I want to display several plots insequence and tried creating a list of polygonplot3d objects called "plotlist" and using them as an argument like this:
display(plotlist)
which triggered the error message:
Error, (in plots:-display) expecting plot structure but received: plotlist
Where's my mistake and how could I achieve the desired outcome? (displaying polygon3dplots in sequence)
Best Regards
I have generated a picture using pointplot and display that creates a grid of colors based on the angle between vectors and (1,0) in R^2. Each angle is given a unique color via the HSV color space. I would like to provide a legend explaining the colour, something along the lines of
red (brown) green (blue) red
0                Pi                 2*Pi
and possibly
red       (brown)       green
angle1                     angle2
Is there an easy way to do this, or will I have to mess around with a custom pointplot/textplot solution?
Good day everyone,
Please I do get numerical output/values in this solution U1.mw
Best regards
please help me a bout:
> u := am+bm*m0*x(t)+cm*n0*y(t);
> v := an+bn*m0*x(t)+cn*n0*y(t);
> eq1 := diff(x(t), t) = 2*A*(sinh(u)-x(t)*cosh(u));
> eq2 := diff(y(t), t) = 2*A*(sinh(v)-y(t)*cosh(v));
> init := x(0) = X, y(0) = Y;
> sol := dsolve({eq1, eq2, init}, {x(t), y(t)});
> param := A = 1/2, am = 0, bm = 1.2*exp(-4), cm = .5*exp(-5), m0 = 10000, an = 0, bn = -exp(-4), cn = 1.2*exp(-3), n0 = 1000;
> save u, v, param, " narm.sav";
Warning, unassigned variable `u` in save statement
Warning, unassigned variable `v` in save statement
Warning, unassigned variable `param` in save statement
> init := x(0) = 0, y(0) = 0.1e-1;
> eq1 := subs(param, eq1);
> eq2 := subs(param, eq2);
> sol := dsolve({eq1, eq2, init}, {x(t), y(t)}, numeric);
> with(plots);
> odeplot(sol, [x(t), y(t)], 0 .. 60, numpoints = 300, view = [-1 .. 1, -1 .. 1]);
How do I control colors in such Maple program using plot3d? Is it possible to define the conditions?
> restart: with(plots): mandelbrot := proc(x, y) local c, z, m; c := evalf(x+y*I); z := c; for m from 0 to 30 while abs(z) < 2 do z := z^2+c od; m
end: > plot3d(0, -2 .. 0.7, -1.2 .. 1.2, orientation=[-90,0], grid=[40, 40], style=point, scaling=constrained, color=mandelbrot);
I have a (251*1) vector for which I need to compute the cumulative sum. I'm currently using :
s:=Statistics[CumulativeSum](prices[1..251,1])
defined under the Statistics package but this method doesn't return an output, even though the argument passed is a vector.
Is there another method I can use?
In my  Standard GUI Maple 2015 (32 bit)  on Windows 8.1  plots[spacecurve]  command does not work:
plots[spacecurve]([cos(t), sin(t), t], t = 0 .. 2*Pi);
Can someone confirm this bug?
dx/dt=2x(1-x/2)-xy,
dy/dt=y(9/4 -y^2)-(x^2)y
hi. please help me about modeling population migration. i am writing a sample for drawing plot in maple, however maple has not any error, but working incorrectly. my program is:
> u := am+bm*m0*x*t+cm*n0*y*t;
> v := an+bn*m0*x*t+cn*n0*y*t;
> eq1 := diff*(x*t, t) = 2*A*(sinh(u)-x*t*cosh(u));
> eq2 := diff*(y*t, t) = 2*A*(sinh(v)-y*t*cosh(v));
> init := x*0 = X, y*0 = Y;
> sol := dsolve*({eq1, eq2, init}, {x(t), y(t)}, numeric);
> param :=A=1/(2) ,am=0 , bm=1.2*(e)^(-4) ,cm= 0.5*(e)^(-5) ,;
> init := x*0 = 0, y*0 = 0.1e-1;
> eq1 := subs*(param, eq1);
> eq2 := subs*(param, eq2);
> with*plots;
> odeplot*(sol, [x*t, y*t], 0 .. 60, numpoints = 300, view = [-1 .. 1, -1 .. 1]);
> odeplot*(sol*d, [t, x*t, y*t], 0 .. 60, numpoints = 300, orientation = [70, 55], colour = black, axes = normal);
> init := x*0 = -1, y*0 = 1;
> sold := dsolve*({eq1, eq2, init}, {x(t), y(t)}, numeric);
> odeplot*(sold, [x*t, y*t], 0 .. 60, numpoints = 300, view = [-1 .. 1, -1 .. 1], color = black);
I have two polynomials, say
x(t) = a[0] + a[1]t + a[2]t^2
y(t) = b[0] + b[2]t + b[3]t^2
with the following conditions, x(0) = 2 and y(0) = 1. The polynomial are related by
x'(t) = y(t)
y'(t) = x(t)
and x(0) = 2, y(0) = 1.
One can show that the solution is x(t) = 2 + t + t^2 + O(t^3) and y(t) = 1 + 2t + 0.5t^2 + O(t^3).
I am trying to write something so that it works on a larger system. I have a set of nonlinear DEs which i want to solve this way. Here is a sample code of a much simplifed problem.
See the uploaded file for details.
edit: link is reparied. I uploaded the wrong file initially
edit2: Some improvements were made, but Maple still not returning.
2-2_tests_01.mw
I've got an excel file and a maple file saved in the same folder and am trying to import the contents of the excel file using  the Exceltools[Import]("name of file.extension") command as given in the manual but it doesn't seem to work. I've also tried copying the entire path of the file in the argument but that doesn't seem to work either. What am I doing incorrectly?
Is it possible to use an option similar to range when using lsode method for dsolve? The ODEs I am trying to solve is stiff and will not work with the flag stiff=true or with method=rosenbrock unless i set Digits:=20. I want to avoid doing that as much as possible, since I believe wit will be very taxing, computationally. I have a very large systeom to solve. I found that method=lsode works with the default Digits=15.
However I need to have the solutions in a given range stored for future access and manipulations. Using range gives me an error:
Error, (in dsolve/numeric/an_args/lsode) lsode keyword was range, optional keyword must be one of 'ctrl', 'initial', 'itask', 'output', 'procedure', 'procvars', 'start', 'number', 'abserr', 'relerr', 'maxfun', 'minstep', 'maxstep', 'initstep', 'startinit', 'implicit', 'optimize', 'complex'
I cannot figure out how to use range or something similar with lsode. Anyone knows?
I am solving a large system of ODEs, using the following command,
> Sol := dsolve({seq(ode[j], j = 0 .. 21), seq(v[j](0) = 0, j = 1 .. 21), v[0](0) = 1}, [seq(v[j](t), j = 0 .. 21)]);
and then plot the quantities I want by something like
> plots:-odeplot(Sol, [t, v[3](t)+v[5](t)], t = 0 .. 1.5);
My problem is that, I do not know a priori which quantity I want to plot, and plotting using above method requires solving the ODEs each time separately, which takes a long time.
So I was curious if there is a scheme that I can solve my system for once and for all, and then plot any quantities that I would like to see.
Hi! I have to solve a very large system of ODEs for a set of functions that can be indexed with two integers, n and l, call them f[n,l](x), where n ranges from 1 to an order 1000 number and l ranges from 1 to an order 10 number.
What is the best strategy in dsolve, keeping in mind I will only need to have quick access to the values of the first few such functions, say f[0,0](x) and f[0,1](x) for any given x in a given range. I dont need to store the rest, and trying to store all of them actually will give me a warning about length of output exceeds limit of 1000000. So, having maple output the result of dsolve in a procedural form seems to be what I want. However in doing so, for evey value of x i call the solving procedure maple will solve the system each time, thus taking a long time.
My dilema is: to save storage space and memory I want to use dsolve output as procedures. To save time, when accessing the functions I need (only the first few in the large set of unknown functions that obey the ODE) for a given value of x, I would like maple to have those already stored instead of computing them with each invocation. So, what I need is a somehow split behavior of output. For some of my unknown functions to act as if i use range in dsolve, so that I have access at the values without further computation, and for the rest of the solutions (most of the unknown functions) just keep them in procedural form. How do I achieve this?
Below is a schematic of my probem:
ODEs:={Set of about 10000 coupled ODEs for functions labeled f[n,l] n ranging from 1..1000 and l from 1..10}
dsolve(ODEs,numeric, output=???)#What options to put in dsolve such that I have quick access to f[0,0](x) and f[0,1](x) in a given range (say xmin=0.1 and xmax=10 for example) but not store the rest.
guys, is there any possibility to obtain field equations of einstein-hilbert action?
best regards
First 1287 1288 1289 1290 1291 1292 1293 Last Page 1289 of 2429
