i want to make a solution that makes sphere not using Sphereplot()
i mean it`s fomula for a sphere that x^2+y^2+z^2=r^2
but, as you know
if i do like this
plot3d(x^2+y^2+z^2,x=0..1,y=0..1)
Warning, expecting only range variables [x, y] in expression x^2+y^2+z^2 to be plotted but found name z
how to make a sphere !?
How to compute Eigenvalues and Eigenvectors of the matrix over finite field? Thank you very much
I want to plot for example cos(theta) from 0 to 2*Pi inside a circle at a radius R. The axis theta of the ploted function is at a radius R.
Is it possible ?
The idea: parameter "a" will have a new random value each 10 days.
The way I did it is working but it can get very long especially if I do it for a system of equations and for long time more than a year (365 days).
The code:
with(DEtools); with(plots);
n := 5;
for i to n do Ra[i] := RandomTools:-Generate(distribution(Uniform(0.1e-1, .5))); a[[i]] := Ra[i] end do;
b := 0.1e-2;
T := 10;
 eq := diff(L(t), t) = a*L(t)-b;
init[1] := L(0) = 100;
 sol[1] := dsolve({init[1], subs(a = a[[1]], eq)}, L(t), range = 0 .. T, numeric);
init[2] := L(T) = rhs(sol[1](T)[2]);
sol[2] := dsolve({init[2], subs(a = a[[2]], eq)}, L(t), range = T .. 2*T, numeric);
init[3] := L(2*T) = rhs(sol[2](2*T)[2]);
sol[3] := dsolve({init[3], subs(a = a[[3]], eq)}, L(t), range = 2*T .. 3*T, numeric);
p[1] := odeplot(sol[1], [t, L(t)], t = 0 .. T);
p[2] := odeplot(sol[2], [t, L(t)], t = T .. 2*T);
p[3] := odeplot(sol[3], [t, L(t)], t = 2*T .. 3*T);
p := display([p[1], p[2], p[3]]);
display(p);
solve.mw
Hi all, I want to determine the roots of this figure that attached here. But the function has 5 parameters so the code doesn't work for it! Help me.
I have another question: The code that attached, determine the roots on horizontal axis, how could I find the values of root on vertical axis?In this figure I want to know the value of F(0) that cut the vertical axis?
I'm trying to calculate and export a huge "Strategy-Matrix". The calculation works in a smaller version with less possible strategies. For this version I use a specialised simulation-PC with enough memory (that was my problem using my own PC). But now I've got this error massage ("Kernel connection has been lost. You should save this worksheet and restart Maple. Executing commands in Maple requires a connection to the Maple kernel. Firewalls have been known to cause problems with kernel connections in Maple. Please ensure that any firewall software is configured to allow Maple to create connections to the kernel. Consult the FAQ for more information.")
The firewall should not be the problem. Below the code. num_Strat is 63001.
m_Gi:= Matrix(num_Strat, num_Strat):
for t from 1 by 1 to num_Strat
do
Digits:= 5:
v_h2:= evalf((-(24/17)* v_pEi[t]^2)*v_h1 + (v_pEi[t]*(-(128/51)*v_pKi[t]+980/51))*v_h1+ v_pEi[t]*((40/51)*v_pKj+(15/17)*v_pEj)-((110/51)*v_pKi[t]^2)*v_h1 + v_pKi[t]*((55/51)*v_pKj+1220/51*v_h1+(10/17)*v_pEj)):
m_Gi(..,t):= v_h2:
ExportMatrix(TestMatrixNK, m_Gi):
plot.mw
Hi all. Please help me to plot this. I don't know why it doesn't work correctly.
     I have a question regarding pdsolve, or Solve from the PDEtools package. I have a set of equations relating partial derivatives, and I'd like to isolate certain terms without explicitly known the functions. I can do this for a single equation, but not multiple ones. I'm curious if Maple can currently handle a system of eqns like these easily, since I will be increasing the number of eqns in the future. Here's the code
PDEtools:-declare(H=H(x,y,t)):
H(x, y, t)*`will now be displayed as`*H
eq1:= H[tt](x,y,t) = H[xx](x,y,t) + H[yy](x,y,t);
H[tt](x, y, t) = H[xx](x, y, t)+H[yy](x, y, t)
eq2 := diff(H[tt](x,y,t), t) = diff(H[tx](x,y,t), x) + diff(H[ty](x,y,t), y);
diff(H[tt](x, y, t), t) = diff(H[tx](x, y, t), x)+diff(H[ty](x, y, t), y)
eq3 := diff(H[tx](x,y,t), t) = diff(H[xx](x,y,t), x) + diff(H[xy](x,y,t), y);
diff(H[tx](x, y, t), t) = diff(H[xx](x, y, t), x)+diff(H[xy](x, y, t), y)
eq4 :=diff(H[ty](x,y,t), t) = diff(H[xy](x,y,t), x) + diff(H[yy](x,y,t), y);
diff(H[ty](x, y, t), t) = diff(H[xy](x, y, t), x)+diff(H[yy](x, y, t), y)
PDEtools:-Solve(eq3, H[xy]);
H[xy](x, y, t) = Int(diff(H[tx](x, y, t), t)-(diff(H[xx](x, y, t), x)), y)+_F1(x, t)
PDEtools:-Solve({eq1, eq2, eq3, eq4}, H[xy]);
Error, (in pdsolve/sys) the input system cannot contain equations in the arbitrary parameters alone; found equation depending only on {H[tt](x,y,t), H[xx](x,y,t), H[yy](x,y,t)}: H[tt](x,y,t)-H[xx](x,y,t)-H[yy](x,y,t)
Download PDESolveHelp.mw
Hi! I am trying to plot and store in memory some specific combinations of the solutions of the systems of ODEs that I get numerically from dsolve for a particular range of the independent variable.
A particular case for my problem is the following system of stiff ODEs for two unknown functions f[0,0](x) and f[1,0](x) beween xini (where the Initial conditions are defined) and xfin, an arbitrary value of x. Note that rosebrock method does not work, and I can only solve it with lsode[adamsfull] or lsode[backfull]. I am attaching a maple file that shows what I have done.
############## System of ODEs that needs to be solved ####################################
xini := .1
.1
xfin := 2
SystemToSolve := diff(f[0, 0](x), x)+(2./x^5+.5000000000/x)*f[0, 0](x) = -15.58845727*sin(.5773502693*x)/x^2+(46.76537182*(3.*sin(.5773502693*x)-1.732050808*x*cos(.5773502693*x)))/x^4, diff(f[1, 0](x), x)+(6./x^5+1.500000000/x)*f[1, 0](x)-1.*f[0, 0](x)/x = (-15.58845727*sin(.5773502693*x)/x^2+(46.76537182*(3.*sin(.5773502693*x)-1.732050808*x*cos(.5773502693*x)))/x^4)*(1.-1.*(1/x^4)^(1/4)*exp(1/x^4)*GAMMA(.7500000000, 1/x^4))-(1.*(-10.39230485*sin(.5773502693*x)/x^2+(31.17691454*(3.*sin(.5773502693*x)-1.732050808*x*cos(.5773502693*x)))/x^4+(4.*((.8660254040*(3.*sin(.5773502693*x)-1.732050808*x*cos(.5773502693*x)))/x+(.8660254040*((3.*(1.-6./x^2))*sin(.5773502693*x)+10.39230485*cos(.5773502693*x)/x))/x))/((1/x^4)^(1/4)*exp(1/x^4)*GAMMA(.7500000000, 1/x^4)*x^5)))*(1/x^4)^(1/4)*exp(1/x^4)*GAMMA(.7500000000, 1/x^4), f[0, 0](xini) = 1.503498546, f[1, 0](xini) = -.5011661819:
ListProcs := dsolve({SystemToSolve}, numeric, method = lsode[backfull], output = listprocedure):
f00 := eval(f[0, 0](x), ListProcs);
proc (x) local _res, _dat, _solnproc, _xout, _ndsol, _pars, _i; option `Copyright (c) 2000 by Waterloo Maple Inc. All rights reserved.`; if 1 < nargs then error "invalid input: too many arguments" end if; _EnvDSNumericSaveDigits := Digits; Digits := 15; if _EnvInFsolve = true then _xout := evalf[_EnvDSNumericSaveDigits](x) else _xout := evalf(x) end if; _dat := Array(1..4, {(1) = proc (_xin) local _xout, _n, _y0, _ctl, _octl, _reinit, _errcd, _fcn, _i, _yini, _pars, _ini, _par; option `Copyright (c) 2002 by the University of Waterloo. All rights reserved.`; table( [( "complex" ) = false ] ) _xout := _xin; _ctl := array( 1 .. 34, [( 1 ) = (2), ( 2 ) = (.1), ( 3 ) = (.1), ( 4 ) = (1), ( 5 ) = (1), ( 6 ) = (22), ( 7 ) = (0), ( 9 ) = (-.5011661819), ( 8 ) = (1.503498546), ( 11 ) = (0.1e-6), ( 10 ) = (0.1e-6), ( 13 ) = (0), ( 12 ) = (0), ( 15 ) = (0), ( 14 ) = (0), ( 18 ) = (0), ( 19 ) = (0), ( 16 ) = (0), ( 17 ) = (0), ( 22 ) = (0), ( 23 ) = (0), ( 20 ) = (0), ( 21 ) = (0), ( 27 ) = (0), ( 26 ) = (0), ( 25 ) = (0), ( 24 ) = (0), ( 31 ) = (0), ( 30 ) = (0), ( 29 ) = (0), ( 28 ) = (0), ( 32 ) = (0), ( 33 ) = (-1), ( 34 ) = (0)  ] ); _octl := array( 1 .. 34, [( 1 ) = (2), ( 2 ) = (.1), ( 3 ) = (.1), ( 4 ) = (1), ( 5 ) = (1), ( 6 ) = (22), ( 7 ) = (0), ( 9 ) = (-.5011661819), ( 8 ) = (1.503498546), ( 11 ) = (0.1e-6), ( 10 ) = (0.1e-6), ( 13 ) = (0), ( 12 ) = (0), ( 15 ) = (0), ( 14 ) = (0), ( 18 ) = (0), ( 19 ) = (0), ( 16 ) = (0), ( 17 ) = (0), ( 22 ) = (0), ( 23 ) = (0), ( 20 ) = (0), ( 21 ) = (0), ( 27 ) = (0), ( 26 ) = (0), ( 25 ) = (0), ( 24 ) = (0), ( 31 ) = (0), ( 30 ) = (0), ( 29 ) = (0), ( 28 ) = (0), ( 32 ) = (0), ( 33 ) = (-1), ( 34 ) = (0)  ] ); _n := trunc(_ctl[1]); _yini := Array(0..2, {(1) = .1, (2) = 1.503498546}); _y0 := Array(0..2, {(1) = .1, (2) = 1.503498546}); _fcn := proc (N, X, Y, YP) option `[Y[1] = f[0,0](x), Y[2] = f[1,0](x)]`; YP[1] := -15.58845727*sin(.5773502693*X)/X^2+46.76537182*(3.*sin(.5773502693*X)-1.732050808*X*cos(.5773502693*X))/X^4-(2./X^5+.5000000000/X)*Y[1]; if 1/X^4 < 0 then YP[1] := undefined; return 0 end if; if 1/X^4 < 0 then YP[1] := undefined; return 0 end if; YP[2] := (-15.58845727*sin(.5773502693*X)/X^2+46.76537182*(3.*sin(.5773502693*X)-1.732050808*X*cos(.5773502693*X))/X^4)*(1.-1.*evalf((1/X^4)^(1/4))*exp(1/X^4)*GAMMA(.7500000000, 1/X^4))-1.*(-10.39230485*sin(.5773502693*X)/X^2+31.17691454*(3.*sin(.5773502693*X)-1.732050808*X*cos(.5773502693*X))/X^4+4.*(.8660254040*(3.*sin(.5773502693*X)-1.732050808*X*cos(.5773502693*X))/X+.8660254040*(3.*(1.-6./X^2)*sin(.5773502693*X)+10.39230485*cos(.5773502693*X)/X)/X)*evalf(1/(1/X^4)^(1/4))/(exp(1/X^4)*GAMMA(.7500000000, 1/X^4)*X^5))*evalf((1/X^4)^(1/4))*exp(1/X^4)*GAMMA(.7500000000, 1/X^4)-(6./X^5+1.500000000/X)*Y[2]+1.*Y[1]/X; 0 end proc; _pars := []; if not type(_xout, 'numeric') then if member(_xout, ["start", "left", "right"]) then return _y0[0] elif _xout = "method" then return "lsode" elif _xout = "numfun" then return trunc(_ctl[24+trunc(_ctl[1])]) elif _xout = "initial" then return [seq(_yini[_i], _i = 0 .. _n)] elif _xout = "parameters" then return [seq(_yini[_n+_i], _i = 1 .. nops(_pars))] elif _xout = "initial_and_parameters" then return [seq(_yini[_i], _i = 0 .. _n)], [seq(_yini[_n+_i], _i = 1 .. nops(_pars))] elif _xout = "last" then if _ctl[2]-_y0[0] = 0. then error "no information is available on last computed point" else _xout := _ctl[2] end if elif _xout = "enginedata" then return eval(_octl, 1) elif _xout = "function" then return eval(_fcn, 1) elif type(_xin, `=`) and type(rhs(_xin), 'list') and member(lhs(_xin), {"initial", "parameters", "initial_and_parameters"}) then _ini, _par := [], []; if lhs(_xin) = "initial" then _ini := rhs(_xin) elif lhs(_xin) = "parameters" then _par := rhs(_xin) elif select(type, rhs(_xin), `=`) <> [] then _par, _ini := selectremove(type, rhs(_xin), `=`) elif nops(rhs(_xin)) < nops(_pars)+1 then error "insufficient data for specification of initial and parameters" else _par := rhs(_xin)[-nops(_pars) .. -1]; _ini := rhs(_xin)[1 .. -nops(_pars)-1] end if; _xout := lhs(_xout); if _par <> [] then `dsolve/numeric/process_parameters`(_n, _pars, _par, _yini) end if; if _ini <> [] then `dsolve/numeric/process_initial`(_n, _ini, _yini, _pars) end if; if _pars <> [] then _par := {seq(rhs(_pars[_i]) = _yini[_n+_i], _i = 1 .. nops(_pars))}; for _i from 0 to _n do _y0[_i] := subs(_par, _yini[_i]) end do; for _i from _n+1 to _n+nops(_pars) do _y0[_i] := _yini[_i] end do else for _i from 0 to _n do _y0[_i] := _yini[_i] end do end if; _octl[2] := _y0[0]; _octl[3] := _y0[0]; for _i to _n do _octl[_i+7] := _y0[_i] end do; for _i to nops(_pars) do _octl[2*_n+30+_i] := _y0[_n+_i] end do; for _i to 34 do _ctl[_i] := _octl[_i] end do; if _Env_smart_dsolve_numeric = true and type(_y0[0], 'numeric') then procname("right") := _y0[0]; procname("left") := _y0[0] end if; if _xout = "initial" then return [seq(_yini[_i], _i = 0 .. _n)] elif _xout = "parameters" then return [seq(_yini[_n+_i], _i = 1 .. nops(_pars))] else return [seq(_yini[_i], _i = 0 .. _n)], [seq(_yini[_n+_i], _i = 1 .. nops(_pars))] end if else return "procname" end if end if; if _xout-_y0[0] = 0. then return [seq(_y0[_i], _i = 0 .. _n)] end if; _reinit := false; if _xin <> "last" then if 0 < 0 and `dsolve/numeric/checkglobals`(0, table( [ ] ), _pars, _n, _yini) then _reinit := true; if _pars <> [] then _par := {seq(rhs(_pars[_i]) = _yini[_n+_i], _i = 1 .. nops(_pars))}; for _i from 0 to _n do _y0[_i] := subs(_par, _yini[_i]) end do; for _i from _n+1 to _n+nops(_pars) do _y0[_i] := _yini[_i] end do else for _i from 0 to _n do _y0[_i] := _yini[_i] end do end if; for _i to _n do _octl[_i+7] := _y0[_i] end do; for _i to nops(_pars) do _octl[2*_n+30+_i] := _y0[_n+_i] end do end if; if _pars <> [] and select(type, {seq(_yini[_n+_i], _i = 1 .. nops(_pars))}, 'undefined') <> {} then error "parameters must be initialized before solution can be computed" end if end if; if not _reinit and _xout-_ctl[2] = 0 then [_ctl[2], seq(_ctl[_i], _i = 8 .. 7+_n)] else if sign(_xout-_ctl[2]) <> sign(_ctl[2]-_y0[0]) or abs(_xout-_y0[0]) < abs(_xout-_ctl[2]) or _reinit then for _i to 34 do _ctl[_i] := _octl[_i] end do end if; _ctl[3] := _xout; if Digits <= evalhf(Digits) then try _errcd := evalhf(`dsolve/numeric/lsode`(_fcn, var(_ctl))) catch: userinfo(2, `dsolve/debug`, print(`Exception in lsode:`, [lastexception])); if searchtext('evalhf', lastexception[2]) <> 0 or searchtext('real', lastexception[2]) <> 0 or searchtext('hardware', lastexception[2]) <> 0 then _errcd := `dsolve/numeric/lsode`(_fcn, _ctl) else error  end if end try else _errcd := `dsolve/numeric/lsode`(_fcn, _ctl) end if; if _errcd < 0 then userinfo(2, {dsolve, `dsolve/lsode`}, `Last values returned:`); userinfo(2, {dsolve, `dsolve/lsode`}, ` t =`, _ctl[2]); _i := 8; userinfo(2, {dsolve, `dsolve/lsode`}, ` y =`, _ctl[_i]); for _i from _i+1 to 7+_n do userinfo(2, {dsolve, `dsolve/lsode`}, `	 `, _ctl[_i]) end do; if _errcd+1. = 0. then if _ctl[14+trunc(_ctl[1])] <> 0 then error "an excessive amount of work was done, maxstep may be too small" else error "an excessive amount of work (greater than mxstep) was done" end if elif _errcd+2. = 0. then error "too much accuracy was requested for the machine being used" elif _errcd+3. = 0. then error "illegal input was detected" elif _errcd+4. = 0. then error "repeated error test failures on the attempted step" elif _errcd+5. = 0. then error "repeated convergence test failures on the attempted step" elif _errcd+6. = 0. then error "pure relative error control requested for a variable that has vanished" elif _errcd+7. = 0. then error "cannot evaluate the solution past %1, maxfun limit exceeded (see <a href='http://www.maplesoft.com/support/help/search.aspx?term=dsolve,maxfun' target='_new'>?dsolve,maxfun</a> for details)", evalf[8](_ctl[2]) else error "unknown error code returned from lsode %1", trunc(_errcd) end if end if; if _Env_smart_dsolve_numeric = true then if _y0[0] < _xout and procname("right") < _xout then procname("right") := _xout elif _xout < _y0[0] and _xout < procname("left") then procname("left") := _xout end if end if; [_xout, seq(_ctl[_i], _i = 8 .. 7+_n)] end if end proc, (2) = Array(1..3, {(1) = 18446744078356217278, (2) = 18446744078356217454, (3) = 18446744078356217630}), (3) = [x, f[0, 0](x), f[1, 0](x)], (4) = []}); _solnproc := _dat[1]; _pars := map(rhs, _dat[4]); if not type(_xout, 'numeric') then if member(x, ["start", 'start', "method", 'method', "left", 'left', "right", 'right', "leftdata", "rightdata", "enginedata", "eventstop", 'eventstop', "eventclear", 'eventclear', "eventstatus", 'eventstatus', "eventcount", 'eventcount', "laxtol", 'laxtol', "numfun", 'numfun', NULL]) then _res := _solnproc(convert(x, 'string')); if 1 < nops([_res]) then return _res elif type(_res, 'array') then return eval(_res, 1) elif _res <> "procname" then return _res end if elif member(x, ["last", 'last', "initial", 'initial', NULL]) then _res := _solnproc(convert(x, 'string')); if type(_res, 'list') then return _res[2] else return NULL end if elif member(x, ["parameters", 'parameters', "initial_and_parameters", 'initial_and_parameters', NULL]) then _xout := convert(x, 'string'); _res := _solnproc(_xout); if _xout = "parameters" then return [seq(_pars[_i] = _res[_i], _i = 1 .. nops(_pars))] else return [_res[2], seq(_pars[_i] = [_res][2][_i], _i = 1 .. nops(_pars))] end if elif type(_xout, `=`) and member(lhs(_xout), ["initial", 'initial', "parameters", 'parameters', "initial_and_parameters", 'initial_and_parameters', NULL]) then _xout := convert(lhs(x), 'string') = rhs(x); if lhs(_xout) = "initial" then if type(rhs(_xout), 'list') then _res := _solnproc(_xout) else _res := _solnproc("initial" = ["single", 2, rhs(_xout)]) end if elif not type(rhs(_xout), 'list') then error "initial and/or parameter values must be specified in a list" elif lhs(_xout) = "initial_and_parameters" and nops(rhs(_xout)) = nops(_pars)+1 then _res := _solnproc(lhs(_xout) = ["single", 2, op(rhs(_xout))]) else _res := _solnproc(_xout) end if; if lhs(_xout) = "initial" then return _res[2] elif lhs(_xout) = "parameters" then return [seq(_pars[_i] = _res[_i], _i = 1 .. nops(_pars))] else return [_res[2], seq(_pars[_i] = [_res][2][_i], _i = 1 .. nops(_pars))] end if elif type(_xout, `=`) and member(lhs(_xout), ["eventdisable", 'eventdisable', "eventenable", 'eventenable', "eventfired", 'eventfired', "direction", 'direction', NULL]) then return _solnproc(convert(lhs(x), 'string') = rhs(x)) elif _xout = "solnprocedure" then return eval(_solnproc) elif _xout = "sysvars" then return _dat[3] end if; if procname <> unknown then return ('procname')(x) else _ndsol := `tools/gensym`("f[0,0](x)"); eval(FromInert(_Inert_FUNCTION(_Inert_NAME("assign"), _Inert_EXPSEQ(ToInert(_ndsol), _Inert_VERBATIM(pointto(_dat[2][2])))))); return FromInert(_Inert_FUNCTION(ToInert(_ndsol), _Inert_EXPSEQ(ToInert(x)))) end if end if; try _res := _solnproc(_xout); _res[2] catch: error  end try end proc
f10 := eval(f[1, 0](x), ListProcs);
proc (x) local _res, _dat, _solnproc, _xout, _ndsol, _pars, _i; option `Copyright (c) 2000 by Waterloo Maple Inc. All rights reserved.`; if 1 < nargs then error "invalid input: too many arguments" end if; _EnvDSNumericSaveDigits := Digits; Digits := 15; if _EnvInFsolve = true then _xout := evalf[_EnvDSNumericSaveDigits](x) else _xout := evalf(x) end if; _dat := Array(1..4, {(1) = proc (_xin) local _xout, _n, _y0, _ctl, _octl, _reinit, _errcd, _fcn, _i, _yini, _pars, _ini, _par; option `Copyright (c) 2002 by the University of Waterloo. All rights reserved.`; table( [( "complex" ) = false ] ) _xout := _xin; _ctl := array( 1 .. 34, [( 1 ) = (2), ( 2 ) = (.1), ( 3 ) = (.1), ( 4 ) = (1), ( 5 ) = (1), ( 6 ) = (22), ( 7 ) = (0), ( 9 ) = (-.5011661819), ( 8 ) = (1.503498546), ( 11 ) = (0.1e-6), ( 10 ) = (0.1e-6), ( 13 ) = (0), ( 12 ) = (0), ( 15 ) = (0), ( 14 ) = (0), ( 18 ) = (0), ( 19 ) = (0), ( 16 ) = (0), ( 17 ) = (0), ( 22 ) = (0), ( 23 ) = (0), ( 20 ) = (0), ( 21 ) = (0), ( 27 ) = (0), ( 26 ) = (0), ( 25 ) = (0), ( 24 ) = (0), ( 31 ) = (0), ( 30 ) = (0), ( 29 ) = (0), ( 28 ) = (0), ( 32 ) = (0), ( 33 ) = (-1), ( 34 ) = (0)  ] ); _octl := array( 1 .. 34, [( 1 ) = (2), ( 2 ) = (.1), ( 3 ) = (.1), ( 4 ) = (1), ( 5 ) = (1), ( 6 ) = (22), ( 7 ) = (0), ( 9 ) = (-.5011661819), ( 8 ) = (1.503498546), ( 11 ) = (0.1e-6), ( 10 ) = (0.1e-6), ( 13 ) = (0), ( 12 ) = (0), ( 15 ) = (0), ( 14 ) = (0), ( 18 ) = (0), ( 19 ) = (0), ( 16 ) = (0), ( 17 ) = (0), ( 22 ) = (0), ( 23 ) = (0), ( 20 ) = (0), ( 21 ) = (0), ( 27 ) = (0), ( 26 ) = (0), ( 25 ) = (0), ( 24 ) = (0), ( 31 ) = (0), ( 30 ) = (0), ( 29 ) = (0), ( 28 ) = (0), ( 32 ) = (0), ( 33 ) = (-1), ( 34 ) = (0)  ] ); _n := trunc(_ctl[1]); _yini := Array(0..2, {(1) = .1, (2) = 1.503498546}); _y0 := Array(0..2, {(1) = .1, (2) = 1.503498546}); _fcn := proc (N, X, Y, YP) option `[Y[1] = f[0,0](x), Y[2] = f[1,0](x)]`; YP[1] := -15.58845727*sin(.5773502693*X)/X^2+46.76537182*(3.*sin(.5773502693*X)-1.732050808*X*cos(.5773502693*X))/X^4-(2./X^5+.5000000000/X)*Y[1]; if 1/X^4 < 0 then YP[1] := undefined; return 0 end if; if 1/X^4 < 0 then YP[1] := undefined; return 0 end if; YP[2] := (-15.58845727*sin(.5773502693*X)/X^2+46.76537182*(3.*sin(.5773502693*X)-1.732050808*X*cos(.5773502693*X))/X^4)*(1.-1.*evalf((1/X^4)^(1/4))*exp(1/X^4)*GAMMA(.7500000000, 1/X^4))-1.*(-10.39230485*sin(.5773502693*X)/X^2+31.17691454*(3.*sin(.5773502693*X)-1.732050808*X*cos(.5773502693*X))/X^4+4.*(.8660254040*(3.*sin(.5773502693*X)-1.732050808*X*cos(.5773502693*X))/X+.8660254040*(3.*(1.-6./X^2)*sin(.5773502693*X)+10.39230485*cos(.5773502693*X)/X)/X)*evalf(1/(1/X^4)^(1/4))/(exp(1/X^4)*GAMMA(.7500000000, 1/X^4)*X^5))*evalf((1/X^4)^(1/4))*exp(1/X^4)*GAMMA(.7500000000, 1/X^4)-(6./X^5+1.500000000/X)*Y[2]+1.*Y[1]/X; 0 end proc; _pars := []; if not type(_xout, 'numeric') then if member(_xout, ["start", "left", "right"]) then return _y0[0] elif _xout = "method" then return "lsode" elif _xout = "numfun" then return trunc(_ctl[24+trunc(_ctl[1])]) elif _xout = "initial" then return [seq(_yini[_i], _i = 0 .. _n)] elif _xout = "parameters" then return [seq(_yini[_n+_i], _i = 1 .. nops(_pars))] elif _xout = "initial_and_parameters" then return [seq(_yini[_i], _i = 0 .. _n)], [seq(_yini[_n+_i], _i = 1 .. nops(_pars))] elif _xout = "last" then if _ctl[2]-_y0[0] = 0. then error "no information is available on last computed point" else _xout := _ctl[2] end if elif _xout = "enginedata" then return eval(_octl, 1) elif _xout = "function" then return eval(_fcn, 1) elif type(_xin, `=`) and type(rhs(_xin), 'list') and member(lhs(_xin), {"initial", "parameters", "initial_and_parameters"}) then _ini, _par := [], []; if lhs(_xin) = "initial" then _ini := rhs(_xin) elif lhs(_xin) = "parameters" then _par := rhs(_xin) elif select(type, rhs(_xin), `=`) <> [] then _par, _ini := selectremove(type, rhs(_xin), `=`) elif nops(rhs(_xin)) < nops(_pars)+1 then error "insufficient data for specification of initial and parameters" else _par := rhs(_xin)[-nops(_pars) .. -1]; _ini := rhs(_xin)[1 .. -nops(_pars)-1] end if; _xout := lhs(_xout); if _par <> [] then `dsolve/numeric/process_parameters`(_n, _pars, _par, _yini) end if; if _ini <> [] then `dsolve/numeric/process_initial`(_n, _ini, _yini, _pars) end if; if _pars <> [] then _par := {seq(rhs(_pars[_i]) = _yini[_n+_i], _i = 1 .. nops(_pars))}; for _i from 0 to _n do _y0[_i] := subs(_par, _yini[_i]) end do; for _i from _n+1 to _n+nops(_pars) do _y0[_i] := _yini[_i] end do else for _i from 0 to _n do _y0[_i] := _yini[_i] end do end if; _octl[2] := _y0[0]; _octl[3] := _y0[0]; for _i to _n do _octl[_i+7] := _y0[_i] end do; for _i to nops(_pars) do _octl[2*_n+30+_i] := _y0[_n+_i] end do; for _i to 34 do _ctl[_i] := _octl[_i] end do; if _Env_smart_dsolve_numeric = true and type(_y0[0], 'numeric') then procname("right") := _y0[0]; procname("left") := _y0[0] end if; if _xout = "initial" then return [seq(_yini[_i], _i = 0 .. _n)] elif _xout = "parameters" then return [seq(_yini[_n+_i], _i = 1 .. nops(_pars))] else return [seq(_yini[_i], _i = 0 .. _n)], [seq(_yini[_n+_i], _i = 1 .. nops(_pars))] end if else return "procname" end if end if; if _xout-_y0[0] = 0. then return [seq(_y0[_i], _i = 0 .. _n)] end if; _reinit := false; if _xin <> "last" then if 0 < 0 and `dsolve/numeric/checkglobals`(0, table( [ ] ), _pars, _n, _yini) then _reinit := true; if _pars <> [] then _par := {seq(rhs(_pars[_i]) = _yini[_n+_i], _i = 1 .. nops(_pars))}; for _i from 0 to _n do _y0[_i] := subs(_par, _yini[_i]) end do; for _i from _n+1 to _n+nops(_pars) do _y0[_i] := _yini[_i] end do else for _i from 0 to _n do _y0[_i] := _yini[_i] end do end if; for _i to _n do _octl[_i+7] := _y0[_i] end do; for _i to nops(_pars) do _octl[2*_n+30+_i] := _y0[_n+_i] end do end if; if _pars <> [] and select(type, {seq(_yini[_n+_i], _i = 1 .. nops(_pars))}, 'undefined') <> {} then error "parameters must be initialized before solution can be computed" end if end if; if not _reinit and _xout-_ctl[2] = 0 then [_ctl[2], seq(_ctl[_i], _i = 8 .. 7+_n)] else if sign(_xout-_ctl[2]) <> sign(_ctl[2]-_y0[0]) or abs(_xout-_y0[0]) < abs(_xout-_ctl[2]) or _reinit then for _i to 34 do _ctl[_i] := _octl[_i] end do end if; _ctl[3] := _xout; if Digits <= evalhf(Digits) then try _errcd := evalhf(`dsolve/numeric/lsode`(_fcn, var(_ctl))) catch: userinfo(2, `dsolve/debug`, print(`Exception in lsode:`, [lastexception])); if searchtext('evalhf', lastexception[2]) <> 0 or searchtext('real', lastexception[2]) <> 0 or searchtext('hardware', lastexception[2]) <> 0 then _errcd := `dsolve/numeric/lsode`(_fcn, _ctl) else error  end if end try else _errcd := `dsolve/numeric/lsode`(_fcn, _ctl) end if; if _errcd < 0 then userinfo(2, {dsolve, `dsolve/lsode`}, `Last values returned:`); userinfo(2, {dsolve, `dsolve/lsode`}, ` t =`, _ctl[2]); _i := 8; userinfo(2, {dsolve, `dsolve/lsode`}, ` y =`, _ctl[_i]); for _i from _i+1 to 7+_n do userinfo(2, {dsolve, `dsolve/lsode`}, `	 `, _ctl[_i]) end do; if _errcd+1. = 0. then if _ctl[14+trunc(_ctl[1])] <> 0 then error "an excessive amount of work was done, maxstep may be too small" else error "an excessive amount of work (greater than mxstep) was done" end if elif _errcd+2. = 0. then error "too much accuracy was requested for the machine being used" elif _errcd+3. = 0. then error "illegal input was detected" elif _errcd+4. = 0. then error "repeated error test failures on the attempted step" elif _errcd+5. = 0. then error "repeated convergence test failures on the attempted step" elif _errcd+6. = 0. then error "pure relative error control requested for a variable that has vanished" elif _errcd+7. = 0. then error "cannot evaluate the solution past %1, maxfun limit exceeded (see <a href='http://www.maplesoft.com/support/help/search.aspx?term=dsolve,maxfun' target='_new'>?dsolve,maxfun</a> for details)", evalf[8](_ctl[2]) else error "unknown error code returned from lsode %1", trunc(_errcd) end if end if; if _Env_smart_dsolve_numeric = true then if _y0[0] < _xout and procname("right") < _xout then procname("right") := _xout elif _xout < _y0[0] and _xout < procname("left") then procname("left") := _xout end if end if; [_xout, seq(_ctl[_i], _i = 8 .. 7+_n)] end if end proc, (2) = Array(1..3, {(1) = 18446744078356217278, (2) = 18446744078356217454, (3) = 18446744078356217630}), (3) = [x, f[0, 0](x), f[1, 0](x)], (4) = []}); _solnproc := _dat[1]; _pars := map(rhs, _dat[4]); if not type(_xout, 'numeric') then if member(x, ["start", 'start', "method", 'method', "left", 'left', "right", 'right', "leftdata", "rightdata", "enginedata", "eventstop", 'eventstop', "eventclear", 'eventclear', "eventstatus", 'eventstatus', "eventcount", 'eventcount', "laxtol", 'laxtol', "numfun", 'numfun', NULL]) then _res := _solnproc(convert(x, 'string')); if 1 < nops([_res]) then return _res elif type(_res, 'array') then return eval(_res, 1) elif _res <> "procname" then return _res end if elif member(x, ["last", 'last', "initial", 'initial', NULL]) then _res := _solnproc(convert(x, 'string')); if type(_res, 'list') then return _res[3] else return NULL end if elif member(x, ["parameters", 'parameters', "initial_and_parameters", 'initial_and_parameters', NULL]) then _xout := convert(x, 'string'); _res := _solnproc(_xout); if _xout = "parameters" then return [seq(_pars[_i] = _res[_i], _i = 1 .. nops(_pars))] else return [_res[3], seq(_pars[_i] = [_res][2][_i], _i = 1 .. nops(_pars))] end if elif type(_xout, `=`) and member(lhs(_xout), ["initial", 'initial', "parameters", 'parameters', "initial_and_parameters", 'initial_and_parameters', NULL]) then _xout := convert(lhs(x), 'string') = rhs(x); if lhs(_xout) = "initial" then if type(rhs(_xout), 'list') then _res := _solnproc(_xout) else _res := _solnproc("initial" = ["single", 3, rhs(_xout)]) end if elif not type(rhs(_xout), 'list') then error "initial and/or parameter values must be specified in a list" elif lhs(_xout) = "initial_and_parameters" and nops(rhs(_xout)) = nops(_pars)+1 then _res := _solnproc(lhs(_xout) = ["single", 3, op(rhs(_xout))]) else _res := _solnproc(_xout) end if; if lhs(_xout) = "initial" then return _res[3] elif lhs(_xout) = "parameters" then return [seq(_pars[_i] = _res[_i], _i = 1 .. nops(_pars))] else return [_res[3], seq(_pars[_i] = [_res][2][_i], _i = 1 .. nops(_pars))] end if elif type(_xout, `=`) and member(lhs(_xout), ["eventdisable", 'eventdisable', "eventenable", 'eventenable', "eventfired", 'eventfired', "direction", 'direction', NULL]) then return _solnproc(convert(lhs(x), 'string') = rhs(x)) elif _xout = "solnprocedure" then return eval(_solnproc) elif _xout = "sysvars" then return _dat[3] end if; if procname <> unknown then return ('procname')(x) else _ndsol := `tools/gensym`("f[1,0](x)"); eval(FromInert(_Inert_FUNCTION(_Inert_NAME("assign"), _Inert_EXPSEQ(ToInert(_ndsol), _Inert_VERBATIM(pointto(_dat[2][3])))))); return FromInert(_Inert_FUNCTION(ToInert(_ndsol), _Inert_EXPSEQ(ToInert(x)))) end if end if; try _res := _solnproc(_xout); _res[3] catch: error  end try end proc
ftoplot := unapply(f00(x)+0.45e-1*f10(x)/x^(3/2), x)
proc (x) options operator, arrow; f00(x)+0.45e-1*f10(x)/x^(3/2) end proc
plot(ftoplot(x), x = xini .. xfin)
Download Test2ODEs.mw
The approach in that file works, however I have a question regarding the efficiency of my method, since I plan to extend the system to many more ODEs besides just 2 and also extend the range to a larger xfin. In this method, since I define the function to plot in terms of f01 and f02, wich are procedures, does this mean that for each x on the grid for the plot(ftoplot,x=xini..xfin) maple actually computes the solutions f00(x) and f01(x) and then forms the ftoplot combination and plots that specific point? If the default sampling of my interval is, say 1000 points, does it mean that the way I wrote it I will have 1000 invocations of the dsolve procedure, for each x in the sample? I am not sure, it seems to me that is the case. This would imply that instead of advancing the solution at each step maple starts over again from xini. How could I just avoid this behavior and instead have access to the values of ftoplot(x) in the range xini to xfin stored from one invocation of dsolve?
The ideal scenario for me would be to have f[0,0](x) and f[0,1](x) stored as an interpolated function between xini and xfin from the solutions of one invocation of dsolve prior to defining ftoplot. Can this be achieved in principle? How? Remember, i have to use method=lsode and range is not accepted.
Its pretty obvious that i would like the to get the answer -exp(-n(cos(phi)+sin(phi))) from the 'simplify' command. What am i doing wrong? the problem
How do we print "Hello" in green in a .mw file in Maple 13?
mapleatha
I would like to pick out specific christoffel symbols once maple calculates them. Right now I am using CoefficientList, but I would like a more direct way, as I am working with someone using Maple 17, and they are put in a different order in the CoefficientList. Here is the bit of my code I would like help with.
hi friends
After this cods i see very error
 > restart;
read(orbit.sav ): whit(plots):
ax := -G*Mz*x/(x^2+y^2)^(3/2);
ay := -G*Mz*y/(x^2+y^2)^(3/2);
i := 'i'; j := i+1;
for k from 0 to 3 do
x := 7*10^6; Vx := 0;
y := 0; Vy := 9000;
dt := evalf(1/2^k);
for i from 0 to 328 do
X[i] := evalf(x); Y[i] := evalf(y);
for n to 40*2^k do
x := evalf((1/2)*ax*dt^2+Vx*dt+x); y := evalf((1/2)*ay*dt^2+Vy*dt+y);
Vx := evalf(ax*dt+Vx); Vy := evalf(ay*dt+Vy)
od;
if i mod 41= 0 then
dX[k, i] := X[i]-XS[j]; dY[k, i] := Y[i]-YS[j]
fi
od;
p[k] := plot([seq([(X[i]-XS[j])*(1/1000), (Y[i]-YS[j])*(1/1000)], i = 0 .. 328)], color = green) end do;
p1 := display({seq(p[k], k = 0 .. 3)}, thickness = 3)
SI := [seq(41*i, i = 0 .. 8)]
p2 := plot({seq([seq([(1/1000)*dX[k, i], (1/1000)*dY[k, i]], k = 0 .. 1), [0, 0]], i = SI)}, color = black)
display({p1, p2}, scaling = constrained, labels = ['dx', 'dy'])
display({p1, p2}, view = [-.1 .. .5, -.4 .. .2], scaling = constrained, labels = ['dx', 'dy'])
can you help me Please?
Is there a Maple command to get ColumnGraph in 3D as bar3 in Matlab.
In 2D, I use:
Statistics[ColumnGraph](A);  # equivalent to bar(A) in Matlab
Dear,
Last week I made a question, which was kindly answered with the conclusion there might be no solutions.
Now as this cannot be (I'll explain later), I have eliminated all extra aspects of the program to just show the code where the problem is occuring. You can find it via this link prob.mw
The problem is as follows:
I have 3 points, of which I need to determine the distances from the 0,0 point. The distance between the points are known and the angle between the neutral axis and the line through a point are also known. The set-up is shown in the rough sketch. (k1,k2,k3,corner 1, corner 2, corner 3 are known; a,b,c are unknown.). With these values known, I can easily calculate a,b,c via the cosine rule.
However I want to make a sensitivity analysis for a parameter that determines the 3 corners (called f in the code). Herefore I need to become an answer of a,b,c in function of f and only f (as I need them in following calculations which are not shown in the code). However this doesnt seem to work. The program does not return a solution.
Do you guys know how I can make sure that this program is runnable, so I can get my a,b,c values in function of f? I'd be very very very thankful as I'm stuck with this crucial part of my calculation for weeks.
With kind regards
Mathieu
First 1288 1289 1290 1291 1292 1293 1294 Last Page 1290 of 2429
