k:=0.99: with(RealDomain):
m:=1: Digits:=2:
x:=(Pi*csc(Pi*(k-m)))/(0.693*GAMMA(k)*GAMMA(m));
x := -1.4*Pi*csc(0.1e-1*Pi)
m1:=MeijerG([[-m],[1-m]],[[0,-m,-m],[k-m]],(-m*k)/snr);
m1 := MeijerG([[-1.], [0.]], [[0., -1., -1.], [-0.1e-1]], -.99/snr)
m2:=MeijerG([[-k],[1-k]],[[0,-k,-k],[m-k]],(-m*k)/snr);
m2 := MeijerG([[-.99], [0.1e-1]], [[0., -.99, -.99], [0.1e-1]], -.99/snr)
c:=x*((((m*k)/snr)^m)*m1-(((m*k)/snr)^k)*m2);
c := -1.4*Pi*csc(0.1e-1*Pi)*(.99*MeijerG([[-1.], [0.]], [[0., -1., -1.], [-0.1e-1]], -.99/snr)/snr-.99*(1/snr)^.99*MeijerG([[-.99], [0.1e-1]], [[0., -.99, -.99], [0.1e-1]], -.99/snr))
plot(c,snr=0..10);
Error, empty plot
Download capacity_kfading.mw
m:=1: Digits:=2:
plot(c,snr=0..10);
Error, empty plot
m:=1: Digits:=2:
plot(c,snr=0..10);
Error, empty plot
m:=1: Digits:=2:
plot(c,snr=0..10);
Error, empty plot
require help to overcome this warning. Thanks.
How do I mark a value on circles
I want to plot Smith Chart and calculate the value Correspond to circles.
Any one can give me some suggestions or better idea to plot Smith Chart.
There are my code:Doc1.doc
Hi Maple friends.
x(x+y)^4 = y(3*x-y)^2
When I differentiate implicitly by hand, I get:
-5*x^4-4*x^3*y+3*y^2/x^4-6*x*y+3*y^2 (my lecturer also got this solution)
Maple gives the result as:
(-2*x(x+y)^3*(D(x))(x+y)+3*y(3*x-y)*(D(y))(3*x-y))/(2*x(x+y)^3*(D(x))(x+y)+y(3*x-y)*(D(y))(3*x-y))
Maybe I am doing something wrong in Maple? From the context menu, I choose implicit differentiation, and then select y as the dependent variable. How can I get Maple to give the same solution?
I have some lengthy formulas in the maple. I don't want to waste time on rewritting them in a word document.
Is there a way to import those equations in a clean and tidy form to a word document or the mathtype program or something else! :)
I wanted to answer a question and show an animation contained in an animated gif file. The file is small gif file and is on my local drive on my PC.
I am not able to find a way to include it here as I can easily do on stackexchange so it plays on the screen when someone sees the post.
Does this forum support such a feature? I tried the image->include, and in the URL I typed  C:\foo.gif, but nothing showed up on the post. So it did not work that way.
I've been instructed to create an animation showing the changing plots of a single square waveform using 5,10,20,40,80,160,320, and 640 terms in my Fourier series. This is my code right now:
with (plots):
L := [seq(2^i, i = 0 .. 6)];
[1, 2, 4, 8, 16, 32, 64]
animate( plot, [2/((2*n-1)*Pi))*sin((2*n-1)*Pi*x], n=L);
Error, `)` unexpected
It doesn't work. Can anyone explain what I'm doing wrong, or how to solve my question?
dualaxisplot(listplot(sols[2], color = red), listplot(sols[1], color = blue), style = line, gridlines = false);
How can I define general matrices in Maple and do symbolic manipulation - for example specifying a matirx M to be of dimension n x m where n and m are integers ?
The permanent of a square matrix is defined similarly to the determinant, as a sum of products of sets of matrix entries that lie in distinct rows and columns. However, where the determinant weights each of these products with a ±1 sign based on the parity of the set, the permanent weights them all with a + 1 sign.While the determinant can be computed in polynomial time by Gaussian elimination, the permanent cannot. Valiant has showed that computing permanents is #P-hard, and even #P-complete for matrices in which all entries are 0 or 1 [L.G. Valiant, The Complexity of Computing the Permanent, Theoretical Computer Science 8 (1979) 189–201]. The development of both exact and approximate algorithms for computing the permanent of a matrix is an active area of research. (see Wikipedia: computing the permanent, more details on permanent)
The best known general exact algorithm is due to H. J. Ryser (1963) [Ryser, Herbert John (1963), Combinatorial Mathematics, The Carus mathematical monographs, The Mathematical Association of America. Ryser formula ]. Ryser's formula can be evaluated using O(2^{n}*n^2) arithmetic operations, whereas O(n!*n) arithmetic operations if we compute the permanent using the definition.
There have been codes of Ryser's algorithm for computing the permanent written in C language and Matlab. I cannot find a Ryser's procedure in Maple. So I try to write a Maple procedure to compute the permanent using Ryser's algorithm. The code is as follows:
permanentRyser := proc (M::Matrix)
      local S, T, B, m, n, s, i, j, rowsum, sum, prod, perm;
      m, n := op(1, M);
      if m <> n then
               error "expecting a square Matrix, got dimensions %1, %2", m, n
      rowsum := 0;
      sum := 0;
      prod := 1;
      S := combinat:-subsets([seq(1 .. m)]);
      Snextvalue();
      while not Sfinished do
             T := Snextvalue();
             s := numelems(T);
             B := LinearAlgebra:-SubMatrix(M, [1 .. m], T);
             for i to m do
                  for j to s do
                          rowsum := rowsum+B[i][j];
                 prod := prod*rowsum;
                 rowsum := 0;
            prod := (-1)^s*prod;
            sum := sum+prod;
            prod := 1 ;
      perm := expand((-1)^m*sum) ;
The last second statement "perm := expand((-1)^m*sum) ;" I mean to compute the permanent of  a matrix containing a variable, e.g. the characteristic matrix. If the matrix is numeric, then "expand" should be deleted.
Now I have two questions:
1. Suppose that A is random matrix of order 20, the time(permanentRyser(A)) is about 716 seconds and time(LinearAlgebra:-Permanent(A)) is about 66 seconds. We can see that LinearAlgebra:-Permanent(A) is much faster than permanentRyser(A).  I don't know whether the code I written is accurate and efficient. Thanks to anyone who gives a more efficient procedure of computing the permanent using Ryser's formular.
2. The source code of the function permanent is as follows.
proc (A::(`~Matrix`(square)), ` $`)
     option `Copyright (c) 1999 Waterloo Maple Inc. All rights reserved.`;
     local m, n, t1;
     m, n := op(1, A);
     if m <> n then
     if n = 1 then t1 := A[1, 1] ;
            tools/ClearRememberTable(Permanent/pminor`);
            t1 := [`$`(1 .. n)];
            t1 := Permanent/pminor(A, t1, t1, n)
      end if
end proc
I cannot understand the source code. Does the source code compute the permanent by Laplacian expansion? If the LinearAlgebra:-Permanent() compute the permanent by Laplacian expansion, then it should take more time than by using Ryser's algorithm.
Thanks all.
1-Suppose that after applying the command "factor(f)" the "f "takes the form:
f=(BesselJ(0,r))*(A very lengthy term)
Is there a way to force maple to show f like below:
f=(A very lengthy term)*(BesselJ(0,r))
2-Suppose f is written as follows:
f=a*b*x+a*b*y
Can you suggest a way (without using "op" command) to write f as:
f=a*(b*x+b*y)
Hi:
i will solve the three equations below with numerical method,how?
eq1 := -2.517407096*10^12*q[1](t)^2-5.292771429*10^12*q[1](t)-1.888055322*10^12*q[2](t) = 0
eq2 := 2.246321962*10^12*q[1](t)^2+1.684741471*10^12*q[2](t)+8.110113889*10^12*q[1](t)-7.480938859*10^10*q[3](t) = 0
eq3 := int((-3.826000000*10^11*q[2](t)*cos(Pi*x)*Pi^2-3.826000000*10^11*q[1](t)^2*cos(Pi*x)*Pi^3*sin(Pi*x)+3.414000000*10^11*q[1](t)^2*sin(Pi*x)^2*Pi^4-3.414000000*10^11*q[1](t)^2*cos(Pi*x)^2*Pi^4+7*(int(exp(10*tau), tau = -infinity .. t))+q(x, t))*sin(Pi*x), x = 0 .. 1) = 0
Hello everybody,
I'm trying to solve for a challenging problem : a moving inclined plane with a block
I want to solve for the acceleration components for the block and the plane and the normal force acting on the block.
Let O=(0,0) be an external origin.
Let h be the upper left height of the inclined plane.
Let x1 be the x-position of the center of gravity of the inclined plane.
Let x2 be the x-postion of the center of gravity of the block.
Let y be the y-position of the center of gravity of the block.
Let m1 be the mass of the plane. Let m2 be the mass of the block.
Let  mu[1] be the coeffiction of kinetic friction between the bottom of the inclined plane and the level surface.
Let mu[2]  be the coeffiction of kinetic friction between the block and the upper surface of the inclined plane.
Let theta be the angle of the plane with the horizontal.
Let Fp a force applied to the inclined plane.
With those defined variables, I make two separable free body diagrams for the block and for the inclined plane, indicating all of the external forces acting on each. It then comes those two vectorial equations :
Block : m2a2=Wweight of block+Fplan acting on block+Ffriction from plan to block+Nnormal from plan to block
Plane : m1a1=Wweight of plane+Fpushing force+Fblock acting on plane+Ffriction from level to plan+Nnormal from level to plane+Ffriction from block to plane+Nnormal from block to plane
I am quite not sure whether I should include the Ffriction from block to plane and the Nnormal from block to plane into the plane's acceleration calculation. Am I right ?
I notice that from the geometry of the figure, I can write down the relation : tan(theta)=(h-y)/(x2-x1)
This implies the relation : -a2y=tan(theta)(a2x-a1x) (equation 1)
Writing down the equations for the x- and y- components of the accelerations of the block and of the plane , this yields :
( equation 2) : m2a2x=m1 sqrt(a1x2+a1y2) cos(theta) -    mu[2]  N1 sin(theta) +Ncos(theta
(equation 3) : m2a2y= m2g+m1 sqrt(a1x2+a1y2) sin(theta) +  mu[2]  N1 cos(theta) +Nsin(theta
(equation 4) : m1a1x=Fp - m2 sqrt(a2x2+a2y2)  sin(theta) +  mu[2]  N1 cos(theta) - Ncos(theta
(equation 5) : m1a1y=-m1g  - m2 sqrt(a2x2+a2y2)  cos(theta) - mu[1] N1 + N1 -  mu[2]  N1 sin(theta) -  mu[2]  N1 cos(theta)
Since N1=m1g,  equation 5 becomes : m1a1y= - m2 sqrt(a2x2+a2y2)  cos(theta)   -  mu[2]  N1 sin(theta) -  mu[2]  N1 cos(theta)
I am confused at this stage because a1y=0, that is to say, the plane remains at the ground level surface.
Where am I wrong ? Does this comes from my previous question ?
I want to solve this problem with Maple and plot the solutions. Thank you for any answer !
I could obtain the simulation of my multibody with kinematic closed chain (CKC).
However, it seems that from a specific time (around 12s) in my model I believe that I have some numerical instabilities. Indeed, I could compare my simulation results with another mulbody software. I obtain the same simulation until 12s and after in MapleSim, it appears many perturbations as you can see on the figures belows.
So, I think that I tune the numerical solver. This numerical solver must solve DAEs equations since my model contains 4 kinematic closed loops.
If i read correctly the help menu, there are the following methods to solve the DAEs :
- use specific DAE numerical solver (3 differents solvers are used : ck45 method, RKF45 method and Rosenbrock method
- use reformulation equations techniques (Baumgarte, Projection) which can be associated (I believe) with a classic solver like (RK4).
For the moment, I have obtained my results with the rosenbrock solver with error absolute : 1.0*10^(-4) and eror relative :error absolute : 1.0*10^(-4)
Do you have some ideas or advices so as to find a better method to solve my multibody systems with kinematic closed loops ? This method should  prevent the creation of numerical instabilities.
Thanks a lot for your help
Hi Everyone
Is there a built-in way to fit a regression using generalized least squares in Maple ?
I would like to apply a torque directly on a revolute joint. I use a torque modulated by a signal source which is modified chirp signal.
I have done like in the figure below :
After having added this torque, my model no longer runs. The error message is only "simulation interrupted".
Do I correctly plug the torque ? Should I plug the torque element more in the flange a or b of the considered revolute joint ?
Do I tick "use support flange" ? Anyway, with or without, my model crashes.
Thanks a lot for your help.
First 1384 1385 1386 1387 1388 1389 1390 Last Page 1386 of 2429
