hello, i went solve these equation ,with a & b take any value
b*x*ln(x)-x*ln(a)+a=0
thank you
In this document, I think that is the relevent section. But I couldnt understand it.
I want something like this
>plot(sin(x),color=yellow);
>plot(sin(x),color=organe);
>plot(sin(x),color=red);
>plot(sin(x),color=green);
>plot(sin(x),color=ABC); # error
>plot(sin(x),color=CBA);# error
optional, but works fine within a given sets of choices.
How do I write a procedure like that?
st6.mw,st7.mwI want to obtain the analytical solution for this PDE by maple   diff(T(x, y, z), x, x)+diff(T(x, y, z), y, y)+diff(T(x, y, z), z, z)+A*exp(-8*x^2/a^2)*cosh(alpha*((1/2)*b+y)) = 0    . But I can not do it. Please help me
((d^2)T/dx^2)+ ((d^2)T/dy^2)+ ((d^2)T/dz^2)=-A*Q(x,y,z)
Where   0 <x<a ,  0 <y<b  ,  0 <z<l
With the boundary conditions:
(dT(0,y,z)/dx)=n-T(0,y,z)    (dT(a,y,z)/dx)=n-T(a,y,z)   (dT(x,0,z)/dy)=n-T(x,0,z)
(dT(x,b,z)/dy)=n-T(x,b,z)     (dT(x,y,0)/dz)=n-T(x,y,0)    (dT(x,y,l)/dz)=n-T(x,y,l)
where n is constant and A is set of parameters.
I am attempting to have Maple pull out the Eurocup qualifying scores from here http://www.uefa.com/uefaeuro/qualifiers/season=2016/matches/all/index.html
It doesn't seem to grab the full page.  Doing a search on Portugal only finds the one match against Albania.  Similarily a search on England only finds the match against Switzerland.  It seems to only find one instance and I'm not sure why it doesn't Get the full page.
Any ideas?
I'm using the command
HTTP[Get]("http://www.uefa.com/uefaeuro/qualifiers/season=2016/matches/all/index.html")
I have updated  Maple from 18.01 to 18.02, but there is something strange happened to me. I can not use int anymore. Here is my codes:
int(sin(x),x);
Error, (in int) wrong number (or type) of arguments: invalid option value passed to indefinite integration: {}
kernelopts(version);
    Maple 18.00, X86 64 LINUX, Feb 10 2014, Build ID 922027
Here is the screenshot:
we have number from 1 to 2014. If we underline the number that divide by 3 and 4, how many pattern of two underlines that next to each other as example?(1,2,3,4,5,6,7,8,9,10,...,2014).
I`m using this program to find the largest prime factor:
Problem: If I insert largest_prime(p^n), where p is prime, it returns n. Which I dont want! I want p to be returned.
Please help me!
Hello all,
I have the following equation:
N*exp(-(1/2)*eta*epsilon*(N*alpha*epsilon*w+2*N*w*C[max]-alpha*epsilon*z-2*Q1*alpha)/(w*N))*S1*upsilon*w-N*S1*upsilon*w+K1^2*alpha*eta*z*epsilon+K1*alpha*eta*z*epsilon*S1 = 0
in which I need to find solution for epsilon (analytical solution) when epsilon>0.
Dmitry
I have a nonlinear system with 4 equations and 4 unknowns. I am using fsolve. I know that there are multiple solutions for each variable but am only getting one. I need the others. what do I do??
This is my code:
R__1 := Matrix([[1, 0] , [0, 1] ]);
R__2 := Matrix([[1/2, sqrt(3)/2] , [-sqrt(3)/2, 1/2] ]);
R__3 := Matrix([[-1/2, sqrt(3)/2] , [-sqrt(3)/2, -1/2] ]);
R__4 := Matrix([[-1, 0] , [0, -1] ]);
R__5 := Matrix([[-1/2, -sqrt(3)/2] , [sqrt(3)/2, -1/2] ]);
d__1 := Vector( [ 0, 5.4] );
d__2 := Vector( [ 6.4, 4.539] );
d__3 := Vector( [ 11, 4.078] );
d__4 := Vector( [ 15.5, 2.079] );
d__5 := Vector( [ 19, 1.039] );
a := Vector( [ a__x, a__y] );
A__1:=R__1.a+d__1;
A__2:=R__2.a+d__2;
A__3:=R__3.a+d__3;
A__4:=R__4.a+d__4;
A__5:=R__5.a+d__5;
OO:=Vector([O__x,O__y]);
DA1:=A__2.A__2-A__1.A__1-2*(A__2-A__1).OO;
DA2:=A__3.A__3-A__1.A__1-2*(A__3-A__1).OO;
DA3:=A__4.A__4-A__1.A__1-2*(A__4-A__1).OO;
DA4:=A__5.A__5-A__1.A__1-2*(A__5-A__1).OO;
fsolve({DA1,DA2,DA3,DA4},{a__x,a__y,O__x,O__y});
Thanks for any tips you may be able to offer
How do I plot the following equations in Maple ?:
I already tried this:
According to the given solution the plot should look like that:
I think I have to tell maple that the function is defined from R^2 -> R, but I don't know how to do this.
Thanks in advance for your kind help.
Hello people in mapleprimes,
I want to draw a graph of a procedure.
filter:=x->if x<10 then 1-x/10 else 0 fi;
plot('filter(x)',x=0..20);
works well. But, I don't know why it is needed for filter(x) is wrapped with foward quotte ' .
I changed that quote to back quote ` but, in this case the result hadn't appeared.
And, without the foward quote ', error appears.
And, even if I wrapped x with ' as in plot('filter(x)','x' =0..20),
a graph appeared properly, though I cannot understand why wrapped x, 'x' is right.
Please teach me the logic of the above code.
Best wishes.
taro yamada
solve(a/(x+1)>1,x)
When I type this command and run it,It returns nothing but this warning
"Warning, solutions may have been lost"
How can I get the correct solution using Maple 18
AoA. How are you hope you will be fine. Sir the following matrix have been given
A := Matrix(2, 2, {(1, 1) = 1, (1, 2) = 2, (2, 1) = -1, (2, 2) = 2});
B := Matrix(2, 2, {(1, 1) = 1, (1, 2) = 0, (2, 1) = -2, (2, 2) = 3});
C := Matrix(2, 2, {(1, 1) = 0, (1, 2) = 0, (2, 1) = 0, (2, 2) = 0});
I want to write M by M matrix using the above matrices like this
P:=[[[A,B,B,...,B],[C,A,B,...,B],[C,C,A,...,B],[.,.,.,...,B],[C,C,C,...,A]]]
PhD (Scholar)
Department of Mathematics
AoA... I want to plot the following functions
f(x)=sin(x)
g(x)=sin(x)-x+x^2
h(x)=cos(x)-sin(x)
I(x)=exp(x)-x
J(x)=sin(x)+exp(x)
in one coordinate having the line style and legend like attached file.
1-s2.0-S0377042714003331-main.pdf
PhD (Scholar)
After I do
plot(cos);
Now I right-click on the plot, and from the menu change the "line" to "dashed" style, so the plot becomes like this:
Now I would like to obtain the Maple plot command that would have generated the above plot, so I can use the command later in my script.  I could not find a menu option to show the Maple command.
Maple 18.02 on windows 7
First 1351 1352 1353 1354 1355 1356 1357 Last Page 1353 of 2429
