In some cases, maple is able to return a series expansion when line A is called but fails to do so when line B is called, and in the help page for asympt it defines them to be identical procedures:
A: asympt(f,z)
B:
this has generally occured when ever the function f is of the form:
where g(z) has an asymptotic expansion and when asympt(f,z) is called, maple provides this expansion divided by the exponential function, however line B as prescribed above returns an error.
So, my question is, which line in showstat(asympt) is responsible for catching the error which line B as above encounters?
I am computing some finite points in the plane. Then I'm using point style plot to plot them. My points have order and I want to conncet the i-th point to the (i+1)-th point with a line segment. I searched the help but I didn't figure out how to do it. Is it possible to do this in Maple?
If I just want to define an itegral and do not want maple to simplify it to a closed form, what should I do?
For example, I want define
s := int(exp(-x^2)*cos(2*x*y), x = 0 .. infinity).
Maple automatically simplify s to
(1/2)*sqrt(Pi)/exp(y^2)
But I want to keep s in integral form.
Is there any method or a command to use or type so Maple start running something or evaluating and if it took more than a specific amount of time, then itself automatically stops itself without needing me to interrupt the evaluation?
For example let's say I wrote a proc, for some inputs it may compute the output fast but in some it may even don't answer after hours. Now I am writing a for and I don't know for which steps it can answer in less than a minute. So I like to add something so that Maple starts the FOR but in steps that it takes more than a minute, it automatically stops evaluation at that step and jump to the next step.
I have a linear system and I would like to generate the matrix from the linear system of equations
MatrixAgenerating.mw
Many thanks for your help
I am trying to plot some graphs for a differential equations class. I need to plot two equations (soln1a, soln1b1) in one graph, with the two curves overlayed on each other. I am trying to plot them on a graph named "gr1c". The error I get says "Error, (in plots/multiple) empty plot". Clicking on the error results in a webpage saying that "There is no help page available for this error".
When I plot each equation separately, there are no errors. The graphing command that works for soln1a is
gr1a:=plot(rhs(soln1a),dom1,color=blue);
and the graphing command that works for soln1b1 is
gr1b1:=plot(rhs(soln1b_1),dom1,color=purple);
My code is as follows. I would greatly appreciate any help ASAP to remove the error. Thank you!
with(plots):with(DEtools):
K:=9;
deG:=diff(theta(t),t,t) + mu*diff(theta(t),t)+K*sin(theta(t))= 0;
deL:=diff(theta(t),t,t) + mu*diff(theta(t),t)+K*theta(t)= 0;
Iv:=theta(0)=0.75, D(theta)(0)=2.0;
dom1:=t=0..10;
soln1a:=dsolve({eval(deL,mu=0),Iv});
soln1b_1:=dsolve({eval(deL,mu=1),Iv});
gr1c:=multiple(plot[soln1a,soln1b1],dom1,color=[blue,purple]);
Unfortunately, the Differential Geometry package is too difficult for non-mathematicians. Is there a package in the Maple for classical differential geometry?
dear all,
I have a problem when I try to find points on boundary of the surface.
the surface ploted from a matrix as follow:
please help me to generate a bondary curve of this surface.
I want to plot three different plots but not at once! I mean I want to have an animated plot / gif file which shows the plots one by one:
first plot1, then plot2 is added, and at the end plot 3 is added!
Let's say my plots are
plot1:=plot(x,x=0..3)
plot2:=plot(x^2,x=0..3)
plot3:=plot(x^3,x=0..3)
Do you have any suggestions for me?
I have made a program to plot y(t) vs x(t). Can you please modify to plot y vs x data from an excel file.
Given x in A column and y in B column in 5 rows.
Example data: [[1,1],[2,4],[3,9],[4,16],[5,26]]
StLine_VRK.msim
Ramakrishnan V
x dot produces x dot (t)
How do I suppress the t in the output display?  The help page shows an Unsuppress all so I thought a Typsetting:-Suppress(all) would do it, but it throws an error message.
Typesetting:-Suppress(x(t)) would do it but I'd prefer the option all.
I have a set of points. I want to make a linear spline of that points and plot the resulting function:
function:=CurveFitting[Spline](points_x,points_y,x,degree=1):
However I need the function to define constant y endpoint values where x is out of points_x range (i.e. first-derivation is zero where x is out of points_x range). Endpoint options does not work for me.
             constant1   x < xmin
function :=  ..
             constant2   otherwise
How can I define spline function like this?
Having difficulties solving pde. Below is the problem and its not plotting. Anyone with useful informations. Please
with(PDEtools, casesplit, declare);
with(DEtools, gensys);
with(Physics);
PDE := diff(theta(x, t), x, x)+beta*theta(x, t)*(diff(theta(x, t), x, x))+beta*((diff(theta(x, t), x))^2)-M^2*theta(x, t)-S[h]*(theta(x, t)^2)+M^2*G*(1+E*theta(x, t))-P[e]*(diff(theta(x, t), x)) = diff(theta(x, t), t);
/ d  / d             \\
|--- |--- theta(x, t)||
\ dx \ dx            //
                      / d  / d             \\
   + beta theta(x, t) |--- |--- theta(x, t)||
                      \ dx \ dx            //
          / d             \     2                               2
   + beta |--- theta(x, t)|  - M  theta(x, t) - S[h] theta(x, t)
          \ dx            /
      2                              / d             \    d
   + M  G (1 + E theta(x, t)) - P[e] |--- theta(x, t)| = ---
                                     \ dx            /    dt
  theta(x, t)
BC := theta(x, 0) = 0, Dt(theta(0, t)) = 0, theta(1, t) = 1;
Codes := [beta = .1, M = .1, S[h] = .1, G = .1, P[e] = .1, E = .1];
S1 := pdsolve({BC, subs(Codes, PDE)});
PDEplot(S1, [[t, theta(x, t)], [x, theta(x, t)]], t = 0 .. 1, x = 0 .. 1, iterations = 2, numchar = [10, 10], stepsize = 0.5e-1, numsteps = [-5, 5]);
   PDEplot([[t, theta(x, t)], [x, theta(x, t)]], t = 0 .. 1,
     stepsize = 0.05, numsteps = [-5, 5])
I've got Maple 2017 linked to MATLAB R2017a but I can't get MATLAB R2017a linked to Maple 2017.
I've got MATLAB R2016b linked to Maple 2017.
Any ideas? (Or do I just need to wait for an update?)
Hello guys!
Could you tell me what are the state-of-the-art algorithms to compute Hermite and Smith normal forms (well or just Hermite since the later can be computed by applying Hermite twice)? I am interested in these algorihtms which outputs also the respective unimodular matrices.
First 993 994 995 996 997 998 999 Last Page 995 of 2460
