Maple gives solutions that do not satisfy the equation. Wondering what do I need to change.
n:=3;m:=2;
eqx:=x^(n/m)=a;
maple_sol:=[PDEtools:-Solve(eqx,x)]; #also tried solve()
F:=map(X->eval(eqx,X),maple_sol);
map(X->evalb(X),F);
I always verified in Mathematica
Any thought what is going on and what do I need to change in my Maple code to make it give the solution x=a^(2/3) only?
It is also possible that Mathematica is the one who is skipping the two complex solutions, but then I need to verify these in Maple, and so far I can't. Only the first solution is verified by Maple.
Even simplification with assuming a>0 do not verify these two extra solution given with complex values. I also tried RealDomain package but this also had no effect. I tired assuming real also and tried simplify with symbolic option.
Anything else I should try?
Maple 2024 on windows 10
update
As I said, I tried RealDomain but with PDEtools:-Solve. With solve it works. Is this a bug? worksheet below
35788
`The "Physics Updates" version in the MapleCloud is 1701. The version installed in this computer is 1693 created 2024, March 7, 17:27 hours Pacific Time, found in the directory C:\Users\Owner\maple\toolbox\2024\Physics Updates\lib\`
n:=3;m:=2;
eqx:=x^(n/m)=a;
use RealDomain in (PDEtools:-Solve(eqx,x)) end use;
F:=map(X->eval(eqx,X),[%]);
map(X->evalb(X),F);
x^(3/2) = a
x = a^(2/3), x = (1/4)*a^(2/3)*(1+I*3^(1/2))^2, x = (1/4)*a^(2/3)*(I*3^(1/2)-1)^2
[a = a, (1/16)*4^(1/2)*(a^(2/3)*(1+I*3^(1/2))^2)^(3/2) = a, (1/16)*4^(1/2)*(a^(2/3)*(I*3^(1/2)-1)^2)^(3/2) = a]
[true, false, false]
n:=3;m:=2;
eqx:=x^(n/m)=a;
use RealDomain in (solve(eqx,x)) end use;
F:=map(X->eval(eqx,x=X),[%]);
map(X->evalb(X),F);
x^(3/2) = a
a^(2/3)
[a = a]
[true]
Download real_domain_solve_vs_PDEtools_Solve.mw
I have used "colour" as my spelling on optional inputs to procedures in my package.  How can I also handle the alternative spelling "color"?
coltest:=proc(c)
  if c="b" then return 1
   elif c="r" then return 2
   elif c="g" then return 3
foo:=proc(a,{colour:="b"})
local COL;
   COL:=coltest(colour);
if COL=1 then return a
  elif COL=2 then return a^2
  elif COL=3 then return a^3
  else error `wrong colour`;
end if ;
foo(3,colour="r")
9
foo(2,colour="p")
Error, (in foo) wrong colour
Download 2024-03-21_Q_colour_or_color.mw
Details here: non-dimensionalization.mw. Thanks!
In short, I want to plot all the ten roots of a 10th-degree polynomial in _Z with 4 or 5 primitive parameters. To do so, I need to find that combination of parameters that allows me to transform/scale/non-dimensionalize the original polynomial in a polynomial in _Z with just (1) one parameter or at maximum (2) two parameters. In the case of (1), I can plot its roots in a standard 2D plot against the single parameter. In the case of (2), I can plot the roots in a standard 3D plot against the two parameters.
May be someone can come up with a way to simplify this ode solution? I used the option useInt but the solution can be written in much simpler way than Maple gives.  Below is worksheet showing Maple's 2024 solution and my hand solution.
(having trouble uploading worksheet, will try again).
144036
ode:=diff(y(x),x)^3=y(x)+x
(diff(y(x), x))^3 = y(x)+x
maple_sol:=dsolve(ode,useInt):
maple_sol:=Vector([maple_sol]);
Vector(3, {(1) = x-Intat(3*_a^2/(_a+1), _a = (y(x)+x)^(1/3))-_C1 = 0, (2) = x-Intat(3*_a^2/(_a+1), _a = -(1/2)*(y(x)+x)^(1/3)-((1/2)*I)*sqrt(3)*(y(x)+x)^(1/3))-_C1 = 0, (3) = x-Intat(3*_a^2/(_a+1), _a = -(1/2)*(y(x)+x)^(1/3)+((1/2)*I)*sqrt(3)*(y(x)+x)^(1/3))-_C1 = 0})
mysol1:= Intat(1/(_a^(1/3) + 1), _a = (y(x) + x))=x+_C1:
mysol2:= Intat(1/( -(-1)^(1/3)*_a^(1/3) + 1), _a = (y(x) + x))=x+_C1:
mysol3:= Intat(1/( (-1)^(2/3)*_a^(1/3) + 1), _a = (y(x) + x))=x+_C1:
mysol:=Vector([mysol1,mysol2,mysol3]);
Vector(3, {(1) = Intat(1/(1+_a^(1/3)), _a = y(x)+x) = x+_C1, (2) = Intat(1/(-(-1)^(1/3)*_a^(1/3)+1), _a = y(x)+x) = x+_C1, (3) = Intat(1/((-1)^(2/3)*_a^(1/3)+1), _a = y(x)+x) = x+_C1})
map(X->odetest(X,ode),mysol)
Vector(3, {(1) = 0, (2) = 0, (3) = 0})
Download simpler_solution.mw
I keep losing the edits I do. I post screen shot. Click submit, then find all my changes are lost. Will try one more time and give up:
This is Maple solution
This is implified version
Both versions are verified correct by odetest. The question is there is a way to obtain the simpler form from Maple.
What is the result of this system command:
This is a bit long. What is the explanation here?
I need your insights on two technical questions regarding my BoxPlot:
1) How to adjust the color of the text (Title and caption)
2) How to remove only the y-axis
S5StatBoxPlotBtest.mw
I want to export plots as PNG but found in the past that when using commands to automate the process (and explicitly controlling for image quality) some symbolic notation on the axes or in the plots themselves are translated to 1D.
Anyway, regardless of the reason just provided, I have a preference for exporting plots as PNG manually rather than automatically in some of my scripts. How to do this while ensuring the best quality? By default, manual exports into PNG have quite bad quality.
I was wondering why Maple do not give this simpler solution to this ode. It solves it as exact. But if solved as separable, the solution is much simpler.
I solved this by hand and Maple verifies my solution. You can see the separable solution is much simpler. Any tricks to make Maple gives the simpler solution?
ode:=diff(y(x),x)^4+f(x)*(y(x)-a)^3*(y(x)-b)^3*(y(x)-c)^2 = 0;
(diff(y(x), x))^4+f(x)*(y(x)-a)^3*(y(x)-b)^3*(y(x)-c)^2 = 0
infolevel[dsolve]:=5;
sol:=dsolve(ode);
odetest(sol,ode);
5
Methods for first order ODEs:
-> Solving 1st order ODE of high degree, 1st attempt
trying 1st order WeierstrassP solution for high degree ODE
trying 1st order WeierstrassPPrime solution for high degree ODE
trying 1st order JacobiSN solution for high degree ODE
trying 1st order ODE linearizable_by_differentiation
trying differential order: 1; missing variables
trying simple symmetries for implicit equations
trying homogeneous types:
trying exact
<- exact successful
Intat(1/((_a-c)^(1/2)*(_a-b)^(3/4)*(_a-a)^(3/4)), _a = y(x))+Intat(-(-f(_a)*(-y(x)+c)^2*(-y(x)+b)^3*(-y(x)+a)^3)^(1/4)/((y(x)-c)^(1/2)*(y(x)-b)^(3/4)*(y(x)-a)^(3/4)), _a = x)+c__1 = 0
mysol:=Intat(1/( (_a-c)^(2/3)*(_a-b)*(_a-a))^(3/4),_a = y(x))=Intat( (-f(_a))^(1/4),_a=x)+_C1;
odetest(mysol,ode)
Intat(1/((_a-c)^(2/3)*(_a-b)*(_a-a))^(3/4), _a = y(x)) = Intat((-f(_a))^(1/4), _a = x)+c__1
Download why_not_this_simpler_solution.mw
Hand solution
Maple 2024
A padel group organises doubles tournaments with the following structure: 16 players participate in four rounds, with each round consisting of four doubles matches. Players switch partners after each round.
So what I require is some code to generate the first round matches, the second round, the third, the nth .....
note the worksheet I bastardised from Tom Leslie's work.
2_man_teams_doubles.mw
it took me hrs to find this as my solution was failing verification and I did not know why.
What logic do you think Maple used to simplify this:
expr:=sqrt(1 + sin(x))/x;
simplify(expr)
To this
How could the above be simpler than
Compare to Mathematica
And this is what I expected. I am now scared to use simplify in Maple as I do not know what I will get back.
Is there a way to tell Maple not to do such strange "simplification"? I am doing this in code, and the code does not know what the expression is.
To see an example of the side effect of this, here is one, where if solution to an ode is simplified first, it no longer verifies by odetest without adding extra assumptions:
155324
ode:=diff(y(x),x)=(cos(x)-2*x*y(x)^2)/(2*x^2*y(x));
sol:=dsolve([ode,y(Pi)=1/Pi]);
odetest(sol,ode);
diff(y(x), x) = (1/2)*(cos(x)-2*x*y(x)^2)/(x^2*y(x))
y(x) = (sin(x)+1)^(1/2)/x
odetest(simplify(sol),ode);
(1/4)*cos(x)*2^(1/2)*csgn(cos((1/2)*x)+sin((1/2)*x))^2*csgn(1, (1/2)*2^(1/2)*(cos((1/2)*x)+sin((1/2)*x)))/x
One does not expect that simplified solution no longer verfiies the ode.
Sure, I can do
          odetest(simplify(sol),ode) assuming real;
and now it gives 0. But the point is that the first one did not need assumptions.
Download simplify_with_odetest.mw
Maple 2024 on windows 10.
I am trying to tidy up cases where a proc returns multiple values. Have being trying Tabulate. I can get it to work when called after the results are returned. I would the procedure to do this but  keep acces to the name(s) assigned to the returned values.
A,B,C:= proc(...)  .....  return a, b, c    end proc.
So basically display a tabulated of a, b, c.
QQFProj := proc(q12::algebraic, q23::algebraic, q34::algebraic, q14::algebraic,{columns:=[QQFproj,Q13proj,Q24proj]},prnt::boolean:=true)
description "Projective quadruple quad formula and intermediate 13 and 24 quads. Useful for cyclic quadrilaterals";
local qqf,q13,q24, sub1,sub2,sub3, R;
#uses  DT = DocumentTools;
sub1:= (q12 + q23 + q34 + q14)^2 - 2*(q12^2 + q23^2 + q34^2 + q14^2) ;
sub2:=-4*(q12*q23*q34+q12*q23*q14+q12*q34*q14+q23*q34*q14)+8*q12*q23*q34*q14;
sub3:=64*q12*q23*q34*q14*(1-q12)*(1-q23)*(1-q34)*(1-q14);
qqf:=(sub1+sub2)^2=sub3;
q13:=((q12-q23)^2-(q34-q14)^2)/(2*(q12+q23-q34-q14-2*q12*q23+2*q34*q14));#check this
q24:=((q23-q34)^2-(q12-q14)^2)/(2*(q23+q34-q12-q14-2*q23*q34+2*q12*q14));#check this
#if prnt then
#return [columns,[qqf,q13,q24]];
if prnt then
print(cat(" ",columns[1],"    ",columns[2],"     ",columns[3])) ;
return qqf ,q13,q24
q12:=1/2:q23:=9/10:q34:=25/26:q41:=9/130: #Cyclic quadrilateral
 AA:=QQFProj(q12,q23,q34,q41,true);
AA[1];
AA[2];
AA[3]
" QQFproj    Q13proj     Q24proj"
9801/2856100 = 9801/2856100, 4/5, 16/65
4/5
16/65
# Can the below be built into the proc to nicely didplay the results but maintain access to the results as shown when prnt=true.
columns:=[QQFproj,Q13proj,Q24proj]:
BB:=QQFProj(q12,q23,q34,q41,false):
DocumentTools:-Tabulate([columns,[BB]],width=55):#could do with a variable width depending on length of output epression.
BB[1];
BB[2];
BB[3]
4/5
16/65
dspformat:=(BB,columns)->DocumentTools:-Tabulate([columns,[BB]],width=75);
proc (BB, columns) options operator, arrow; DocumentTools:-Tabulate([columns, [BB]], width = 75) end proc
CC:=dspformat(BB,columns):#layout not as expected
CC[1] ; #  just gives  letters from Tabulate
"T"
Download 2024-03-18_Q_Format_Returned_Results_into_a_Table..mw
I calculate the standard deviation using Maple, which differs from the standard deviation obtained by the calculator (TI). Can you provide an explanation for this difference?
StDevQ.mw
I am trying to get Maple to simplify the following trigonometric expressions (for "generic" parameters) as much as possible
sineExpr(3) := (
   sin(a[2] - b[1])*sin(a[3] - b[1]))/(
   sin(b[2] - b[1])*sin(b[3] - b[1]))*sin(a[1] - b[1]) + (
   sin(a[3] - b[2])*sin(a[1] - b[2]))/(
   sin(b[3] - b[2])*sin(b[1] - b[2]))*sin(a[2] - b[2]) + (
   sin(a[1] - b[3])*sin(a[2] - b[3]))/(
   sin(b[1] - b[3])*sin(b[2] - b[3]))*sin(a[3] - b[3]);
   (('RealDomain:-sin'(a[2]-b[1])*'RealDomain:-sin'(a[3]-b[1]))/('RealDomain:-sin'(b[2]-b[1])*'RealDomain:-sin'(b[3]-b[1])))&*'RealDomain:-sin'(a[1]-b[1])+(('RealDomain:-sin'(a[3]-b[2])*'RealDomain:-sin'(a[1]-b[2]))/('RealDomain:-sin'(b[3]-b[2])*'RealDomain:-sin'(b[1]-b[2])))&*'RealDomain:-sin'(a[2]-b[2])+(('RealDomain:-sin'(a[1]-b[3])*'RealDomain:-sin'(a[2]-b[3]))/('RealDomain:-sin'(b[1]-b[3])*'RealDomain:-sin'(b[2]-b[3])))&*'RealDomain:-sin'(a[3]-b[3])
sineExpr(4) := (
   sin(a[2] - b[1])*sin(a[3] - b[1])*sin(a[4] - b[1]))/(
   sin(b[2] - b[1])*sin(b[3] - b[1])*sin(b[4] - b[1]))*
   sin(a[3] - b[2])*sin(a[4] - b[2])*sin(a[1] - b[2]))/(
   sin(b[3] - b[2])*sin(b[4] - b[2])*sin(b[1] - b[2]))*
   sin(a[4] - b[3])*sin(a[1] - b[3])*sin(a[2] - b[3]))/(
   sin(b[4] - b[3])*sin(b[1] - b[3])*sin(b[2] - b[3]))*
   sin(a[3] - b[3]) + (
   sin(a[1] - b[4])*sin(a[2] - b[4])*sin(a[3] - b[4]))/(
   sin(b[1] - b[4])*sin(b[2] - b[4])*sin(b[3] - b[4]))*
   sin(a[4] - b[4]);
(('RealDomain:-sin'(a[2]-b[1])*'RealDomain:-sin'(a[3]-b[1])*'RealDomain:-sin'(a[4]-b[1]))/('RealDomain:-sin'(b[2]-b[1])*'RealDomain:-sin'(b[3]-b[1])*'RealDomain:-sin'(b[4]-b[1])))&*'RealDomain:-sin'(a[1]-b[1])+(('RealDomain:-sin'(a[3]-b[2])*'RealDomain:-sin'(a[4]-b[2])*'RealDomain:-sin'(a[1]-b[2]))/('RealDomain:-sin'(b[3]-b[2])*'RealDomain:-sin'(b[4]-b[2])*'RealDomain:-sin'(b[1]-b[2])))&*'RealDomain:-sin'(a[2]-b[2])+(('RealDomain:-sin'(a[4]-b[3])*'RealDomain:-sin'(a[1]-b[3])*'RealDomain:-sin'(a[2]-b[3]))/('RealDomain:-sin'(b[4]-b[3])*'RealDomain:-sin'(b[1]-b[3])*'RealDomain:-sin'(b[2]-b[3])))&*'RealDomain:-sin'(a[3]-b[3])+(('RealDomain:-sin'(a[1]-b[4])*'RealDomain:-sin'(a[2]-b[4])*'RealDomain:-sin'(a[3]-b[4]))/('RealDomain:-sin'(b[1]-b[4])*'RealDomain:-sin'(b[2]-b[4])*'RealDomain:-sin'(b[3]-b[4])))&*'RealDomain:-sin'(a[4]-b[4])
So far, all of my attempts have failed:
kernelopts('version');
`Maple 2024.0, X86 64 WINDOWS, Mar 01 2024, Build ID 1794891`
`The "Physics Updates" version in the MapleCloud is 1701 and is the same as the version installed in this computer, created 2024, March 17, 17:24 hours Pacific Time.`
sineExpr := proc (m::posint) options operator, arrow; add(mul(ifelse(j <> t, (':-sin')(a[j]-b[t])/(':-sin')(b[j]-b[t]), (':-sin')(a[t]-b[t])), j = 1 .. m), t = 1 .. m) end proc
Warning, (in sineExpr) `t` is implicitly declared local
Warning, (in sineExpr) `j` is implicitly declared local
combine(simplify(normal(sineExpr(1), expanded), trig), trig);
sin(a[1]-b[1])
combine(simplify(normal(sineExpr(2), expanded), trig), trig); # which can be transformed into sin((a[1]+a[2])-(b[1]+b[2])) only in certain legacy versions!
-(1/2)*(cos(-2*b[2]+a[1]+a[2])-cos(-2*b[1]+a[1]+a[2]))/sin(b[1]-b[2])
combine(simplify(normal(sineExpr(3), expanded), trig), trig);
(1/2)*(cos(-b[1]-3*b[2]+b[3]+a[2]+a[3]+a[1])-cos(b[1]-3*b[2]-b[3]+a[2]+a[3]+a[1])-cos(-b[1]-3*b[3]+a[2]+a[3]+a[1]+b[2])+cos(b[1]-3*b[3]-b[2]+a[2]+a[3]+a[1])+cos(-3*b[1]+a[2]+a[3]+a[1]+b[2]-b[3])-cos(-3*b[1]+a[2]+a[3]+a[1]-b[2]+b[3]))/(sin(-2*b[2]+2*b[1])-sin(-2*b[3]+2*b[1])+sin(2*b[2]-2*b[3]))
CodeTools:-Usage(combine(simplify(normal(sineExpr(4), expanded), trig), trig));
memory used=244.67MiB, alloc change=0 bytes, cpu time=6.17s, real time=5.49s, gc time=1000.00ms
(1/2)*(sin(-2*a[3]+4*a[4]+2*a[2]-b[3]-b[4]-b[2]-b[1])-sin(4*a[2]-2*a[4]-b[3]-b[4]-b[2]-b[1]+2*a[1])+sin(-2*a[2]-b[3]-b[4]-b[2]-b[1]+4*a[4]+2*a[1])+sin(-2*a[2]+b[3]+b[4]+b[2]+b[1]-4*a[4]+2*a[1])+sin(-b[3]-b[4]-b[2]-b[1]+4*a[1]-2*a[3]+2*a[4])-sin(4*a[3]-2*a[4]+2*a[2]-b[3]-b[4]-b[2]-b[1])-sin(-4*a[3]-2*a[4]+2*a[2]+b[3]+b[4]+b[2]+b[1])+sin(-2*a[3]-4*a[4]+2*a[2]+b[3]+b[4]+b[2]+b[1])-sin(-2*a[3]+2*a[4]+4*a[2]-b[3]-b[4]-b[2]-b[1])+sin(-4*a[3]+b[3]+b[4]+b[2]+b[1]-2*a[4]+2*a[1])-sin(4*a[4]-2*a[3]-b[3]-b[4]-b[2]-b[1]+2*a[1])-sin(-2*a[2]-b[3]-b[4]-b[2]-b[1]+4*a[3]+2*a[1])-sin(-2*a[2]+b[3]+b[4]+b[2]+b[1]-4*a[3]+2*a[1])+sin(2*a[3]-2*a[4]+4*a[2]-b[3]-b[4]-b[2]-b[1])-sin(-4*a[2]-2*a[4]+b[3]+b[4]+b[2]+b[1]+2*a[1])+sin(4*a[3]-b[3]-b[4]-b[2]-b[1]-2*a[4]+2*a[1])-sin(-b[3]-b[4]-b[2]-b[1]+4*a[1]+2*a[3]-2*a[4])-sin(-b[3]-b[4]-b[2]-b[1]+4*a[1]+2*a[4]-2*a[2])+sin(-b[3]-b[4]-b[2]-b[1]+4*a[1]-2*a[4]+2*a[2])+sin(-b[3]-b[4]-b[2]-b[1]+4*a[1]+2*a[3]-2*a[2])-sin(-b[3]-b[4]-b[2]-b[1]+4*a[1]-2*a[3]+2*a[2])-sin(-4*a[4]-2*a[3]+b[3]+b[4]+b[2]+b[1]+2*a[1])+sin(4*a[2]-2*a[3]-b[3]-b[4]-b[2]-b[1]+2*a[1])+sin(-4*a[2]-2*a[3]+b[3]+b[4]+b[2]+b[1]+2*a[1]))/(cos(a[1]-a[2]-3*a[3]+3*a[4])-cos(a[1]-a[2]+3*a[3]-3*a[4])+cos(-3*a[2]-a[3]+a[4]+3*a[1])-cos(-3*a[2]+a[3]-a[4]+3*a[1])-cos(a[1]+3*a[2]-3*a[3]-a[4])+cos(a[3]-3*a[4]-a[2]+3*a[1])-cos(-a[3]-3*a[4]+a[2]+3*a[1])+cos(-3*a[3]-a[4]+a[2]+3*a[1])-cos(-3*a[3]+a[4]-a[2]+3*a[1])+cos(a[1]-3*a[2]+3*a[3]-a[4])-cos(a[1]-3*a[2]-a[3]+3*a[4])+cos(a[1]+3*a[2]-a[3]-3*a[4]))
CodeTools:-Usage(combine(simplify(normal(sineExpr(5), expanded), trig), trig)): # rather lengthy
memory used=4.23GiB, alloc change=-32.00MiB, cpu time=2.66m, real time=2.29m, gc time=29.98s
Can sineExpr(3), sineExpr(4), and sineExpr(5) be reduced to sin(a[1]+a[2]+a[3]-b[1]-b[2]-b[3]), sin(a[1]+a[2]+a[3]+a[4]-b[1]-b[2]-b[3]-b[4]), and sin(a[1]+a[2]+a[3]+a[4]+a[5]-b[1]-b[2]-b[3]-b[4]-b[5]) respectively by Maple itself (that is, with as little user-intervention as possible) if one is not aware of such reductions in advance?
Download sinIdentity.mw
Note that because zero testing is frequently considerably easier, combine always succeeds in showing that the difference between the simplest possible and the original version is zero.
combine(sin((a[1]+a[2]+a[3])-(b[1]+b[2]+b[3]))-sineExpr(3));
combine(sin((a[1]+a[2]+a[3]+a[4])-(b[1]+b[2]+b[3]+b[4]))-sineExpr(4));
However, I wonder if Maple can thoroughly simplify them without knowing those known “simplest possible” form beforehand
I also tried some other functions like rationalize, radnormal, and `convert/trig`, yet Maple appears to have not been capable of completely simplifying even the sub-simplest case 𝑚=2. Is there any workaround?
Of note, it can be demonstrated inductively that m∈ℕ
where none of the denominators is 0. Nevertheless, as mentioned above, is it possible to transform  and  (as well as , if possible) into potentially more elegant forms (Ideally,  is rewritten into ,  is rewritten into , and  is rewritten into .) without any such a priori knowledge
In Mma, these may be done using TrigReduce directly (cf. ); unfortunately, I cannot found a Maple equivalent to such functionality.
Good everyone,
I am solving a pde problem and I wanted to get the table values for u(0,0.1) but it's just returning the pds. Attach below is the maple worksheet for the code.
Anyone with suggestions, please.
Test.mw
When I calculate the edge values of a matrix the result is lengthy expression that could be simplified if evaluated numerically, Why is that not done?
First 123 124 125 126 127 128 129 Last Page 125 of 2429
