  Excuse me, I tried to substract in a series expansion. It works for Taylor-type expansion, but not Laurent-type ones
ffff:=1/(t-3);
ggg:=taylor(ffff,t=infinity,3);
coeff(ggg,t,-1);
ffff:=exp(t);
ggg:=taylor(ffff,t=0,3);
coeff(ggg,t,1);
Maple gives me
Error, unable to compute coeff
. My question is, why "coeff" does not work in the first case? how to make it work? Though I can copy the expansion part, assign it to another variable, and "coeff" will work
Excuse me,
  I have the following input
fff:=x1^k;
int(fff,x1=0..x2);
I would like to obtain
1/(k+1)* (x2^(k+1)), k<>-1
but maple gives me just the same integral. Is there any way to get the expression?
Im solving 4 ODE equations with BC. im trying to shoot the initial value but im having this error:
""Error, (in isolate) cannot isolate for a function when it appears with different arguments""
anyone could help me???
shooting92.mw
Shootlib := "E:\\shooting/":
libname := Shootlib, libname:
with(Shoot):
n := 2:
FNS := {F(eta), H(eta), f(eta), g(eta), u(eta), v(eta)}:
ODE := {g(eta)*(diff(g(eta), eta))+B*(f(eta)+g(eta)) = 0, g(eta)*(diff(F(eta), eta))+F(eta)^2+B*(F(eta)-u(eta)) = 0, g(eta)*(diff(H(eta), eta))+H(eta)*(diff(g(eta), eta))+F(eta)*H(eta) = 0, diff(v(eta), eta)+f(eta)*v(eta)-u(eta)^2+B*H(eta)*(F(eta)-u(eta))-M*u(eta) = 0, diff(f(eta), eta) = u(eta), diff(u(eta), eta) = v(eta)};
{g(eta)*(diff(H(eta), eta))+H(eta)*(diff(g(eta), eta))+F(eta)*H(eta) = 0, g(eta)*(diff(g(eta), eta))+0.2e-1*f(eta)+0.2e-1*g(eta) = 0, g(eta)*(diff(F(eta), eta))+F(eta)^2+0.2e-1*F(eta)-0.2e-1*u(eta) = 0, diff(v(eta), eta)+f(eta)*v(eta)-u(eta)^2+0.2e-1*H(eta)*(F(eta)-u(eta))-3*u(eta) = 0, diff(f(eta), eta) = u(eta), diff(u(eta), eta) = v(eta)}
IC := {F(0) = gamma, H(0) = Q, f(0) = 0, g(0) = z, u(0) = 1, v(0) = alpha};
BC := {F(L) = 0, H(L) = n, g(L) = -f(L), u(L) = 0};
{F(6) = 0, H(6) = 2, g(6) = -f(6), u(6) = 0}
infolevel[shoot] := 1:
S := shoot(ODE, IC, BC, FNS, [alpha = 0, gamma = 0, z = -.2, Q = 0])
Download shooting92.mw
I am trying to make a plot3d on my Surface Pro  3 running Windows8.1.
The plot looks like a ghost.  Pale grey.  It looked nice and colourful when I executed the same command on an older computer a few hours ago.  (I know it was exactly the same command because I saved the file on my old computer and then opened in on the Surface Pro 3)
Is there a way to fix this?
plot3d(-x^2+y^2-3*x+2*y+100, x = -5 .. 8, y = -5 .. 5, transparency = 0, lightmodel = light1, glossiness = 1, filled = true, style = wireframeopaque, shading = zhue, view = [-5 .. 10, -5 .. 8, 0 .. 150]);
 OOPS!  Now the problem has corrected itself.
I'm getting worried about all the weird things Maple is doing on this Surface Pro 3.  I'm trying to make up a final exam tonight (the exam is tomorrow).
I have downloaded MaplePlayer on my iPad.   I see that it comes with a number of "pre-recorded" programs that it can run.  Is there a way to have it run a Maple worksheet that I have written?   If so, how do I use this app to open an existing worksheet?
Also, are there any plans for this app on the Android platform any time soon?
I have written a program and at one point I have an assignment statement like BG(i, j) :=1    When ever I run the program, I get a dialog box which asks me to choose between "function definition" and "remember table assignment."  Is there a way to tell the program that I want this to be a table assignment in the code so that I don't always have to answer the question?
I have written a program and I would like to embed a check near the beginning to see if input data was entered correctly.  I have written an "if statement" to check on this and I would like the program to stop execution at this point if the "if statement" criteria are met.   I get an error saying that this command is disabled.   I have tried "stop", "end" and "quit," as I understand that they are all the same.
Dear friends,
Recently I was surprised when discovered the following error in using the function solve. If I run the simlest example from the help system for the first time (or after restarting), the following error occurs:
If I run this example repeatedly, this brings the following:
Previously in earlier versions I used solve many times for very complex computations and have never seen something similar.
Any suggestions are welcomed.
Where u and v are the displacement components in x and y directions respectively.
Hello I wonder if there any good solution for linear manipulation of sytem of equations(like sum, substract mulpiplication and etc. of equations). But main thing I want to find is there any demonstrative solution?
Something like a built-in equation manipulator but which serves system of equations.
I found the page:http://12000.org/my_notes/rankTest/test.htm,
Comparing with MMa&Matlab, Maple is abit slow.
The author guess the reason is Intel MKL.
I searched the help page, http://www.maplesoft.com/support/help/Maple/view.aspx?path=copyright,
found this info:
Intel® MKL Copyright © 1999, 2000-2008 Intel Corporation. All rights reserved.
 Does this means the Intel MKL in maple is a 6 years old product?
Is this important?
I want to know.
I have a simple transfer function like
I want to calculate the amplitude ratio and the phase shift.
Without maple I would set s=I*omega and solve for real and imaginary part to obtain the phase shift and amplitude ratio.
Is there any possibility to do that in Maple more easily?
I have equation, which includes square roots. e.g.:
I know, that sqrt() will only return positive value, therefore when I put some values of a,b and c:
I get only one answer:
3.000000000
My question is how to calculate that second branch of the solution without altering eq. itself? (In my case this equation is derived from somewhere else and it cannot be modified)
When I run a maple program which take a long time (in command line), I have this kind of message every second:
"memory used=43867.3MB, alloc=147.3MB, time=856.28"
Does there exist any way to avoid this display ?
First 1340 1341 1342 1343 1344 1345 1346 Last Page 1342 of 2429
