I am new to Maple, and I would like to get some help. Thank you.
I have an assignment where I had to make a power-regression of some numbers.
Now, I did this. I got this  1,18971*x*0,38480
The next task is to make a prognosis (lol, I don't know how to say that in english), but I had to get to know what x = 17.
Ussualy, you would just put 17 in your function and then calcuate what x=17 is.
Now, I want to know if there's a method in maple where you can solve what x=17 is.
The reason i ask is because our assignment is a "Maple-assignment" so if there's a solve-function, then please let me know.
I appreciate your help.
Hi EveryOne!
I have polynomial: p(x) = x^4 + 27x^3 + x^2 + 16x +1 over finite field F=GF(2^8)/f(x)=x^8 + x^4 +x^3 +1
The factors of this polynomial are: (x + 37)(x + 217)(x^2 + 213x +30) (in maple)
Hence there two roots of p(x): x = 37 and x = 217 in GF(2^8). The factor x^2 + 231x +30 is of degree 2. There are not roots in F. But in extension field GF((2^8)^2) of F, also there are two roots of factor x^2 + 213x + 30 (for example: x = 256 and x = 256^256 = 487).
How to find these roots of p(x) in extension field GF((2^8)^2) by maple? Please help me! Thanks a lot.
So I've been trying to plot a parametric equation with the command:
But I keep recieving the error: Error, (in plot) incorrect first argument [cos(2*t)+sin(2*t), -2*sin(2*t)+2*cos(2*t), t = 0 .. 6.29]
Do any of you have an idea of what I'm doing wrong?
I have written the code below, and received the error message in the bottom. Can any body help me?
> with(plots);
> u := 100*sin((1/2)*pi*x)*((1-cosh(pi))*sinh((1/2)*pi*y)+sinh(pi)*cosh((1/2)*pi*y))/sin(pi);
> implicitplot({u = 10, u = 20, u = 30, u = 40, u = 50, u = 60, u = 70, u = 80, u = 90}, x = 0 .. 2, y = 0 .. 2, grid = [100, 100]);
Error, (in plots/implicitplot) invalid input: the following extra unknowns were found in the input expression: {pi}
Hey
As a lot of people before me I'm severely dissappointed my Maple's ability to export a .mw file to .tex.
The output looks horrible and even disappears off the side of the page in some places.
I've searched far and wide on the internet but it's difficult for me to understand the few, outdated, results I've dug up.
Is it completely impossible to get my hands on a good (or just working) Maple 18 to LaTex exporter? It's not possible for me to begin coding my own.
So I paid for Maple 2015 and accidentaly mistyped my email address.  I was wondering if there is anyway that I can resend the same download to the correct email address.  If anyone can help this would be greatly appreciated.
The following command:
limit(CDF(cos(RandomVariable(Normal(0,1))),x),x=infinity);
returns erf(Pi/sqrt(2)) instead of 1, as expected for a CDF.
Does someone has an explanation for this strange behaviour?
Best regards,
Régis
Hi all, I am new to MAPLE, I have been using Mathematica mostly. Here is what i am trying to do in MAPLE,
Use the procedure plotmotion 2 on the plotmo worksheet to animate the motion of a marble in a bowl of the shape of the bottom half of the ellipsoid x^2/16 + y^2/12 +z^2/9 = 1
Can anyone help? It will be greatly appreciated.
I'm trying to define a matrix that will have all the possible game results in a 9 team competition in one round. The results are a column in the form [game 1 home team, game 1 away team, game 2 home team, ... , game 9 away team]
This should give me a matrix with 18 rows, and 512 columns, where each column is a possible game result.
In essense, to continue the pattern of this matrix on for all 512 columns.
I've fiddled with for statements, but it ends up getting very messy given the number of nests that are required.
Thoughts? Any help would be much appreciated,
Thanks, Alex, Australia.
Hi Maple People,
I got stuck trying to write a procedue for my project today.  My topic is Prime Constellations.
If you want to help me, please read my primer on constellations
https://docs.google.com/viewer?a=v&pid=sites&srcid=ZGVmYXVsdGRvbWFpbnxwcmltZWNvbnN0ZWxsYXRpb25zfGd4OjNmOWZlNWQxZDY2ODY4YmQ
The procedure should refine an offset Vector and increase a multiplier scalar.
I want to delay putting the broken procedure until I can simplify it and try again.
Matt Anderson
hi friends
I encountered a problem and I can not draw the plot of this code
> sol := fsolve({diff(S, x) = 0, diff(S, y) = 0}, {x, y});
> with(VectorCalculus);
> with(linalg);
> s1 := evalf(subs(sol, linalg[grad](S, [x, y])));
> with(LinearAlgebra);
> s2 := evalf(subs(sol, linalg[hessian](S, [x, y]))); pmp0 := [x-subs(sol, x), y-subs(sol, y)]; sapprox := s0+evalm(`&*`(`&*`(transpose(pmp0), s2), pmp0));
> with(Statistics);
> with(stats); statevalf[icdf, chisquare[4]](.95);
> with(plottools);
> with(plots);
> with(linalg); ellips := {seq(stats*([statevalf[icdf, chisquare[4]]])(c) = sapprox, c = [.5, .95, .999])};
> plots(ellips(x, y), x = 950 .. 1000, y = 700 .. 750, grid = [50, 50], view = [950 .. 1000, 700 .. 750]);
can you helpe me?Thank you
Dear Friends,
I am solving 6 ODEs using maple15. then i got this error. anyone know abou this? thank you.
problem2.mw
restart:with (plots): B:=1:M:=1:Gr:=0.5:Pr:=3:w:=0.02:blt:=5:Bi:=10:
Eq1:=diff(f(eta),eta,eta,eta)-(diff(f(eta),eta))^(2)+f(eta)*diff(f(eta),eta,eta)+B*H(eta)*(F(eta)-diff(f(eta),eta))-M*diff(f(eta),eta)+Gr*theta(eta)=0;
diff(diff(diff(f(eta), eta), eta), eta)-(diff(f(eta), eta))^2+f(eta)*(diff(diff(f(eta), eta), eta))+H(eta)*(F(eta)-(diff(f(eta), eta)))-(diff(f(eta), eta))+.5*theta(eta) = 0
Eq2:=(1+Nr)*diff(theta(eta),eta,eta)+Pr*f(eta)*diff(theta(eta),eta)+(2/3)*H(eta)*B*(theta1(eta)-theta(eta))=0;
(1+Nr)*(diff(diff(theta(eta), eta), eta))+3*f(eta)*(diff(theta(eta), eta))+(2/3)*H(eta)*(theta1(eta)-theta(eta)) = 0
Eq3:=H(eta)*F(eta)+H(eta)*diff(G(eta),eta)+G(eta)*diff(H(eta),eta)=0;
H(eta)*F(eta)+H(eta)*(diff(G(eta), eta))+G(eta)*(diff(H(eta), eta)) = 0
Eq4:=F(eta)^2+G(eta)*diff(F(eta),eta)+B*(F(eta)-diff(f(eta),eta))=0;
F(eta)^2+G(eta)*(diff(F(eta), eta))+F(eta)-(diff(f(eta), eta)) = 0
Eq5:=G(eta)*diff(G(eta),eta)+B*(f(eta)+G(eta))=0;
G(eta)*(diff(G(eta), eta))+f(eta)+G(eta) = 0
Eq6:=G(eta)*diff(theta1(eta),eta)+l*B*(theta1(eta)-theta(eta))=0;
G(eta)*(diff(theta1(eta), eta))+l*(theta1(eta)-theta(eta)) = 0
bcs:=f(0)=0,(D(f))(0)=1,(D(theta))(0)=-Bi*(1-theta(0)),(D(f))(blt)=0,F(blt)=0,G(blt)=-f(blt),H(eta)=w,theta(blt)=0,theta1(blt)=0;
f(0) = 0, (D(f))(0) = 1, (D(theta))(0) = -10+10*theta(0), (D(f))(5) = 0, F(5) = 0, G(5) = -f(5), H(eta) = 0.2e-1, theta(5) = 0, theta1(5) = 0
L:=[0.5,1,1.5,2];
[.5, 1, 1.5, 2]
for k from 1 to 4 do p:=dsolve(eval({Eq1,Eq2,Eq3,Eq4,Eq5,Eq6,bcs},Nr=L[k]),[f(eta),F(eta),G(eta),H(eta),theta(eta),theta1(eta)],numeric,output=listprocedure);end do:
Error, (in dsolve/numeric/bvp) unevaluated names in system not allowed: {Y[9], Y[10]}
Download problem2.mw
When I take the derivative of this function wrt p, I am getting this:
Why the program gives , instead of only
Sorry for the format, I just copy and paste.
First 1286 1287 1288 1289 1290 1291 1292 Last Page 1288 of 2429
