Dear all, how can I plot the edge coordinates of a 2d plane?
using diff command to find  partial dervative of function g give zero in maple...it shouldn't be zero...how to fix itpartial_dervative.mw
sigma_t:= map(epsilon-> E_0[90]*epsilon_dot*((epsilon/epsilon_dot)-(sum(p[i], i = 1 .. 3)*(epsilon/epsilon_dot))+(sum(p[i]*tau[i],i=1..3))-(sum(p[i]*tau[i]*exp(-(epsilon/(epsilon_dot*tau[i]))),i=1..3))),true_strain):
 g:= sum(( sigma[j]-sigma_t[j])^2,j=1..10):
diff(g,p[1]);
Download partial_dervative.mw
if i want to solve non linear least square problem ..maple optimazation Interactive box show ..many option...but when it comes to least square default....what kind of algothrim does it used....and in maple ..NonLinear fit commad use what kind of algothrim?..Levenberg-Marquardt algorithm?
I use one engine per one worksheet. So one would expect that doing restart; command; to always behave the same way. Right?
Because each time, new or refreshed mserver.exe is used.  But here is a worksheet, where I run it few times (all with restart each time), where sometime the command timelimit hangs, and sometime does not. I do not mean it takes little longer sometime. I mean completely hang.
I've waited 10-20 minutes and nothing happens. And sometime I saw it return back in 2 or 3 minutes. But most of the time it hangs.
I wish someone could explain this to me. If it hangs each time, or not hang each time, I can understand. (ofcourse timelimit should never hang, as it was supposed to have been fixed in 2021, but this is separate issue).
But why it hangs sometimes and not other times? Does Maple use some sort of random number generator inside it to decide on things? For me, software should behave the same each time when run from same initial state.
It also depends on the amount of timeout given if it hangs or not.
What can cause this different behavior and most important, what can one do to make it behave same way each time? I thought that what restart supposed to do.
Any insight what can cause this is welcome.
I also found that closing the worksheet completely and opening it again, results in different behavior in the timing. It looks like restart does not clear everything, as what happens when closing the worksheet and reopeing it again.
i.e. Sometimes when it completes and not hang, then issuing restart again and running the int() command, it will also not hang most likely.
It seems Maple have remembered something. But closing the worksheet and opening it again, it will hang again most of the times.
The point of all this, is that Maple behaves differently each time. But why??
9704
`The "Physics Updates" version in the MapleCloud is 1762. The version installed in this computer is 1757 created 2024, June 6, 14:53 hours Pacific Time, found in the directory C:\Users\Owner\maple\toolbox\2024\Physics Updates\lib\`
expr:=-4*(1-exp(I*x))^(-4*x)*(exp(I*x)+1)^(4*x)*exp(4*I*(polylog(2,exp(I*x)))-polylog(2,-exp(I*x) ))*csc(x)*x*(tan(x)^2-1)
-4*(1-exp(I*x))^(-4*x)*(exp(I*x)+1)^(4*x)*exp((4*I)*polylog(2, exp(I*x))-polylog(2, -exp(I*x)))*csc(x)*x*(tan(x)^2-1)
time();
#hangs sometimes and not other times. Most of the time it hangs. increasing time
#will improve the chance it will hang
timelimit(60,int(expr,x,method=_RETURNVERBOSE));
time();
.375
Download hangs_int_june_16_2024.mw
Here is one screen shot of one of those times where it returned back. Took little over one minute. Good.
Here is second screen shot where it took about1,800 real time seconds to return. (30 minutes, even though timelimit was one minute). Same exact code.
update
I tried the suggestion given below to use _EnvProbabilistic:=0 but it had no effect on making Maple behavior consistent each time.
Below worksheet shows this. I tried 6 trials, each with restart.
First trial it timeout at 74 second. good. Second trial took 1403 seconds !  Third trial went back to 74 seconds again (good).  Trial 4 took also took about 74 seconds (good). trial 5 went back to being slow and took about 1400 seconds again. Trial 6 went back to being fast and took about 74 seconds.
So the pattern seems to be
                     fast SLOW fast fast SLOW fast.....
But I also tried this whole test again, by closing the worksheet and opening. Now the pattern changed to
                     SLOW fast fast fast SLOW SLOW ....
I also attached the worksheet for the above below.
So Maple still behaves in random fashion in doing the integration above. sometimes it is slow, sometimes fast. All using same exact code and same integral. Extra points to anyone who could find out why and how to fix this.
This worksheet have pattern    fast SLOW fast fast SLOW fast....
1036
Trial #1
_EnvProbabilistic:=0;
expr:=-4*(1-exp(I*x))^(-4*x)*(exp(I*x)+1)^(4*x)*exp(4*I*(polylog(2,exp(I*x)))-polylog(2,-exp(I*x) ))*csc(x)*x*(tan(x)^2-1);
st:=time[real]();
print("time taken ",time[real]()-st);
4019.660
Error, (in PDEtools/NumerDenom) time expired
"time taken ", 74.618
Trial #2
st:=time[real]():
Error, (in sdmp:-mul) time expired
"time taken ", 1403.978
Trial #3
st:=time[real]():
"time taken ", 73.979
Trial #4
st:=time[real]():
"time taken ", 73.732
Trial #5
st:=time[real]():
"time taken ", 1396.089
Trila #6
st:=time[real]():
Error, (in anonymous procedure called from PDEtools/NumerDenom) time expired
"time taken ", 73.383
Download hangs_int_V2_june_16_2024.mw
This worksheet below have pattern      SLOW fast fast fast SLOW SLOW ....
Trial #1
st:=time[real]();
28.483
"time taken ", 1400.316
Trial #2
st:=time[real]():
"time taken ", 74.404
Trial #3
st:=time[real]():
"time taken ", 73.993
Trial #4
st:=time[real]():
"time taken ", 73.550
Trial #5
st:=time[real]():
"time taken ", 1373.684
Trila #6
st:=time[real]():
"time taken ", 1383.174
Download hangs_int_V3_june_16_2024.mw
Observation: When it finishes fast, timeout is always in  PDEtools/NumerDenom.
When it takes long time, timeout is always in sdmp:-mull
Any other suggestions what to try are welcome.
expr:=cos(x)^2;
expr=combine[trig](expr);
(x->x=combine[trig])(expr);
Update:
Same outcome with
expr=`combine/trig`(expr);
(x->x=`combine/trig`)(expr);
                          2   1            1
                    cos(x)  = - cos(2 x) + -
                              2            2
                     cos(x)  = combine/trig
Hi everyone ...
How can I define the below Matrix with for command: (A[n] is n*n and n=1...i)
Tnx...
It seems like there exists a bug when taking the following limit in Maple (I tried Maple 2021):
If I run this command:
> evalf(limit(CylinderU(0,CylinderU(0,x)),x=0));
1.2722774800
the result is 1.2722774800, which seems to be incorrect.
However, when I run this command:
> evalf(CylinderU(0,limit(CylinderU(0,x),x=0)));
0.5456799403
the result is 0.5456799403, which seems to be correct.
Finally, when I run this command:
> evalf(CylinderU(0,CylinderU(0,0)));
0.5456799403
the result is 0.5456799403 which is also correct.
My expectation is that all three commands must return the same result, thus I consider this a bug.
I also run the following command in WolframAlpha
> limit ParabolicCylinderU(0,ParabolicCylinderU(0,x)) as x->0.0
and obtained the correct result 0.54568, confirming that in Maple this is evaluated incorrectly.
Would appreciate if anybody can confirm that this is a bug.
How such Maple bug should be reported?
Is this a valid behvior by int?
int(A,x,method=_RETURNVERBOSE) hangs.
But  int(simplify(A),x,method=_RETURNVERBOSE) returns in few seconds with "default" result same as int(A,x)
Should this have happen? I try to avoid calling simplify unless neccessary because it can add csgn's and signums and so on to the result.
But the question is: Should one really need to simplify the integrand to get the result in this example? Does this mean one should call simplify on the integrand to avoid the hang that can show up?
This only happens when using method=_RETURNVERBOSE
Just trying to find out if this is normal behavior and can be expected sometimes.
25844
A:=exp(-1/2*cos(2*x))*exp(-sin(x)^2);
int(A,x);
exp(-(1/2)*cos(2*x))*exp(-sin(x)^2)
exp(1/2)*exp(-1)*x
int(A,x,method=_RETURNVERBOSE);  #hangs
["default" = x*exp(-1/2), "risch" = x*exp(-1/2), "orering" = x*exp(-sin(x)^2-(1/2)*cos(2*x)), FAILS = ("gosper", "lookup", "derivativedivides", "norman", "trager", "meijerg", "elliptic", "pseudoelliptic", "parallelrisch", "parts")]
Download why_int_hang_unless_simplify_june_15_2024.mw
How do you substitute into a contravariant index of a tensor say
T[~mu, nu]     ?
Nothing seems to work, I tried to subs(~mu=~1,T[~mu, nu]), subs(mu=1,T[~mu, nu]), and all permutations.
Substituting values into the covariant index works fine but not contravariant.
Surely it must be possible ?
When executing the attached work sheet, the output
changes to
Why is that (local seetings maybe?) and how to reproduce the former, more compact output?
Copy-pasted from the wonderful:
Advanced Engineering Mathematics
Dr. Robert J. Lopez
Emeritus Professor of Mathematics
Maple Fellow
© Maplesoft, a division of Waterloo Maple Inc., 2023
This is obtained in Maple by writing the differential equation
q := diff(x(t),t) = k*(40 - 16/18*x(t))*(8 - 2/18*x(t));
diff(x(t), t) = k*(40-(8/9)*x(t))*(8-(1/9)*x(t))
and solving via the syntax
X := simplify(rhs(dsolve({q,x(0)=0},x(t))));
(-360+360*exp((8/3)*t*k))/(8*exp((8/3)*t*k)-5)
The differential equation is actually separable, and can be solved with the techniques of elementary calculus discussed in Section 3.1.
If an observation provides the data that at time t = 1 there were 6 grams of water, then the constant of proportionality k can be computed.  In Maple, the data point gives the equation
eq := eval(X, t=1) = 6;
(-360+360*exp((8/3)*k))/(8*exp((8/3)*k)-5) = 6
whose solution is
K := solve(eq,k);
(3/8)*ln(55/52)
Download Output_formated_with_rational_factor_.mw
Hi everyone...
I want to know how can I convert python code & c+ code into maple, is there any command or algorithm for these converts?
Tnx...
with(combinat);
F := unapply(rsolve({F(1) = 1, F(2) = 1, F(n + 1) = F(n) + F(n - 1)}, F(n)), n);
combine(expand(F(n + 1)*F(n + 2) - F(n)*F(n + 3)));
F := n -> fibonacci(n);
combine(expand(F(n + 1)^2 - F(n)*F(n + 3) + (-1)^n));
is(F(n + 1)^2 = F(n)*F(n + 2) + (-1)^n);#should be true
G := n -> arctan(1/F(n));
is(G(4) = G(5) + G(6));
is(G(2*n) = G(2*n + 1) + G(2*n + 2));#should be true
How to establish these formulas ? Thank you.
odetest should be made more robust.
Here is an example where the same exact solution and same exact IC, but when solution is just writtent in a  little different form, odetest no longer verifies it.
Do you consider this a bug? How is the user supposed to know their solution is correct or not now, since it depends on how it is written? What can a user then do to help odetest in this case verify the solution?
ode:=diff(y(x), x)*x^2 + cos(2*y(x)) = 1;
ic:=y(infinity)=10/3*Pi;
e1:=2/x+1/3*sqrt(3);
SOL1:=y(x)=arccot(e1) + Pi*3;
odetest(SOL1,[ode,ic]);
(diff(y(x), x))*x^2+cos(2*y(x)) = 1
y(infinity) = (10/3)*Pi
2/x+(1/3)*3^(1/2)
y(x) = arccot(2/x+(1/3)*3^(1/2))+3*Pi
[0, 0]
#now we rewrite the solution a little different. But same solution
e2:=simplify(e1);
(1/3)*(3^(1/2)*x+6)/x
#Now maple no longer verifies the solution
SOL2:=y(x)=arccot(e2) + Pi*3;
odetest(SOL2,[ode,ic])
y(x) = arccot((1/3)*(3^(1/2)*x+6)/x)+3*Pi
[0, -(1/6)*Pi]
Download same_solution_not_verified_june_13_2024.mw
How can I get Prof. Wilhelm Werner's  FourierSeries  package? (See also "Fourier and Other Orthogonal Function Expansions in Maple" by Dr. Robert Lopez):
First 100 101 102 103 104 105 106 Last Page 102 of 2429
