v=u+at                      (1)
s=u*t+1/2*a*t^2        (2)
below 3 equations, can substitute  (1)  into it to form (2)
s=1/2*(u+v)*t       (3)
v^2=u^2+2*a*s    (4)
s=v*t-1/2*a*t^2    (5)
can these 5 equations be considered as a solution set of solve function?
or
is only first 2 equations be a solution set?
if so, number of equations less than 5 variables, is there something missing?
i want to dsolve frome this equation . but i cant
1.mw
op(2, -(1/4)*z^2-(1/18*I)*z^3+(1/96)*z^4+(1/600*I)*z^5-(1/4320)*z^6-(1/35280*I)*z^7+(1/322560)*z^8+(1/3265920*I)*z^9-(1/36288000)*z^10-(1/439084800*I)*z^11+O(z^12))
-((1/18)*I)*z^3
op(2, series(Ei(I*z)-gamma-ln(z)-I*csgn(I*z)*Pi-I*z, z, 12))
series(-(1/4)*z^2-((1/18)*I)*z^3+(1/96)*z^4+((1/600)*I)*z^5-(1/4320)*z^6-((1/35280)*I)*z^7+(1/322560)*z^8+((1/3265920)*I)*z^9-(1/36288000)*z^10-((1/439084800)*I)*z^11+O(z^12),z,12)
is(series(Ei(I*z)-gamma-ln(z)-I*csgn(I*z)*Pi-I*z, z, 12) = -(1/4)*z^2-(1/18*I)*z^3+(1/96)*z^4+(1/600*I)*z^5-(1/4320)*z^6-(1/35280*I)*z^7+(1/322560)*z^8+(1/3265920*I)*z^9-(1/36288000)*z^10-(1/439084800*I)*z^11+O(z^12))
Download op_error.mw
Is there a Maple command for copying a text to the clipboard ? (Apart from using the contextual menu or the Edit-Copy menu option)
For example:
ee := x^2+y^2+z^2
CopyToClipboard( convert(ee,string) )
Thank you,
César Lozada
work.mw
I'm having problems plotting these three functions on the same graph. I can get two of them, but as soon as I try to add the third, it throws a couple errors no matter what I do. It doesn't help that the docs are confusing. The first two functions are approximating diff(y(x),x) = -2xy(x)+1 with the Euler method (step size of 0.05 and 0.1) that I implemented using a for loop. I gather the data into an array and then plot those. That works. But once I try to set y(x) equal to a Taylor approximation, I can plot that graph but the values for the other functions are strangely absent. I've attached my work. What is wrong with my syntax and how can I plot all three functions at once?
I want to plot a function f(x,y)=x^3-2x^2y. But I only want to plot values where $x^2+y^2 <= 1$. So far I specified the plotting range in the standard way, but I really need to specify it like I described. I want to use plot3d.
How can we write a code for solving following system of Pdes ?
PDE1:=m1*diff(w1(x,t),t$2)-S1*diff(w1(x,t),x$2)+k*(w1(x,t)-w2(x,t))=F1(t)*delta(x-x1);
PDE2:=m2*diff(w2(x,t),t$2)-S2*diff(w2(x,t),x$2)+k*(w2(x,t)-w1(x,t))=F2(t)*delta(x-x2);
In here,  Ki, mi, xi and k are constants where i=1,2.
Since F1(t) and F2(t) are unspecified (ungiven) functions, solutions u1,u2 which we seek, will be depended on  F1(t) and F2(t).
Thanks for your valuable and praiseworthy suggestions and comments.
When one uses the PolynomialIdeals package, then how should he ask the elemnts in an ideal or the number of generators?
An idea can be writing a proc getting a polynomialideal and returning a list with the generators as its elements in this way. Converting the polynomialideal to a list, then deleting its three last entries. But I'm wondering if there is any other way to do this? It's reasonable to be able to ask generators of an ideal of result of some computations in polynomialideal package.
Dear Maple users,
I want to label Y axis such that it doesn't encroach the numbers. The figure below illustrates the difficulty I am facing. How can I change the default setting to put letter '\bar{U}' at some distance from Y axis so that it doesn't look crowded? Thanks.
Edit. One crude way to do this is by using typesetting command.
labels = [log(n), typeset(conjugate(U), " ")]
i am trying to write the differential equation
u_{t}=u_{xx}+2u^{2}(1-u) in my maple 15.
but it shows error,
Error, empty number and  1 additional error.
I'm trying to program a procedure that will return me a list of positions defining equally spaced points (planets) around a circumference, for example:
PSI := [0, Pi]; # Location of 2 planets
PSI := [0, ((2/3)*Pi) , ((4/3)*Pi) ]; # For 3 Planets
I'm new to maple so most commands are new to me, I tried building the size of the list with [0 $ n] because I want the first position to always be at 0 degrees. The first problem is that I get this error:
Error, reserved word `for` unexpected
nplanets := 2;
make_PSI :=
proc(nplanets);
local n,psin,i,PSI:
n = nplanets;
psin  :=(pi*2)/n;
PSI := [0 $ n];
for i from 1 to n do
 angle :=(psin*i);
 op(i,PSI) := angle;
end;
Any advice would be appreciated!
Download planetspace.mw
If I let Maple be running on the computer for a while, maybe a day or 2 or so, I almost certainly get a change of several
characters. See my favourite palette:
As you can see the eternity sign e.g changes to a big N. If I rerun the worksheet everything works ok except for the change of characters.
Not seen above: :=  changes to d
Remedy?
hello...how I can pdsolve three equations with related boundary conditions?
please help me.
thanks...
J := f1(r, z)*f2(r, z)*f3(r, z):
`f&theta;` := f2(r, z)*f3(r, z)/fz:
m0 := 1:
g := r*ph/l:
sy := (1/2)*arctan(2*g*fz^2/(-fz^2+g^2+`f&theta;`^2-1)):
I4 := (f2(r, z)^2*cos(sy)^2+f3(r, z)^2*sin(sy)^2-(.25*(f2(r, z)^2-f3(r, z)^2))*sin(2*sy)^2/(f2(r, z)^2*sin(sy)^2+f3(r, z)^2*cos(sy)^2))*cos(b)^2+.5*f2(r, z)*f3(r, z)*(f2(r, z)^2-f3(r, z)^2)*sin(2*sy)*sin(2*b)/(f2(r, z)^2*sin(sy)^2+f3(r, z)^2*cos(sy)^2)+((f2(r, z)^2*sin(sy)^2+f3(r, z)^2*cos(sy)^2)^2+(.25*(f2(r, z)^2-f3(r, z)^2))*sin(2*sy)^2/(f2(r, z)^2*sin(sy)^2+f3(r, z)^2*cos(sy)^2))*sin(b)^2:
I6 := (f2(r, z)^2*cos(sy)^2+f3(r, z)^2*sin(sy)^2-(.25*(f2(r, z)^2-f3(r, z)^2))*sin(2*sy)^2/(f2(r, z)^2*sin(sy)^2+f3(r, z)^2*cos(sy)^2))*cos(b)^2-.5*f2(r, z)*f3(r, z)*(f2(r, z)^2-f3(r, z)^2)*sin(2*sy)*sin(2*b)/(f2(r, z)^2*sin(sy)^2+f3(r, z)^2*cos(sy)^2)+((f2(r, z)^2*sin(sy)^2+f3(r, z)^2*cos(sy)^2)^2+(.25*(f2(r, z)^2-f3(r, z)^2))*sin(2*sy)^2/(f2(r, z)^2*sin(sy)^2+f3(r, z)^2*cos(sy)^2))*sin(b)^2:
L := (I4-1)*exp(K2*(I4-1)^2-1):
N := (I6-1)*exp(K2*(I6-1)^2-1):
P23 := -f2(r, z)*f3(r, z)*sin(b)*cos(b)+(.5*(f2(r, z)^2-f3(r, z)^2))*sin(sy)^2*sin(b)^2:
P32 := -f2(r, z)*f3(r, z)*sin(b)*cos(b)+(.5*(f2(r, z)^2-f3(r, z)^2))*sin(sy)^2*sin(b)^2:
P33 := (f2(r, z)^2*sin(sy)^2+f3(r, z)^2*cos(sy)^2)*sin(b)^2:
P22 := ((f2(r, z)^2*cos(sy)^2+f3(r, z)^2*sin(sy)^2)^2-(.25*(f2(r, z)^2-f3(r, z)^2))*sin(2*sy)^2)*cos(b)^2/(f2(r, z)^2*sin(sy)^2+f3(r, z)^2*cos(sy)^2)-f2(r, z)*f3(r, z)*(f2(r, z)^2-f3(r, z)^2)*sin(2*sy)*sin(b)*cos(b)/(f2(r, z)^2*sin(sy)^2+f3(r, z)^2*cos(sy)^2)+(.25*(f2(r, z)^2-f3(r, z)^2))*sin(2*sy)^2*sin(b)^2/(f2(r, z)^2*sin(sy)^2+f3(r, z)^2*cos(sy)^2):
S23 := f2(r, z)*f3(r, z)*sin(b)*cos(b)+(.5*(f2(r, z)^2-f3(r, z)^2))*sin(sy)^2*sin(b)^2:
S32 := f2(r, z)*f3(r, z)*sin(b)*cos(b)+(.5*(f2(r, z)^2-f3(r, z)^2))*sin(sy)^2*sin(b)^2:
S33 := (f2(r, z)^2*sin(sy)^2+f3(r, z)^2*cos(sy)^2)*sin(b)^2:
S22 := ((f2(r, z)^2*cos(sy)^2+f3(r, z)^2*sin(sy)^2)^2-(.25*(f2(r, z)^2-f3(r, z)^2))*sin(2*sy)^2)*cos(b)^2/(f2(r, z)^2*sin(sy)^2+f3(r, z)^2*cos(sy)^2)+f2(r, z)*f3(r, z)*(f2(r, z)^2-f3(r, z)^2)*sin(2*sy)*sin(b)*cos(b)/(f2(r, z)^2*sin(sy)^2+f3(r, z)^2*cos(sy)^2)+(.25*(f2(r, z)^2-f3(r, z)^2))*sin(2*sy)^2*sin(b)^2/(f2(r, z)^2*sin(sy)^2+f3(r, z)^2*cos(sy)^2):
Trr := k0*(J-1)+(1/3)*m0*(2*f1(r, z)^2-f2(r, z)^2-f3(r, z)^2)/J^(5/3):
`T&theta;&theta;` := k0*(J-1)+m0*(f2(r, z)^2*cos(sy)^2+f3(r, z)^2*sin(sy)^2-(1/3)*f1(r, z)^2-(1/3)*f2(r, z)^2-(1/3)*f3(r, z)^2)/J^(5/3)+2*k1*(L*S22+N*P22)/J:
`T&theta;z` := m0*(f2(r, z)^2-f3(r, z)^2)*sin(sy)*cos(sy)/J^(5/3)+2*k1*(L*S23+N*P23)/J:
`Tz&theta;` := m0*(f2(r, z)^2-f3(r, z)^2)*sin(sy)*cos(sy)/J^(5/3)+2*k1*(L*S23+N*P23)/J:
Tzz := k0*(J-1)+m0*(f2(r, z)^2*sin(sy)^2+f3(r, z)^2*cos(sy)^2-(1/3)*f1(r, z)^2-(1/3)*f2(r, z)^2-(1/3)*f3(r, z)^2)/J^(5/3)+2*k1*(L*S33+N*P33)/J:
`Tr&theta;` := 0:
`T&theta;r` := 0:
Trz := 0:
Tzr := 0:
NULLpartial equations
equ(1) := r*(diff(Trr, r))+Trr-`T&theta;&theta;`:
equ(2) := diff(`T&theta;z`, z):
equ(3) := diff(Tzz, z):
# BOUNDARY CONDITIONS
Trr := proc (ro, z) options operator, arrow; 0 end proc:
int((`T&theta;&theta;`-Trr)/r, r, ri, ro) := 13.3*10^3:
2*Pi*(int(Tzz*r, r, ri, ro))-13.3*Pi*ri^2*10^3
Error, (in int) wrong number (or type) of arguments: invalid options or option values passed to indefinite integration. Unknown options: {ro, .8333333333*f1(r, z)*f2(r, z)}
int(`T&theta;z`*r^2, r, ri, ro) := 10:
Download for_site.mw
hello...how I can pdsolve three equation with related boundary conditions?
please help me.
thanks...
for_site.mw
I'm having trouble seeing which command is calling the "thaw" for the code below and was wondering if someone is able to save me the trouble from working it out myself. i know its not when the "is" function is called from viewing the showstat for it, but the output prior to mapping that function pops out with no troubles, so im guessing its the generic mapping proc, but of course, in built function so i can only assume its the same way i would write it but im pretty sure i dont use thaw either so anyway the line in question:
map(is, seq(seq(map(eval, Matrix(3, omega[1]) = Matrix(3, omega[0]), [n = i, m = j]), i = 1 .. 10), j = 1 .. 10));
Error, (in thaw) too many levels of recursion
Hi guys ,
i have a manifold ( schwarzschild spacetime ) which want to find Gibbons-Hawking boundary term.
boundary.mw
First 992 993 994 995 996 997 998 Last Page 994 of 2463
