I'm having trouble of converting my y-axis to decibel.  Here is is my script:
loglogplot(1/(1+f), f = 10^(-4) .. 10^4);
Everything is fine except for the y-axis, which is not in dB.
I'm computing a matrix which is a hessian of a quadratic function and it should be symmetric.
Unfortunately, because of the numerical errors, the hessian matrix becomes unsymmetric.
Then, I want to use this matrix as the input for the QPSolve procedure, and I get the error that the matrix is unsymmetric.
To obtain the symmetric matrix, I'm doing the following redundant computation:
A := MTM[triu](B, 1) + Transpose(MTM[triu](B)):
Is there a better solution to this problem?
Hi everyone, I have been trying to plot the Taylor Polynomial approximation with the following code. However, my maple crushes everytime I run it. I indexed some of the variables to get the plot. The code works fine without the index. What did I do wrong?
y := array(1 .. 2);
Digits := 10;
n := 30;
h := .1;
T := 0;
X := 1;
f := (x, t) -> 1/(3*x(t)-t-2);
one := 1/(3*x(t)-t-2);
two := diff(f(x, t), t);
first := diff(x(t), t)
for k to n do
y[1] := subs(t = T(k), x(T(k)) = X(k), one);
y[2] := subs(first = y[1], t = T, x(T(k)) = X(k), two);
X[k+1] := X+sum(y[i]*h^i/factorial(i), i = 1 .. 2);
T[k+1] := T+h
X[n];
data := [seq([T[n], X[n]], n = 0 .. 30)];
p[2] := plot(data, style = point, color = blue);
p[3] := plot(data, style = line, color = blue);
display(p[2],  p[3])
The code without Index (which works fine)
y := array(1 .. 2);
Digits := 10;
n := 30;
h := .1;
T := 1;
X := .1547196278;
one := x(t)^4*e^t-(1/3)*x(t);
first := diff(x(t), t);
for k to n do
y[1] := subs(t = T, x(T) = X, one);
y[2] := subs(first = y[1], t = T, x(T) = X, two);
X := X+sum(y[i]*h^i/factorial(i), i = 1 .. 2);
T := T+h
end do
Today I have a problem with assign that never arised before. I solved a system of equations with two solutions and wanted to assign, e.g. the second one. Does anybody know why "assign" here does not work, even though I often used it before in the same way. (I also tried it with the array-solution, but I received the same problem.
Output:
  {rH = 0., rL = 0., xH = 0.2289428485, xL = 0.2289428485}, {
    rH = 22.70954353, rL = 32.28670872, xH = 0.4250775404,
    xL = 0.4393791233}
    xL = 0.4393791233}
assign {rH = 22.70954353, rL = 32.28670872, xH = 0.4250775404,
  xL = 0.4393791233}
                         rL, rH, xL, xH
I would be very glad, if anybody could help me.
And here is the whole algorithm:
Hi,I'm using Maple 15. When I plot with the command
Aplot:= Plot2D(Q[2 .. 26, 13], Q[2 .. 26, 14], style = point, color = blue, symbol = solidcircle, symbolsize = 16, font = [Arial, Bold, 13], axes = box, axis = [thickness = 1, tickmarks = [5, subticks = 5]]);
There is the report of problem
Error, (in plot/options2d) unexpected axis suboption: thickness = 1
Thank you for helping me.
I have been having problems with using the BodePlot function with units:
R1 := 18.2*10^3*Unit('Omega');
R2 := 10^3*Unit('Omega');
C1 := 470*10^(-12)*Unit('F');
C2 := 4.7*10^(-9)*Unit('F');
# wo is in hertz
wo := 1/sqrt(R1*R2*C1*C2);
# Q is unitless
Q := wo*R1*R2*C2/(R1+R2)
with(DynamicSystems);
sys := TransferFunction(wo^2/(s^2+wo*s/Q+wo^2));
This is the error message I got:
Error, (in Units:-Standard:-+) the units `1` and `Hz` have incompatible dimensions
I think the problem is that the BodePlot function doesn't expect 'wo' to have units.
So I tried to work around the issue by using the loglogplot but it doesn't seem to like
complex function even when I used abs to find the magnitude (with or without units).
 Any workaround is appreciated.
I'm using MAPLE files, and a little to bored to run all commands in it.
Instead of it would be a bit easier to make a package.
Is there any post here how can I do it?
how to derive poincare series from symmetric function in maple
use taylor function need to specify its limit
if we do not know its limit,
how to know whether a function is finite in taylor expression
for example poincare series
1/((1+x)*(1+x^2))
how to display as taylor series without specify the limit of degree
because do not want to approximate poincare series with taylor
want a complete taylor series
goal is to find the polynomials which degree are 1 and 2 in above example
Strings := {"buffalo", "zebra", "aardvark", "aardwolf", "anteater", "antelope", "bumblebee"};
CP := {seq(seq(StringTools:-Take(x, StringTools:-CommonPrefix(x, y)), x in Strings), y in Strings)};
P := table(map(proc (x) options operator, arrow; x = "" end proc, Strings));
for x in CP do for y in `minus`(CP, {x}) do if `and`(StringTools*IsPrefix(y, x), `implies`(assigned(P[x]), StringTools*IsPrefix(P[x], y))) then P[x] := y end if end do end do;
Error, cannot determine if this expression is true or false: StringTools*IsPrefix("a", "")
Hi I tried to apply these command in maple to see hoe cluster graphic after that can work .. but i face this problem ,
I am a begginer in maple working on it for a term paper to demonstrate it is ability to view the cluster analysis .
if u have any benefcial resources I ll be so happy.
thanks very much
How would one in Maple solve this, which is an inequality equation in some variables, which can be nonlinear, with constraints on range of each variable. I.e. I want to find conditions on the variables to make the inequality satisfied.
In Mathematica, I use the Reduce command
Clear[x, y];
eq = 1/2 - x + x^2 - y + y^2;
Reduce[{eq > 0, 0 < x < 1 && 0 < y < 1}, {x, y}, Reals]
How would one do the same in Maple? I tried solve, but can't give constraints.
eq:=1/2 -x+x^2-y+y^2:
solve(eq>0 , {x1, x2});
So I need to do the same as in the Mathematica command, but in Maple. I do not want numerical solution, but algebraic as shown above.
Using Maple 18.2 on windows.
x_1 = 1;
x_n = 1/2 (x_n-1 + 3/x_n-1 ) for n>=2
Is there a maple command to check if the above statement is rational, eventhough it is obvious enough?
I tried to evaluate x_2 using subs(n=2, x_n) but keep getting an expression in terms of x_1. Using evalf(x_2), the result was x_2.
I'm very new to maple, so please help :(
Hello people in mapleprimes,
I want to ask a question about modification of expression.
Basically, what I want to do is to change the expression of sqrt((-a)^2) to sqrt(a^2).
The expression I want to modify is this:
aa:=phi[n, j] = a[j, D]-a-sqrt((-a[j, D]+a+tau[n, j])^2+4*gamma*f[c, n, j]/L[j])
I want to change this to
phi[n, j] = a[j, D]-a-sqrt((a[j, D]-a-tau[n, j])^2+4*gamma*f[c, n, j]/L[j])
To do this, I wrote as
subs(sqrt((-a[j, D]+a+tau[n, j])^2+4*gamma*f[c, n, j]/L[j]) = sqrt((a[j, D]-a-tau[n, j])^2+4*gamma*f[c, n, j]/L[j]), phi[n, j] = a[j, D]-a-((-a[j, D]+a+tau[n, j])^2+4*gamma*f[c, n, j]/L[j])^(1/2))
Or, I wrote as
subs(op([2,3,2,1,1],aa)=(a[j, D]-a-tau[n, j])^2,aa)
If there is better ways, please tell me them.
Best wishes.
taro
AoA. Hope you will be fine. I want to factorize 2046 as
2046=2*1023
but maple gives
ifactor(2046)=11*(2*3)*31
PhD (Scholar)
Department of Mathematics
I have the following system I need to solve:
dy(t)/dt = alpha(t)-y(t)
alpha(t)=alpha0*(x(t)-x0)
dx(t)/dt=y(t)-beta(t)
beta(t)=beta0*(x(t)-x0)
 I am trying to get functions of y(t) and x(t), so I can plot y(t), x(t) and alpha(t) as it changes over time.
I have tried using dsolve to no effect.  I define the inital conditions, I define the functions I am looking for and when I press enter dsolve doesn't return anything.  I also know all the constants and defined them as well.
First 1341 1342 1343 1344 1345 1346 1347 Last Page 1343 of 2429
