I got a message "there are problems during the loading process. Worksheet may be incomplete"
I know that looking at the file in a text editor can help, but I dont know how to recognise the problems.
It doesnt look as a problem of strange characters either...
Its a pretty long worksheet, with many important work. Any help would be higlhy appreciatd. Thanks
Here is the worksheet
FenixHPbien.mw
Vicente
one of the most confusing thing for me with learning Maple, is pi vs. Pi. I keep mixing them up since do not remember half the time which one to use.
What is the point of having both? Mathematica only has Pi. If one wants numerical value for it, simply do N[Pi] which is similar to Maple evalf(Pi).
I just spend 5 minutes trying to figure why int((sin(x))^3*sin(k*x),x=-pi..pi); was giving me
While in Mathematica it gives
Then I noticed the Pi vs. pi, and now Maple gives same output.
Why pi was even introduced? was this done early on, or added in later versions? Why not keep Pi a symbolic and with evalf it gives numerical value as with Mathematica? Also, would one use pi?  It if just symbol (evalf(pi)) does nothing, then what is its use? if I can see a good use for pi vs. Pi, may be I'll understand the logic behind this duel system.
For my thesis I would like to illustrate the inclination of the solar system objects in a plane. Imagine the Solar system as a circular plane which is the average of the motions of all objects orbiting the Sun. Each individual planet/object is inclined towards this averaged plane - some more, some less. E.g. this image. Behind Neptune there lies the so-called Kuiper belt with many thousands of dwarf planets (Pluto is one of them and there are over 1000 objects known out there already). Now imagine that the big heavy Jupiter and other big planets perturb those small objects out there: so they are also inclined towards the average plane, see this image. Their inclination depends on their radial distance to the Sun (measured usually in Astronomical Units...1 unit is the distance Sun-Earth...we are talking about 40 to 50 units here). For one, I want to visualise this: imagine a circular plane and each orbit out there has another angle to the average plane. This is the first. But now: imagine the circle with it's 360°. Each object reaches it's highest point on its orbit around the Sun on another angle on this 360° circle. Neptune e.b. at 170°, Pluto at 250° etc. You get the picture. So not only are the objects in the Kuiper belt inclined differently, but their maximum orbit positions are also scattered across an imaginary 360° circle. I want to show this with a 3d-plane like this image but not with two peaks for one orbit. Is there a way to do/plot/visualise this in Maple? I am just interested in a visualisation of the principle without any empirical data behind this.
hello , to solve a differential euqations , maple gave me this error. please help me.
TG.mw
I use maple worksheet to organize a derivation, etc.
But most of the paragraphs and subparagraphs should normally be closed.
But after executing the file (using !!!) every paragraph is opened.
We need better ability to control the opening/closing of paragraphs.
How do I close ALL paragraphs.
Also, how do I close all TOP level paragraphs (but not subparagraphs).
Thanks, Chee
I'm trying to initialize a 4-vector and promote it as a tensor in Maple 16 using the Physics package. My attempt so far has been unsuccessful :)
This 4-vector needs to be a function of the coordinates X. What I'm trying to do is to allocate terms by terms my tensor as indicated in my attempt below. Everything looks fine (the query is telling me F2 is a tensor) but when I'm trying to compute contravariant quantities, I can't obtain an answer for a given coordinate (here F2[~n](X) is not equal du v_1(X))... Finally, the last line, computing the sum over all the indexes is not giving me an answer...
restart; with(Physics):
Setup(mathematicalnotation=true):
Setup(coordinatesystems = cartesian):
Define();
g_[]:
F2[1]:=(x,y,z,t)->v_1(X);F2[2]:=(x,y,z,t)->v_2(X);F2[3]:=(x,y,z,t)->v_3(X);F2[4]:=(x,y,z,t)->1;
Define(F2[mu](X));
Define(F2,query);
F2[1](X);F2[2](X);
F2[~1](X);F2[~2](X);
F2[~nu].F2[nu]
Surely, something is wrong in my way of defining a spacetime tensor. What would be the solution to obtain a decent contravariant F2?
Another more or less related question would be to know how to compute a taylor expansion of a function itself i.e. 1/(1+f(X))~ 1-f(X) since f<<1? Would there be a built-in fonction to do such a thing?
Many thanks!
Vincent
Hello people in mapleprimes,
I hope you will give an answer to my following question.
This is a question of nonunit(algebraic) in patmatch.
In help page of maple this examples are on.
Case i)
>patmatch(a, A::(nonunit(algebraic))+B::(nonunit(algebraic)), 'la');
Case ii)
>patmatch(a,A::(nonunit(algebraic))+B::algebraic,'la'); la
ture
[A=a,B=0]
Is unit in the case of sum zero, so that in Case i) false is shown, though in Case ii) B=0 is returned?
Best wishes.
taro
I`m new with the Physics package. I have a Hamiltonian in a lattice written in terms of creation and annihilation operators. The Question is, How can I label a Creation and an Annihiliation operator for each site in the Lattice. WIth this, I can compute mean values and other stuffs associated with the Hamiltonian.
Many thanks in advance
Dear people in mapleprimes,
>define(INT, linear, conditional(INT(a::algebraic, X::name) = a*X, _type(a, freeof(X))), INT(X::name, X::name) = (1/2)*X^2);
>INT(2*x+4, x);
x^2 + 4*x
>INT(z+x, z);
(1/2)* z ^2+ x*z
is written in the help page of maple.
This code is to make a function INT.
What it means is that if INT(a::algebraic, x::name) then this is transformed into a*X, where a is independent from x.
And, INT(X::name,X::name) is transformed into (1/2)*X^2.
The first of what I want to ask you is the way of use of "_type", which is not in the help page, and as for names with "_" ahead,
it is written that "_" means internal command for Maple, so not to use it. Is it right to use a name with "_" ahead of it here?
The second of what I want to know is the way to use "conditional."
Please teach me the meaning of this.
I hope you will teach me the above questions.
Best wishes.
taro
Hello guys
I have a linear differentional equation which is in the 4th order. It is shown in the below:
P:=phi(x):
eq:=a11*diff(p,x,x,x,x)+a22*diff(p,x,x)+a33*p:
eq:=0:
where a11 and a22 and a33 are constant coefficients. The boundary value for this equation is:
phi(a)=sigma1 , phi(-a)=sigma1 , diff(p,x)(a)=0 , diff(p,x)=0
Now consider :
a11:=2.731e-10:
a22:=-1.651e-9:
a33:=3.09027e-10:
a:=35.714:
sigma1:=200e6:
when I use dsolve for deriving a good answer in this equation. there are four real roots .How can I solve it with these boundary condition?
I need to extract phi(x) from this equation.
seq(i,i=1..5);  gives output 1,2,3,4,5
seq(i,i=5..1);  seems to get ignored in Maple 7.  It does not return an error message.
I was hoping to step back from a large number to a smaller one in stepsof minus one.  The for loop structure allows negative "increments" - so I experimented by putting the decrement value of -1 between the two dots.  I was expecting it to givean error message, so was surprisd when it gavesome output!
eg  seq(i, i=5.-1.2);  gives output of 38, -1
I'm curious as to what is happening here?  Also, has the seq command been upgraded in later versions of Maple?  eg is it possible to do negative decrements?
I have to find the volume of a solid using the disk/washer method and the shell method.  I think I have the first part(disk/washer) right.   I think the shell is off. The problem is "the region in the first quadrant that is bounded above by the curve y = 1/x^1/4, on the left by the line x = 1/16, and below bythe line y = 1 is revolved about the x-axis to generate a solid."    I am having computer problems so any help is appreciated. Thanks
Consider a plot generaged by:
export_plot_options:=font=[TIMES, roman, 30], axis=[thickness=4, location=low], size=[850,850]:
points := [seq([seq(exp(-(x^2+y^2)*(1/100)), x = -10.0 .. 10.0)], y = -10.0 .. 10.0)]:
plots:-listdensityplot(points, export_plot_options);
How can one get rid of white space between the axes and the actual data??
Hi there,
I would like to know whether there is some way to print non-integer axis numbers for a given plot.
Let's say I have an array for an independent variable such as [0.5 1 1.5 2]. I would like Maple to use these values in the corresponding axis instead of printing the array indices [1, 2, 3, 4].
I would like to know how this is done for a surface plot.
Attached is the worksheet where "b" is such a parameter/independent variable: MapleSimulation_test11.mw
Thank you,
jon
I am just starting with Maple 18 on Windows 8.1. I did not like the default color palette for 2D graphs and tried another one. So I edited my maple.ini file, which was in
First 1339 1340 1341 1342 1343 1344 1345 Last Page 1341 of 2429
