L := 1;
R := 0.57e-1;
0.57e-1
V := evalf(Pi*R^2*L);
0.1020703453e-1
pcy := m/V;
97.97164858*m
Am := 0.6e-1;
0.6e-1
k := evalf(2*Pi/(1.56*T*T));
4.027682890/T^2
h := 10; -1; zz := h+Am*cos(omega*t)
10+0.6e-1*cos(omega*t)
g := 9.81;
9.81
pe := 1025;
1025
T := 3.57;
3.57
omega := 2*Pi/T;
1.759995884
m := (1/2)*pe*evalf(Pi*R^2*L);
5.231105195
eq := m*(diff(z(t), `$`(t, 2)))-pe*g*L*R^2-pe*L*R^2*(diff(z(t), `$`(t, 2)))+I*R^3*pe*L*cosh(k*(zz+h))*cos(omega*t)*exp(-I*omega*t)/cosh(k*h)
1.900880195*(diff(diff(z(t), t), t))-32.66950725+(0.1607410765e-1*I)*cosh(6.320462130+0.1896138639e-1*cos(1.759995884*t))*cos(1.759995884*t)*exp(-(1.759995884*I)*t)
csi := z(0) = 0, (D(z))(0) = 0;
(14)
sol := dsolve({csi, eq}, numeric, maxfun = 0):
sol2 := simplify(evalf(expand(sol))):
fg1 := evalc(Re(sol)):
odeplot(rhs(sol), [t, z(t)], t = 0 .. 3, labels = ["t", "z(t)"], color = blue, thickness = 1, legend = ["z(t) "], axes = boxed)
Error, invalid input: rhs received sol, which is not valid for its 1st argument, expr
complexplot(sol, [t, z(t)], t = 0 .. 3, labels = ["t", "z(t)"], color = blue, thickness = 1, legend = ["z(t) "], axes = boxed)
Error, (in plots:-complexplot) invalid input: `plots/complexplot` expects its 2nd argument, r, to be of type {range, name = range}, but received [t, z(t)]
Download mapleprime.mwmapleprime.mw
I created a loop to calculate, using random numbers, the probability of a die roll. I got 0, which I originally attributed to the fact that the probability might have just been that low, but in comparing it to a binomial distribution, it shouldn't be 0.
I tried editing the loop to do a coin toss instead, where the probability is 0.5, and that worked fine. So I don't think my loop structure is necessarily wrong. But perhaps I wrongly input getting a 0.167 probability somehow.
Any advice would be appreciated!
dierollfail.mw
https://drive.google.com/file/d/0Bxs_ao6uuBDUNmd5ZVJtX29GT3c/view?usp=sharing
https://drive.google.com/file/d/0Bxs_ao6uuBDUSUdHSTcwSEQtS3M/view?usp=sharing
would like to return K map of P1
Summation expression for logic only consider 1 but how about wildcard x ?
if consider wildcard x as 1 too, then will use below
source = [[0,0,1,0],[0,0,1,1],[0,1,0,1],[0,1,1,0],[0,1,1,1],[1,0,0,0],[1,0,0,1],[1,0,1,0],[1,0,1,1],[1,1,0,0],[1,1,0,1],[1,1,1,0],[1,1,1,1]];
i use Quine Mccluskey algorithm
got result below
wildcard is 5 or x
[[0, 5, 1, 5], [5, 0, 1, 5], [5, 5, 1, 0], [1, 0, 5, 5], [1, 5, 0, 5], [1, 5, 5, 0], [5, 5, 1, 1], [5, 1, 5, 1], [5, 1, 1, 5], [1, 5, 5, 1], [1, 5, 1, 5], [1, 1, 5, 5]]
A'C + B'C + CD' + AB' + AC' + AD' + CD + BD + BC + AD + AC + AB
table1 = [[0,0,0,0],
[0,0,0,1],
[0,0,1,0],
[0,0,1,1],
[0,1,0,0],
[0,1,0,1],
[0,1,1,0],
[0,1,1,1],
[1,0,0,0],
[1,0,0,1],
[1,0,1,0],
[1,0,1,1],
[1,1,0,0],
[1,1,0,1],
[1,1,1,0],
[1,1,1,1]];
loand(lonot(tt[0]),tt[2])
loand(lonot(tt[1]),tt[2])
loand(lonot(tt[3]),tt[2])
loand(lonot(tt[1]),tt[0])
loand(lonot(tt[2]),tt[0])
loand(lonot(tt[3]),tt[0])
loand(tt[2],tt[3])
loand(tt[1],tt[3])
loand(tt[1],tt[2])
loand(tt[0],tt[3])
loand(tt[0],tt[2])
loand(tt[0],tt[1])
loor(loor(loor(loor(loor(loor(loor(loor(loor(loor(loor(loand(lonot(tt[0]),tt[2]),
loand(lonot(tt[1]),tt[2])),
loand(lonot(tt[3]),tt[2])),
loand(lonot(tt[1]),tt[0])),
loand(lonot(tt[2]),tt[0])),
loand(lonot(tt[3]),tt[0])),
loand(tt[2],tt[3])),
loand(tt[1],tt[3])),
loand(tt[1],tt[2])),
loand(tt[0],tt[3])),
loand(tt[0],tt[2])),
loand(tt[0],tt[1]));
def lonot(z):
    if z == 1:
        return 0
    else:
        return 1
def loand(a, b):
    if a == 1 and b == 1:
        return 1
    else:
        return 0
def loor(a, b):
    if a == 0 and b == 0:
        return 0
    else:
        return 1
#A'C + B'C + AB' + CD + A'BD
for tt in table1:
    print loor(loor(loor(loor(loor(loor(loor(loor(loor(loor(loor(loand(lonot(tt[0]),tt[2]),
finally i use python to verify
return
seems correct if wildcard is 1 too, but
can boolean simplify function simplify this
to
C + A + B.D   which is
P1 = D + Q0 + Q1.N in png file ?
Hi, friends
I need to calculate the double integral over a non-rectangular domain.
Say, the domain is the triangle (in red)
When I enter
int(int((x^2+y^2)*`if`((y-x-1/2 <= 0) and (y+2*x-2<=0) and (y+x/2-1/2>=0), 1, 0), x=0..1, numeric = true), y=0..1, numeric = true);
or
int(int((x^2+y^2)*eval(`if`((y-x-1/2 <= 0) and (y+2*x-2<=0) and (y+x/2-1/2>=0), 1, 0)), x=0..1, numeric = true), y=0..1, numeric = true);
an error occur (Error, (in int) cannot determine if this expression is true or false: y-x <= 1/2 and y+2*x <= 2 and 0 <= y+(1/2)*x-1/2)
For me, it is desirable to write boundary conditions in the int operator itself, not as a separate expession.
Regarding my recent question http://www.mapleprimes.com/questions/221909-How-To-Extract-Data-From-Implicit-Function I would like to share an interesting observation. Here the code of the program:
R0 := ln(y)+Re(Psi(1/2+(2*(p^2+(1/2)*sqrt(2*I+4*ksi_fs^2*p^2)*tanh(sqrt(2*I+4*ksi_fs^2*p^2)*x)/(tau+0.5e-2*a)))/y))+gamma+2*ln(2)
tau:= 10.000:ksi_fs:=10:p:=0.037:
R0p:= unapply(R0, [a,x]):
R0f:= proc(a,x)
local r:= fsolve(R0p(a,x), y= 0..1);
   `if`(r::float, r, Float(undefined))
M:= Matrix(
   (100,100),
   (i,j)-> R0f(i, 1 + (j-1)*(0.5-0)/(100-1)),
   datatype= float[8]
After approximately 2 hours of calculations I get a message window
But I repeat this calculations on another computer with the same Windows 7 64 bit and Maple 17 I don't get such error and I obtain desired data.
So can Maple be sensitive to the hardware?
I don't like the font times new roman in Math 2D input. Can't find where to set a font anywhere except in the head at a new worksheet. But that alters immediately after executing a command. There should be a place in preferences at least to do a persistent change of font.
I want to calculate the Jacobian of my function in terms of x,y,z. It is a Gerstner function and I need to caculate the normal of the displaced point. This can be achieved by getting the Jacobian Matrix. However when using Maple it isn't caculating it. The way I'm calling it is below. I have a vector function for tx,ty,tz:
with(VectorCalculus);
Jacobian([tx, ty, tz], [x, y]);
I'm not well versed in Maple I was wondering if anyone can help me out on how to get the Jacobian Matrix for tx,ty,tz
Best Regards
Paul
Hello everyone.
Please I am trying to obtain series expansion of the expression below in u and v up to order 30 but encounter difficulties cum maple is slow to display solution. Can I get help on the code and what to do to optimize the displayed time of maple?
Thank you in anticipation of your quick and positive responses and suggestions.
convert(series(convert(series((y[n]+((-8 h u^2 v^2-4 u^3 sin(u) h+2 sin(2 u) h u^3+2 sin(2 v) h v^3-4 v^3 h sin(v)+2 v^3 h sin(2 u+v)+2 u^3 h sin(u-2 v)+2 u^3 h sin(u+2 v)-2 v^3 h sin(2 u-v)-u^3 h sin(2 u+2 v)-v^3 h sin(2 u+2 v)-u^3 h sin(2 u-2 v)+v^3 h sin(2 u-2 v)+4 h u^3 v^2 sin(2 u)+4 h u^2 v^3 sin(2 v)-4 h u^3 v^2 sin(u-v)+4 h u^2 v^3 sin(u-v)-4 h u^3 v^2 sin(u+v)-4 h u^2 v^3 sin(u+v)+4 h u^2 v^2 cos(u)+4 h u^2 v^2 cos(2 u)+4 h u^2 v^2 cos(2 v)+4 h u^2 v^2 cos(v)-4 h u^3 v cos(2 u-v)-2 h u^2 v^2 cos(2 u-v)+2 h u v^3 cos(2 u-v)+4 h u^3 v cos(2 u+v)-2 h u^2 v^2 cos(2 u+v)-2 h u v^3 cos(2 u+v)+2 h u^3 v cos(u-2 v)-2 h u^2 v^2 cos(u-2 v)-4 h u v^3 cos(u-2 v)-2 h u^3 v cos(u+2 v)-2 h u^2 v^2 cos(u+2 v)+4 h u v^3 cos(u+2 v)+4 h u^3 v cos(u-v)+4 h u v^3 cos(u-v)-4 h u^3 v cos(u+v)-4 h u v^3 cos(u+v)+4 u sin(u) v^2 h-2 sin(2 u) h u v^2-2 sin(2 v) h u^2 v+4 v h sin(v) u^2-2 v u^2 h sin(2 u+v)-2 u v^2 h sin(u-2 v)-2 u v^2 h sin(u+2 v)+2 v u^2 h sin(2 u-v)+v u^2 h sin(2 u+2 v)+u v^2 h sin(2 u+2 v)-v u^2 h sin(2 u-2 v)+u v^2 h sin(2 u-2 v)) f[n])/(-12 u^2 v^2+4 sin(u) u^3 v^2+4 sin(2 u) u^3 v^2+4 sin(2 v) u^2 v^3+4 sin(v) u^2 v^3-2 sin(2 u+v) u^3 v^2+2 sin(2 u+v) u^2 v^3-4 sin(u-v) u^3 v^2+4 sin(u-v) u^2 v^3-4 sin(u+v) u^3 v^2-4 sin(u+v) u^2 v^3+2 sin(u-2 v) u^3 v^2+2 sin(u-2 v) u^2 v^3+2 sin(u+2 v) u^3 v^2-2 sin(u+2 v) u^2 v^3-2 sin(2 u-v) u^3 v^2-2 sin(2 u-v) u^2 v^3+8 cos(u) u^2 v^2+4 cos(2 u) u^2 v^2+4 cos(2 v) u^2 v^2+8 cos(v) u^2 v^2-2 cos(2 u-v) u^3 v-4 cos(2 u-v) u^2 v^2-2 cos(2 u-v) u v^3+2 cos(2 u+v) u^3 v-4 cos(2 u+v) u^2 v^2+2 cos(2 u+v) u v^3-2 cos(u-2 v) u^3 v-4 cos(u-2 v) u^2 v^2-2 cos(u-2 v) u v^3+2 cos(u+2 v) u^3 v-4 cos(u+2 v) u^2 v^2+2 cos(u+2 v) u v^3-cos(2 u+2 v) u^3 v+2 cos(2 u+2 v) u^2 v^2-cos(2 u+2 v) u v^3+cos(2 u-2 v) u^3 v+2 cos(2 u-2 v) u^2 v^2+cos(2 u-2 v) u v^3+4 cos(u-v) u^3 v+4 cos(u-v) u v^3-4 cos(u+v) u^3 v-4 cos(u+v) u v^3)+((-8 h u^2 v^2+8 u^3 sin(u) h-4 sin(2 u) h u^3-4 sin(2 v) h v^3+8 v^3 h sin(v)-4 v^3 h sin(2 u+v)-4 u^3 h sin(u-2 v)-4 u^3 h sin(u+2 v)+4 v^3 h sin(2 u-v)+2 u^3 h sin(2 u+2 v)+2 v^3 h sin(2 u+2 v)+2 u^3 h sin(2 u-2 v)-2 v^3 h sin(2 u-2 v)+8 h u^3 v^2 sin(u)+8 h u^2 v^3 sin(v)-4 h u^3 v^2 sin(2 u+v)+4 h u^2 v^3 sin(2 u+v)+4 h u^3 v^2 sin(u-2 v)+4 h u^2 v^3 sin(u-2 v)+4 h u^3 v^2 sin(u+2 v)-4 h u^2 v^3 sin(u+2 v)-4 h u^3 v^2 sin(2 u-v)-4 h u^2 v^3 sin(2 u-v)+8 h u^2 v^2 cos(u)+8 h u^2 v^2 cos(v)+4 h u^3 v cos(2 u-v)-4 h u^2 v^2 cos(2 u-v)-8 h u v^3 cos(2 u-v)-4 h u^3 v cos(2 u+v)-4 h u^2 v^2 cos(2 u+v)+8 h u v^3 cos(2 u+v)-8 h u^3 v cos(u-2 v)-4 h u^2 v^2 cos(u-2 v)+4 h u v^3 cos(u-2 v)+8 h u^3 v cos(u+2 v)-4 h u^2 v^2 cos(u+2 v)-4 h u v^3 cos(u+2 v)-2 h u^3 v cos(2 u+2 v)+4 h u^2 v^2 cos(2 u+2 v)-2 h u v^3 cos(2 u+2 v)+2 h u^3 v cos(2 u-2 v)+4 h u^2 v^2 cos(2 u-2 v)+2 h u v^3 cos(2 u-2 v)-8 u sin(u) v^2 h+4 sin(2 u) h u v^2+4 sin(2 v) h u^2 v-8 v h sin(v) u^2+4 v u^2 h sin(2 u+v)+4 u v^2 h sin(u-2 v)+4 u v^2 h sin(u+2 v)-4 v u^2 h sin(2 u-v)-2 v u^2 h sin(2 u+2 v)-2 u v^2 h sin(2 u+2 v)+2 v u^2 h sin(2 u-2 v)-2 u v^2 h sin(2 u-2 v)) f[n+1])/(-12 u^2 v^2+4 sin(u) u^3 v^2+4 sin(2 u) u^3 v^2+4 sin(2 v) u^2 v^3+4 sin(v) u^2 v^3-2 sin(2 u+v) u^3 v^2+2 sin(2 u+v) u^2 v^3-4 sin(u-v) u^3 v^2+4 sin(u-v) u^2 v^3-4 sin(u+v) u^3 v^2-4 sin(u+v) u^2 v^3+2 sin(u-2 v) u^3 v^2+2 sin(u-2 v) u^2 v^3+2 sin(u+2 v) u^3 v^2-2 sin(u+2 v) u^2 v^3-2 sin(2 u-v) u^3 v^2-2 sin(2 u-v) u^2 v^3+8 cos(u) u^2 v^2+4 cos(2 u) u^2 v^2+4 cos(2 v) u^2 v^2+8 cos(v) u^2 v^2-2 cos(2 u-v) u^3 v-4 cos(2 u-v) u^2 v^2-2 cos(2 u-v) u v^3+2 cos(2 u+v) u^3 v-4 cos(2 u+v) u^2 v^2+2 cos(2 u+v) u v^3-2 cos(u-2 v) u^3 v-4 cos(u-2 v) u^2 v^2-2 cos(u-2 v) u v^3+2 cos(u+2 v) u^3 v-4 cos(u+2 v) u^2 v^2+2 cos(u+2 v) u v^3-cos(2 u+2 v) u^3 v+2 cos(2 u+2 v) u^2 v^2-cos(2 u+2 v) u v^3+cos(2 u-2 v) u^3 v+2 cos(2 u-2 v) u^2 v^2+cos(2 u-2 v) u v^3+4 cos(u-v) u^3 v+4 cos(u-v) u v^3-4 cos(u+v) u^3 v-4 cos(u+v) u v^3)+((-8 h u^2 v^2-4 u^3 sin(u) h+2 sin(2 u) h u^3+2 sin(2 v) h v^3-4 v^3 h sin(v)+2 v^3 h sin(2 u+v)+2 u^3 h sin(u-2 v)+2 u^3 h sin(u+2 v)-2 v^3 h sin(2 u-v)-u^3 h sin(2 u+2 v)-v^3 h sin(2 u+2 v)-u^3 h sin(2 u-2 v)+v^3 h sin(2 u-2 v)+4 h u^3 v^2 sin(2 u)+4 h u^2 v^3 sin(2 v)-4 h u^3 v^2 sin(u-v)+4 h u^2 v^3 sin(u-v)-4 h u^3 v^2 sin(u+v)-4 h u^2 v^3 sin(u+v)+4 h u^2 v^2 cos(u)+4 h u^2 v^2 cos(2 u)+4 h u^2 v^2 cos(2 v)+4 h u^2 v^2 cos(v)-4 h u^3 v cos(2 u-v)-2 h u^2 v^2 cos(2 u-v)+2 h u v^3 cos(2 u-v)+4 h u^3 v cos(2 u+v)-2 h u^2 v^2 cos(2 u+v)-2 h u v^3 cos(2 u+v)+2 h u^3 v cos(u-2 v)-2 h u^2 v^2 cos(u-2 v)-4 h u v^3 cos(u-2 v)-2 h u^3 v cos(u+2 v)-2 h u^2 v^2 cos(u+2 v)+4 h u v^3 cos(u+2 v)+4 h u^3 v cos(u-v)+4 h u v^3 cos(u-v)-4 h u^3 v cos(u+v)-4 h u v^3 cos(u+v)+4 u sin(u) v^2 h-2 sin(2 u) h u v^2-2 sin(2 v) h u^2 v+4 v h sin(v) u^2-2 v u^2 h sin(2 u+v)-2 u v^2 h sin(u-2 v)-2 u v^2 h sin(u+2 v)+2 v u^2 h sin(2 u-v)+v u^2 h sin(2 u+2 v)+u v^2 h sin(2 u+2 v)-v u^2 h sin(2 u-2 v)+u v^2 h sin(2 u-2 v)) f[n+2])/(-12 u^2 v^2+4 sin(u) u^3 v^2+4 sin(2 u) u^3 v^2+4 sin(2 v) u^2 v^3+4 sin(v) u^2 v^3-2 sin(2 u+v) u^3 v^2+2 sin(2 u+v) u^2 v^3-4 sin(u-v) u^3 v^2+4 sin(u-v) u^2 v^3-4 sin(u+v) u^3 v^2-4 sin(u+v) u^2 v^3+2 sin(u-2 v) u^3 v^2+2 sin(u-2 v) u^2 v^3+2 sin(u+2 v) u^3 v^2-2 sin(u+2 v) u^2 v^3-2 sin(2 u-v) u^3 v^2-2 sin(2 u-v) u^2 v^3+8 cos(u) u^2 v^2+4 cos(2 u) u^2 v^2+4 cos(2 v) u^2 v^2+8 cos(v) u^2 v^2-2 cos(2 u-v) u^3 v-4 cos(2 u-v) u^2 v^2-2 cos(2 u-v) u v^3+2 cos(2 u+v) u^3 v-4 cos(2 u+v) u^2 v^2+2 cos(2 u+v) u v^3-2 cos(u-2 v) u^3 v-4 cos(u-2 v) u^2 v^2-2 cos(u-2 v) u v^3+2 cos(u+2 v) u^3 v-4 cos(u+2 v) u^2 v^2+2 cos(u+2 v) u v^3-cos(2 u+2 v) u^3 v+2 cos(2 u+2 v) u^2 v^2-cos(2 u+2 v) u v^3+cos(2 u-2 v) u^3 v+2 cos(2 u-2 v) u^2 v^2+cos(2 u-2 v) u v^3+4 cos(u-v) u^3 v+4 cos(u-v) u v^3-4 cos(u+v) u^3 v-4 cos(u+v) u v^3)+((-6 u^2 h^2-6 v^2 h^2-4 cos(2 u) h^2 u^2 v^2-4 cos(2 v) h^2 u^2 v^2+8 v^2 u^2 h^2 cos(u-v)+8 v^2 u^2 h^2 cos(u+v)+8 u sin(u) v^2 h^2+8 sin(2 u) h^2 u v^2+8 sin(2 v) h^2 u^2 v+8 v h^2 sin(v) u^2+4 v u^2 h^2 sin(2 u+v)-4 u v^2 h^2 sin(2 u+v)+8 v u^2 h^2 sin(u-v)-8 sin(u-v) h^2 u v^2-8 v u^2 h^2 sin(u+v)-8 sin(u+v) h^2 u v^2+4 v u^2 h^2 sin(u-2 v)+4 u v^2 h^2 sin(u-2 v)-4 v u^2 h^2 sin(u+2 v)+4 u v^2 h^2 sin(u+2 v)-4 v u^2 h^2 sin(2 u-v)-4 u v^2 h^2 sin(2 u-v)-4 u v h^2 cos(2 u-v)+4 u v h^2 cos(2 u+v)-4 u v h^2 cos(u-2 v)+4 u v h^2 cos(u+2 v)-2 u v h^2 cos(2 u+2 v)+2 u v h^2 cos(2 u-2 v)+8 cos(u-v) h^2 u v-8 cos(u+v) h^2 u v-8 v^2 u^2 h^2+8 h^2 cos(u) u^2-2 cos(2 u) h^2 u^2+6 cos(2 u) h^2 v^2+6 cos(2 v) h^2 u^2-2 cos(2 v) h^2 v^2+8 h^2 cos(v) v^2-4 v^2 h^2 cos(2 u-v)-4 v^2 h^2 cos(2 u+v)-4 u^2 h^2 cos(u-2 v)-4 u^2 h^2 cos(u+2 v)+u^2 h^2 cos(2 u+2 v)+v^2 h^2 cos(2 u+2 v)+u^2 h^2 cos(2 u-2 v)+v^2 h^2 cos(2 u-2 v)) g[n])/(-12 u^2 v^2+4 sin(u) u^3 v^2+4 sin(2 u) u^3 v^2+4 sin(2 v) u^2 v^3+4 sin(v) u^2 v^3-2 sin(2 u+v) u^3 v^2+2 sin(2 u+v) u^2 v^3-4 sin(u-v) u^3 v^2+4 sin(u-v) u^2 v^3-4 sin(u+v) u^3 v^2-4 sin(u+v) u^2 v^3+2 sin(u-2 v) u^3 v^2+2 sin(u-2 v) u^2 v^3+2 sin(u+2 v) u^3 v^2-2 sin(u+2 v) u^2 v^3-2 sin(2 u-v) u^3 v^2-2 sin(2 u-v) u^2 v^3+8 cos(u) u^2 v^2+4 cos(2 u) u^2 v^2+4 cos(2 v) u^2 v^2+8 cos(v) u^2 v^2-2 cos(2 u-v) u^3 v-4 cos(2 u-v) u^2 v^2-2 cos(2 u-v) u v^3+2 cos(2 u+v) u^3 v-4 cos(2 u+v) u^2 v^2+2 cos(2 u+v) u v^3-2 cos(u-2 v) u^3 v-4 cos(u-2 v) u^2 v^2-2 cos(u-2 v) u v^3+2 cos(u+2 v) u^3 v-4 cos(u+2 v) u^2 v^2+2 cos(u+2 v) u v^3-cos(2 u+2 v) u^3 v+2 cos(2 u+2 v) u^2 v^2-cos(2 u+2 v) u v^3+cos(2 u-2 v) u^3 v+2 cos(2 u-2 v) u^2 v^2+cos(2 u-2 v) u v^3+4 cos(u-v) u^3 v+4 cos(u-v) u v^3-4 cos(u+v) u^3 v-4 cos(u+v) u v^3)+((6 u^2 h^2+6 v^2 h^2+4 cos(2 u) h^2 u^2 v^2+4 cos(2 v) h^2 u^2 v^2-8 v^2 u^2 h^2 cos(u-v)-8 v^2 u^2 h^2 cos(u+v)-8 u sin(u) v^2 h^2-8 sin(2 u) h^2 u v^2-8 sin(2 v) h^2 u^2 v-8 v h^2 sin(v) u^2-4 v u^2 h^2 sin(2 u+v)+4 u v^2 h^2 sin(2 u+v)-8 v u^2 h^2 sin(u-v)+8 sin(u-v) h^2 u v^2+8 v u^2 h^2 sin(u+v)+8 sin(u+v) h^2 u v^2-4 v u^2 h^2 sin(u-2 v)-4 u v^2 h^2 sin(u-2 v)+4 v u^2 h^2 sin(u+2 v)-4 u v^2 h^2 sin(u+2 v)+4 v u^2 h^2 sin(2 u-v)+4 u v^2 h^2 sin(2 u-v)+4 u v h^2 cos(2 u-v)-4 u v h^2 cos(2 u+v)+4 u v h^2 cos(u-2 v)-4 u v h^2 cos(u+2 v)+2 u v h^2 cos(2 u+2 v)-2 u v h^2 cos(2 u-2 v)-8 cos(u-v) h^2 u v+8 cos(u+v) h^2 u v+8 v^2 u^2 h^2-8 h^2 cos(u) u^2+2 cos(2 u) h^2 u^2-6 cos(2 u) h^2 v^2-6 cos(2 v) h^2 u^2+2 cos(2 v) h^2 v^2-8 h^2 cos(v) v^2+4 v^2 h^2 cos(2 u-v)+4 v^2 h^2 cos(2 u+v)+4 u^2 h^2 cos(u-2 v)+4 u^2 h^2 cos(u+2 v)-u^2 h^2 cos(2 u+2 v)-v^2 h^2 cos(2 u+2 v)-u^2 h^2 cos(2 u-2 v)-v^2 h^2 cos(2 u-2 v)) g[n+2])/(-12 u^2 v^2+4 sin(u) u^3 v^2+4 sin(2 u) u^3 v^2+4 sin(2 v) u^2 v^3+4 sin(v) u^2 v^3-2 sin(2 u+v) u^3 v^2+2 sin(2 u+v) u^2 v^3-4 sin(u-v) u^3 v^2+4 sin(u-v) u^2 v^3-4 sin(u+v) u^3 v^2-4 sin(u+v) u^2 v^3+2 sin(u-2 v) u^3 v^2+2 sin(u-2 v) u^2 v^3+2 sin(u+2 v) u^3 v^2-2 sin(u+2 v) u^2 v^3-2 sin(2 u-v) u^3 v^2-2 sin(2 u-v) u^2 v^3+8 cos(u) u^2 v^2+4 cos(2 u) u^2 v^2+4 cos(2 v) u^2 v^2+8 cos(v) u^2 v^2-2 cos(2 u-v) u^3 v-4 cos(2 u-v) u^2 v^2-2 cos(2 u-v) u v^3+2 cos(2 u+v) u^3 v-4 cos(2 u+v) u^2 v^2+2 cos(2 u+v) u v^3-2 cos(u-2 v) u^3 v-4 cos(u-2 v) u^2 v^2-2 cos(u-2 v) u v^3+2 cos(u+2 v) u^3 v-4 cos(u+2 v) u^2 v^2+2 cos(u+2 v) u v^3-cos(2 u+2 v) u^3 v+2 cos(2 u+2 v) u^2 v^2-cos(2 u+2 v) u v^3+cos(2 u-2 v) u^3 v+2 cos(2 u-2 v) u^2 v^2+cos(2 u-2 v) u v^3+4 cos(u-v) u^3 v+4 cos(u-v) u v^3-4 cos(u+v) u^3 v-4 cos(u+v) u v^3)),u=0,32),polynom),v=0,32),polynom);
Consider the following:
with(Physics):
Setup(anticommutativeprefix = psi):
psi^2,psi__1^2,psi__a^2;   # double underscores
Why does the square of psi__a (double underscore) not vanish as well? Or, perhaps, more to the point: why is psi__a not as well considered Grassmann-odd by Maple? Is this counter-intuitive behaviour intentional, or is it a bug?
I'm trying to numerically solve the differential equation: y' = -2xy + 1. Naturally, I come across the non-elementary integral of e^(x^2). By hand, I used a 2nd degree MacLaurin polynomial to get y = xe^(-x^2) + x^3/3e^(-x^2)+x^3/6e(-x^2).
How do I use Maple to numerically solve this, with step sizes of h=0.1 and h=0.05 and plot them?
I have a csvfile that contains text and real numbers. As it contains text there must be some trick to force maple read only floating points and then plot it.
The below works fine if the file doesn't contain text:
 A:= ExcelTools :- Import("C:\\Users\\path\\filename.xls");
p1 := plots:-pointplot(A, style = line, linestyle = dash, color = blue);
plots[display]([p1]);
I'm trying to calculate the trajectory of a 3-particle system. I defined my parameters. Wrote a do loop. Got the number of iterations I expected. But when I look at the tables of position for each particle after I run the loop, the trajectory only changes for the first iteration, then it stays the same. In other words, it shows that the particle moved slightly after the first increment of time, but thereafter it doesn't move.
for i to N do x[11] := x[1]+tau*vx[1]+(1/2)*tau^2*F[x1]; y[11] := y[1]+tau*vy[1]+(1/2)*tau^2*F[y1]; x[21] := x[2]+tau*vx[2]+(1/2)*tau^2*F[x2]; y[21] := y[2]+tau*vy[2]+(1/2)*tau^2*F[y2]; x[31] := x[3]+tau*vx[3]+(1/2)*tau^2*F[x3]; y[31] := y[3]+tau*vy[3]+(1/2)*tau^2*F[y3]; R[1] := [op(R[1]), [x[11], y[11]]]; R[2] := [op(R[2]), [x[21], y[21]]]; R[3] := [op(R[3]), [x[31], y[31]]]; V[1] := [op(V[1]), [vx[11], vy[11]]]; V[2] := [op(V[2]), [vx[21], vy[21]]]; V[3] := [op(V[3]), [vx[31], vy[31]]] end do:
101
HI experts,
fibonacci_sequence_with_coefficient.pdf
Is there a Last name associated with a double 'hailstone problem' with variable integer coefficients?
Just curious.
Matt
I am trying to solve system consisting of two equations and two unknowns. I tried solve but it gives back unevaluated then I tried fsolve which gives an error.
restart; x := 2.891022275*`&epsilon;`^4*sin(phi)^5*cos(phi)+1.080128320*`&epsilon;`^8*sin(phi)^11*cos(phi)+.1742483217*`&epsilon;`^10*sin(phi)^9*cos(phi)+3.293959886*`&epsilon;`^4*sin(phi)^15*cos(phi)+0.1414814731e-3*`&epsilon;`^12*sin(phi)*cos(phi)+0.1186386550e-1*`&epsilon;`^10*sin(phi)^3*cos(phi)+4.689119196*`&epsilon;`^2*sin(phi)^11*cos(phi)+.2775645236*`&epsilon;`^8*sin(phi)^5*cos(phi)+2.242139502*`&epsilon;`^6*sin(phi)^7*cos(phi)+6.170463035*`&epsilon;`^4*sin(phi)^9*cos(phi)+.2212715683*`&epsilon;`^2*sin(phi)*cos(phi)+.2565381358*`&epsilon;`^4*sin(phi)*cos(phi)+6.282275004*`&epsilon;`^4*sin(phi)^11*cos(phi)+0.9582543506e-5*`&epsilon;`^14*sin(phi)*cos(phi)+1.375810863*`&epsilon;`^2*sin(phi)^3*cos(phi)+0.4588193106e-1*`&epsilon;`^10*sin(phi)^5*cos(phi)+.6194422970*`&epsilon;`^8*sin(phi)^7*cos(phi)+0.1249753779e-2*`&epsilon;`^12*sin(phi)^3*cos(phi)+3.258184644*`&epsilon;`^6*sin(phi)^9*cos(phi)+3.520102051*`&epsilon;`^2*sin(phi)^13*cos(phi)+0.9608710101e-4*`&epsilon;`^14*sin(phi)^3*cos(phi)+5.222697446*`&epsilon;`^4*sin(phi)^13*cos(phi)+0.4740690151e-6*`&epsilon;`^16*sin(phi)*cos(phi)+.1124269022*`&epsilon;`^10*sin(phi)^7*cos(phi)+0.5349926002e-2*`&epsilon;`^12*sin(phi)^5*cos(phi)+.9885168554*`&epsilon;`^8*sin(phi)^9*cos(phi)+3.656113028*`&epsilon;`^6*sin(phi)^11*cos(phi)+2.252753163*`&epsilon;`^2*sin(phi)^15*cos(phi)+0.1562649478e-2*`&epsilon;`^10*sin(phi)*cos(phi)+0.8234222560e-1*`&epsilon;`^8*sin(phi)^3*cos(phi)+0.1277730241e-1*`&epsilon;`^12*sin(phi)^7*cos(phi)+1.148250169*`&epsilon;`^6*sin(phi)^5*cos(phi)+0.4933078791e-5*`&epsilon;`^16*sin(phi)^3*cos(phi)+4.857729947*`&epsilon;`^4*sin(phi)^7*cos(phi)+5.282506255*`&epsilon;`^2*sin(phi)^9*cos(phi)+0.1560418629e-7*`&epsilon;`^18*sin(phi)*cos(phi)-.6257226193*sin(phi)*cos(phi)+.6645139802*sin(phi)^11*cos(phi)+0.4077214292e-3*`&epsilon;`^14*sin(phi)^5*cos(phi)+.1265580305*sin(phi)^17*cos(phi)+.2494189998*sin(phi)^15*cos(phi)+.4337136311*sin(phi)^13*cos(phi)-.1331733921*sin(phi)^3*cos(phi)+.5467360220*sin(phi)^5*cos(phi)+.8861408610*sin(phi)^7*cos(phi)+4.820745909*`&epsilon;`^2*sin(phi)^7*cos(phi)+1.134364300*`&epsilon;`^2*sin(phi)^17*cos(phi)+0.7437311918e-1*`&epsilon;`^6*sin(phi)*cos(phi)+0.1283200926e-1*`&epsilon;`^8*sin(phi)*cos(phi)+1.168884099*`&epsilon;`^4*sin(phi)^3*cos(phi)+.3981616844*`&epsilon;`^6*sin(phi)^3*cos(phi)+3.270035435*`&epsilon;`^2*sin(phi)^5*cos(phi)+.8667852062*sin(phi)^9*cos(phi)+0.5208654259e-1*sin(phi)^19*cos(phi)+2.975771526*`&epsilon;`^6*sin(phi)^13*cos(phi); y := 2.891022275*`&epsilon;`^4*sin(phi)^5*cos(phi)+1.080128320*`&epsilon;`^8*sin(phi)^11*cos(phi)+.1742483217*`&epsilon;`^10*sin(phi)^9*cos(phi)+3.293959886*`&epsilon;`^4*sin(phi)^15*cos(phi)+0.1414814731e-3*`&epsilon;`^12*sin(phi)*cos(phi)+0.1186386550e-1*`&epsilon;`^10*sin(phi)^3*cos(phi)+4.689119196*`&epsilon;`^2*sin(phi)^11*cos(phi)+.2775645236*`&epsilon;`^8*sin(phi)^5*cos(phi)+2.242139502*`&epsilon;`^6*sin(phi)^7*cos(phi)+6.170463035*`&epsilon;`^4*sin(phi)^9*cos(phi)+.2212715683*`&epsilon;`^2*sin(phi)*cos(phi)+.2565381358*`&epsilon;`^4*sin(phi)*cos(phi)+6.282275004*`&epsilon;`^4*sin(phi)^11*cos(phi)+0.9582543506e-5*`&epsilon;`^14*sin(phi)*cos(phi)+1.375810863*`&epsilon;`^2*sin(phi)^3*cos(phi)+0.4588193106e-1*`&epsilon;`^10*sin(phi)^5*cos(phi)+.6194422970*`&epsilon;`^8*sin(phi)^7*cos(phi)+0.1249753779e-2*`&epsilon;`^12*sin(phi)^3*cos(phi)+3.258184644*`&epsilon;`^6*sin(phi)^9*cos(phi)+3.520102051*`&epsilon;`^2*sin(phi)^13*cos(phi)+0.9608710101e-4*`&epsilon;`^14*sin(phi)^3*cos(phi)+5.222697446*`&epsilon;`^4*sin(phi)^13*cos(phi)+0.4740690151e-6*`&epsilon;`^16*sin(phi)*cos(phi)+.1124269022*`&epsilon;`^10*sin(phi)^7*cos(phi)+0.5349926002e-2*`&epsilon;`^12*sin(phi)^5*cos(phi)+.9885168554*`&epsilon;`^8*sin(phi)^9*cos(phi)+3.656113028*`&epsilon;`^6*sin(phi)^11*cos(phi)+2.252753163*`&epsilon;`^2*sin(phi)^15*cos(phi)+0.1562649478e-2*`&epsilon;`^10*sin(phi)*cos(phi)+0.8234222560e-1*`&epsilon;`^8*sin(phi)^3*cos(phi)+0.1277730241e-1*`&epsilon;`^12*sin(phi)^7*cos(phi)+1.148250169*`&epsilon;`^6*sin(phi)^5*cos(phi)+0.4933078791e-5*`&epsilon;`^16*sin(phi)^3*cos(phi)+4.857729947*`&epsilon;`^4*sin(phi)^7*cos(phi)+5.282506255*`&epsilon;`^2*sin(phi)^9*cos(phi)+0.1560418629e-7*`&epsilon;`^18*sin(phi)*cos(phi)-.6257226193*sin(phi)*cos(phi)+.6645139802*sin(phi)^11*cos(phi)+0.4077214292e-3*`&epsilon;`^14*sin(phi)^5*cos(phi)+.1265580305*sin(phi)^17*cos(phi)+.2494189998*sin(phi)^15*cos(phi)+.4337136311*sin(phi)^13*cos(phi)-.1331733921*sin(phi)^3*cos(phi)+.5467360220*sin(phi)^5*cos(phi)+.8861408610*sin(phi)^7*cos(phi)+4.820745909*`&epsilon;`^2*sin(phi)^7*cos(phi)+1.134364300*`&epsilon;`^2*sin(phi)^17*cos(phi)+0.7437311918e-1*`&epsilon;`^6*sin(phi)*cos(phi)+0.1283200926e-1*`&epsilon;`^8*sin(phi)*cos(phi)+1.168884099*`&epsilon;`^4*sin(phi)^3*cos(phi)+.3981616844*`&epsilon;`^6*sin(phi)^3*cos(phi)+3.270035435*`&epsilon;`^2*sin(phi)^5*cos(phi)+.8667852062*sin(phi)^9*cos(phi)+0.5208654259e-1*sin(phi)^19*cos(phi)+2.975771526*`&epsilon;`^6*sin(phi)^13*cos(phi); evalf(solve({x = 0, y = 0}, {phi, `&epsilon;`})); fsolve({x = 0, y = 0}, {phi, `&epsilon;`})
.9885168554*`&epsilon;`^8*sin(phi)^9*cos(phi)+0.1249753779e-2*`&epsilon;`^12*sin(phi)^3*cos(phi)+3.258184644*`&epsilon;`^6*sin(phi)^9*cos(phi)+.1124269022*`&epsilon;`^10*sin(phi)^7*cos(phi)+0.4588193106e-1*`&epsilon;`^10*sin(phi)^5*cos(phi)+.2565381358*`&epsilon;`^4*sin(phi)*cos(phi)+6.282275004*`&epsilon;`^4*sin(phi)^11*cos(phi)+0.4933078791e-5*`&epsilon;`^16*sin(phi)^3*cos(phi)+5.282506255*`&epsilon;`^2*sin(phi)^9*cos(phi)+2.242139502*`&epsilon;`^6*sin(phi)^7*cos(phi)+6.170463035*`&epsilon;`^4*sin(phi)^9*cos(phi)+0.8234222560e-1*`&epsilon;`^8*sin(phi)^3*cos(phi)+0.9608710101e-4*`&epsilon;`^14*sin(phi)^3*cos(phi)+3.656113028*`&epsilon;`^6*sin(phi)^11*cos(phi)+5.222697446*`&epsilon;`^4*sin(phi)^13*cos(phi)+0.1562649478e-2*`&epsilon;`^10*sin(phi)*cos(phi)+.6194422970*`&epsilon;`^8*sin(phi)^7*cos(phi)+3.520102051*`&epsilon;`^2*sin(phi)^13*cos(phi)+0.1186386550e-1*`&epsilon;`^10*sin(phi)^3*cos(phi)+4.689119196*`&epsilon;`^2*sin(phi)^11*cos(phi)+1.375810863*`&epsilon;`^2*sin(phi)^3*cos(phi)+0.4740690151e-6*`&epsilon;`^16*sin(phi)*cos(phi)+0.4077214292e-3*`&epsilon;`^14*sin(phi)^5*cos(phi)+0.9582543506e-5*`&epsilon;`^14*sin(phi)*cos(phi)+0.5349926002e-2*`&epsilon;`^12*sin(phi)^5*cos(phi)+.1742483217*`&epsilon;`^10*sin(phi)^9*cos(phi)+1.148250169*`&epsilon;`^6*sin(phi)^5*cos(phi)+0.1277730241e-1*`&epsilon;`^12*sin(phi)^7*cos(phi)+0.7437311918e-1*`&epsilon;`^6*sin(phi)*cos(phi)+1.080128320*`&epsilon;`^8*sin(phi)^11*cos(phi)+2.975771526*`&epsilon;`^6*sin(phi)^13*cos(phi)+1.134364300*`&epsilon;`^2*sin(phi)^17*cos(phi)+3.293959886*`&epsilon;`^4*sin(phi)^15*cos(phi)+1.168884099*`&epsilon;`^4*sin(phi)^3*cos(phi)+3.270035435*`&epsilon;`^2*sin(phi)^5*cos(phi)+0.1283200926e-1*`&epsilon;`^8*sin(phi)*cos(phi)+4.820745909*`&epsilon;`^2*sin(phi)^7*cos(phi)+.3981616844*`&epsilon;`^6*sin(phi)^3*cos(phi)+2.891022275*`&epsilon;`^4*sin(phi)^5*cos(phi)+0.1414814731e-3*`&epsilon;`^12*sin(phi)*cos(phi)+.2212715683*`&epsilon;`^2*sin(phi)*cos(phi)+2.252753163*`&epsilon;`^2*sin(phi)^15*cos(phi)+4.857729947*`&epsilon;`^4*sin(phi)^7*cos(phi)+.2775645236*`&epsilon;`^8*sin(phi)^5*cos(phi)+0.1560418629e-7*`&epsilon;`^18*sin(phi)*cos(phi)-.6257226193*sin(phi)*cos(phi)+.8667852062*sin(phi)^9*cos(phi)+0.5208654259e-1*sin(phi)^19*cos(phi)+.1265580305*sin(phi)^17*cos(phi)+.2494189998*sin(phi)^15*cos(phi)+.4337136311*sin(phi)^13*cos(phi)-.1331733921*sin(phi)^3*cos(phi)+.5467360220*sin(phi)^5*cos(phi)+.8861408610*sin(phi)^7*cos(phi)+.6645139802*sin(phi)^11*cos(phi)
{phi = 0., `&epsilon;` = `&epsilon;`}, {phi = 1.570796327, `&epsilon;` = `&epsilon;`}, {phi = phi, `&epsilon;` = RootOf(1560418629*_Z^18+(47406901510+493307879100*sin(phi)^2)*_Z^16+(40772142920000*sin(phi)^4+9608710101000*sin(phi)^2+958254350600)*_Z^14+(14148147310000+124975377900000*sin(phi)^2+534992600200000*sin(phi)^4+1277730241000000*sin(phi)^6)*_Z^12+(11242690220000000*sin(phi)^6+1186386550000000*sin(phi)^2+17424832170000000*sin(phi)^8+156264947800000+4588193106000000*sin(phi)^4)*_Z^10+(8234222560000000*sin(phi)^2+61944229700000000*sin(phi)^6+98851685540000000*sin(phi)^8+108012832000000000*sin(phi)^10+27756452360000000*sin(phi)^4+1283200926000000)*_Z^8+(7437311918000000+114825016900000000*sin(phi)^4+297577152600000000*sin(phi)^12+325818464400000000*sin(phi)^8+365611302800000000*sin(phi)^10+224213950200000000*sin(phi)^6+39816168440000000*sin(phi)^2)*_Z^6+(485772994700000000*sin(phi)^6+628227500400000000*sin(phi)^10+522269744600000000*sin(phi)^12+329395988600000000*sin(phi)^14+25653813580000000+617046303500000000*sin(phi)^8+116888409900000000*sin(phi)^2+289102227500000000*sin(phi)^4)*_Z^4+(22127156830000000+137581086300000000*sin(phi)^2+468911919600000000*sin(phi)^10+352010205100000000*sin(phi)^12+225275316300000000*sin(phi)^14+528250625500000000*sin(phi)^8+327003543500000000*sin(phi)^4+113436430000000000*sin(phi)^16+482074590900000000*sin(phi)^6)*_Z^2-62572261930000000-13317339210000000*sin(phi)^2+12655803050000000*sin(phi)^16+54673602200000000*sin(phi)^4+86678520620000000*sin(phi)^8+43371363110000000*sin(phi)^12+66451398020000000*sin(phi)^10+88614086100000000*sin(phi)^6+24941899980000000*sin(phi)^14+5208654259000000*sin(phi)^18)}
Error, (in fsolve) number of equations, 1, does not match number of variables, 2
Download equations_solve.mw
First 991 992 993 994 995 996 997 Last Page 993 of 2460
